[PATCH 21/30] leon, griommu: add GR740 IOMMU driver
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:30 UTC 2017
The driver is limited to the access protection bit-vector. It
currently does not support the IOMMU page-table functionality.
 c/src/lib/libbsp/sparc/Makefile.am              |    4 +
 c/src/lib/libbsp/sparc/leon2/Makefile.am        |    4 +
 c/src/lib/libbsp/sparc/leon2/preinstall.am      |    4 +
 c/src/lib/libbsp/sparc/leon3/Makefile.am        |    4 +
 c/src/lib/libbsp/sparc/leon3/preinstall.am      |    4 +
 c/src/lib/libbsp/sparc/shared/include/griommu.h |  187 +++
 c/src/lib/libbsp/sparc/shared/iommu/griommu.c   | 1454 +++++++++++++++++++++++
 cpukit/libdrvmgr/drvmgr_confdefs.h              |    4 +
 8 files changed, 1665 insertions(+)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/griommu.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/iommu/griommu.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 43e1d9e..2535752 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -99,6 +99,10 @@ EXTRA_DIST += shared/mem/mctrl.c
 EXTRA_DIST += shared/l2c/l2c.c
 EXTRA_DIST += shared/include/l2c.h
+# GRIOMMU
+EXTRA_DIST += shared/iommu/griommu.c
+EXTRA_DIST += shared/include/griommu.h
 # MIL-STD-B1553 (Core1553BRM)
 EXTRA_DIST += shared/1553/b1553brm.c
 EXTRA_DIST += shared/1553/b1553rt.c
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 29a2ebd..9078cf5 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -192,6 +192,10 @@ include_bsp_HEADERS += ../../sparc/shared/include/mctrl.h
 libbsp_a_SOURCES += ../../sparc/shared/l2c/l2c.c
 include_bsp_HEADERS += ../../sparc/shared/include/l2c.h
+# griommu
+libbsp_a_SOURCES += ../../sparc/shared/iommu/griommu.c
+include_bsp_HEADERS += ../../sparc/shared/include/griommu.h
 # timer
 libbsp_a_SOURCES += timer/timer.c
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index c37b77a..2aad5f9 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -257,6 +257,10 @@ $(PROJECT_INCLUDE)/bsp/l2c.h: ../../sparc/shared/include/l2c.h $(PROJECT_INCLUDE
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/l2c.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/l2c.h
+$(PROJECT_INCLUDE)/bsp/griommu.h: ../../sparc/shared/include/griommu.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/griommu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/griommu.h
 $(PROJECT_INCLUDE)/bsp/grtc.h: ../../sparc/shared/include/grtc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/grtc.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/grtc.h
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 84669b7..3386cf0 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -209,6 +209,10 @@ include_bsp_HEADERS += ../../sparc/shared/include/mctrl.h
+# griommu
 # timer
 libbsp_a_SOURCES += timer/watchdog.c
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 84ec208..b8ac694 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -285,6 +285,10 @@ $(PROJECT_INCLUDE)/bsp/l2c.h: ../../sparc/shared/include/l2c.h $(PROJECT_INCLUDE
 $(PROJECT_INCLUDE)/bsp/watchdog.h: include/watchdog.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/watchdog.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/watchdog.h
diff --git a/c/src/lib/libbsp/sparc/shared/include/griommu.h b/c/src/lib/libbsp/sparc/shared/include/griommu.h
new file mode 100644
index 0000000..2bafe4c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/griommu.h
@@ -0,0 +1,187 @@
+ *  GRIOMMU Driver Interface
+ *  COPYRIGHT (c) 2017
+ *  Cobham Gaisler AB
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ *  OVERVIEW
+ *  This driver controls the GRIOMMU device located
+ *  at an on-chip AMBA.
+#ifndef __GRIOMMU_H__
+#define __GRIOMMU_H__
+#include <stdint.h>
+#include <stdio.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+extern void griommu_register_drv(void);
+#define GRIOMMU_ERR_OK 0
+#define GRIOMMU_ERR_NOINIT -1
+#define GRIOMMU_ERR_EINVAL -2
+#define GRIOMMU_ERR_IMPLEMENTED -3
+#define GRIOMMU_ERR_NOTFOUND -4
+/* Size of APV (has to be divided by page size in bytes) */
+#define GRIOMMU_APV_SIZE 0x20000000
+/* Alignment of APV */
+#define GRIOMMU_APV_ALIGN 0x10
+/* IOMMU APV allocation helper functions */
+extern void * griommu_apv_new(void);
+extern void griommu_apv_delete(void * apv);
+/* IOMMU Master Setup */
