[PATCH v2 6/7] Adding test cases for FREEBSD termios support through tty
Kevin Kirspel kevin-kirspel at idexx.com
Fri Apr 7 16:49:59 UTC 2017
 .../include/rtems/bsd/test/default-termios-init.h  | 158 ++++
 testsuite/termios/test_main.c                      | 856 +++++++++++++++++++++
 testsuite/termios/test_termios_driver.c            | 136 ++++
 testsuite/termios/test_termios_driver.h            |  32 +
 testsuite/termios/test_termios_utilities.c         | 233 ++++++
 testsuite/termios/test_termios_utilities.h         |  33 +
 testsuite/termios01/test_main.c                    | 690 +++++++++++++++++
 testsuite/termios02/test_main.c                    | 140 ++++
 testsuite/termios03/test_main.c                    |  73 ++
 testsuite/termios04/test_main.c                    |  69 ++
 testsuite/termios05/test_main.c                    |  65 ++
 testsuite/termios06/test_main.c                    | 492 ++++++++++++
 12 files changed, 2977 insertions(+)
 create mode 100644 testsuite/include/rtems/bsd/test/default-termios-init.h
 create mode 100644 testsuite/termios/test_main.c
 create mode 100644 testsuite/termios/test_termios_driver.c
 create mode 100644 testsuite/termios/test_termios_driver.h
 create mode 100644 testsuite/termios/test_termios_utilities.c
 create mode 100644 testsuite/termios/test_termios_utilities.h
 create mode 100644 testsuite/termios01/test_main.c
 create mode 100644 testsuite/termios02/test_main.c
 create mode 100644 testsuite/termios03/test_main.c
 create mode 100644 testsuite/termios04/test_main.c
 create mode 100644 testsuite/termios05/test_main.c
 create mode 100644 testsuite/termios06/test_main.c
diff --git a/testsuite/include/rtems/bsd/test/default-termios-init.h b/testsuite/include/rtems/bsd/test/default-termios-init.h
new file mode 100644
index 0000000..16c7ad7
--- /dev/null
+++ b/testsuite/include/rtems/bsd/test/default-termios-init.h
@@ -0,0 +1,158 @@
+ *  Shared Network Test Initialization File
+#ifndef RTEMS_BSD_TEST_DEFAULT_INIT_H
+#define RTEMS_BSD_TEST_DEFAULT_INIT_H
+#include <bsp.h>
+#include <assert.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <rtems/printer.h>
+#include <rtems/stackchk.h>
+#include <rtems/bsd/bsd.h>
+static void default_set_self_prio( rtems_task_priority prio )
+  rtems_status_code sc;
+  sc = rtems_task_set_priority(RTEMS_SELF, prio, &prio);
+  assert(sc == RTEMS_SUCCESSFUL);
+static void default_on_exit( int exit_code, void *arg )
+  rtems_printer printer;
+  rtems_print_printer_printf(&printer);
+  rtems_stack_checker_report_usage_with_plugin(&printer);
+  if ( exit_code == 0 ) {
+    puts( "*** END OF TEST " TEST_NAME " ***" );
+rtems_task Init(
+  rtems_task_argument ignored
+   * Default the syslog priority to 'debug' to aid developers.
+  rtems_bsd_setlogpriority("debug");
+  puts( "*** " TEST_NAME " TEST ***" );
+   *  BSD must support the new "shared IRQ PIC implementation" at this point.
+   *  BSPs must also provide rtems_interrupt_server_initialize() which
+   *  just requires including irq-server.[ch] in their build.
+  on_exit( default_on_exit, NULL );
+#ifdef DEFAULT_EARLY_INITIALIZATION
+  early_initialization();
+#endif
+  /* Let other tasks run to complete background work */
+  default_set_self_prio( RTEMS_MAXIMUM_PRIORITY - 2 );
+  rtems_bsd_initialize();
+  /* Let the callout timer allocate its resources */
+  sc = rtems_task_wake_after( 2 );
+  test_main();
+  /* should not return */
+  assert( 0 );
+ * Configure RTEMS.
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_MAXIMUM_DRIVERS 32
+#define CONFIGURE_FILESYSTEM_DOSFS
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_STACK_CHECKER_ENABLED
+#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE (64 * 1024)
+#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE (256 * 1024)
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#include <rtems/confdefs.h>
+ * Configure LIBBSD device.
+ #include <bsp/nexus-devices.h>
+ * Configure RTEMS Shell.
+#define CONFIGURE_SHELL_COMMANDS_INIT
+#include <bsp/irq-info.h>
+#include <rtems/netcmds-config.h>
+#define CONFIGURE_SHELL_USER_COMMANDS \
+  &bsp_interrupt_shell_command, \
+  &rtems_shell_STTY_Command, \
+  &rtems_shell_SYSCTL_Command
+#define CONFIGURE_SHELL_COMMAND_CPUUSE
+#define CONFIGURE_SHELL_COMMAND_PERIODUSE
+#define CONFIGURE_SHELL_COMMAND_STACKUSE
+#define CONFIGURE_SHELL_COMMAND_PROFREPORT
+#define CONFIGURE_SHELL_COMMAND_PWD
+#define CONFIGURE_SHELL_COMMAND_LS
+#define CONFIGURE_SHELL_COMMAND_LN
+#define CONFIGURE_SHELL_COMMAND_LSOF
+#define CONFIGURE_SHELL_COMMAND_CHDIR
+#define CONFIGURE_SHELL_COMMAND_CD
+#define CONFIGURE_SHELL_COMMAND_MKDIR
+#define CONFIGURE_SHELL_COMMAND_RMDIR
+#define CONFIGURE_SHELL_COMMAND_CAT
+#define CONFIGURE_SHELL_COMMAND_MV
+#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
+#define CONFIGURE_SHELL_COMMAND_BLKSTATS
+#define CONFIGURE_SHELL_COMMAND_BLKSYNC
+#define CONFIGURE_SHELL_COMMAND_MOUNT
+#define CONFIGURE_SHELL_COMMAND_UNMOUNT
+#include <rtems/shellconfig.h>
+#endif /* RTEMS_BSD_TEST_DEFAULT_INIT_H */
\ No newline at end of file
diff --git a/testsuite/termios/test_main.c b/testsuite/termios/test_main.c
index 0000000..90e3382
--- /dev/null
+++ b/testsuite/termios/test_main.c
@@ -0,0 +1,856 @@
+ *  COPYRIGHT (c) 1989-2010.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <stdio.h>
+#include <rtems/console.h>
+#include <rtems/shell.h>
+#include <termios.h>
+#include "test_termios_driver.h"
+#define TEST_NAME "LIBBSD TERMIOS"
+/* forward declarations to avoid warnings */
+void print_32bits(unsigned long bits, unsigned char size, char * names[]);
+void print_c_iflag(struct termios * tp);
+void print_c_oflag(struct termios * tp);
+void print_c_lflag(struct termios * tp);
+void print_c_cflag(struct termios * tp);
+void print_c_cc(struct termios * tp);
+void print_baud(const char* name, speed_t spd);
+void print_termios(struct termios *tp);
+unsigned long get_baud_rate(void);
+unsigned long get_parity(void);
+unsigned long get_stop_bits(void);
+unsigned long get_data_bits(void);
+void change_line_settings(struct termios *tp);
+void canonical_input(struct termios *tp);
+void do_raw_input(int vmin, int vtime);
+void usage(void);
+#if !defined(fileno)
+int fileno( FILE *stream); /* beyond ANSI */
+#endif
+/* Some of the termios dumping code depends on bit positions! */
+void print_32bits( unsigned long bits, unsigned char size, char * names[] )
+  unsigned char i;
+  for( i = 0; i < size; i++ ) {
+    if( (bits >> i) & 0x1 )
+      printf( "%s ", names[i] );
+void print_c_iflag( struct termios * tp )
+  char * c_iflag_bits [] = {
+    "IGNBRK",   /* 0000001 */
+    "BRKINT",   /* 0000002 */
+    "IGNPAR",   /* 0000004 */
+    "PARMRK",   /* 0000010 */
+    "INPCK",    /* 0000020 */
+    "ISTRIP",   /* 0000040 */
+    "INLCR",    /* 0000100 */
+    "IGNCR",    /* 0000200 */
+    "ICRNL",    /* 0000400 */
+    "IUCLC",    /* 0001000 */
+    "IXON",     /* 0002000 */
+    "IXANY",    /* 0004000 */
+    "IXOFF",    /* 0010000 */
+    "IMAXBEL",  /* 0020000 */
+    "unknown",  /* 0040000 */
+    "unknown",  /* 0100000 */
