4.10 m32c tools fail to build on CentOS 7
Sun Sep 4 18:50:11 UTC 2016
Hi
This may be something we deal with on the master but not on the branch.
Probably need to disable this iconv variant.
/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/m32c-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/./gcc/xgcc
-B/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/m32c-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/./gcc/
-nostdinc
-B/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/m32c-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/m32c-rtems4.10/m32cm/newlib/
-isystem
/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/m32c-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/build/m32c-rtems4.10/m32cm/newlib/targ-include
-isystem
/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/m32c-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-gnu-1/gcc-4.4.7/newlib/libc/include
-B/home/joel/rtems-4.11-work/tools/4.10/m32c-rtems4.10/bin/
-B/home/joel/rtems-4.11-work/tools/4.10/m32c-rtems4.10/lib/ -isystem
/home/joel/rtems-4.11-work/tools/4.10/m32c-rtems4.10/include -isystem
/home/joel/rtems-4.11-work/tools/4.10/m32c-rtems4.10/sys-include
 -mcpu=m32cm -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
-DPACKAGE_VERSION=\"1.18.0\" -DPACKAGE_STRING=\"newlib\ 1.18.0\"
-DPACKAGE_BUGREPORT=\"\" -I.
-I../../../../../../../gcc-4.4.7/newlib/libc/iconv/ccs -Os
-DPREFER_SIZE_OVER_SPEED -DSMALL_MEMORY -D_COMPILING_NEWLIB
-DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
-DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL
-DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS
-D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN -fno-builtin      -g -O2
 -mcpu=m32cm -c -o lib_a-cns11643_plane14.o `test -f 'cns11643_plane14.c'
|| echo
'../../../../../../../gcc-4.4.7/newlib/libc/iconv/ccs/'`cns11643_plane14.c
../../../../../../../gcc-4.4.7/newlib/libc/iconv/ccs/big5.c:12574: error:
size of array is too large
make[10]: *** [lib_a-big5.o] Error 1
make[10]: *** Waiting for unfinished jobs....
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160904/0d0770cb/attachment-0001.html>