+/* IOMMU Master find */
+ * GRIOMMU MASTER register fields
+#define MASTER_VENDOR (0xff << MASTER_VENDOR_BIT)
+#define MASTER_DEVICE (0xfff << MASTER_DEVICE_BIT)
+#define MASTER_BS (0x1 << MASTER_BS_BIT)
+#define MASTER_GROUP (0xf << MASTER_GROUP_BIT)
+#define MASTER_VENDOR_BIT 24
+#define MASTER_DEVICE_BIT 12
+#define MASTER_BS_BIT 4
+#define MASTER_GROUP_BIT 0
+#define GRIOMMU_OPTIONS_BUS0 0
+#define GRIOMMU_OPTIONS_BUS1 1
+extern int griommu_master_setup(int master, int group, int options);
+extern int griommu_master_find(int vendor, int device, int instance);
+extern int griommu_master_info(int master, uint32_t * info);
+#define griommu_get_master_vendor(info) \
+	((info & MASTER_VENDOR) >> MASTER_VENDOR_BIT)
+#define griommu_get_master_device(info) \
+	((info & MASTER_DEVICE) >> MASTER_DEVICE_BIT)
+#define griommu_get_master_routing(info) \
+	((info & MASTER_BS) >> MASTER_BS_BIT)
+#define griommu_get_master_group(info) \
+	((info & MASTER_GROUP) >> MASTER_GROUP_BIT)
+/* IOMMU Group Setup */
+#define GRIOMMU_OPTIONS_GROUP_PASSTHROUGH 2
+#define GRIOMMU_OPTIONS_GROUP_ENABLE 1
+#define GRIOMMU_OPTIONS_GROUP_DISABLE 0
+extern int griommu_group_setup(int group, void * apv, int options);
+extern int griommu_group_info(int group, uint32_t * info);
+#define GRIOMMU_OPTIONS_APV_ALLOW 0x1
+#define GRIOMMU_OPTIONS_APV_DONTALLOW 0x0
+extern int griommu_group_apv_init(int group, int options);
+extern int griommu_group_apv_address_set(int group, uint32_t addr, int size,
+		int options);
+extern int griommu_group_apv_page_set(int group, int index, int size,
+		int options);
+extern int griommu_group_apv_flush(int group);
+/* IOMMU Setup */
+ * GRIOMMU CTRL register fields
+#define CTRL_PGSZ (0x7 << CTRL_PGSZ_BIT)
+#define CTRL_LB (0x1 << CTRL_LB_BIT)
+#define CTRL_SP (0x1 << CTRL_SP_BIT)
+#define CTRL_ITR (0xf << CTRL_ITR_BIT)
+#define CTRL_DP (0x1 << CTRL_DP_BIT)
+#define CTRL_SIV (0x1 << CTRL_SIV_BIT)
+#define CTRL_HPROT (0x3 << CTRL_HPROT_BIT)
+#define CTRL_AU (0x1 << CTRL_AU_BIT)
+#define CTRL_WP (0x1 << CTRL_WP_BIT)
+#define CTRL_DM (0x1 << CTRL_DM_BIT)
+#define CTRL_GS (0x1 << CTRL_GS_BIT)
+#define CTRL_CE (0x1 << CTRL_CE_BIT)
+#define CTRL_PM (0x3 << CTRL_PM_BIT)
+#define CTRL_PM_APV (0x0 << CTRL_PM_BIT)
+#define CTRL_PM_IOMMU (0x1 << CTRL_PM_BIT)
+#define CTRL_EN (0x1 << CTRL_EN_BIT)
+#define CTRL_PGSZ_BIT 18
+#define CTRL_LB_BIT 17
+#define CTRL_SP_BIT 16
+#define CTRL_ITR_BIT 12
+#define CTRL_DP_BIT 11
+#define CTRL_SIV_BIT 10
+#define CTRL_HPROT_BIT 8
+#define CTRL_AU_BIT 7
+#define CTRL_WP_BIT 6
+#define CTRL_DM_BIT 5
+#define CTRL_GS_BIT 4
+#define CTRL_CE_BIT 3
+#define CTRL_PM_BIT 1
+#define CTRL_EN_BIT 0
+#define GRIOMMU_OPTIONS_LOOKUPBUS_BUS0 0
+#define GRIOMMU_OPTIONS_LOOKUPBUS_BUS1 CTRL_LB
+#define GRIOMMU_OPTIONS_CACHE_DISABLE 0
+#define GRIOMMU_OPTIONS_CACHE_ENABLE CTRL_CE
+#define GRIOMMU_OPTIONS_GROUPADDRESSING_DISABLE 0
+#define GRIOMMU_OPTIONS_GROUPADDRESSING_ENABLE CTRL_GS
+#define GRIOMMU_OPTIONS_WPROTONLY_DISABLE 0
+#define GRIOMMU_OPTIONS_WPROTONLY_ENABLE CTRL_WP
+#define GRIOMMU_OPTIONS_AHBUPDATE_DISABLE 0
+#define GRIOMMU_OPTIONS_AHBUPDATE_ENABLE CTRL_AU
+#define GRIOMMU_OPTIONS_PREFETCH_DISABLE CTRL_DP
+#define GRIOMMU_OPTIONS_PREFETCH_ENABLE 0
+#define GRIOMMU_OPTIONS_PAGESIZE_4KIB 0
+#define GRIOMMU_OPTIONS_PAGESIZE_8KIB (0x1 << CTRL_PGSZ_BIT)
+#define GRIOMMU_OPTIONS_PAGESIZE_16KIB (0x2 << CTRL_PGSZ_BIT)
+#define GRIOMMU_OPTIONS_PAGESIZE_32KIB (0x3 << CTRL_PGSZ_BIT)
+#define GRIOMMU_OPTIONS_PAGESIZE_64KIB (0x4 << CTRL_PGSZ_BIT)
+#define GRIOMMU_OPTIONS_PAGESIZE_128KIB (0x5 << CTRL_PGSZ_BIT)
+#define GRIOMMU_OPTIONS_PAGESIZE_256KIB (0x6 << CTRL_PGSZ_BIT)
+#define GRIOMMU_OPTIONS_PAGESIZE_512KIB (0x7 << CTRL_PGSZ_BIT)
+extern int griommu_setup(int options);
+extern int griommu_status(void);
+#define GRIOMMU_MODE_IOMMU 1
+#define GRIOMMU_MODE_GROUPAPV 0
+extern int griommu_enable(int mode);
+extern int griommu_disable(void);
+/* IOMMU APV setup */
+extern int griommu_apv_flush(void);
+extern int griommu_apv_init(void * apv, int options);
+extern int griommu_apv_address_set(void * apv, uint32_t addr, int size,
+		int options);
+extern int griommu_apv_page_set(void * apv, int index, int size, int options);
+/* GRIOMMU Interrupts */
+/* Function Interrupt-Code ISR callback prototype.