+    "unknown",  /* 0200000 */
+    "unknown",  /* 0400000 */
+    "unknown",  /* 1000000 */
+    "unknown",  /* 2000000 */
+    "unknown"   /* 4000000 */
+  printf( "c_iflag = 0x%08x\n\t", tp->c_iflag );
+  print_32bits( tp->c_iflag, sizeof( c_iflag_bits )/sizeof( char * ), c_iflag_bits );
+  printf( "\n" );
+void print_c_oflag( struct termios * tp )
+  printf( "c_oflag = 0x%08x\n\t", tp->c_oflag );
+  if( tp->c_oflag & OPOST )
+    printf( "OPOST " );
+  if( tp->c_oflag & OLCUC )
+    printf( "OLCUC " );
+  if( tp->c_oflag & ONLCR )
+    printf( "ONLCR " );
+  if( tp->c_oflag & ONOEOT )
+    printf( "ONOEOT " );
+  if( tp->c_oflag & OCRNL )
+    printf( "OCRNL " );
+  if( tp->c_oflag & ONOCR )
+    printf( "ONOCR " );
+  if( tp->c_oflag & ONLRET )
+    printf( "ONLRET " );
+  if( tp->c_oflag & OFILL )
+    printf( "OFILL " );
+  if( tp->c_oflag & OFDEL )
+    printf( "OFDEL " );
+  switch( tp->c_oflag & NLDLY ) {
+    case NL0:
+      printf( "NL0 " );
+      break;
+    case NL1:
+      printf( "NL1 " );
+      break;
+  switch( tp->c_oflag & CRDLY ) {
+    case CR0:
+      printf( "CR0 " );
+      break;
+    case CR1:
+      printf( "CR1 " );
+      break;
+    case CR2:
+      printf( "CR2 " );
+      break;
+    case CR3:
+      printf( "CR3 " );
+      break;
+  switch( tp->c_oflag & TABDLY ) {
+    case TAB0:
+      printf( "TAB0 " );
+      break;
+    case TAB1:
+      printf( "TAB1 " );
+      break;
+    case TAB2:
+      printf( "TAB2 " );
+      break;
+    case TAB3:
+      printf( "TAB3 " );
+      break;
+  switch( tp->c_oflag & BSDLY ) {
+    case BS0:
+      printf( "BS0 " );
+      break;
+    case BS1:
+      printf( "BS1 " );
+      break;
+  switch( tp->c_oflag & VTDLY ) {
+    case VT0:
+      printf( "VT0 " );
+      break;
+    case VT1:
+      printf( "VT1 " );
+      break;
+  switch( tp->c_oflag & FFDLY ) {
+    case FF0:
+      printf( "FF0" );
+      break;
+    case FF1:
+      printf( "FF1" );
+      break;
+  printf( "\n" );
+void print_c_lflag( struct termios * tp )
+  char * c_lflag_bits [] = {
+    "ECHOKE",      /* 0x00000001 */
+    "ECHOE",       /* 0x00000002 */
+    "ECHOK",       /* 0x00000004 */
+    "ECHO",        /* 0x00000008 */
+    "ECHONL",      /* 0x00000010 */
+    "ECHOPRT",     /* 0x00000020 */
+    "ECHOCTL",     /* 0x00000040 */
+    "ISIG",        /* 0x00000080 */
+    "ICANON",      /* 0x00000100 */
+    "ALTWERASE",   /* 0x00000200 */
+    "IEXTEN",      /* 0x00000400 */
+    "EXTPROC",     /* 0x00000800 */
+    "XCASE",       /* 0x00001000 */
+    "unknown",     /* 0x00002000 */
+    "unknown",     /* 0x00004000 */
+    "unknown",     /* 0x00008000 */
+    "unknown",     /* 0x00010000 */
+    "unknown",     /* 0x00020000 */
+    "unknown",     /* 0x00040000 */
+    "unknown",     /* 0x00080000 */
+    "unknown",     /* 0x00100000 */
+    "unknown",     /* 0x00200000 */
+    "TOSTOP",      /* 0x00400000 */
+    "FLUSHO",      /* 0x00800000 */
+    "unknown",     /* 0x01000000 */
+    "NOKERNINFO",  /* 0x02000000 */
+    "unknown",     /* 0x04000000 */
+    "unknown",     /* 0x08000000 */
+    "unknown",     /* 0x10000000 */
+    "PENDIN",      /* 0x20000000 */
+    "unknown",     /* 0x40000000 */
+    "NOFLSH",      /* 0x80000000 */
+  printf( "c_lflag = 0x%08x\n\t", tp->c_lflag );
+  print_32bits( tp->c_lflag, sizeof( c_lflag_bits )/sizeof( char * ), c_lflag_bits );
+  printf( "\n" );
+void print_c_cflag( struct termios * tp )
+  printf( "c_cflag = 0x%08x\n", tp->c_cflag );
+  switch( tp->c_cflag & CSIZE ) {
+    case CS5:
+      printf( "\tCSIZE =\tCS5\n" );
+      break;
+    case CS6:
+      printf( "\tCSIZE =\tCS6\n" );
+      break;
+    case CS7:
+      printf( "\tCSIZE =\tCS7\n" );
+      break;
+    case CS8:
+      printf( "\tCSIZE =\tCS8\n" );
+      break;
+  if( tp->c_cflag & CIGNORE )
+    printf( "\tCIGNORE set: iqnore c_cflags enabled\n" );
+  else
+    printf( "\tCIGNORE clear: iqnore c_cflags disabled\n" );
+  if( tp->c_cflag & CSTOPB )
+    printf( "\tCSTOPB set: send 2 stop bits\n" );
+  else
+    printf( "\tCSTOPB clear: send 1 stop bit\n" );
+  if( tp->c_cflag & PARENB )
+    printf( "\tPARENB set: parity enabled\n" );
+  else
+    printf( "\tPARENB clear: parity disabled\n" );
+  if( tp->c_cflag & PARODD )
+    printf( "\tPARODD set: parity odd\n" );
+  else
+    printf( "\tPARODD clear: parity even\n" );
+  if( tp->c_cflag & CREAD )
+    printf( "\tCREAD set: receiver enabled\n" );
+  else
+    printf( "\tCREAD clear: treceiver disabled\n" );
+  if( tp->c_cflag & HUPCL )
+    printf( "\tHUPCL set: enabled\n" );
+  else
+    printf( "\tHUPCL clear: disabled\n" );
+  if( tp->c_cflag & CLOCAL )
+    printf( "\tCLOCAL set: ignore modem lines\n" );
+  else
+    printf( "\tCLOCAL clear: don't ignore modem lines\n" );
+  if( tp->c_cflag & CCTS_OFLOW )
+    printf( "\tCCTS_OFLOW: hardware CTS output flow control enabled\n" );
+  else
+    printf( "\tCCTS_OFLOW: hardware CTS output flow control disabled\n" );
+  if( tp->c_cflag & CRTS_IFLOW )
+    printf( "\tCRTS_IFLOW: hardware RTS input flow control enabled\n" );
+  else
+    printf( "\tCRTS_IFLOW: hardware RTS input flow control disabled\n" );
+  if( tp->c_cflag & CRTSCTS )
+    printf( "\tCRTSCTS: harware flow control enabled?\n" );
+  else
+    printf( "\tCRTSCTS: hardware flow control disabled?\n" );
+  if( tp->c_cflag & CDSR_OFLOW )
+    printf( "\tCDSR_OFLOW: hardware DSR output flow control enabled\n" );
+  else
+    printf( "\tCDSR_OFLOW: hardware DSR output flow control disabled\n" );
+  if( tp->c_cflag & CDTR_IFLOW )
+    printf( "\tCDTR_IFLOW: hardware DTR input flow control enabled\n" );
+  else
+    printf( "\tCDTR_IFLOW: hardware DTR input flow control disabled\n" );
+  if( tp->c_cflag & CCAR_OFLOW )
+    printf( "\tCCAR_OFLOW: hardware CD output flow control enabled\n" );
+  else
+    printf( "\tCCAR_OFLOW: hardware CD output flow control disabled\n" );
+void print_c_cc( struct termios * tp )
+  size_t i;
+  char * cc_index_names [ /* NCCS */ ] = {
+    "[VEOF]    ",   /* 0 */
+    "[VEOL]    ",   /* 1 */
+    "[VEOL2]   ",   /* 2 */
+    "[VERASE]  ",   /* 3 */
+    "[VWERASE] ",   /* 4 */
+    "[VKILL]   ",   /* 5 */
+    "[VREPRINT]",   /* 6 */
+    "[VERASE2] ",   /* 7 */
+    "[VINTR]   ",   /* 8 */
+    "[VQUIT]   ",   /* 9 */
+    "[VSUSP]   ",   /* 10 */
+    "[VDSUSP]  ",   /* 11 */
+    "[VSTART]  ",   /* 12 */
+    "[VSTOP]   ",   /* 13 */
+    "[VLNEXT]  ",   /* 14 */
+    "[VDISCARD]",   /* 15 */
+    "[VMIN]    ",   /* 16 */
+    "[VTIME]   ",   /* 17 */
+    "[VSTATUS] ",   /* 18 */
+    "unknown   ",   /* 19 */
+  for( i = 0; i < sizeof(cc_index_names)/sizeof(char*) ; i++ ) {
+    printf( "c_cc%s = 0x%08x\n", cc_index_names[i], tp->c_cc[i] );
+void print_baud( const char* name, speed_t spd )
+  switch( spd ) {
+  case B0:
+    printf( "%s = B0\n", name );
+    break;
+  case B50:
+    printf( "%s = B50\n", name );
+    break;
+  case B75:
+    printf( "%s = B75\n", name );
+    break;
+  case B110:
+    printf( "%s = B110\n", name );
+    break;
+  case B134:
+    printf( "%s = B134\n", name );
+    break;
+  case B150:
+    printf( "%s = B150\n", name );
+    break;
+  case B200:
+    printf( "%s = B200\n", name );
+    break;
+  case B300:
+    printf( "%s = B300\n", name );
+    break;
+  case B600:
+    printf( "%s = B600\n", name );
+    break;
+  case B1200:
+    printf( "%s = B1200\n", name );
+    break;
+  case B1800:
+    printf( "%s = B1800\n", name );
+    break;
+  case B2400:
+    printf( "%s = B2400\n", name );
+    break;
+  case B4800:
+    printf( "%s = B4800\n", name );
+    break;
+  case B9600:
+    printf( "%s = B9600\n", name );
+    break;
+  case B19200:
+    printf( "%s = B19200\n", name );
+    break;
+  case B38400:
+    printf( "%s = B38400\n", name );
+    break;
+  case B7200:
+    printf( "%s = B7200\n", name );
+    break;
+  case B14400:
+    printf( "%s = B14400\n", name );
+    break;
+  case B28800:
+    printf( "%s = B28800\n", name );
+    break;
+  case B57600:
+    printf( "%s = B57600\n", name );
+    break;
+  case B76800:
+    printf( "%s = B76800\n", name );
+    break;
+  case B115200:
+    printf( "%s = B115200\n", name );
+    break;
+  case B230400:
+    printf( "%s = B230400\n", name );
+    break;
+  case B460800:
+    printf( "%s = B460800\n", name );
+    break;
+  case B921600:
+    printf( "%s = B921600\n", name );
+    break;
+  default:
+    printf( "%s = unknown (0x%08x)\n", name, (unsigned int)spd );
+    break;
+void print_termios( struct termios *tp )
+  printf( "\nLooking at the current termios settings:\n\n" );
+  print_c_iflag( tp );
+  print_c_oflag( tp );
+  print_c_cflag( tp );
+  print_c_lflag( tp );
+  print_c_cc( tp );
+  print_baud( "c_ispeed", tp->c_ispeed );
+  print_baud( "c_ospeed", tp->c_ospeed );
+  printf( "\n" );
+  unsigned long baud_rate;
+  while( 1 ) {
+    printf( "Enter the numerical value for the new baud rate.\n" );
+    printf( "Choices are: 50, 75, 110, 134, 150, 200, 300, 600, 1200, 1800\n" );
+    printf( "2400, 4800, 9600, 19200, 38400, 7200, 14400, 28800, 57600, 76800\n" );
+    printf( "115200, 230400, 460800, 921600\n" );
+    printf( "\nYour choice: " );
+    scanf( "%lu", &baud_rate );
+    printf( "\n" );
+    switch( baud_rate ) {
+      case 50:     return B50;
+      case 75:     return B75;
+      case 110:    return B110;
+      case 134:    return B134;
+      case 150:    return B150;
+      case 200:    return B200;
+      case 300:    return B300;
+      case 600:    return B600;
+      case 1200:   return B1200;
+      case 1800:   return B1800;
+      case 2400:   return B2400;
+      case 4800:   return B4800;
+      case 9600:   return B9600;
+      case 19200:  return B19200;
+      case 38400:  return B38400;
+      case 7200:   return B7200;
+      case 14400:  return B14400;
+      case 28800:  return B28800;
+      case 57600:  return B57600;
+      case 76800:  return B76800;
+      case 115200: return B115200;
+      case 230400: return B230400;
+      case 460800: return B460800;
+      case 921600: return B921600;
+      default:
+        printf( "%lu is not a valid choice. Try again.\n\n", baud_rate );
+        break;
+  int parity;
+  while( 1 ) {
+    printf( "Enter the numerical value for the new parity\n" );
+    printf( "Choices are: 0 for no parity, 1 for even parity, 2 for odd parity\n" );
+    scanf( "%d", &parity );
+    printf( "\n" );
+    switch( parity ) {
+      case 0:
+        return 0;
+      case 1:
+        return PARENB;
+      case 2:
+        return PARENB | PARODD;
+      default:
+        printf( "%d is not a valid choice. Try again.\n\n", parity );
+        break;
+  int stop_bits;
+  while( 1 ) {
+    printf( "Enter the numerical value for the new number of stop bits\n" );
+    printf( "Choices are: 1 or 2\n" );
+    scanf( "%d", &stop_bits );
+    printf( "\n" );
+    switch( stop_bits ) {
+      case 1:
+        return 0;
+      case 2:
+        return CSTOPB;
+      default:
+        printf( "%d is not a valid choice. Try again.\n\n", stop_bits );
+        break;
+  int data_bits;
+  while( 1 ) {
+    printf( "Enter the numerical value for the new number of data bits\n" );
+    printf( "Choices are: 5, 6, 7 or 8\n" );
+    scanf( "%d", &data_bits );
+    printf( "\n" );
+    switch( data_bits ) {
+      case 5:
+        return CS5;
+      case 6:
+        return CS6;
+      case 7:
+        return CS7;
+      case 8:
+        return CS8;
+      default:
+        printf( "%d is not a valid choice. Try again.\n\n", data_bits );
+        break;
+void change_line_settings( struct termios *tp )
+  unsigned long baud_rate, parity, stop_bits, data_bits, sleep_time;
+  printf( "\nSetting line characteristics\n\n" );
+  baud_rate = get_baud_rate();
+  parity = get_parity();
+  stop_bits = get_stop_bits();
+  data_bits = get_data_bits();
+  printf( "NOTE: You will not see output until you switch your terminal settings!\n" );
+  printf( "WARNING: If you do not switch your terminal settings, your terminal may hang.\n" );
+  printf( "Enter the number of seconds the test will wait for you to switch your terminal\n" );
+  printf( "settings before it continues\n" );
+  printf( "Sleep time (in seconds): " );
+  scanf( "%lu", &sleep_time );
+  printf( "\n" );
+  printf( "Setting line to new termios settings in %lu seconds.\n", sleep_time );
+  sleep( sleep_time );
+  tp->c_cflag = CLOCAL | CREAD | parity | stop_bits | data_bits;
+  tp->c_ispeed = baud_rate;
+  tp->c_ospeed = baud_rate;
+  if( tcsetattr( fileno( stdin ), TCSADRAIN, tp ) < 0 ) {
+    perror( "change_line_settings(): tcsetattr() failed" );
+    exit( 1 );
+  printf( "Line settings set.\n" );
+void canonical_input( struct termios *tp )
+  char c;
+  bool first_time = true;
+  printf( "\nTesting canonical input\n\n" );
+  printf( "Setting line to canonical input mode.\n" );
+  tp->c_lflag = ISIG | ICANON | ECHO | ECHONL | ECHOK | ECHOE | ECHOPRT | ECHOCTL | IEXTEN;
+  tp->c_iflag = BRKINT | ICRNL | IXON | IMAXBEL;
+    perror( "canonical_input(): tcsetattr() failed" );
+    exit( 1 );
+  while ( ( c = getchar () ) != '\n');
+  printf( "Testing getchar(). Type some text followed by carriage return\n" );
+  printf( "Each character you entered will be echoed back to you\n\n" );
+  while ( ( c = getchar () ) != '\n') {
+    if( first_time ) {
+      printf( "\nYou typed:\n");
+      first_time = false;
+    printf( "%c", c );
+  printf( "\n\nCanonical input test done.\n" );
+ * Test raw (ICANON=0) input
+void do_raw_input( int vmin, int vtime )
+  int i;
+  struct termios old, new;
+  rtems_interval ticksPerSecond, then, now;
+  unsigned int msec;
+  unsigned long count;
+  int nread;
+  unsigned char cbuf[100];
+  printf( "Raw input test with VMIN=%d  VTIME=%d\n", vmin, vtime );
+  ticksPerSecond = rtems_clock_get_ticks_per_second();
+  if ( tcgetattr( fileno ( stdin ), &old ) < 0 ) {
+    perror( "do_raw_input(): tcgetattr() failed" );
+    return;
+  new = old;
+  new.c_lflag &= ~( ICANON | ECHO | ECHONL | ECHOK | ECHOE | ECHOPRT | ECHOCTL );
+  new.c_cc[VMIN] = vmin;
+  new.c_cc[VTIME] = vtime;
+  if( tcsetattr( fileno( stdin ), TCSADRAIN, &new ) < 0 ) {
