[PATCH 22/30] leon, memscrub: add GR740 memory scrubber driver
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:31 UTC 2017
 c/src/lib/libbsp/sparc/Makefile.am                 |   4 +
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |   4 +
 c/src/lib/libbsp/sparc/leon2/preinstall.am         |   4 +
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |   4 +
 c/src/lib/libbsp/sparc/leon3/preinstall.am         |   4 +
 .../sparc/shared/include/drvmgr/ambapp_bus.h       |   1 +
 c/src/lib/libbsp/sparc/shared/include/memscrub.h   | 172 +++++
 c/src/lib/libbsp/sparc/shared/scrub/memscrub.c     | 691 +++++++++++++++++++++
 cpukit/libdrvmgr/drvmgr_confdefs.h                 |   4 +
 9 files changed, 888 insertions(+)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/memscrub.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/scrub/memscrub.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 2535752..84056ed 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -182,5 +182,9 @@ EXTRA_DIST += shared/include/grtc.h
 EXTRA_DIST += shared/tmtc/grtm.c
 EXTRA_DIST += shared/include/grtm.h
+# MEMSCRUB
+EXTRA_DIST += shared/stat/memscrub.c
+EXTRA_DIST += shared/include/memscrub.h
 include $(top_srcdir)/../../../automake/subdirs.am
 include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 9078cf5..6106f03 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -205,6 +205,10 @@ include_bsp_HEADERS += ../../sparc/shared/include/grtm.h
 libbsp_a_SOURCES += ../../sparc/shared/tmtc/grtc.c
 libbsp_a_SOURCES += ../../sparc/shared/tmtc/grtm.c
+# MEMSCRUB
+libbsp_a_SOURCES += ../../sparc/shared/scrub/memscrub.c
+include_bsp_HEADERS += ../../sparc/shared/include/memscrub.h
 # Driver Manager
 include_drvmgrdir = $(includedir)/drvmgr
 include_drvmgr_HEADERS = ../../sparc/shared/include/drvmgr/ambapp_bus.h
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index 2aad5f9..eae20e7 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -269,6 +269,10 @@ $(PROJECT_INCLUDE)/bsp/grtm.h: ../../sparc/shared/include/grtm.h $(PROJECT_INCLU
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/grtm.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/grtm.h
+$(PROJECT_INCLUDE)/bsp/memscrub.h: ../../sparc/shared/include/memscrub.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/memscrub.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/memscrub.h
 $(PROJECT_INCLUDE)/drvmgr/$(dirstamp):
 	@$(MKDIR_P) $(PROJECT_INCLUDE)/drvmgr
 	@: > $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 3386cf0..d8db46a 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -239,6 +239,10 @@ include_bsp_HEADERS += ../../sparc/shared/include/grtm.h
+# MEMSCRUB
 # Driver Manager
 include_drvmgr_HEADERS = ../../sparc/shared/include/drvmgr/ambapp_bus_grlib.h
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index b8ac694..bc709a7 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -317,6 +317,10 @@ $(PROJECT_INCLUDE)/bsp/grtm.h: ../../sparc/shared/include/grtm.h $(PROJECT_INCLU
diff --git a/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h b/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
index 203e7e9..41df26e 100644
--- a/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
+++ b/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
@@ -57,6 +57,7 @@ extern "C" {
 #define DRIVER_AMBAPP_GAISLER_SPWCUC_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPWCUC)
 #define DRIVER_AMBAPP_GAISLER_SPW_ROUTER_ID	DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW_ROUTER)
 #define DRIVER_AMBAPP_GAISLER_L2CACHE_ID	DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L2CACHE)
+#define DRIVER_AMBAPP_GAISLER_MEMSCRUB_ID	DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_MEMSCRUB)
 /*** ESA Hardware Device Driver IDs ***/
 #define DRIVER_AMBAPP_ESA_MCTRL_ID		DRIVER_AMBAPP_ID(VENDOR_ESA, ESA_MCTRL)
diff --git a/c/src/lib/libbsp/sparc/shared/include/memscrub.h b/c/src/lib/libbsp/sparc/shared/include/memscrub.h
new file mode 100644
index 0000000..1e55d8e
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/memscrub.h
@@ -0,0 +1,172 @@
+/*  MEMSCRUB driver interface
+ *  COPYRIGHT (c) 2017.
