[PATCH 06/11] Inserted inttype macros, fix 11 format warnings.
Joel Sherrill
joel at rtems.org
Fri Apr 7 22:58:49 UTC 2017
On Fri, Apr 7, 2017 at 5:37 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> When I got rid of the casts I was left with char * and couldn't find an
> inttype to fit it so I left the casts in.
char * can be printed with %p. printk() should support that but check.
Do a simple test on Linux to see but I don't think you have to put 0x%p,
it just prints an address correctly.
Another approach would be to cast it to a uintptr_t and (hopefully), there
is a PRI constant for that. but %p is preferable.
--joel
> .../lib/libbsp/powerpc/virtex5/startup/bspstart.c | 25
> 1 file changed, 13 insertions(+), 12 deletions(-)
> diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
> b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
> index 9d610e4..fef18d3 100644
> --- a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
> +++ b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
> @@ -69,6 +69,7 @@
> #include <string.h>
> #include <fcntl.h>
> +#include <inttypes.h>
> #define DO_DOWN_ALIGN(x,a) ((x) & ~((a)-1))
> @@ -227,20 +228,20 @@ void bsp_start(void)
> /* Let the user know what parameters we were compiled with */
> printk(" Base/Start End Size\n"
> - "RAM: 0x%08x 0x%x\n"
> - "RTEMS: 0x%08x\n"
> + "RAM: 0x%08" PRIx32 " 0x%" PRIx32 "\n"
> + "RTEMS: 0x%08" PRIx32 "\n"
> "Interrupt Stack: 0x%08x 0x%x\n"
> - "Stack: 0x%08x 0x%08x 0x%x\n"
> - "Workspace: 0x%08x 0x%08x\n"
> - "MsgArea: 0x%08x 0x%x\n"
> - "Physical RAM 0x%08x\n",
> - (uint32_t)RamBase,
> (uint32_t)RamSize,
> - (uint32_t)__rtems_end,
> + "Stack: 0x%08" PRIx32 "0x%08" PRIx32 "0x%" PRIx32 "\n"
> + "Workspace: 0x%08" PRIx32 "0x%08" PRIx32 "\n"
> + "MsgArea: 0x%08" PRIx32 "0x%" PRIx32 "\n"
> + "Physical RAM 0x%08" PRIx32 "\n",
> + (uint32_t) RamBase, (uint32_t) RamSize,
> + (uint32_t) __rtems_end,
> intrStackStart, intrStackSize,
> - (uint32_t)__stack_base, (uint32_t)_stack,
> (uint32_t)StackSize,
> - (uint32_t)WorkAreaBase, (uint32_t)__bsp_ram_end,
> - (uint32_t)MsgAreaBase,
> (uint32_t)MsgAreaSize,
> - (uint32_t)__phy_ram_end);
> + (uint32_t) __stack_base, (uint32_t) _stack, (uint32_t) StackSize,
> + (uint32_t) WorkAreaBase, (uint32_t) __bsp_ram_end,
> + (uint32_t) MsgAreaBase, (uint32_t) MsgAreaSize,
> + (uint32_t) __phy_ram_end);
> * Initialize RTEMS IRQ system
> 2.7.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170407/1106278b/attachment.html>