+ * arg	   - Custom arg provided by user
+ * access  - AHB Access that failed
+ * status  - Error status register of the GRIOMMU core
+typedef void (*griommu_isr_t)(void *arg, uint32_t access, uint32_t status);
+#define GRIOMMU_INTERRUPT_ALL (0x2f << 0)
+#define GRIOMMU_INTERRUPT_PARITY_ERROR (0x1 << 5)
+#define GRIOMMU_INTERRUPT_FLUSH_COMPLETED (0x1 << 3)
+#define GRIOMMU_INTERRUPT_FLUSH_START (0x1 << 2)
+#define GRIOMMU_INTERRUPT_ACCESS_DENIED (0x1 << 1)
+#define GRIOMMU_INTERRUPT_TRANSLATION_ERROR (0x1 << 0)
+extern int griommu_isr_register(griommu_isr_t isr, void * arg, int options);
+extern int griommu_isr_unregister(void);
+extern int griommu_interrupt_unmask(int options);
+extern int griommu_interrupt_mask(int options);
+extern int griommu_error_status(uint32_t * access);
+extern int griommu_print(void);
+#ifdef __cplusplus
+#endif
+#endif /* __GRIOMMU_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/iommu/griommu.c b/c/src/lib/libbsp/sparc/shared/iommu/griommu.c
index 0000000..30e6914
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/iommu/griommu.c
@@ -0,0 +1,1454 @@
+#include <stdlib.h>
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/ambapp_bus.h>
+#include <ambapp.h>
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/griommu.h>
+/*#define STATIC*/
+#define STATIC static
+/*#define INLINE*/
+#define INLINE inline
+#define UNUSED __attribute__((unused))
+/*#define DEBUG 1*/
+#ifdef DEBUG
+#define DBG(x...) printf(x)
+#else
+#define DBG(x...)
+#endif
+ * GRIOMMU CAP0 register fields
+#define CAP0_A (0x1 << CAP0_A_BIT)
+#define CAP0_AC (0x1 << CAP0_AC_BIT)
+#define CAP0_CA (0x1 << CAP0_CA_BIT)
+#define CAP0_CP (0x1 << CAP0_CP_BIT)
+#define CAP0_NARB (0xf << CAP0_NARB_BIT)
+#define CAP0_CS (0x1 << CAP0_CS_BIT)
+#define CAP0_FT (0x3 << CAP0_FT_BIT)
+#define CAP0_ST (0x1 << CAP0_ST_BIT)
+#define CAP0_I (0x1 << CAP0_I_BIT)
+#define CAP0_IT (0x1 << CAP0_IT_BIT)
+#define CAP0_IA (0x1 << CAP0_IA_BIT)
+#define CAP0_IP (0x1 << CAP0_IP_BIT)
+#define CAP0_MB (0x1 << CAP0_MB_BIT)
+#define CAP0_GRPS (0xf << CAP0_GRPS_BIT)
+#define CAP0_MSTS (0xf << CAP0_MSTS_BIT)
+#define CAP0_A_BIT 31
+#define CAP0_AC_BIT 30
+#define CAP0_CA_BIT 29
+#define CAP0_CP_BIT 28
+#define CAP0_NARB_BIT 20
+#define CAP0_CS_BIT 19
+#define CAP0_FT_BIT 17
+#define CAP0_ST_BIT 16
+#define CAP0_I_BIT 15
+#define CAP0_IT_BIT 14
+#define CAP0_IA_BIT 13
+#define CAP0_IP_BIT 12
+#define CAP0_MB_BIT 8
+#define CAP0_GRPS_BIT 4
+#define CAP0_MSTS_BIT 0
+ * GRIOMMU CAP1 register fields
+#define CAP1_CADDR (0xfff << CAP1_CADDR_BIT)
+#define CAP1_CMASK (0xf << CAP1_CMASK_BIT)
+#define CAP1_CTAGBITS (0xff << CAP1_CTAGBITS_BIT)
+#define CAP1_CISIZE (0x7 << CAP1_CISIZE_BIT)
+#define CAP1_CLINES (0x1f << CAP1_CLINES_BIT)
+#define CAP1_CADDR_BIT 20
+#define CAP1_CMASK_BIT 16
+#define CAP1_CTAGBITS_BIT 8
+#define CAP1_CISIZE_BIT 5
+#define CAP1_CLINES_BIT 0
+ * DEFINED IN HEADER FILE
+ * GRIOMMU FLUSH register fields
+#define FLUSH_FGRP (0xf << FLUSH_FGRP_BIT)
+#define FLUSH_GF (0x1 << FLUSH_GF_BIT)
+#define FLUSH_F (0x1 << FLUSH_F_BIT)
+#define FLUSH_FGRP_BIT 4
+#define FLUSH_GF_BIT 1
+#define FLUSH_F_BIT 0
+ * GRIOMMU STATUS register fields
+#define STS_PE (0x1 << STS_PE_BIT)
+#define STS_DE (0x1 << STS_DE_BIT)
+#define STS_FC (0x1 << STS_FC_BIT)
+#define STS_FL (0x1 << STS_FL_BIT)
+#define STS_AD (0x1 << STS_AD_BIT)
+#define STS_TE (0x1 << STS_TE_BIT)
+#define STS_ALL (STS_PE | STS_DE | STS_FC | STS_FL | STS_AD | STS_TE)
+#define STS_PE_BIT 5
+#define STS_DE_BIT 4
+#define STS_FC_BIT 3
+#define STS_FL_BIT 2
+#define STS_AD_BIT 1
+#define STS_TE_BIT 0
+ * GRIOMMU IMASK register fields
+#define IMASK_PEI (0x1 << IMASK_PEI_BIT)
+#define IMASK_FCI (0x1 << IMASK_FCI_BIT)
+#define IMASK_FLI (0x1 << IMASK_FLI_BIT)
+#define IMASK_ADI (0x1 << IMASK_ADI_BIT)
+#define IMASK_TEI (0x1 << IMASK_TEI_BIT)
+#define IMASK_ALL (IMASK_PEI | IMASK_FCI | IMASK_FLI | IMASK_ADI | IMASK_TEI)
+#define IMASK_PEI_BIT 5
+#define IMASK_FCI_BIT 3
+#define IMASK_FLI_BIT 2
+#define IMASK_ADI_BIT 1
+#define IMASK_TEI_BIT 0
+/* DEFINED IN HEADER FILE
+#define MASTER_BS_BUS0 0
+#define MASTER_BS_BUS1 MASTER_BS
+ * GRIOMMU GROUP register fields
+#define GRP_BASE (0xfffffff << GRP_BASE_BIT)
+#define GRP_P (0x1 << GRP_P_BIT)
+#define GRP_AG (0x1 << GRP_AG_BIT)
+#define GRP_BASE_BIT 4
+#define GRP_P_BIT 1
+#define GRP_AG_BIT 0