+    perror ("do_raw_input(): tcsetattr() failed" );
+    return;
+  do {
+    then = rtems_clock_get_ticks_since_boot();
+    count = 0;
+    for(;;) {
+      nread = read( fileno( stdin ), cbuf, sizeof cbuf );
+      if( nread < 0 ) {
+        perror( "do_raw_input(): read() failed" );
+        goto out;
+      count++;
+      if( nread != 0 )
+        break;
+    now = rtems_clock_get_ticks_since_boot();
+    msec = (now - then) * 1000 / ticksPerSecond;
+    printf( "Count:%-10lu  Interval:%3u.%3.3d  Char:",
+          count, msec / 1000, msec % 1000 );
+    for( i = 0 ; i < nread ; i++ )
+      printf (" 0x%2.2x", cbuf[i]);
+    printf ("\n");
+  } while( cbuf[0] != 'q' );
+out:
+  if( tcsetattr( fileno( stdin ), TCSADRAIN, &old) < 0 )
+    perror("do_raw_input(): tcsetattr() failed: %s\n" );
+static void raw_input( struct termios *tp )
+  printf( "\nTesting raw input input\n\n" );
+  printf( "Hit 'q' to terminate the test\n" );
+  do_raw_input( 0, 0 );
+  do_raw_input( 0, 20 );
+  do_raw_input( 5, 0 );
+  do_raw_input( 5, 20 );
+  printf( "\nRaw input test done.\n" );
+void usage( void )
+  printf( "\nYou have the following choices:\n" );
+  printf( "  1 - Reset the struct termios\n" );
+  printf( "  2 - Look at the current termios setting\n" );
+  printf( "  3 - Change the line characteristics\n" );
+  printf( "  4 - Test canonical input\n" );
+  printf( "  5 - Test raw input\n" );
+  printf( "  9 - Exit\n" );
+  printf( "Enter your choice (1 to 5 or 9, followed by a carriage return): " );
+static void notification( int fd, int seconds_remaining, void *arg )
+  printf(
+    "Press any key to check the termios input capabilities (%is remaining)\n",
+    seconds_remaining
+static void
+test_main(void)
+  rtems_status_code status = RTEMS_SUCCESSFUL;
+  bool quit = false;
+  char c;
+  struct termios orig_termios, test_termios;
+  test_termios_make_dev();
+  status = rtems_shell_wait_for_input(
+    STDIN_FILENO,
+    20,
+    notification,
+    NULL
+  if (status == RTEMS_SUCCESSFUL) {
+    if( tcgetattr( fileno( stdin ), &orig_termios ) < 0 ) {
+      perror( "tcgetattr() failed" );
+      exit( 0 );
+    test_termios = orig_termios;
+    usage();
+    while(!quit) {
+      switch( c = getchar() ) {
+        case '1':
+          printf( "\nResetting the line to the original termios setting\n\n" );
+          if( tcsetattr( fileno( stdin ), TCSADRAIN, &test_termios ) < 0 ) {
+            perror( "tcsetattr() failed" );
+            exit( 1 );
+          usage();
+          break;
+        case '2':
+          print_termios( &test_termios );
+          usage();
+          break;
+        case '3':
+          change_line_settings( &test_termios );
+          usage();
+          break;
+        case '4':
+          canonical_input( &test_termios );
+          usage();
+          break;
+        case '5':
+          raw_input( &test_termios );
+          usage();
+          break;
+        case '9':
+          quit = true;
+          break;
+        case '\n':
+          break;
+        default:
+          printf( "\n%c is not a valid choice. Try again\n\n", c );
+          usage();
+          break;
+  status = rtems_shell_init("SHLL", 16 * 1024, 1, CONSOLE_DEVICE_NAME,
+      false, true, NULL);
+  assert(status == RTEMS_SUCCESSFUL);
+  exit(0);
+#include <rtems/bsd/test/default-termios-init.h>
diff --git a/testsuite/termios/test_termios_driver.c b/testsuite/termios/test_termios_driver.c
index 0000000..35637b9
--- /dev/null
+++ b/testsuite/termios/test_termios_driver.c
@@ -0,0 +1,136 @@
+#include <machine/rtems-bsd-kernel-space.h>
+#include <sys/types.h>
+#include <sys/conf.h>
+#include <sys/tty.h>
+#include <sys/serial.h>
+#include <rtems/seterr.h>
+#include "../termios/test_termios_driver.h"
+static tsw_open_t test_termios_open;
+static tsw_close_t test_termios_close;
+static tsw_ioctl_t test_termios_ioctl;
+static tsw_modem_t test_termios_modem;
+static tsw_param_t test_termios_param;
+static tsw_outwakeup_t test_termios_outwakeup;
+static tsw_inwakeup_t test_termios_inwakeup;
+static tsw_free_t test_termios_free;
+static struct ttydevsw test_termios_class = {
+  .tsw_flags = TF_INITLOCK | TF_CALLOUT,
+  .tsw_open = test_termios_open,
+  .tsw_close = test_termios_close,
+  .tsw_outwakeup = test_termios_outwakeup,
+  .tsw_inwakeup = test_termios_inwakeup,
+  .tsw_ioctl = test_termios_ioctl,
+  .tsw_param = test_termios_param,
+  .tsw_modem = test_termios_modem,
+  .tsw_free = test_termios_free,
+struct test_termios_softc tt_softc;
+static int
+test_termios_open(struct tty *tp)
+  return (0);
+static void
+test_termios_close(struct tty *tp)
+static void
+test_termios_outwakeup(struct tty *tp)
+static void
+test_termios_inwakeup(struct tty *tp)
+static int
+test_termios_ioctl(struct tty *tp, u_long cmd, caddr_t data, struct thread *td)
+  return (ENOIOCTL);
+static int
+test_termios_param(struct tty *tp, struct termios *t)
+  return (0);
+static int
+test_termios_modem(struct tty *tp, int sigon, int sigoff)
+  struct test_termios_softc *sc = tty_softc(tp);
+  if ((sigon == 0) && (sigoff == 0)) {
+    if (sc->sc_mcr & SER_DTR) {
+      sigon |= SER_DTR;
+    if (sc->sc_mcr & SER_RTS) {
+      sigon |= SER_RTS;
+    if (sc->sc_msr & SER_CTS) {
+      sigon |= SER_CTS;
+    if (sc->sc_msr & SER_DCD) {
+      sigon |= SER_DCD;
+    if (sc->sc_msr & SER_DSR) {
+      sigon |= SER_DSR;
+    if (sc->sc_msr & SER_RI) {
+      sigon |= SER_RI;
+    return (sigon);
+  if (sigon & SER_DTR) {
+    sc->sc_mcr |= SER_DTR;
+  if (sigoff & SER_DTR) {
+    sc->sc_mcr &= ~SER_DTR;
+  if (sigon & SER_RTS) {
+    sc->sc_mcr |= SER_RTS;
+  if (sigoff & SER_RTS) {
+    sc->sc_mcr &= ~SER_RTS;
+  return (0);
+static void
+test_termios_free(void *xsc)
+void
+test_termios_make_dev(void)
+  struct tty *tp = NULL;
+  memset( &tt_softc, 0, sizeof( tt_softc ));
+  tt_softc.sc_msr = SER_DCD | SER_CTS | SER_DSR;
+  tp = tty_alloc_mutex(&test_termios_class, &tt_softc, NULL);
+  assert(tp != NULL);
+  tt_softc.tp = tp;
+  tty_makedev( tp, NULL, "%s", TERMIOS_TEST_DRIVER_TTY_PREFIX TERMIOS_TEST_DRIVER_TTY_UNIT);
diff --git a/testsuite/termios/test_termios_driver.h b/testsuite/termios/test_termios_driver.h
index 0000000..b8cf0b9
--- /dev/null
+++ b/testsuite/termios/test_termios_driver.h
@@ -0,0 +1,32 @@
+#ifndef TEST_TERMIOS_DRIVER_H
+#define TEST_TERMIOS_DRIVER_H
+ *  This macro defines the standard name for the USB serial device
+ *  that is available to applications.
+#define TERMIOS_TEST_DRIVER_TTY_PREFIX "T"
+#define TERMIOS_TEST_DRIVER_TTY_UNIT "0"
+#define TERMIOS_TEST_DRIVER_DEVICE_NAME "/dev/tty" TERMIOS_TEST_DRIVER_TTY_PREFIX TERMIOS_TEST_DRIVER_TTY_UNIT
+struct test_termios_softc {
+  uint8_t sc_lsr;
+  uint8_t sc_msr;
+  uint8_t sc_mcr;
+  struct tty *tp;
+extern void test_termios_make_dev(void);
+extern struct test_termios_softc tt_softc;
+#endif /* TEST_TERMIOS_DRIVER_H */
diff --git a/testsuite/termios/test_termios_utilities.c b/testsuite/termios/test_termios_utilities.c
index 0000000..e8caf81
--- /dev/null
+++ b/testsuite/termios/test_termios_utilities.c
@@ -0,0 +1,233 @@
+ *  COPYRIGHT (c) 1989-2017.