+ *  Cobham Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef __MEMSCRUB_H__
+#define __MEMSCRUB_H__
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define MEMSCRUB_ERR_OK 0
+#define MEMSCRUB_ERR_EINVAL -1
+#define MEMSCRUB_ERR_ERROR -2
+extern void memscrub_register_drv(void);
+ * MEMORYSCRUBBER CONFIG register fields
+#define CONFIG_DELAY_BIT 8
+#define CONFIG_IRQD_BIT 7
+#define CONFIG_SERA_BIT 5
+#define CONFIG_LOOP_BIT 4
+#define CONFIG_MODE_BIT 2
+#define CONFIG_ES_BIT 1
+#define CONFIG_SCEN_BIT 0
+#define CONFIG_DELAY (0xff << CONFIG_DELAY_BIT)
+#define CONFIG_IRQD (0x1 << CONFIG_IRQD_BIT)
+#define CONFIG_SERA (0x1 << CONFIG_SERA_BIT)
+#define CONFIG_LOOP (0x1 << CONFIG_LOOP_BIT)
+#define CONFIG_MODE (0x3 << CONFIG_MODE_BIT)
+#define CONFIG_ES (0x1 << CONFIG_ES_BIT)
+#define CONFIG_SCEN (0x1 << CONFIG_SCEN_BIT)
+#define CONFIG_MODE_SCRUB (0x0 << CONFIG_MODE_BIT)
+#define CONFIG_MODE_REGEN (0x1 << CONFIG_MODE_BIT)
+#define CONFIG_MODE_INIT (0x2 << CONFIG_MODE_BIT)
+#define MEMSCRUB_OPTIONS_INTERRUPTDONE_ENABLE CONFIG_IRQD
+#define MEMSCRUB_OPTIONS_INTERRUPTDONE_DISABLE 0
+#define MEMSCRUB_OPTIONS_EXTERNALSTART_ENABLE CONFIG_ES
+#define MEMSCRUB_OPTIONS_EXTERNALSTART_DISABLE 0
+#define MEMSCRUB_OPTIONS_LOOPMODE_ENABLE CONFIG_LOOP
+#define MEMSCRUB_OPTIONS_LOOPMODE_DISABLE 0
+#define MEMSCRUB_OPTIONS_SECONDARY_MEMRANGE_ENABLE CONFIG_SERA
+#define MEMSCRUB_OPTIONS_SECONDARY_MEMRANGE_DISABLE 0
+/* Scrubbing modes */
+extern int memscrub_init_start(uint32_t value, uint8_t delay, int options);
+extern int memscrub_scrub_start(uint8_t delay, int options);
+extern int memscrub_regen_start(uint8_t delay, int options);
+extern int memscrub_stop(void);
+extern int memscrub_active(void);
+/* Set/get memory ranges */
+extern int memscrub_range_set(uint32_t start, uint32_t end);
+extern int memscrub_range_get(uint32_t * start, uint32_t * end);
+extern int memscrub_secondary_range_set(uint32_t start, uint32_t end);
+extern int memscrub_secondary_range_get(uint32_t * start, uint32_t * end);
+/* Interrupts */
+/* MEMSCRUB Interrupts */
+/* Function Interrupt-Code ISR callback prototype.