+#define REG_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+#define REG_READ(addr) (*(volatile unsigned int *)(addr))
+ * GRIOMMU APB Register MAP
+struct griommu_regs {
+	volatile unsigned int cap0;			/* 0x00 - Capability 0 */
+	volatile unsigned int cap1;			/* 0x04 - Capability 1 */
+	volatile unsigned int cap2;			/* 0x08 - Capability 2 */
+	volatile unsigned int resv1;		/* 0x0c - Reserved */
+	volatile unsigned int ctrl;			/* 0x10 - Control */
+	volatile unsigned int flush;		/* 0x14 - TLB/cache flush */
+	volatile unsigned int status;		/* 0x18 - Status */
+	volatile unsigned int imask;		/* 0x1c - Interrupt mask */
+	volatile unsigned int ahbstat;		/* 0x20 - AHB Failing Access */
+	volatile unsigned int resv2[7];		/* 0x24-0x3c - Reserved. No access */
+	volatile unsigned int master[16];	/* 0x40-0x7c - Master configuration */
+	volatile unsigned int grp_ctrl[16]; /* 0x80-0xbc - Group control */
+	volatile unsigned int diag_ca;		/* 0xc0 - Diagnostic cache access */
+	volatile unsigned int diag_cad[8];	/* 0xc4-0xe0 - Diagnostic cache data */
+	volatile unsigned int diag_cat;		/* 0xe4 - Diagnostic cache tag */
+	volatile unsigned int ei_data;		/* 0xe8 - Data RAM error injection */
+	volatile unsigned int ei_tag;		/* 0xec - Tag RAM error injection */
+	volatile unsigned int resv3[4];		/* 0xf0-0xfc - Reserved. No access */
+	volatile unsigned int asmpctrl[16]; /* 0x100-0x13c - ASMP access control */
+#define DEVNAME_LEN 9
+ * GRIOMMU Driver private data struture
+struct griommu_priv {
+	struct drvmgr_dev	*dev;
+	char devname[DEVNAME_LEN];
+	/* GRIOMMU control registers */
+	struct griommu_regs	*regs;
+	/* GRIOMMU capabilities */
+	int apv;
+	int apv_cache;
+	int apv_cache_addr;
+	int conf_pagesize;
+	int groups;
+	int masters;
+	/* GRIOMMU page size */
+	int pagesize;
+	/* GRIOMMU APV cache */
+	int cache_enabled;
+	int group_addressing;
+	/* User defined ISR */
+	griommu_isr_t isr;
+	void *isr_arg;
+ * GRIOMMU internal prototypes
+/* -Register access functions */
+STATIC INLINE unsigned int griommu_reg_cap0(void);
+STATIC INLINE unsigned int griommu_reg_cap1(void);
+STATIC INLINE unsigned int griommu_reg_ctrl(void);
+STATIC INLINE int griommu_reg_ctrl_set(unsigned int val);
+STATIC INLINE int griommu_reg_flush_set(unsigned int val);
+STATIC INLINE unsigned int griommu_reg_status(void);
+STATIC INLINE int griommu_reg_status_clear(unsigned int val);
+STATIC INLINE unsigned int griommu_reg_imask(void);
+STATIC INLINE int griommu_reg_imask_set(int mask);
+STATIC INLINE unsigned int griommu_reg_ahbfas(void);
+STATIC INLINE unsigned int griommu_reg_master(int master);
+STATIC INLINE int griommu_reg_master_set(int master, unsigned int val);
+STATIC INLINE unsigned int griommu_reg_group(int group);
+STATIC INLINE int griommu_reg_group_set(int group, unsigned int val);
+/* APV helper functions */
+STATIC void griommu_apv_set_word(unsigned int * wordptr, int startbitidx,
+		int nbits, unsigned int val);
+STATIC int griommu_apv_set(void * apv, int index, int size, unsigned int val);
+/* -Init function called by drvmgr */
+int griommu_init1(struct drvmgr_dev *dev);
+STATIC int griommu_init(struct griommu_priv *priv);
+/* -IRQ handler */
+void griommu_isr(void *arg);
+ * GRIOMMU static members
+static struct griommu_priv *griommupriv = NULL;
+/* GRIOMMU DRIVER */
+struct drvmgr_drv_ops griommu_ops =
+	.init = {griommu_init1, NULL, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct amba_dev_id griommu_ids[] =
+	{VENDOR_GAISLER, GAISLER_GRIOMMU},
+	{0, 0}		/* Mark end of table */
+struct amba_drv_info griommu_info =
+		DRVMGR_OBJ_DRV,					/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_AMBAPP_GAISLER_GRIOMMU_ID,/* Driver ID */
+		"GRIOMMU_DRV",			/* Driver Name */
+		DRVMGR_BUS_TYPE_AMBAPP,		/* Bus Type */
+		&griommu_ops,
+		NULL,				/* Funcs */
+		0,				/* No devices yet */
+		sizeof(struct griommu_priv),	/* Make drvmgr alloc private */
+	&griommu_ids[0]
+void griommu_register_drv(void)
+	DBG("Registering GRIOMMU driver\n");
+	drvmgr_drv_register(&griommu_info.general);
+/* Initializes the GRIOMMU core and driver
+ * Return values
+ *	0			  Successful initalization
+	struct ambapp_ahb_info *ahb;
+	struct amba_dev_info *ainfo = priv->dev->businfo;
+	/* Find GRIOMMU core from Plug&Play information */
+	ahb = ainfo->info.ahb_slv;
+	/* Found GRIOMMU core, init private structure */