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <inttypes.h>
+#include <rtems/libcsupport.h>
+#include <rtems/termiostypes.h>
+#include "../termios/test_termios_utilities.h"
+int Test_fd;
+uint8_t read_helper_buffer[256];
+uint8_t Tx_Buffer[TX_MAX];
+void open_it(void)
+  puts( "open(" TERMIOS_TEST_DRIVER_DEVICE_NAME ") - OK " );
+  Test_fd = open( TERMIOS_TEST_DRIVER_DEVICE_NAME, O_RDWR );
+  assert( Test_fd != -1 );
+  change_iflag("BRKINT|ICRNL|IXON|IMAXBEL", 0xFFFFFFFF, BRKINT|ICRNL|IXON|IMAXBEL);
+  change_lflag("ISIG|ICANON|IEXTEN|ECHO|ECHOK|ECHOE|ECHOCTL", 0xFFFFFFFF, ISIG|ICANON|IEXTEN|ECHO|ECHOK|ECHOE|ECHOCTL);
+  change_oflag("OPOST|ONLCR|XTABS", 0xFFFFFFFF, OPOST|ONLCR|XTABS);
+void close_it(void)
+  int rc;
+  puts( "close(" TERMIOS_TEST_DRIVER_DEVICE_NAME ") - OK " );
+  rc = close( Test_fd );
+  assert( rc == 0 );
+void read_it( ssize_t expected )
+  ssize_t rc;
+  char    buf[32];
+  assert( expected <= sizeof(buf) );
+  printf( "read - %zd expected\n", expected );
+  rc = read( Test_fd, buf, expected );
+  if ( expected != rc )
+    printf( "ERROR - expected=%zd rc=%zd\n", expected, rc );
+  assert( expected == rc );
+void write_it(void)
+  ssize_t sc;
+  char    ch[10] = "PPPD TEST";
+  puts( "write(PPPD TEST) - OK " );
+  sc = write(Test_fd, ch, sizeof(ch));
+  assert( sc == sizeof(ch) );
+void change_iflag( const char *desc, int mask, int new )
+  int            rc;
+  struct termios attr;
+  printf( "Changing c_iflag to: %s\n", desc );
+  rc = tcgetattr( Test_fd, &attr );
+  attr.c_iflag &= ~mask;
+  attr.c_iflag |= new;
+  rc = tcsetattr( Test_fd, TCSANOW, &attr );
+void change_lflag( const char *desc, int mask, int new )
+  int            rc;
+  printf( "Changing c_lflag to: %s\n", desc );
+  attr.c_lflag &= ~mask;
+  attr.c_lflag |= new;
+void change_oflag( const char *desc, int mask, int new )
+  int            rc;
+  printf( "Changing c_oflag to: %s\n", desc );
+  attr.c_oflag &= ~mask;
+  attr.c_oflag |= new;
+void change_vmin_vtime( const char *desc, int min, int time )
+  int            rc;
+  printf( "Changing %s - VMIN=%d VTIME=%d\n", desc, min, time );
+  attr.c_cc[VMIN] = min;
+  attr.c_cc[VTIME] = time;
+void enable_non_blocking(bool enable)
+  int flags;
+  int rv;
+  flags = fcntl(Test_fd, F_GETFL, 0);
+  assert(flags >= 0);
+  if (enable) {
+    flags |= O_NONBLOCK;
+  } else {
+    flags &= ~O_NONBLOCK;
+  rv = fcntl(Test_fd, F_SETFL, flags);
+  assert(rv == 0);
+void write_helper( int fd, const char *c )
+  size_t   len;
+  int      rc;
+  len = strlen( c );
+  printf( "Writing: %s", c );
+  rc = write( fd, c, len );
+  assert( rc == len );
+  termios_test_driver_dump_tx("Transmitted");
+void read_helper( int fd, const char *expected )
+  int    rc;
+  size_t len;
+  len = strlen( expected );
+  termios_test_driver_set_rx( expected, len );
+  printf( "\nReading (expected):\n" );
+  rtems_print_buffer( (unsigned char *)expected, len-1 );
+  rc = read( fd, read_helper_buffer, sizeof(read_helper_buffer) );
+  assert( rc != -1 );
+  printf( "Read %d bytes from read(2)\n", rc );
+  rtems_print_buffer( read_helper_buffer, rc );
+  termios_test_driver_dump_tx("Echoed");
+int termios_test_driver_read_tx(void)
+  int Tx_Index = 0;
+  int Tx_Size = TX_MAX;
+  int Tx_Length;
+  for (;;) {
+    Tx_Length = ttydisc_getc(tt_softc.tp, &Tx_Buffer[Tx_Index], Tx_Size);
+    if (Tx_Length == 0)
+        break;
+    Tx_Index += Tx_Length;
+    Tx_Size -= Tx_Length;
+  return Tx_Index;
+void termios_test_driver_dump_tx(const char *c)
+  int Tx_Index;
+  Tx_Index = termios_test_driver_read_tx();
+  printf( "%s %d characters\n", c, Tx_Index );
+  if( Tx_Index > 0 ) {
+    rtems_print_buffer( &Tx_Buffer[0], Tx_Index );
+void termios_test_driver_set_rx( const void *p, size_t len )
+  tcflush(Test_fd, TCIFLUSH );
+  ttydisc_rint_simple(tt_softc.tp, p, len);
+  ttydisc_rint_done(tt_softc.tp);
+void termios_test_driver_set_rx_char( char ch )
+  char chs[1];
+  chs[0] = ch;
+  termios_test_driver_set_rx( &chs[0], 1 );
diff --git a/testsuite/termios/test_termios_utilities.h b/testsuite/termios/test_termios_utilities.h
index 0000000..c655c6f
--- /dev/null
+++ b/testsuite/termios/test_termios_utilities.h
@@ -0,0 +1,33 @@
+#ifndef TEST_TERMIOS_UTILITIES_H
+#define TEST_TERMIOS_UTILITIES_H
+#define TX_MAX 1024
+extern void open_it(void);
+extern void close_it(void);
+extern void change_iflag(const char *desc, int mask, int new);
+extern void change_lflag(const char *desc, int mask, int new);
+extern void change_oflag(const char *desc, int mask, int new);
+extern void change_vmin_vtime( const char *desc, int min, int time );
+extern void enable_non_blocking(bool enable);
+extern void write_helper(int fd, const char *c);
+extern void read_helper(int fd, const char *expected);
+extern void termios_test_driver_dump_tx(const char *c);
+extern int termios_test_driver_read_tx(void);
+extern void termios_test_driver_set_rx( const void *p, size_t len );
+extern void termios_test_driver_set_rx_char( char ch );
+extern int Test_fd;
+extern uint8_t read_helper_buffer[256];
+extern uint8_t Tx_Buffer[TX_MAX];
+#endif /* TEST_TERMIOS_UTILITIES_H */
diff --git a/testsuite/termios01/test_main.c b/testsuite/termios01/test_main.c
index 0000000..0ed991d
--- /dev/null
+++ b/testsuite/termios01/test_main.c
@@ -0,0 +1,690 @@
+#define TTYDEFCHARS
+#include <sys/ttydefaults.h>
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD TERMIOS 1"
+/* rtems_termios_baud_t is a typedefs to int32_t */
+#define PRIdrtems_termios_baud_t PRId32
+ *  Baud Rate Constant Mapping Entry
+typedef struct {
+  tcflag_t constant;
+  rtems_termios_baud_t baud;
+} termios_baud_test_r;
+#define INVALID_CONSTANT ((tcflag_t) -2)
+#define INVALID_BAUD ((rtems_termios_baud_t) -2)
+ *  Baud Rate Constant Mapping Table
+static const termios_baud_test_r baud_table[] = {
+  { B0,           0 },
+  { B50,         50 },
+  { B75,         75 },
+  { B110,       110 },
+  { B134,       134 },
+  { B150,       150 },
+  { B200,       200 },
+  { B300,       300 },
+  { B600,       600 },
+  { B1200,     1200 },
+  { B1800,     1800 },
+  { B2400,     2400 },
+  { B4800,     4800 },
+  { B9600,     9600 },
+  { B19200,   19200 },
+  { B38400,   38400 },
+  { B7200,     7200 },
+  { B14400,   14400 },
+  { B28800,   28800 },
+  { B57600,   57600 },
+  { B76800,   76800 },
+  { B115200, 115200 },
+  { B230400, 230400 },
+  { B460800, 460800 },
+  { B921600, 921600 },
+  { INVALID_CONSTANT, INVALID_BAUD }
+ *  Character Size Constant Mapping Entry
+typedef struct {
+  int bits;
+} termios_character_size_test_r;
+ *  Character Size Constant Mapping Table
+static const termios_character_size_test_r char_size_table[] = {
+  { CS5,      5 },
+  { CS6,      6 },
+  { CS7,      7 },
+  { CS8,      8 },
+  { INVALID_CONSTANT, -1 }
+ *  Parity Constant Mapping Entry
+typedef struct {
+  const char *parity;
+} termios_parity_test_r;
+ *  Parity Constant Mapping Table
+static const termios_parity_test_r parity_table[] = {
+  { 0,                "none" },
+  { PARENB,           "even" },
+  { PARENB | PARODD,  "odd" },
+  { INVALID_CONSTANT, NULL }
+ *  Stop Bit Constant Mapping Entry
+typedef struct {
+  int stop;
+} termios_stop_bits_test_r;
+ *  Stop Bit Constant Mapping Table
+static const termios_stop_bits_test_r stop_bits_table[] = {
+  { 0,       1 },
+  { CSTOPB,  2 },
+ *  Test converting baud rate into an index
+static void test_termios_baud2index(void)
+  int i;
+  int index;
+  puts( "Test termios_baud2index..." );
+  puts( "termios_baud_to_index(-2) - NOT OK" );
+  i = rtems_termios_baud_to_index( INVALID_CONSTANT );
+  assert( i == -1 );
+  for (i=0 ; baud_table[i].constant != INVALID_CONSTANT ; i++ ) {
+    printf(
+      "termios_baud_to_index(B%" PRIdrtems_termios_baud_t ") - OK\n",
+      baud_table[i].baud
+    index = rtems_termios_baud_to_index( baud_table[i].constant );
+    assert(index == i);
+ *  Test converting termios baud constant to baud number
+static void test_termios_baud2number(void)
+  int i;
+  rtems_termios_baud_t number;
+  puts(
+    "\n"
+    "Test termios_baud2number..."