+ * arg	   - Custom arg provided by user
+ * access  - AHB Access that failed
+ * ahbstatus  - AHB status register of the MEMSCRUB core
+ * status  - status register of the MEMSCRUB core
+typedef void (*memscrub_isr_t)(void *arg, uint32_t ahbaccess,
+		uint32_t ahbstatus, uint32_t scrubstatus);
+extern int memscrub_isr_register(memscrub_isr_t isr, void * data);
+extern int memscrub_isr_unregister(void);
+extern int memscrub_error_status(uint32_t *ahbaccess, uint32_t *ahbstatus,
+		uint32_t *scrubstatus);
+/* Set the different error thresholds. */
+ * MEMORYSCRUBBER AHBS register fields
+#define AHBS_CECNT_BIT 22
+#define AHBS_UECNT_BIT 14
+#define AHBS_DONE_BIT 13
+#define AHBS_SEC_BIT 11
+#define AHBS_SBC_BIT 10
+#define AHBS_CE_BIT 9
+#define AHBS_NE_BIT 8
+#define AHBS_HW_BIT 7
+#define AHBS_HM_BIT 3
+#define AHBS_HS_BIT 0
+#define AHBS_CECNT (0x3ff << AHBS_CECNT_BIT)
+#define AHBS_UECNT (0xff << AHBS_UECNT_BIT)
+#define AHBS_DONE (1 << AHBS_DONE_BIT)
+#define AHBS_SEC (1 << AHBS_SEC_BIT)
+#define AHBS_SBC (1 << AHBS_SBC_BIT)
+#define AHBS_CE (1 << AHBS_CE_BIT)
+#define AHBS_NE (1 << AHBS_NE_BIT)
+#define AHBS_HW (1 << AHBS_HW_BIT)
+#define AHBS_HM (0xf << AHBS_HM_BIT)
+#define AHBS_HS (0x7 << AHBS_HS_BIT)
+ * MEMORYSCRUBBER STAT register fields
+#define STAT_RUNCOUNT_BIT 22
+#define STAT_BLKCOUNT_BIT 14
+#define STAT_DONE_BIT 13
+#define STAT_BURSTLEN_BIT 1
+#define STAT_ACTIVE_BIT 0
+#define STAT_RUNCOUNT (0x3ff << STAT_RUNCOUNT_BIT)
+#define STAT_BLKCOUNT (0xff << STAT_BLKCOUNT_BIT)
+#define STAT_DONE (0x1 << STAT_DONE_BIT)
+#define STAT_BURSTLEN (0xf << STAT_BURSTLEN_BIT)
+#define STAT_ACTIVE (0x1 << STAT_ACTIVE_BIT)
+ * MEMORYSCRUBBER AHBERC register fields
+#define AHBERC_CECNTT_BIT 22
+#define AHBERC_UECNTT_BIT 14
+#define AHBERC_CECTE_BIT 1
+#define AHBERC_UECTE_BIT 0
+#define AHBERC_CECNTT (0x3ff << AHBERC_CECNTT_BIT)
+#define AHBERC_UECNTT (0xff << AHBERC_UECNTT_BIT)
+#define AHBERC_CECTE (0x1 << AHBERC_CECTE_BIT)
+#define AHBERC_UECTE (0x1 << AHBERC_UECTE_BIT)
+ * MEMORYSCRUBBER ETHRES register fields
+#define ETHRES_RECT_BIT 22
+#define ETHRES_BECT_BIT 14
+#define ETHRES_RECTE_BIT 1
+#define ETHRES_BECTE_BIT 0
+#define ETHRES_RECT (0x3ff << ETHRES_RECT_BIT)
+#define ETHRES_BECT (0xff << ETHRES_BECT_BIT)
+#define ETHRES_RECTE (0x1 << ETHRES_RECTE_BIT)
+#define ETHRES_BECTE (0x1 << ETHRES_BECTE_BIT)
+#define MEMSCRUB_OPTIONS_AHBERROR_CORTHRES_ENABLE AHBERC_CECTE
+#define MEMSCRUB_OPTIONS_AHBERROR_CORTHRES_DISABLE 0
+#define MEMSCRUB_OPTIONS_AHBERROR_UNCORTHRES_ENABLE AHBERC_UECTE
+#define MEMSCRUB_OPTIONS_AHBERROR_UNCORTHRES_DISABLE 0
+#define MEMSCRUB_OPTIONS_SCRUBERROR_RUNTHRES_ENABLE ETHRES_RECTE
+#define MEMSCRUB_OPTIONS_SCRUBERROR_RUNTHRES_DISABLE 0
+#define MEMSCRUB_OPTIONS_SCRUBERROR_BLOCKTHRES_ENABLE ETHRES_BECTE
+#define MEMSCRUB_OPTIONS_SCRUBERROR_BLOCKTHRES_DISABLE 0
+extern int memscrub_ahberror_setup(int uethres, int cethres, int options);
+extern int memscrub_scruberror_setup(int blkthres, int runthres,
+		int options);
+extern int memscrub_scrub_position(uint32_t * position);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/scrub/memscrub.c b/c/src/lib/libbsp/sparc/shared/scrub/memscrub.c
index 0000000..cf02689
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/scrub/memscrub.c
@@ -0,0 +1,691 @@
+/*  Memory Scrubber register driver
+#include <stdlib.h>
+#include <stdio.h>
+#include <rtems/bspIo.h>
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/ambapp_bus.h>
+#include <bsp/memscrub.h>
+/*#define STATIC*/
+#define STATIC static
+#define UNUSED __attribute__((unused))
+/*#define DEBUG 1*/
+#ifdef DEBUG
+#define DBG(x...) printf(x)
+#else
+#define DBG(x...)