+	priv->regs = (struct griommu_regs *)ahb->start[0];
+	/* Mask all interrupts */
+	griommu_reg_imask_set(0);
+	/* Initialize GRIOMMU capabilities */
+	uint32_t cap0 = griommu_reg_cap0();
+	priv->apv = (cap0 & CAP0_A) >> CAP0_A_BIT;
+	priv->apv_cache = (cap0 & CAP0_AC) >> CAP0_AC_BIT;
+	priv->apv_cache_addr = (cap0 & CAP0_CA) >> CAP0_CA_BIT;
+	priv->conf_pagesize = (cap0 & CAP0_CS) >> CAP0_CS_BIT;
+	priv->groups = ((cap0 & CAP0_GRPS) >> CAP0_GRPS_BIT) + 1;
+	priv->masters = ((cap0 & CAP0_MSTS) >> CAP0_MSTS_BIT) + 1;
+	/* Get GRIOMMU pagesize */
+	uint32_t ctrl = griommu_reg_ctrl();
+	if (priv->conf_pagesize){
+		priv->pagesize = (4*1024 << ((ctrl & CTRL_PGSZ) >> CTRL_PGSZ_BIT));
+	}else{
+		priv->pagesize = 4*1024;
+	priv->cache_enabled = (ctrl & CTRL_CE);
+	priv->group_addressing = (ctrl & CTRL_GS);
+	DBG("GRIOMMU Capabilities: APV=%d, APVC=%d, APVCA=%d, CS=%d, "
+			"GRPS=%d, MSTS=%d\n",
+			priv->apv, priv->apv_cache, priv->apv_cache_addr,
+			priv->conf_pagesize, priv->groups, priv->masters);
+	DBG("GRIOMMU driver initialized\n");
+	return 0;
+/* Called when a core is found with the AMBA device and vendor ID
+ * given in griommu_ids[]. IRQ, Console does not work here
+	int status;
+	struct griommu_priv *priv;
+	DBG("GRIOMMU[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
+	if (griommupriv) {
+		DBG("Driver only supports one GRIOMMU core\n");
+		return DRVMGR_FAIL;
+	priv = dev->priv;
+	if (!priv)
+		return DRVMGR_NOMEM;
+	priv->dev = dev;
+	strncpy(&priv->devname[0], "griommu0", DEVNAME_LEN);
+	griommupriv = priv;
+	/* Initialize GRIOMMU Hardware */
+	status = griommu_init(priv);
+	if (status) {
+		printf("Failed to initialize griommu driver %d\n", status);
+		return -1;
+	return DRVMGR_OK;
+	struct griommu_priv *priv = griommupriv;
+	return REG_READ(&priv->regs->cap0);
+	return REG_READ(&priv->regs->cap1);
+	return REG_READ(&priv->regs->ctrl);
+	REG_WRITE(&priv->regs->ctrl, val);
+	return 0;
+	REG_WRITE(&priv->regs->flush, val);
+	return 0;
+   return REG_READ(&priv->regs->status);
+	/* Clear errors */
+	REG_WRITE(&priv->regs->status, (val & STS_ALL));
+	return 0;
+   return REG_READ(&priv->regs->imask);
+	REG_WRITE(&priv->regs->imask, (mask & IMASK_ALL));
+	return 0;
+   return REG_READ(&priv->regs->ahbstat);
+	/* Change master conf */
+	REG_WRITE(&priv->regs->master[master], val);
+	return 0;
+	return REG_READ(&priv->regs->master[master]);
+	return REG_READ(&priv->regs->grp_ctrl[group]);
+	REG_WRITE(&priv->regs->grp_ctrl[group], val);
+	return 0;
+	unsigned int mask;
+	unsigned int word = *wordptr;
+	int endbitidx = startbitidx + nbits - 1;
+	/* Set initial mask */
+	mask = 0xffffffff;
+	/* Adjust mask for the starting bit */
+	mask >>= startbitidx;
+	/* Adjust mask for the end bit */
+	mask >>= (31 - endbitidx);
+	mask <<= (31 - endbitidx);
+	DBG("Setting word: startbitdx=%d, endbitidx=%d, mask=0x%02x",
+			startbitidx, endbitidx, (unsigned int) mask);
+	/* Clear written bits with mask */
+	word &= ~(mask);
+	/* Set bits in val with mask */
+	mask &= val;
+	word |= mask;
+	DBG(", old word=0x%08x, new word=0x%08x\n",*wordptr, word);
+	/* Write word */
+	*wordptr=word;
+/* Set certains bits of the APV to val */
+	unsigned int * words = (unsigned int *) apv;
+	int len = size;
+	int wordidx = (index/32);
+	int startbit = (index % 32);
+	int nbits;
+	int nwords;
+	/* First incomplete word is a special case */
+	if (startbit != 0){
+		/* Get how many bits are we changing in this word */
+		if (startbit + len  < 32){
+			nbits = len;
+		}else{
+			nbits = 32 - startbit;
+		griommu_apv_set_word(&words[wordidx], startbit, nbits, val);
+		DBG("First word: wordidx=%d, startbit=%d, bits=%d, val=0x%08x\n",
+				wordidx, startbit, nbits, words[wordidx]);
+		/* Update wordidx and len */
+		len = len - nbits;
+		wordidx++;
+	/* Write all complete full words */
+	if (len != 0){
+		nwords = (len/32);
+		memset((void *) &words[wordidx], val, nwords*4);
+		DBG("Middle words: wordidx=%d, nwords=%d\n", wordidx, nwords);
+		/* Update wordidx and len*/
+		wordidx = wordidx + nwords;
+		len = len - nwords*32;
+	/* Last word is a special case */
+	if (len != 0){
+		nbits = len;
+		griommu_apv_set_word(&words[wordidx], 0, nbits, val);
+				wordidx, 0, nbits, words[wordidx]);
+		/* Update len */
+		len = len - (nbits);
+	return GRIOMMU_ERR_OK;
+/* GRIOMMU Interrupt handler, called when there may be a GRIOMMU interrupt.