+  puts( "termios_baud_to_number(-2) - NOT OK" );
+  number = rtems_termios_baud_to_number( INVALID_CONSTANT );
+  assert( number == 0 );
+    printf(
+      "termios_baud_to_number(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    number = rtems_termios_baud_to_number( baud_table[i].constant );
+    assert( number == baud_table[i].baud );
+ *  Test converting baud number to termios baud constant
+static void test_termios_number_to_baud(void)
+  int i;
+  tcflag_t termios_baud;
+  puts(
+    "\n"
+    "Test termios_number_to_baud..."
+  puts( "termios_number_to_baud(-2) - NOT OK" );
+  termios_baud = rtems_termios_number_to_baud( INVALID_BAUD );
+  assert( termios_baud == 0 );
+    printf(
+      "termios_number_to_baud(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    termios_baud = rtems_termios_number_to_baud( baud_table[i].baud );
+    assert( termios_baud == baud_table[i].constant );
+ *  Test all the baud rate options
+static void test_termios_set_baud(
+  int test
+  int             sc;
+  int             i;
+  puts( "Test termios setting device baud rate..." );
+    sc = tcgetattr( test, &attr );
+    assert(sc == 0);
+    attr.c_ispeed = baud_table[i].constant;
+    attr.c_ospeed = baud_table[i].constant;
+    printf(
+      "tcsetattr(TCSANOW, B%" PRIdrtems_termios_baud_t ") - OK\n",
+    sc = tcsetattr( test, TCSANOW, &attr );
+    assert(sc == 0);
+    printf(
+      "tcsetattr(TCSADRAIN, B%" PRIdrtems_termios_baud_t ") - OK\n",
+    assert(sc == 0);
+    printf(
+      "tcsetattr(TCSAFLUSH, B%" PRIdrtems_termios_baud_t ") - OK\n",
+    sc = tcsetattr( test, TCSAFLUSH, &attr );
+    assert(sc == 0);
+ *  Test all the character size options
+static void test_termios_set_charsize(
+  int test
+  int             sc;
+  int             i;
+  puts(
+    "\n"
+    "Test termios setting device character size ..."
+  for (i=0 ; char_size_table[i].constant != INVALID_CONSTANT ; i++ ) {
+    tcflag_t csize = CSIZE;
+    assert(sc == 0);
+    attr.c_cflag &= ~csize;
+    attr.c_cflag |= char_size_table[i].constant;
+    printf( "tcsetattr(TCSANOW, CS%d) - OK\n", char_size_table[i].bits );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSADRAIN, CS%d) - OK\n", char_size_table[i].bits );
+    sc = tcsetattr( test, TCSADRAIN, &attr );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSAFLUSH, CS%d) - OK\n", char_size_table[i].bits );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSASOFT, CS%d) - OK\n", char_size_table[i].bits );
+    sc = tcsetattr( test, TCSASOFT, &attr );
+    assert(sc == 0);
+ *  Test all the parity options
+static void test_termios_set_parity(
+  int test
+  int             sc;
+  int             i;
+  puts(
+    "\n"
+    "Test termios setting device parity ..."
+  for (i=0 ; parity_table[i].constant != INVALID_CONSTANT ; i++ ) {
+    tcflag_t par = PARENB | PARODD;
+    assert(sc == 0);
+    attr.c_cflag &= ~par;
+    attr.c_cflag |= parity_table[i].constant;
+    printf( "tcsetattr(TCSANOW, %s) - OK\n", parity_table[i].parity );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSADRAIN, %s) - OK\n", parity_table[i].parity );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSAFLUSH, %s) - OK\n", parity_table[i].parity );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSASOFT, %s) - OK\n", parity_table[i].parity );
+    assert(sc == 0);
+ *  Test all the stop bit options
+static void test_termios_set_stop_bits(
+  int test
+  int             sc;
+  int             i;
+  puts(
+    "\n"
+  for (i=0 ; stop_bits_table[i].constant != INVALID_CONSTANT ; i++ ) {
+    tcflag_t cstopb = CSTOPB;
+    assert(sc == 0);
+    attr.c_cflag &= ~cstopb;
+    attr.c_cflag |= stop_bits_table[i].constant;
+    printf( "tcsetattr(TCSANOW, %d bit%s) - OK\n",
+      stop_bits_table[i].stop,
+      ((stop_bits_table[i].stop == 1) ? "" : "s")
+    assert(sc == 0);
+    printf( "tcsetattr(TCSADRAIN, %d bits) - OK\n", stop_bits_table[i].stop );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSAFLUSH, %d bits) - OK\n", stop_bits_table[i].stop );
+    assert(sc == 0);
+    printf( "tcsetattr(TCSASOFT, %d bits) - OK\n", stop_bits_table[i].stop );
+    assert(sc == 0);
+static void test_termios_cfoutspeed(void)
+  int i;
+  int sc;
+  speed_t speed;
+  struct termios term;
+  speed_t bad;
+  bad = B921600 << 1;
+  memset( &term, '\0', sizeof(term) );
+  puts( "cfsetospeed(BAD BAUD) - EINVAL" );
+  sc = cfsetospeed( &term, bad );
+  assert( sc == -1 );
+  assert( errno == EINVAL );
+    printf(
+      "cfsetospeed(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    sc = cfsetospeed( &term, baud_table[i].constant );
+    assert( !sc );
+    printf(
+      "cfgetospeed(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    speed = cfgetospeed( &term );
+    assert( speed == baud_table[i].constant );
+static void test_termios_cfinspeed(void)
+  int             i;
+  int             sc;
+  speed_t         speed;
+  speed_t         bad;
+  puts( "cfsetispeed(BAD BAUD) - EINVAL" );
+  sc = cfsetispeed( &term, bad );
+    printf(
+      "cfsetispeed(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    sc = cfsetispeed( &term, baud_table[i].constant );
+    assert( !sc );
+    printf(
+      "cfgetispeed(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    speed = cfgetispeed( &term );
+static void test_termios_cfsetspeed(void)
+  int             i;
+  int             status;
+  speed_t         speed;
+  speed_t         bad;
+  puts( "cfsetspeed(BAD BAUD) - EINVAL" );
+  status = cfsetspeed( &term, bad );
+  assert( status == -1 );
+    printf(
+      "cfsetspeed(B%" PRIdrtems_termios_baud_t ") - OK\n",
+    status = cfsetspeed( &term, baud_table[i].constant );
+    assert( !status );
+    printf(
+      "cfgetspeed(B%" PRIdrtems_termios_baud_t ") - checking both inspeed and outspeed - OK\n",
+static void test_termios_cfmakeraw(void)
+  cfmakeraw( &term );
+  puts( "cfmakeraw - OK" );
+  /* Check that all of the flags were set correctly */
+  assert( ~(term.c_iflag & (IMAXBEL|IGNBRK|BRKINT|PARMRK|ISTRIP|INLCR|IGNCR|ICRNL|IXON)) );
+  assert( term.c_iflag & (IGNBRK) );
+  assert( ~(term.c_oflag & OPOST) );
+  assert( ~(term.c_lflag & (ECHO|ECHONL|ICANON|ISIG|IEXTEN)) );
+  assert( ~(term.c_cflag & (CSIZE|PARENB)) );
+  assert( term.c_cflag & (CS8|CREAD) );
+  assert( term.c_cc[VMIN] == 1 );
+  assert( term.c_cc[VTIME] == 0 );
+static void test_termios_cfmakesane(void)
+  cfmakesane( &term );
+  puts( "cfmakesane - OK" );
+  assert( term.c_iflag == TTYDEF_IFLAG );
+  assert( term.c_oflag == TTYDEF_OFLAG );
+  assert( term.c_lflag == TTYDEF_LFLAG );
+  assert( term.c_cflag == TTYDEF_CFLAG );
+  assert( term.c_ispeed == TTYDEF_SPEED );
+  assert( term.c_ospeed == TTYDEF_SPEED );
+  assert( memcmp(&term.c_cc, ttydefchars, sizeof(term.c_cc)) == 0 );
+static void test_set_best_baud(void)
+  static const struct {
+    uint32_t baud;
