Rework thread priority management
Wed Sep 7 01:44:53 UTC 2016
I will try to read this code, but probably not until Friday.
One question from the high-level description, can you clarify what
"aggregation" means? Maybe this comes clear in one of the patches.
Gedare
On Tue, Sep 6, 2016 at 8:40 AM, Sebastian Huber
> This patch set reworks the thread priority management.  The main goals are
> 1. an enhanced implementation of the priority inheritance protocol, and
> 2. support for the OMIP locking protocol.
> Instead of the current and real priority values in combination with the
> resource count use thread priority nodes which contribute to the overall thread
> priority.
> The actual priority of a thread is now an aggregation of priority nodes.
> The thread priority aggregation for the home scheduler instance of a
> thread consists of at least one priority node, which is normally the
> real priority of the thread.  The locking protocols (e.g. priority
> ceiling and priority inheritance), rate-monotonic period objects and the
> POSIX sporadic server add, change and remove priority nodes.
> A thread changes its priority now immediately, e.g. priority changes are
> not deferred until the thread releases its last resource.
> devel mailing list
> devel at rtems.org