+	struct griommu_priv *priv = arg;
+	unsigned int sts = griommu_reg_status();
+	unsigned int mask = griommu_reg_imask();
+	unsigned int access = griommu_reg_ahbfas();
+	/* Make sure that the interrupt is pending and unmasked,
+	 * otherwise it migth have been other core
+	 * sharing the same interrupt line */
+	if ((sts & STS_ALL) & (mask & IMASK_ALL)){
+		/* Reset error status */
+		griommu_reg_status_clear(sts);
+		/* Execute user IRQ (ther will always be one ISR */
+		(priv->isr)(priv->isr_arg, access, sts);
+/* Setup IOMMU master:
+int griommu_master_setup(int master, int group, int options)
+	struct griommu_priv * priv = griommupriv;
+	if (priv == NULL){
+		DBG("GRIOMMU not initialized.\n");
+		return GRIOMMU_ERR_NOINIT;
+	if ((master < 0) || (master >= priv->masters)){
+		DBG("Wrong master id.\n");
+		return GRIOMMU_ERR_EINVAL;
+	if ((group < 0) || (group >= priv->groups)){
+		DBG("Wrong group id.\n");
+	griommu_reg_master_set(master,
+			((options & GRIOMMU_OPTIONS_BUS1)? MASTER_BS_BUS1: MASTER_BS_BUS0)|
+			((group << MASTER_GROUP_BIT) & MASTER_GROUP)
+	DBG("IOMMU master setup: master %d, traffic routed %s, group %d\n",
+			master,
+			(options & GRIOMMU_OPTIONS_BUS1) ?
+					"to Secondary bus":"to Primary bus",
+			group);
+/* Get IOMMU master info:
+int griommu_master_info(int master, uint32_t * info)
+	if (info == NULL){
+		DBG("Wrong pointer.\n");
+	/* Get master */
+	*info = griommu_reg_master(master);
+/* Find IOMMU master:
+int griommu_master_find(int vendor, int device, int instance)
+	int i, gotvendor, gotdevice;
+	unsigned int master;
+	int found;
+	/* Find which master */
+	found=0;
+	for (i=0; i< priv->masters; i++){
+		master = griommu_reg_master(i);
+		gotvendor = (master & MASTER_VENDOR) >> MASTER_VENDOR_BIT;
+		gotdevice = (master & MASTER_DEVICE) >> MASTER_DEVICE_BIT;
+		if ((gotvendor == vendor) && (gotdevice == device)){
+			if(found == instance){
+				DBG("Found master %d: VENDOR=%s(0x%02x), DEVICE=%s(0x%03x), "
+					"Instance=%d\n",
+					i,
+					ambapp_vendor_id2str(vendor), vendor,
+					ambapp_device_id2str(vendor,device), device, instance
+				return i;
+			found++;
+	DBG("Master not found: VENDOR=%s(0x%02x), DEVICE=%s(0x%03x), "
+		"Instance=%d\n",
+	return GRIOMMU_ERR_NOTFOUND;
+/* Setup IOMMU:
+int griommu_setup(int options)
+	unsigned int ctrl;
+	/* Check Cache */
+	if (options & GRIOMMU_OPTIONS_CACHE_ENABLE) {
+		if (priv->apv_cache){
+			/* Flush cache */
+			griommu_reg_flush_set(FLUSH_F);
+			priv->cache_enabled = 1;
+		}else{
+			DBG("GRIOMMU APV cache not supported.\n");
+			return GRIOMMU_ERR_IMPLEMENTED;
+	}else{
+		priv->cache_enabled = 0;
+	/* Check group addressing */
+	if (options & GRIOMMU_OPTIONS_GROUPADDRESSING_ENABLE){
+		if (priv->apv_cache_addr){
+			priv->group_addressing = 1;
+		}else{
+			DBG("GRIOMMU APV cache group addressing not supported.\n");
+	}else{
+		priv->group_addressing = 0;
+	/* Check pagesize */
+	if ((options & CTRL_PGSZ) != GRIOMMU_OPTIONS_PAGESIZE_4KIB){
+		if (priv->conf_pagesize == 0){
+			DBG("GRIOMMU Configurable pagesize not supported.\n");
+	/* Get CTRL IOMMU */
+	ctrl = griommu_reg_ctrl();
+	/* Clear used fields */
+	ctrl &= ~(CTRL_CE | CTRL_GS | CTRL_PGSZ | CTRL_LB |
+			CTRL_DP | CTRL_AU | CTRL_WP);
+	/* Clear not used fields */
+	options &= (CTRL_CE | CTRL_GS | CTRL_PGSZ | CTRL_LB |
+	/* Set new values */
+	ctrl |= options;
+	/* Set CTRL IOMMU */
+	griommu_reg_ctrl_set(ctrl);
+	DBG("IOMMU setup: prefetching %s, cache %s, groupaddr %s, "
+		"lookup bus %s, ahb update %s,\nwprot only %s, pagesize %d KiB\n",
+			((options & GRIOMMU_OPTIONS_PREFETCH_DISABLE)?
+					"disabled":"enabled"),
+			((options & GRIOMMU_OPTIONS_CACHE_ENABLE)? "enabled":"disabled"),
+			((options & GRIOMMU_OPTIONS_GROUPADDRESSING_ENABLE)?