+#endif
+#define REG_WRITE(addr, val) (*(volatile uint32_t *)(addr) = (uint32_t)(val))
+#define REG_READ(addr) (*(volatile uint32_t *)(addr))
+ * DEFINED IN HEADER FILE
+/* MEMORYSCRUBBER Registers layout */
+struct memscrub_regs {
+	volatile uint32_t ahbstatus; /* 0x00 */
+	volatile uint32_t ahbfailing; /* 0x04 */
+	volatile uint32_t ahberc; /* 0x08 */
+	volatile uint32_t resv1; /* 0x0c */
+	volatile uint32_t status; /* 0x10 */
+	volatile uint32_t config; /* 0x14 */
+	volatile uint32_t rangel; /* 0x18 */
+	volatile uint32_t rangeh; /* 0x1c */
+	volatile uint32_t pos; /* 0x20 */
+	volatile uint32_t ethres; /* 0x24 */
+	volatile uint32_t init; /* 0x28 */
+	volatile uint32_t rangel2; /* 0x2c */
+	volatile uint32_t rangeh2; /* 0x30 */
+#define DEVNAME_LEN 10
+struct memscrub_priv {
+	struct drvmgr_dev *dev;
+	char devname[DEVNAME_LEN];
+	struct memscrub_regs *regs;
+	int minor;
+	int burstlen;
+	int blockmask;
+	/* Cached error */
+	uint32_t last_status;
+	uint32_t last_address;
+	/* User defined ISR */
+	memscrub_isr_t isr;
+	void *isr_arg;
+static struct memscrub_priv * memscrubpriv = NULL;
+STATIC int memscrub_init2(struct drvmgr_dev *dev);
+STATIC int memscrub_init(struct memscrub_priv *priv);
+void memscrub_isr(void *arg);
+struct drvmgr_drv_ops memscrub_ops =
+	.init = {NULL, memscrub_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct amba_dev_id memscrub_ids[] =
+	{VENDOR_GAISLER, GAISLER_MEMSCRUB},
+	{0, 0}		/* Mark end of table */
+struct amba_drv_info memscrub_drv_info =
+		DRVMGR_OBJ_DRV,			/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_AMBAPP_GAISLER_MEMSCRUB_ID,/* Driver ID */
+		"MEMSCRUB_DRV",			/* Driver Name */
+		DRVMGR_BUS_TYPE_AMBAPP,		/* Bus Type */
+		&memscrub_ops,
+		NULL,				/* Funcs */
+		0,				/* No devices yet */
+		sizeof(struct memscrub_priv),
+	&memscrub_ids[0]
+void memscrub_register_drv (void)
+	drvmgr_drv_register(&memscrub_drv_info.general);
+	struct ambapp_ahb_info *ahb;
+	struct amba_dev_info *ainfo = priv->dev->businfo;
+	unsigned int tmp;
+	int i,j;
+	/* Get device information from AMBA PnP information */
+	if (ainfo == NULL){
+		return MEMSCRUB_ERR_ERROR;
+	/* Find MEMSCRUB core from Plug&Play information */
+	ahb = ainfo->info.ahb_slv;
+	priv->regs = (struct memscrub_regs *)ahb->start[0];
+	DBG("MEMSCRUB regs 0x%08x\n", (unsigned int) priv->regs);
+	/* Find MEMSCRUB capabilities */
+	tmp = REG_READ(&priv->regs->status);
+	i = (tmp & STAT_BURSTLEN) >> STAT_BURSTLEN_BIT;
+	for (j=1; i>0; i--) j <<= 1;
+	priv->burstlen = j;
+	/* If scrubber is active, we cannot stop it to read blockmask value */
+	if (tmp & STAT_ACTIVE){
+		priv->blockmask = 0;
+	}else{
+		/* Detect block size in bytes and burst length */
+		tmp = REG_READ(&priv->regs->rangeh);
