[PATCH v2 5/7] Adding RTEMS support for FREEBSD TTY
    Kevin Kirspel
    kevin-kirspel at idexx.com
    Fri Apr  7 16:49:58 UTC 2017
 rtemsbsd/include/machine/rtems-bsd-commands.h     |  2 +
 rtemsbsd/include/machine/rtems-bsd-kernel-space.h |  1 +
 rtemsbsd/include/rtems/bsd/local/opt_gdb.h        |  1 +
 rtemsbsd/include/rtems/netcmds-config.h           |  2 +
 rtemsbsd/rtems/rtems-bsd-shell-stty.c             | 40 +++++++++++
 rtemsbsd/sys/fs/devfs/devfs_devs.c                | 86 +++++++++++++++++++++--
 6 files changed, 126 insertions(+), 6 deletions(-)
 create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_gdb.h
 create mode 100644 rtemsbsd/rtems/rtems-bsd-shell-stty.c
 mode change 100755 => 100644 rtemsbsd/sys/fs/devfs/devfs_devs.c
diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h b/rtemsbsd/include/machine/rtems-bsd-commands.h
index c0524c8..9e9ed1c 100644
--- a/rtemsbsd/include/machine/rtems-bsd-commands.h
+++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
@@ -70,6 +70,8 @@ int rtems_bsd_command_vmstat(int argc, char **argv);
 int rtems_bsd_command_wlanstats(int argc, char **argv);
+int rtems_bsd_command_stty(int argc, char **argv);
 __END_DECLS
 #endif /* _RTEMS_BSD_MACHINE_RTEMS_BSD_COMMANDS_H_ */
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
index 10ce9d2..9d0484a 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
@@ -48,6 +48,7 @@
 #define	__GLOBL(sym)	__GLOBL1(sym)
 #define O_CLOEXEC 0
+#define IO_NDELAY O_NONBLOCK
 #define __FreeBSD__ 1
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_gdb.h b/rtemsbsd/include/rtems/bsd/local/opt_gdb.h
new file mode 100644
index 0000000..936ffd8
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/opt_gdb.h
@@ -0,0 +1 @@
+/* EMPTY */
diff --git a/rtemsbsd/include/rtems/netcmds-config.h b/rtemsbsd/include/rtems/netcmds-config.h
index b3bc66f..515b265 100644
--- a/rtemsbsd/include/rtems/netcmds-config.h
+++ b/rtemsbsd/include/rtems/netcmds-config.h
@@ -45,6 +45,8 @@ extern rtems_shell_cmd_t rtems_shell_VMSTAT_Command;
 extern rtems_shell_cmd_t rtems_shell_WLANSTATS_Command;
+extern rtems_shell_cmd_t rtems_shell_STTY_Command;
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/rtemsbsd/rtems/rtems-bsd-shell-stty.c b/rtemsbsd/rtems/rtems-bsd-shell-stty.c
index 0000000..530b442
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-bsd-shell-stty.c
@@ -0,0 +1,40 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <rtems/netcmds-config.h>
+#include <machine/rtems-bsd-commands.h>
+rtems_shell_cmd_t rtems_shell_STTY_Command = {
+  .name = "stty",
+  .usage = "stty [args]",
+  .topic = "serial",
+  .command = rtems_bsd_command_stty
diff --git a/rtemsbsd/sys/fs/devfs/devfs_devs.c b/rtemsbsd/sys/fs/devfs/devfs_devs.c
old mode 100755
new mode 100644
index 0ee71ff..a91a02e
--- a/rtemsbsd/sys/fs/devfs/devfs_devs.c
+++ b/rtemsbsd/sys/fs/devfs/devfs_devs.c
@@ -36,6 +36,7 @@
 #include <sys/kernel.h>
 #include <sys/file.h>
 #include <sys/malloc.h>
+#include <sys/proc.h>
 #include <unistd.h>
@@ -50,8 +51,16 @@
 const char rtems_cdev_directory[] = RTEMS_CDEV_DIRECTORY;
+ * The one true (but secret) list of active devices in the system.