+					"enabled":"disabled"),
+			((options & GRIOMMU_OPTIONS_LOOKUPBUS_BUS1)? "bus1":"bus0"),
+			((options & GRIOMMU_OPTIONS_AHBUPDATE_ENABLE)?
+			((options & GRIOMMU_OPTIONS_WPROTONLY_ENABLE)?
+			(4 << ((options & GRIOMMU_OPTIONS_PAGESIZE_512KIB) >> 18))
+/* Status IOMMU:
+int griommu_status(void)
+	DBG("IOMMU status: prefetching %s, cache %s, groupaddr %s, "
+			((ctrl & CTRL_DP)? "disabled":"enabled"),
+			((ctrl & CTRL_CE)? "enabled":"disabled"),
+			((ctrl & CTRL_GS)? "enabled":"disabled"),
+			((ctrl & CTRL_LB)? "bus1":"bus0"),
+			((ctrl & CTRL_AU)? "enabled":"disabled"),
+			((ctrl & CTRL_WP)? "enabled":"disabled"),
+			(4 << ((ctrl & CTRL_PGSZ) >> CTRL_PGSZ_BIT))
+	return ctrl;
+int griommu_isr_register(griommu_isr_t isr, void * arg, int options)
+	if (isr == NULL){
+		DBG("GRIOMMU wrong isr.\n");
+	/* Get mask */
+	mask = 0 |
+		((options & GRIOMMU_INTERRUPT_PARITY_ERROR)? IMASK_PEI:0) |
+		((options & GRIOMMU_INTERRUPT_FLUSH_COMPLETED)? IMASK_FCI:0) |
+		((options & GRIOMMU_INTERRUPT_FLUSH_START)? IMASK_FLI:0) |
+		((options & GRIOMMU_INTERRUPT_ACCESS_DENIED)? IMASK_ADI:0) |
+		((options & GRIOMMU_INTERRUPT_TRANSLATION_ERROR)? IMASK_TEI:0);
+	/* Clear previous interrupts and mask them*/
+	griommu_reg_status_clear(STS_ALL);
+	/* First time registering an ISR */
+	if (priv->isr == NULL){
+		/* Install and Enable GRIOMMU interrupt handler */
+		drvmgr_interrupt_register(priv->dev, 0, priv->devname, griommu_isr,
+				priv);
+	/* Install user ISR */
+	priv->isr=isr;
+	priv->isr_arg=arg;
+	/* Now it is safe to unmask interrupts */
+	griommu_reg_imask_set(mask);
+int griommu_isr_unregister(void)
+	/* Uninstall and disable GRIOMMU interrupt handler */
+	drvmgr_interrupt_unregister(priv->dev, 0, griommu_isr, priv);
+	/* Uninstall user ISR */
+	priv->isr=NULL;
+	priv->isr_arg=NULL;
+int griommu_interrupt_unmask(int options)
+	unsigned int mask, irq;
+	/* Unmask interrupts in GRIOMMU */
+	mask = 0 |
+	/* Clear previous interrupts*/
+	/* Get previous mask */
+	irq = griommu_reg_imask() & IMASK_ALL;
+	/* Set new mask */
+	griommu_reg_imask_set(irq | mask);
+int griommu_interrupt_mask(int options)
+	/* Mask interrupts in GRIOMMU */
+	mask = 0 |
+	griommu_reg_imask_set(irq & ~(mask));
+int griommu_error_status(uint32_t * access)
+	int status;
+	/* Get status mask */
+	status = griommu_reg_status();
+	if (status != 0){
+		/* Update pointed value */
+		if (access != NULL){
+			*access = griommu_reg_ahbfas();
+		griommu_reg_status_clear(status);
+	return status;
+/* Print IOMMU masters
+ * DEBUG function
+int griommu_print(void)
+	#ifdef DEBUG
+	/* Print IOMMU status */
+	printf("IOMMU status: prefetching %s, lookup bus %s, ahb update %s,\n"
+			"wprot only %s, pagesize %d KiB\n",
+	/* Print each master configuration */
+	int i, vendor, device, routing;
+	for (i=0; i < priv->masters; i++){
+		vendor = (master & MASTER_VENDOR) >> MASTER_VENDOR_BIT;
+		device = (master & MASTER_DEVICE) >> MASTER_DEVICE_BIT;
+		routing = (master & MASTER_BS);
+		printf("IOMMU master %d: VENDOR=%s(0x%02x), DEVICE=%s(0x%03x), "
+				"BS=%s\n",
+				i,
+				(routing == MASTER_BS_BUS0? "Primary bus" : "Secondary bus")
+	#endif
+void * griommu_apv_new(void)
+		return NULL;
+	/* Allocate APV */
+	unsigned int * orig_ptr = (unsigned int *) malloc(
+			(GRIOMMU_APV_SIZE/priv->pagesize) + GRIOMMU_APV_ALIGN);
+	if (orig_ptr == NULL) return NULL;
+	/* Get the aligned pointer */
+	unsigned int aligned_ptr = (
+		((unsigned int) orig_ptr + GRIOMMU_APV_ALIGN) &
+		~(GRIOMMU_APV_ALIGN - 1));
+	/* Save the original pointer before the aligned pointer */
+	unsigned int ** tmp_ptr =
+		(unsigned int **) (aligned_ptr - sizeof(orig_ptr));
+	*tmp_ptr= orig_ptr;
+	/* Return aligned pointer */
+	return (void *) aligned_ptr;
+void griommu_apv_delete(void * apv)
+	/* Recover orignal pointer placed just before the aligned pointer */
+	unsigned int * orig_ptr;
+	unsigned int ** tmp_ptr =  (unsigned int **) (apv - sizeof(orig_ptr));
+	orig_ptr = *tmp_ptr;
+	/* Deallocate memory */
+	free(orig_ptr);
+int griommu_enable(int mode)
+	switch (mode){
+		case GRIOMMU_MODE_IOMMU:
+		default:
+			DBG("IOMMU mode not implemented in driver.\n");
+			break;
+		case GRIOMMU_MODE_GROUPAPV:
+			if (priv->apv == 0){
+				DBG("IOMMU APV not supported.\n");