+		REG_WRITE(&priv->regs->rangeh, 0);
+		priv->blockmask = REG_READ(&priv->regs->rangeh);
+		REG_WRITE(&priv->regs->rangeh, tmp);
+	/* DEBUG print */
+	DBG("MEMSCRUB with following capabilities:\n");
+	DBG(" -Burstlength: %d\n", priv->burstlen);
+	return MEMSCRUB_ERR_OK;
+	struct memscrub_priv *priv = dev->priv;
+	DBG("MEMSCRUB[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
+	if (memscrubpriv) {
+		DBG("Driver only supports one MEMSCRUB core\n");
+		return DRVMGR_FAIL;
+	if (priv==NULL){
+		return DRVMGR_NOMEM;
+	/* Assign priv */
+	priv->dev = dev;
+	strncpy(&priv->devname[0], "memscrub0", DEVNAME_LEN);
+	memscrubpriv=priv;
+	/* Initilize driver struct */
+	if (memscrub_init(priv) != MEMSCRUB_ERR_OK){
+	/* Startup Action:
+	 *	- Clear status
+	 *	- Register ISR
+	/* Initialize hardware by clearing its status */
+	REG_WRITE(&priv->regs->ahbstatus, 0);
+	REG_WRITE(&priv->regs->status, 0);
+	return DRVMGR_OK;
+int memscrub_init_start(uint32_t value, uint8_t delay, int options)
+	struct memscrub_priv *priv = memscrubpriv;
+	uint32_t sts, tmp;
+	int i;
+	if (priv==NULL){
+		DBG("MEMSCRUB not init.\n");
+	/* Check if scrubber is active */
+	sts = REG_READ(&priv->regs->status);
+	if (sts & STAT_ACTIVE){
+		DBG("MEMSCRUB running.\n");
+	/* Check if we need to probe blockmask */
+	if (priv->blockmask == 0){
+	/* Set data value */
+	for (i=0; i<priv->blockmask; i+=4){
+		REG_WRITE(&priv->regs->init,value);
+	/* Clear unused bits */
+	options = options & ~(CONFIG_MODE | CONFIG_DELAY);
+	/* Enable scrubber */
+	REG_WRITE(&priv->regs->config, options |
+			((delay << CONFIG_DELAY_BIT) & CONFIG_DELAY) |
+			CONFIG_MODE_INIT | CONFIG_SCEN);
+	DBG("MEMSCRUB INIT STARTED\n");
+int memscrub_scrub_start(uint8_t delay, int options)
+	uint32_t ctrl,sts;
+	if (priv==NULL){
+		/* Check if mode is not init */
+		ctrl = REG_READ(&priv->regs->config);
+		if ((ctrl & CONFIG_MODE)==CONFIG_MODE_INIT){
+			DBG("MEMSCRUB init running.\n");
+			CONFIG_MODE_SCRUB | CONFIG_SCEN);
+	DBG("MEMSCRUB SCRUB STARTED\n");
+int memscrub_regen_start(uint8_t delay, int options)
+	if (priv==NULL){
+			CONFIG_MODE_REGEN | CONFIG_SCEN);
+	DBG("MEMSCRUB REGEN STARTED\n");
+int memscrub_stop(void)
+	if (priv==NULL){
+	/* Disable scrubber */
+	REG_WRITE(&priv->regs->config, 0);
+	/* Wait until finished */
+	while(REG_READ(&priv->regs->status) & STAT_ACTIVE){};
+	DBG("MEMSCRUB STOPPED\n");
+int memscrub_range_set(uint32_t start, uint32_t end)
+	if (priv==NULL){
+	if (end <= start){
+		DBG("MEMSCRUB wrong address.\n");
+		return MEMSCRUB_ERR_EINVAL;
+	if (REG_READ(&priv->regs->status) & STAT_ACTIVE){
+	/* Set range */
+	REG_WRITE(&priv->regs->rangel, start);
+	REG_WRITE(&priv->regs->rangeh, end);
+	DBG("MEMSCRUB range: 0x%08x-0x%08x\n",