+ * Locked by dev_lock()/devmtx
+struct cdev_priv_list cdevp_list = TAILQ_HEAD_INITIALIZER(cdevp_list);
 struct unrhdr *devfs_inos;
+static MALLOC_DEFINE(M_CDEVP, "DEVFS1", "DEVFS cdev_priv storage");
 static struct cdev *
 devfs_imfs_get_context_by_iop(rtems_libio_t *iop)
@@ -62,11 +71,19 @@ static int
 devfs_imfs_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
 	struct cdev *cdev = devfs_imfs_get_context_by_iop(iop);
+	struct file *fp = rtems_bsd_iop_to_fp(iop);
 	struct thread *td = rtems_bsd_get_curthread_or_null();
+	struct file *fpop;
 	int error;
 	if (td != NULL) {
+		fpop = td->td_fpop;
+		curthread->td_fpop = fp;
 		error = cdev->si_devsw->d_open(cdev, oflag, 0, td);
+		/* Clean up any cdevpriv upon error. */
+		if (error != 0)
+			devfs_clear_cdevpriv();
+		curthread->td_fpop = fpop;
 	} else {
 		error = ENOMEM;
@@ -78,12 +95,17 @@ static int
 devfs_imfs_close(rtems_libio_t *iop)
 	int flags = rtems_libio_to_fcntl_flags(iop->flags);
 	int error;
 	if (td != NULL) {
 		error = cdev->si_devsw->d_close(cdev, flags, 0, td);
 	} else {
 		error = ENOMEM;
@@ -96,6 +118,7 @@ devfs_imfs_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
     ssize_t total)
 	struct uio uio = {
 		.uio_iov = __DECONST(struct iovec *, iov),
@@ -106,11 +129,15 @@ devfs_imfs_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
 		.uio_rw = UIO_READ,
 		.uio_td = td
 	int error;
 	if (td != NULL) {
 		error = cdev->si_devsw->d_read(cdev, &uio,
 		    rtems_libio_to_fcntl_flags(iop->flags));
+		td->td_fpop = fpop;
 	} else {
 		error = ENOMEM;
@@ -138,6 +165,7 @@ devfs_imfs_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
     ssize_t total)
 	struct uio uio = {
@@ -148,11 +176,15 @@ devfs_imfs_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
 		.uio_rw = UIO_WRITE,
 		.uio_td = td
 	int error;
 	if (td != NULL) {
 		error = cdev->si_devsw->d_write(cdev, &uio,
 	} else {
 		error = ENOMEM;
@@ -179,13 +211,18 @@ static int
 devfs_imfs_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
 	int error;
 	if (td != 0) {
 		error = cdev->si_devsw->d_ioctl(cdev, request, buffer, flags,
 		    td);
 	} else {
 		error = ENOMEM;
@@ -197,17 +234,34 @@ static int
 devfs_imfs_poll(rtems_libio_t *iop, int events)
+	struct thread *td = rtems_bsd_get_curthread_or_wait_forever();
+	int error;
+	error = cdev->si_devsw->d_poll(cdev, events, td);
-	return (cdev->si_devsw->d_poll(cdev, events,
-	    rtems_bsd_get_curthread_or_wait_forever()));
+	return error;
 static int
 devfs_imfs_kqfilter(rtems_libio_t *iop, struct knote *kn)
+	int error;
+	error = cdev->si_devsw->d_kqfilter(cdev, kn);
-	return (cdev->si_devsw->d_kqfilter(cdev, kn));
+	return error;
 static const rtems_filesystem_file_handlers_r devfs_imfs_handlers = {
@@ -235,12 +289,17 @@ static const IMFS_node_control devfs_imfs_control = IMFS_GENERIC_INITIALIZER(
 struct cdev *
 devfs_alloc(int flags)
+	struct cdev_priv *cdp;
 	struct cdev *cdev;
-	cdev = malloc(sizeof *cdev, M_TEMP, M_ZERO);
-	if (cdev == NULL)
+	cdp = malloc(sizeof *cdp, M_CDEVP, M_ZERO |
+	    ((flags & MAKEDEV_NOWAIT) ? M_NOWAIT : M_WAITOK));
+	if (cdp == NULL)
 		return (NULL);
+	cdev = &cdp->cdp_c;
+	LIST_INIT(&cdev->si_children);
 	memcpy(cdev->si_path, rtems_cdev_directory, sizeof(cdev->si_path));
 	return (cdev);
@@ -248,7 +307,11 @@ devfs_alloc(int flags)
 void
 devfs_free(struct cdev *cdev)
-	free(cdev, M_TEMP);
+	cdp = cdev2priv(cdev);
+	devfs_free_cdp_inode(cdp->cdp_inode);
+	free(cdp, M_CDEVP);
@@ -286,6 +349,7 @@ devfs_create_directory(const char *devname)
 void
 devfs_create(struct cdev *dev)
 	int rv;
 	mode_t mode = S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO;
@@ -294,13 +358,23 @@ devfs_create(struct cdev *dev)
 	rv = IMFS_make_generic_node(dev->si_path, mode, &devfs_imfs_control,
 	    dev);
 	BSD_ASSERT(rv == 0);
+	cdp = cdev2priv(dev);
+	cdp->cdp_flags |= CDP_ACTIVE;
+	cdp->cdp_inode = alloc_unrl(devfs_inos);
+	dev_refl(dev);
+	TAILQ_INSERT_TAIL(&cdevp_list, cdp, cdp_list);
 void
 devfs_destroy(struct cdev *dev)
 	int rv;
+	cdp->cdp_flags &= ~CDP_ACTIVE;
 	rv = unlink(dev->si_path);
1.9.1