+			/* Enable IOMMU */
+			ctrl = (griommu_reg_ctrl() & ~(CTRL_PM));
+			griommu_reg_ctrl_set(ctrl | CTRL_PM_APV | CTRL_EN);
+			/* Wait until change has effect */
+			while((griommu_reg_ctrl() & CTRL_EN)==0){};
+			DBG("IOMMU enabled.\n");
+			break;
+int griommu_disable(void)
+	/* Disable IOMMU */
+	ctrl = (griommu_reg_ctrl() & ~(CTRL_EN));
+	while(griommu_reg_ctrl() & CTRL_EN){};
+int griommu_group_setup(int group, void * apv, int options)
+	if ((options < 0) || (options > GRIOMMU_OPTIONS_GROUP_PASSTHROUGH)){
+		DBG("Wrong options.\n");
+	if (options == GRIOMMU_OPTIONS_GROUP_DISABLE){
+		if ((unsigned int) apv & (GRIOMMU_APV_ALIGN -1)){
+		/* Disable GROUP */
+		griommu_reg_group_set(group, (((unsigned int) apv) & GRP_BASE) | 0);
+		DBG("GROUP[%d] DISABLED.\n", group);
+	}else if (options == GRIOMMU_OPTIONS_GROUP_PASSTHROUGH){
+		/* Group in passthrough */
+				(((unsigned int) apv) & GRP_BASE) | GRP_P | GRP_AG);
+		DBG("GROUP[%d] set to PASSTHROUGH.\n", group);
+	}else{
+		if ((apv == NULL) || ((unsigned int) apv & (GRIOMMU_APV_ALIGN -1))){
+		/* Set up base and enable */
+				(((unsigned int) apv) & GRP_BASE) | GRP_AG);
+		DBG("GROUP[%d] set to APV (0x%08x).\n", group, (unsigned int) apv);
+int griommu_group_apv_init(int group, int options)
+	void * apv;
+	int val;
+	int ret;
+	size_t len;
+	/* Flush APV cache if needed.
+	 * This function checks for priv and group being valid.*/
+	ret = griommu_group_apv_flush(group);
+	if (ret < 0){
+		return ret;
+	/* Get APV group */
+	apv = (void *) (griommu_reg_group(group) & GRP_BASE);
+	if (apv == NULL){
+	/* Get init value (is a char) */
+	if (options == GRIOMMU_OPTIONS_APV_ALLOW){
+		val = 0x00;
+	}else{
+		val = 0xff;
+	/* Get APV length */
+	len = GRIOMMU_APV_SIZE/priv->pagesize;
+	/* Initialize structure */
+	memset(apv, val, len);
+int griommu_group_apv_page_set(int group, int index, int size, int options)
+	void * apv;
+	unsigned int val;
+	int ret;
+	if (ret < 0){
+		return ret;
+	if (apv == NULL){
+	/* Get init value */
+		val = 0x0;
+	}else{
+		val = 0xffffffff;
+	return griommu_apv_set(apv, index, size, val);
+int griommu_group_apv_address_set(int group, uint32_t addr, int size,
+		int options)
+	void * apv;
+	unsigned int val;
+	int ret;
+	int startpage;
+	int endpage;
+	int npages;
+	if (ret < 0){
+		return ret;
+	if (apv == NULL){
+		val = 0x0;
+	}else{
+		val = 0xffffffff;
+	/* Get start page */
+	startpage = (addr / priv->pagesize);
+	/* Get end page */
+	endpage = ((addr + size)/ priv->pagesize);
+	/* Get number of pages */
+	npages = endpage - startpage + 1;
+	return griommu_apv_set(apv, startpage, npages, val);
+int griommu_apv_init(void * apv, int options)
+	int val;
+	size_t len;
+		val = 0x00;
+	}else{
+		val = 0xff;
+int griommu_apv_page_set(void * apv, int index, int size, int options)
+	unsigned int val;
+		val = 0x0;
+	}else{
+		val = 0xffffffff;
+int griommu_apv_address_set(void * apv, uint32_t addr, int size, int options)
+	unsigned int val;
+	int startpage;
+	int endpage;
+	int npages;
+		val = 0x0;
+	}else{
+		val = 0xffffffff;
+int griommu_group_info(int group, uint32_t * info)
+	/* Get group */
+	*info = griommu_reg_group(group);
+/* Flush APV cache group:
+int griommu_group_apv_flush(int group)
+	/* Flush cache	*/
+	if (priv->cache_enabled){
+		if (priv->group_addressing){
+			griommu_reg_flush_set(((group << FLUSH_FGRP_BIT) & FLUSH_FGRP) |
+					FLUSH_GF | FLUSH_F);
+		}else{
+		DBG("GRIOMMU APV cache flushed.\n");
+/* Flush APV cache:
+int griommu_apv_flush(void)
+	/* Flush cache	*/
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index 465f66f..fd19139 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -48,6 +48,7 @@ extern void pcif_register_drv(void);
 extern void grpci_register_drv(void);
 extern void mctrl_register_drv(void);
 extern void l2cache_register_drv(void);
 extern void grpci2_register_drv(void);
 extern void spictrl_register_drv(void);
 extern void i2cmst_register_drv(void);
@@ -139,6 +140,9 @@ drvmgr_drv_reg_func drvmgr_drivers[] = {
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_L2CACHE
 	l2cache_register_drv,
 #endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRIOMMU
+	griommu_register_drv,
+#endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPICTRL
 	spictrl_register_drv,
 #endif
2.7.4
