Rework thread priority management
Wed Sep 7 05:25:19 UTC 2016
The new thread priority data structures are:
  * @brief The priority node to build up a priority aggregation.
typedef struct {
    * @brief Node component for a chain or red-black tree.
   union {
     Chain_Node Chain;
     RBTree_Node RBTree;
   } Node;
    * @brief The priority value of this node.
   Priority_Control priority;
} Priority_Node;
  * @brief The priority action type.
typedef enum {
   PRIORITY_ACTION_ADD,
   PRIORITY_ACTION_CHANGE,
   PRIORITY_ACTION_REMOVE,
   PRIORITY_ACTION_INVALID
} Priority_Action_type;
typedef struct Priority_Aggregation Priority_Aggregation;
  * @brief The priority aggregation.
struct Priority_Aggregation {
    * @brief A priority node reflection the overall priority of the
aggregation.
    * May be used to add this aggregation to another aggregation to
build up a
    * recursive priority scheme.
   Priority_Node Node;
    * @brief A red-black tree to contain priority nodes contributing to the
    * overall priority of the this priority aggregation.
   RBTree_Control Contributors;
#if defined(RTEMS_SMP)
    * @brief The scheduler instance of this priority aggregation.
   const struct Scheduler_Control *scheduler;
#endif
    * @brief A priority action block to manage priority node additions,
changes
    * and removals.
   struct {
      * @brief The next priority aggregation in the action chain.
     Priority_Aggregation *next;
#endif
      * @brief The priority node of the action.
     Priority_Node *node;
      * @brief The type of the action.
     Priority_Action_type type;
   } Action;
  * @brief A set of priority actions.
typedef struct {
    * @brief The first action of a priority action chain.
   Priority_Aggregation *actions;
} Priority_Actions;
A thread priority is now a basically a priority queue.
On 07/09/16 03:44, Gedare Bloom wrote:
> I will try to read this code, but probably not until Friday.
> One question from the high-level description, can you clarify what
> "aggregation" means? Maybe this comes clear in one of the patches.
> Gedare
> On Tue, Sep 6, 2016 at 8:40 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> This patch set reworks the thread priority management.  The main goals are
>> 1. an enhanced implementation of the priority inheritance protocol, and
>> 2. support for the OMIP locking protocol.
>> Instead of the current and real priority values in combination with the
>> resource count use thread priority nodes which contribute to the overall thread
>> priority.
>> The actual priority of a thread is now an aggregation of priority nodes.
>> The thread priority aggregation for the home scheduler instance of a
>> thread consists of at least one priority node, which is normally the
>> real priority of the thread.  The locking protocols (e.g. priority
>> ceiling and priority inheritance), rate-monotonic period objects and the
>> POSIX sporadic server add, change and remove priority nodes.
>> A thread changes its priority now immediately, e.g. priority changes are
>> not deferred until the thread releases its last resource.
>> devel mailing list
>> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