+    speed_t speed;
+  } baud_to_speed_table[] = {
+    { 0,          B0 },
+    { 25,         B0 },
+    { 26,         B50 },
+    { 50,         B50 },
+    { 62,         B50 },
+    { 63,         B75 },
+    { 75,         B75 },
+    { 110,        B110 },
+    { 134,        B134 },
+    { 150,        B150 },
+    { 200,        B200 },
+    { 300,        B300 },
+    { 600,        B600 },
+    { 1200,       B1200 },
+    { 1800,       B1800 },
+    { 2400,       B2400 },
+    { 4800,       B4800 },
+    { 9600,       B9600 },
+    { 19200,      B19200 },
+    { 38400,      B38400 },
+    { 57600,      B57600 },
+    { 115200,     B115200 },
+    { 230400,     B230400 },
+    { 460800,     B460800 },
+    { 0xffffffff, B460800 }
+  size_t n = RTEMS_ARRAY_SIZE(baud_to_speed_table);
+  size_t i;
+  for ( i = 0; i < n; ++i ) {
+    memset( &term, 0xff, sizeof( term ) );
+    rtems_termios_set_best_baud( &term, baud_to_speed_table[ i ].baud );
+    assert( term.c_ispeed == baud_to_speed_table[ i ].speed );
+    assert( term.c_ospeed == baud_to_speed_table[ i ].speed );
+static void
+test_main(void)
+  int                       rc;
+  rtems_device_major_number registered;
+  int                       test;
+  struct termios            t;
+  int index = 0;
+   * Test baud rate
+  test_termios_baud2index();
+  test_termios_baud2number();
+  test_termios_number_to_baud();
+  puts( "Init - open - " TERMIOS_TEST_DRIVER_DEVICE_NAME " - OK" );
+  test = open( TERMIOS_TEST_DRIVER_DEVICE_NAME, O_RDWR );
+  assert(test != -1);
+   * tcsetattr - ERROR invalid operation
+  puts( "tcsetattr - invalid operation - EINVAL" );
+  rc = tcsetattr( test, INT_MAX, &t );
+  assert(rc == -1);
+  assert(errno == EINVAL);
+  test_termios_cfmakeraw();
+  test_termios_cfmakesane();
+   * tcsetattr - TCSADRAIN
+  puts( "\ntcsetattr - drain - OK" );
+  rc = tcsetattr( test,  TCSADRAIN, &t );
+  assert(rc == 0);
+  test_termios_set_baud(test);
+  puts( "Init - close - " TERMIOS_TEST_DRIVER_DEVICE_NAME " - OK" );
+  rc = close( test );
+  assert(rc == 0);
+   * Test character size
+  puts(
+    "\n"
+    "Init - open - " TERMIOS_TEST_DRIVER_DEVICE_NAME " - OK"
+  test_termios_set_charsize(test);
+  assert(rc == 0);
+   * Test parity
+  puts(
+    "\n"
+  test_termios_set_parity(test);
+  assert(rc == 0);
+   * Test stop bits
+  puts(
+    "\n"
+  test_termios_set_stop_bits(test);
+  test_termios_cfoutspeed();
+  test_termios_cfinspeed();
+  test_termios_cfsetspeed();
+  assert(rc == 0);
+  puts( "Multiple open of the device" );
+  for( ; index < 26; ++index ) {
+    assert(rc == 0);
+  puts( "" );
+  test_set_best_baud();
+  exit(0);
diff --git a/testsuite/termios02/test_main.c b/testsuite/termios02/test_main.c
index 0000000..3ec5c0b
--- /dev/null
+++ b/testsuite/termios02/test_main.c
@@ -0,0 +1,140 @@
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD TERMIOS 2"
+static void
+test_main(void)
+  int sc;
+  pid_t pid;
+  char *term_name_p;
+  char term_name[32];
+  open_it();
+  puts( "tcdrain() - OK" );
+  sc = tcdrain(Test_fd);
+  assert( !sc );
+  puts( "" );
+  /***** TEST TCFLOW *****/
+  puts( "tcflow(TCOOFF) - ENOTSUP" );
+  errno = 0;
+  sc = tcflow( Test_fd, TCOOFF );
+  assert( errno == ENOTSUP );
+  puts( "tcflow(TCOON) - ENOTSUP" );
+  errno = 0;
+  sc = tcflow( Test_fd, TCOON );
+  puts( "tcflow(TCIOFF) - ENOTSUP" );
+  errno = 0;
+  sc = tcflow( Test_fd, TCIOFF );
+  puts( "tcflow(TCION) - ENOTSUP" );
+  errno = 0;
+  sc = tcflow( Test_fd, TCION );
+  puts( "tcflow(22) - EINVAL" );
+  errno = 0;
+  sc = tcflow( Test_fd, 22 );
+  puts( "" );
+  /***** TEST TCFLUSH *****/
+  puts( "tcflush(TCIFLUSH) - OK" );
+  errno = 0;
+  sc = tcflush( Test_fd, TCIFLUSH );
+  assert( sc == 0 );
+  assert( errno == 0 );
+  puts( "tcflush(TCOFLUSH) - OK" );
+  sc = tcflush( Test_fd, TCOFLUSH );
+  puts( "tcflush(TCIOFLUSH) - OK" );
+  sc = tcflush( Test_fd, TCIOFLUSH );
+  puts( "tcflush(22) - EINVAL" );
+  errno = 0;
+  sc = tcflush( Test_fd, 22 );
+  puts( "" );
+  /***** TEST TCGETPGRP *****/
+  puts( "tcgetpgrp() - OK" );
+  pid = tcgetpgrp(Test_fd);
+  assert( pid == getpid() );
+  puts( "tcsetpgrp(3) - OK" );
+  sc = tcsetpgrp( Test_fd, 3 );
+  assert( !sc );
+  puts( "" );
+  /***** TEST TCSENDBREAK *****/
+  puts( "tcsendbreak(0) - OK" );
+  sc = tcsendbreak( Test_fd, 0 );
+  assert( !sc );
+  puts( "" );
+  /***** TEST CTERMID *****/
+  puts( "ctermid( NULL ) - OK" );
+  term_name_p = ctermid( NULL );
+  assert( term_name_p );
+  printf( "ctermid ==> %s\n", term_name_p );
+  puts( "ctermid( term_name ) - OK" );
+  term_name_p = ctermid( term_name );
+  assert( term_name_p == term_name );
+  close_it();
+  exit(0);
diff --git a/testsuite/termios03/test_main.c b/testsuite/termios03/test_main.c
index 0000000..c92c4f0
--- /dev/null
+++ b/testsuite/termios03/test_main.c
@@ -0,0 +1,73 @@
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD TERMIOS 3"
+const char ExpectedOutput_1[] = "This is test output.\n";
+const char ExpectedInput_1[] = "Test input this is.\n";
+const char ExpectedInput_2[] = "1235\b456.\n";
+const char ExpectedInput_3[] = "tab\ttab.\n";
+const char ExpectedInput_4[] = "cr\r.";
+const char ExpectedInput_5[] = "aBcDeFgH.\n";
+const char ExpectedInput_6[] = "Testing VERASE\177.\n";
+const char ExpectedInput_7[] = "Testing VKILL\025.\n";
+const char ExpectedInput_8[] = "\177Testing VERASE in column 1.\n";
+const char ExpectedInput_9[] = "\t tab \tTesting VKILL after tab.\025\n";
+static void
+test_main(void)
+  open_it();
+  /* some basic cases */
+  write_helper( Test_fd, ExpectedOutput_1 );
+  read_helper( Test_fd, ExpectedInput_1 );
+  read_helper( Test_fd, ExpectedInput_2 );
+  read_helper( Test_fd, ExpectedInput_3 );
+  read_helper( Test_fd, ExpectedInput_4 );
+  /* test to lower case input mapping */
+  read_helper( Test_fd, ExpectedInput_5 );
+  //IUCLC is not supported within FREEBSD so this should not change the output
+  change_iflag( "Enable to lower case mapping on input", IUCLC, IUCLC );
+  change_iflag( "Disable to lower case mapping on input", IUCLC, 0 );
+  read_helper( Test_fd, ExpectedInput_6 );
+  read_helper( Test_fd, ExpectedInput_7 );
+  read_helper( Test_fd, ExpectedInput_8 );
+  read_helper( Test_fd, ExpectedInput_9 );
+  puts( "" );
+  close_it();
+  exit(0);
diff --git a/testsuite/termios04/test_main.c b/testsuite/termios04/test_main.c
index 0000000..f4d9476
--- /dev/null
+++ b/testsuite/termios04/test_main.c
@@ -0,0 +1,69 @@
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD TERMIOS 4"
+const char XON_String[] = "\021";
+const char XOFF_String[] = "\023";
+"0123456789012345678901234567890123456789"
+"0123456789012345678901234567890123456789\n";
+static void
+test_main(void)
+  open_it();
+  change_iflag( "Set XON/XOFF", IXON|IXOFF, IXON|IXOFF );
+  printf( "XOFF\n" );
+  termios_test_driver_set_rx( XOFF_String, 1 );
