[PATCH] score: Unify CORE mutex seize/surrender
Tue Sep 27 14:59:44 UTC 2016
OK. A mostly unrelated question: why do we have two different
_Semaphore_Get functions, one static in score/src/semaphore.c and the
other inlined from semimpl.h?
On Tue, Sep 27, 2016 at 9:25 AM, Sebastian Huber
> Use the Thread_Control::resource_count for the no protocol mutexes.
> Merge the no protocol and priority inherit CORE mutex seize/surrender
> operations.
>  cpukit/libnetworking/rtems/rtems_glue.c          |  2 +
>  cpukit/posix/src/mutexlocksupp.c                 |  3 +-
>  cpukit/posix/src/mutexunlock.c                   |  3 +-
>  cpukit/rtems/src/semobtain.c                     |  3 +-
>  cpukit/rtems/src/semrelease.c                    |  4 +-
>  cpukit/score/include/rtems/score/coremuteximpl.h | 93 ++----------------------
>  cpukit/score/src/apimutexlock.c                  |  1 +
>  cpukit/score/src/apimutexunlock.c                |  1 +
>  8 files changed, 18 insertions(+), 92 deletions(-)
> diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
> index 9a7f82f..46f8765 100644
> --- a/cpukit/libnetworking/rtems/rtems_glue.c
> +++ b/cpukit/libnetworking/rtems/rtems_glue.c
> @@ -379,6 +379,7 @@ rtems_bsdnet_semaphore_obtain (void)
>         _Thread_queue_Context_set_no_timeout( &queue_context );
>         status = _CORE_recursive_mutex_Seize (
>                 &the_networkSemaphore->Core_control.Mutex.Recursive,
> +               CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
>                 _Thread_Executing,
>                 true,                   /* wait */
>                 _CORE_recursive_mutex_Seize_nested,
> @@ -412,6 +413,7 @@ rtems_bsdnet_semaphore_release (void)
>         _ISR_lock_ISR_disable(&queue_context.Lock_context.Lock_context);
>         status = _CORE_recursive_mutex_Surrender(
>                 _Thread_Executing,
>                 &queue_context
> diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
> index 1da6238..ea4c4e3 100644
> --- a/cpukit/posix/src/mutexlocksupp.c
> +++ b/cpukit/posix/src/mutexlocksupp.c
> @@ -76,7 +76,7 @@ int _POSIX_Mutex_Lock_support(
>        break;
>      case POSIX_MUTEX_NO_PROTOCOL:
> -      status = _CORE_recursive_mutex_Seize_no_protocol(
> +      status = _CORE_recursive_mutex_Seize(
>          &the_mutex->Mutex.Recursive,
>          POSIX_MUTEX_NO_PROTOCOL_TQ_OPERATIONS,
>          executing,
> @@ -89,6 +89,7 @@ int _POSIX_Mutex_Lock_support(
>        _Assert( the_mutex->protocol == POSIX_MUTEX_PRIORITY_INHERIT );
>          executing,
>          wait,
>          _POSIX_Mutex_Lock_nested,
> diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
> index 3144314..c15f7e6 100644
> --- a/cpukit/posix/src/mutexunlock.c
> +++ b/cpukit/posix/src/mutexunlock.c
> @@ -53,7 +53,7 @@ int pthread_mutex_unlock(
>        break;
> -      status = _CORE_recursive_mutex_Surrender_no_protocol(
> +      status = _CORE_recursive_mutex_Surrender(
>          executing,
> @@ -64,6 +64,7 @@ int pthread_mutex_unlock(
>          executing,
>          &queue_context
> diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
> index 9afef54..b81612e 100644
> --- a/cpukit/rtems/src/semobtain.c
> +++ b/cpukit/rtems/src/semobtain.c
> @@ -75,6 +75,7 @@ rtems_status_code rtems_semaphore_obtain(
>      case SEMAPHORE_VARIANT_MUTEX_INHERIT_PRIORITY:
>          &the_semaphore->Core_control.Mutex.Recursive,
>          executing,
>          wait,
> @@ -91,7 +92,7 @@ rtems_status_code rtems_semaphore_obtain(
>        break;
>      case SEMAPHORE_VARIANT_MUTEX_NO_PROTOCOL:
>          _Semaphore_Get_operations( the_semaphore ),
>          executing,
> diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
> index 39c467d..40860a1 100644
> --- a/cpukit/rtems/src/semrelease.c
> +++ b/cpukit/rtems/src/semrelease.c
> @@ -52,6 +52,7 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
>          executing,
>          &queue_context
> @@ -64,13 +65,12 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
>        break;
