4.10 RSB h8300 tools on CentOS 7
Mon Sep 5 00:10:17 UTC 2016
I should have mentioned. This is using the 4.10 branch of the
RSB and not the rc1 candidate. I started doing this before you
cut that.
On Sun, Sep 4, 2016 at 7:02 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 05/09/2016 04:46, Joel Sherrill wrote:
>> Hi
> Thank you for testing 4.10 RC1 and reporting the issues.
> The h8300 tools fail to build on CentOS 7:
>> /data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/
>> build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-linux-
>> gnu-1/build/./gcc/xgcc
>> -B/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems
>> /build/h8300-rtems4.10-gcc-4.4.7-newlib-1.18.0-x86_64-
>> linux-gnu-1/build/./gcc/
>> -nostdinc
>> linux-gnu-1/build/h8300-rtems4.10/newlib/
>> -isystem
>> gnu-1/build/h8300-rtems4.10/newlib/targ-include
>> -isystem
>> gnu-1/gcc-4.4.7/newlib/libc/include
>> -B/home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/bin/
>> -B/home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/lib/ -isystem
>> /home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/include -isystem
>> /home/joel/rtems-4.11-work/tools/4.10/h8300-rtems4.10/sys-include
>> -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>> -DPACKAGE_VERSION=\"1.18.0\" -DPACKAGE_STRING=\"newlib\ 1.18.0\"
>> -DPACKAGE_BUGREPORT=\"\" -I.
>> -I../../../../../../gcc-4.4.7/newlib/libc/iconv/lib -D_COMPILING_NEWLIB
>> -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
>> -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE
>> -DHAVE_FCNTL -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT
>> -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN
>> -fno-builtin      -g -O2   -c -o lib_a-iconvnls.o `test -f 'iconvnls.c'
>> || echo '../../../../../../gcc-4.4.7/newlib/libc/iconv/lib/'`iconvnls.c
>> /tmp/ccweOScM.s: Assembler messages:
>> /tmp/ccweOScM.s:123: Warning: operand #0xffffffffffffffff out of range.
>> /tmp/ccj0h68L.s: Assembler messages:
>> /tmp/ccj0h68L.s:26: Warning: operand #0xfffffffffffffff4 out of range.
>> /tmp/cckRh3aM.s: Assembler messages:
>> /tmp/cckRh3aM.s:26: Warning: operand #0xfffffffffffffffd out of range.
>> /tmp/cckRh3aM.s:50: Warning: operand #0xffffffffffffffff out of range.
>> /tmp/cckRh3aM.s:110: Warning: operand #0xfffffffffffffff4 out of range.
>> /tmp/cckRh3aM.s:118: Warning: operand #0xfffffffffffffffd out of range.
>> /tmp/cckRh3aM.s:142: Warning: operand #0xffffffffffffffff out of range.
> I have pushed a change to the RSB to fix this so h8300 builds on FreeBSD.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160904/3f5b1050/attachment-0002.html>