+  sc = rtems_task_wake_after( 2 * rtems_clock_get_ticks_per_second() );
+  assert( sc == RTEMS_SUCCESSFUL );
+  printf( "XON\n" );
+  termios_test_driver_set_rx( XON_String, 1 );
+  close_it();
+  exit(0);
diff --git a/testsuite/termios05/test_main.c b/testsuite/termios05/test_main.c
index 0000000..faad94f
--- /dev/null
+++ b/testsuite/termios05/test_main.c
@@ -0,0 +1,65 @@
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD TERMIOS 5"
+static void
+test_main(void)
+  open_it();
+  change_lflag( "non-canonical", ICANON, 0 );
+  change_vmin_vtime( "to polling", 0, 0 );
+  read_it( 0 );
+  change_vmin_vtime( "to half-second timeout", 0, 5 );
+  read_it( 0 );
+  change_vmin_vtime( "to half-second timeout", 5, 3 );
+  puts( "Enqueue 2 characters" );
+  termios_test_driver_set_rx( "ab", 2 );
+  read_it( 2 );
+  puts( "Enqueue 1 character" );
+  termios_test_driver_set_rx( "b", 1 );
+  read_it( 1 );
+  puts( "Enqueue 7 characters" );
+  termios_test_driver_set_rx( "1234567", 7 );
+  read_it( 5 );
+  read_it( 2 );
+  close_it();
+  exit(0);
diff --git a/testsuite/termios06/test_main.c b/testsuite/termios06/test_main.c
index 0000000..dc6e3d6
--- /dev/null
+++ b/testsuite/termios06/test_main.c
@@ -0,0 +1,492 @@
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD TERMIOS 6"
+static struct termios term;
+static rtems_id flush_task_id;
+static void init_term(void)
+  int rv;
+  rv = tcgetattr(Test_fd, &term);
+  assert(rv == 0);
+  term.c_iflag &= ~(IGNBRK | BRKINT | PARMRK | ISTRIP
+    | INLCR | IGNCR | ICRNL | IXON);
+  term.c_lflag &= ~(ECHO | ECHOE | ECHOK | ECHONL | ECHOPRT
+    | ECHOCTL | ECHOKE | ICANON | ISIG | IEXTEN);
+  term.c_cflag &= ~(CSIZE | PARENB);
+  term.c_cflag |= CS8;
+  term.c_oflag &= ~(OPOST | ONLRET | ONLCR | OCRNL
+    | TABDLY | OLCUC);
+  term.c_cc[VMIN] = 0;
+  term.c_cc[VTIME] = 0;
+  rv = tcsetattr(Test_fd, TCSANOW, &term);
+  assert(rv == 0);
+static void test_igncr(void)
+  ssize_t n;
+  char c;
+  c = 'x';
+  change_iflag("IGNCR", 0, IGNCR);
+  n = read(Test_fd, &c, sizeof(c));
+  assert(n == 0);
+  assert(c == 'x');
+  termios_test_driver_set_rx_char('\r');
+  assert(n == 0);
+  assert(c == 'x');
+  change_iflag("~IGNCR", IGNCR, 0);
+  assert(n == 1);
+  assert(c == '\r');
+static void test_istrip(void)
+  ssize_t n;
+  char c;
+  c = 'x';
+  change_iflag("ISTRIP", 0, ISTRIP);
+  assert(n == 0);
+  assert(c == 'x');
+  termios_test_driver_set_rx_char('\376');
+  assert(n == 1);
+  assert(c == '~');
+  change_iflag("~ISTRIP", ISTRIP, 0);
+  assert(n == 1);
+  assert(c == '\376');
+static void test_iuclc(void)
+  ssize_t n;
+  char c;
+  c = 'x';
+  change_iflag("IUCLC", 0, IUCLC);
+  assert(n == 0);
+  assert(c == 'x');
+  termios_test_driver_set_rx_char('A');
+  assert(n == 1);
+  assert(c == 'A');
+  change_iflag("~IUCLC", IUCLC, 0);
+  assert(n == 1);
+  assert(c == 'A');
+static void test_icrnl(void)
+  ssize_t n;
+  char c;
+  c = 'x';
+  change_iflag("ICRNL", 0, ICRNL);
+  assert(n == 0);
+  assert(c == 'x');
+  assert(n == 1);
+  assert(c == '\n');
+  change_iflag("~ICRNL", ICRNL, 0);
+  assert(n == 1);
+static void test_inlcr(void)
+  ssize_t n;
+  char c;
+  c = 'x';
+  change_iflag("INLCR", 0, INLCR);
+  assert(n == 0);
+  assert(c == 'x');
+  termios_test_driver_set_rx_char('\n');
+  assert(n == 1);
+  change_iflag("~INLCR", INLCR, 0);
+  assert(n == 1);
+static void test_onlret(void)
+  char c;
+  ssize_t n;
+  tt_softc.tp->t_column = 0;
+  tcflush(Test_fd, TCOFLUSH);
+  change_oflag("OPOST|ONLRET", 0, OPOST|ONLRET);
+  c = 'a';
+  n = write(Test_fd, &c, sizeof(c));
+  assert(n == 1);
+  assert(tt_softc.tp->t_column == 1);
+  n = termios_test_driver_read_tx();
+  assert(n == 1);
+  assert(Tx_Buffer[0] == 'a');
+  c = '\n';
+  assert(n == 1);
+  assert(tt_softc.tp->t_column == 0);
+  assert(n == 1);
+  assert(Tx_Buffer[0] == '\n');
+  change_oflag("~(OPOST|ONLRET)", OPOST|ONLRET, 0);
+static void test_onlcr(void)
+  char c;
+  ssize_t n;
+  change_oflag("OPOST|ONLCR", 0, OPOST|ONLCR);
+  c = 'a';
+  assert(n == 1);
+  assert(n == 1);
+  c = '\n';
+  assert(n == 1);
+  assert(n == 2);
+  assert(Tx_Buffer[0] == '\r');
+  assert(Tx_Buffer[1] == '\n');
+  change_oflag("~(OPOST|ONLCR)", OPOST|ONLCR, 0);
+static void test_onocr(void)
+  char c;
+  ssize_t n;
+  change_oflag("OPOST|ONOCR", 0, OPOST|ONOCR);
+  c = '\r';
+  assert(n == 1);
+  assert(n == 0);
+  c = 'a';
+  assert(n == 1);
+  assert(n == 1);
+  c = '\r';
+  assert(n == 1);
+  assert(n == 1);
+  change_oflag("~(OPOST|ONOCR)", OPOST|ONOCR, 0);
+static void test_ocrnl(void)
+  char c;
+  ssize_t n;
+  change_oflag("OPOST|OCRNL", 0, OPOST|OCRNL);
+  c = '\r';
+  assert(n == 1);
+  assert(n == 1);
+  change_oflag("~(OPOST|OCRNL)", OPOST|OCRNL, 0);
+static void test_ocrnl_onlret(void)
+  char c;
+  ssize_t n;
+  change_oflag("OPOST|OCRNL|ONLRET", 0, OPOST|OCRNL|ONLRET);
+  c = 'a';
+  assert(n == 1);
+  assert(n == 1);
+  c = '\r';
+  assert(n == 1);
+  assert(n == 1);
+  change_oflag("~(OPOST|OCRNL|ONLRET)", OPOST|OCRNL|ONLRET, 0);
+static void test_opost(void)
+  char c;
+  ssize_t n;
+  change_oflag("OPOST", 0, OPOST);
+  c = 'a';
+  assert(n == 1);
+  assert(n == 1);
+  c = '\33';
+  assert(n == 1);
+  assert(n == 1);
+  assert(Tx_Buffer[0] == '\33');
+  c = '\t';
+  assert(n == 1);
+  assert(tt_softc.tp->t_column == 8);
+  assert(n == 1);
+  assert(Tx_Buffer[0] == '\t');
+  c = '\b';
+  assert(n == 1);
+  assert(tt_softc.tp->t_column == 7);
+  assert(n == 1);
+  assert(Tx_Buffer[0] == '\b');
+  c = '\r';
+  assert(n == 1);
+  assert(n == 1);
+  change_oflag("~OPOST", OPOST, 0);
+static void test_xtabs(void)
+  char c;
+  ssize_t n;
+  change_oflag("OPOST|XTABS", 0, OPOST|XTABS);
+  c = 'a';
+  assert(n == 1);
+  assert(n == 1);
+  c = '\t';
+  assert(n == 1);
+  assert(n == 7);
+  assert(Tx_Buffer[0] == ' ');
+  assert(Tx_Buffer[1] == ' ');
+  assert(Tx_Buffer[2] == ' ');
+  assert(Tx_Buffer[3] == ' ');
+  assert(Tx_Buffer[4] == ' ');
+  assert(Tx_Buffer[5] == ' ');
+  assert(Tx_Buffer[6] == ' ');
+  change_oflag("~(OPOST|XTABS)", OPOST|XTABS, 0);
+static void test_olcuc(void)
+  char c;
+  ssize_t n;
+  //OLCUC is not supported within FREEBSD so this should not change the output
+  change_oflag("OPOST|OLCUC", 0, OPOST|OLCUC);
+  c = 'a';
+  assert(n == 1);
+  assert(n == 1);
+  c = 'B';
+  assert(n == 1);
+  assert(tt_softc.tp->t_column == 2);
+  assert(n == 1);
+  assert(Tx_Buffer[0] == 'B');
+  c = '9';
+  assert(n == 1);
+  assert(tt_softc.tp->t_column == 3);
+  assert(n == 1);
+  assert(Tx_Buffer[0] == '9');
+  change_oflag("~(OPOST|OLCUC)", OPOST|OLCUC, 0);
+static void
+test_main(void)
+  open_it();
+  init_term();
+  test_igncr();
+  test_istrip();
+  test_iuclc();
+  test_icrnl();
+  test_inlcr();
+  test_onlret();
+  test_onlcr();
+  test_onocr();
+  test_ocrnl();
+  test_ocrnl_onlret();
+  test_opost();
+  test_xtabs();
+  test_olcuc();
+  close_it();
+  exit(0);
1.9.1
