What to do with Thread_Control::resource_count?
Fri Sep 23 13:45:23 UTC 2016
On Fri, Sep 23, 2016 at 5:19 AM, Sebastian Huber
> Hello,
> due to the new thread priority management, the
> Thread_Control::resource_count is no longer needed to maintain the thread
> priority. The only relevant user of the thread resource count is
> static void _Thread_Make_zombie( Thread_Control *the_thread )
>   if ( _Thread_Owns_resources( the_thread ) ) {
>     _Terminate(
>       INTERNAL_ERROR_CORE,
>       false,
>       INTERNAL_ERROR_RESOURCE_IN_USE
> which issues a fatal error in case a thread terminates with a non-zero
> resource count.
> The question is now: should we maintain the resource count solely for this
> diagnostic purpose (the resource count increment/decrement is in the hot
> path of the mutex obtain/release)?
It could be made conditional on DEBUG.
Rather than using refcnts, is there a costlier method (e.g. iterating
some structures) to discover a thread is holding a mutex at this point
of thread destruction that makes sense to use instead?
> Terminating threads which own mutexes make these mutexes indestructible or
> lead to surprises in case the thread control block is re-used by a new
> thread. The current fatal error is new in 4.11, previous RTEMS didn't detect
> this situation.
> If we decide to keep the resource count, then I suggest to use it for the
> no-protocol mutexes as well. This leads to code re-use with the priority
> inheritance mutexes.
> devel mailing list
> devel at rtems.org