> -      _CORE_recursive_mutex_Surrender_no_protocol(
>          executing,
>          &queue_context
> -      status = STATUS_SUCCESSFUL;
>        break;
>      case SEMAPHORE_VARIANT_SIMPLE_BINARY:
>        status = _CORE_semaphore_Surrender(
> diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
> index d30e38d..2580606 100644
> --- a/cpukit/score/include/rtems/score/coremuteximpl.h
> +++ b/cpukit/score/include/rtems/score/coremuteximpl.h
> @@ -134,6 +134,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_nested(
>  RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
>    CORE_recursive_mutex_Control  *the_mutex,
> +  const Thread_queue_Operations *operations,
>    Thread_Control                *executing,
>    bool                           wait,
>    Status_Control              ( *nested )( CORE_recursive_mutex_Control * ),
> @@ -163,7 +164,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
>    return _CORE_mutex_Seize_slow(
>      &the_mutex->Mutex,
> -    CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
> +    operations,
>      executing,
>      wait,
>      queue_context
> @@ -171,9 +172,10 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
>  RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender(
> -  CORE_recursive_mutex_Control *the_mutex,
> -  Thread_Control               *executing,
> -  Thread_queue_Context         *queue_context
> +  CORE_recursive_mutex_Control  *the_mutex,
> +  Thread_Control                *executing,
> +  Thread_queue_Context          *queue_context
>    unsigned int        nest_level;
> @@ -209,91 +211,8 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender(
>      heads,
>      executing,
>      queue_context,
> -  return STATUS_SUCCESSFUL;
> -RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_no_protocol(
> -  const Thread_queue_Operations *operations,
> -  bool                           wait,
> -  Status_Control              ( *nested )( CORE_recursive_mutex_Control * ),
> -  Thread_Control *owner;
> -  _CORE_mutex_Acquire_critical( &the_mutex->Mutex, queue_context );
> -  owner = _CORE_mutex_Get_owner( &the_mutex->Mutex );
> -  if ( owner == NULL ) {
> -    _CORE_mutex_Set_owner( &the_mutex->Mutex, executing );
> -    _CORE_mutex_Release( &the_mutex->Mutex, queue_context );
> -  if ( owner == executing ) {
> -    Status_Control status;
> -    status = ( *nested )( the_mutex );
> -    return status;
> -  return _CORE_mutex_Seize_slow(
> -    &the_mutex->Mutex,
> -    operations,
> -    executing,
> -    wait,
> -    queue_context
> -RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender_no_protocol(
> -  unsigned int    nest_level;
> -  Thread_Control *new_owner;
> -  if ( !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing ) ) {
> -    return STATUS_NOT_OWNER;
> -  nest_level = the_mutex->nest_level;
> -  if ( nest_level > 0 ) {
> -    the_mutex->nest_level = nest_level - 1;
> -  new_owner = _Thread_queue_First_locked(
> -    &the_mutex->Mutex.Wait_queue,
>      operations
> -  _CORE_mutex_Set_owner( &the_mutex->Mutex, new_owner );
> -  if ( new_owner == NULL ) {
> -  _Thread_queue_Extract_critical(
> -    &the_mutex->Mutex.Wait_queue.Queue,
> -    operations,
> -    new_owner,
> -    queue_context
> diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
> index cf90a76..879562d 100644
> --- a/cpukit/score/src/apimutexlock.c
> +++ b/cpukit/score/src/apimutexlock.c
> @@ -36,6 +36,7 @@ void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
>      &the_mutex->Mutex,
>      _Thread_Executing,
>      true,
> diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
> index f04e47a..e1fe645 100644
> --- a/cpukit/score/src/apimutexunlock.c
> +++ b/cpukit/score/src/apimutexunlock.c
> @@ -35,6 +35,7 @@ void _API_Mutex_Unlock( API_Mutex_Control *the_mutex )
>    _ISR_lock_ISR_disable( &queue_context.Lock_context.Lock_context );
>      &the_mutex->Mutex,
>      _Thread_Executing,
>      &queue_context
> 1.8.4.5
> devel mailing list
> devel at rtems.org