+			(unsigned int) start,
+			(unsigned int) end);
+int memscrub_secondary_range_set(uint32_t start, uint32_t end)
+	if (priv==NULL){
+	/* Set range */
+	REG_WRITE(&priv->regs->rangel2, start);
+	REG_WRITE(&priv->regs->rangeh2, end);
+	DBG("MEMSCRUB 2nd range: 0x%08x-0x%08x\n",
+int memscrub_range_get(uint32_t * start, uint32_t * end)
+	if (priv==NULL){
+	if ((start==NULL) || (end == NULL)){
+		DBG("MEMSCRUB wrong pointer.\n");
+	/* Get range */
+	*start = REG_READ(&priv->regs->rangel);
+	*end = REG_READ(&priv->regs->rangeh);
+int memscrub_secondary_range_get(uint32_t * start, uint32_t * end)
+	if (priv==NULL){
+	/* Get range */
+	*start = REG_READ(&priv->regs->rangel2);
+	*end = REG_READ(&priv->regs->rangeh2);
+int memscrub_ahberror_setup(int uethres, int cethres, int options)
+	if (priv==NULL){
+	/* Set AHBERR */
+	REG_WRITE(&priv->regs->ahberc,
+			((cethres << AHBERC_CECNTT_BIT) & AHBERC_CECNTT) |
+			((uethres << AHBERC_UECNTT_BIT) & AHBERC_UECNTT) |
+			(options & (AHBERC_CECTE | AHBERC_UECTE)));
+	DBG("MEMSCRUB ahb err: UE[%d]:%s, CE[%d]:%s\n",
+			(unsigned int) uethres,
+			(options & AHBERC_UECTE)? "enabled":"disabled",
+			(unsigned int) cethres,
+			(options & AHBERC_CECTE)? "enabled":"disabled"
+int memscrub_scruberror_setup(int blkthres, int runthres, int options)
+	if (priv==NULL){
+	/* Set ETHRES */
+	REG_WRITE(&priv->regs->ethres,
+			((blkthres << ETHRES_BECT_BIT) & ETHRES_BECT) |
+			((runthres << ETHRES_RECT_BIT) & ETHRES_RECT) |
+			(options & (ETHRES_RECTE | ETHRES_BECTE)));
+	DBG("MEMSCRUB scrub err: BLK[%d]:%s, RUN[%d]:%s\n",
+			(unsigned int) blkthres,
+			(options & ETHRES_BECTE)? "enabled":"disabled",
+			(unsigned int) runthres,
+			(options & ETHRES_RECTE)? "enabled":"disabled"
+int memscrub_scrub_position(uint32_t * position)
+	if (priv==NULL){
+	if (position==NULL){
+	*position = REG_READ(&priv->regs->pos);
+int memscrub_isr_register(memscrub_isr_t isr, void * data)
+	unsigned int ethres, ahberc, config;
+	if (priv==NULL){
+	if (isr==NULL){
+	/* Mask interrupts */
+	ethres = REG_READ(&priv->regs->ethres);
+	REG_WRITE(&priv->regs->ethres, ethres & ~(ETHRES_RECTE | ETHRES_BECTE));
+	ahberc = REG_READ(&priv->regs->ahberc);
+	REG_WRITE(&priv->regs->ahberc, ahberc & ~(AHBERC_CECTE | AHBERC_UECTE));
+	config = REG_READ(&priv->regs->config);
+	REG_WRITE(&priv->regs->config, config & ~(CONFIG_IRQD));
+	/* Install IRQ handler if needed */
+	if (priv->isr == NULL){
+		drvmgr_interrupt_register(priv->dev, 0, priv->devname, memscrub_isr,
+				priv);
+	/* Install user ISR */
+	priv->isr=isr;
+	priv->isr_arg=data;
+	/* Unmask interrupts */
+	REG_WRITE(&priv->regs->ethres, ethres);
+	REG_WRITE(&priv->regs->ahberc, ahberc);
+	REG_WRITE(&priv->regs->config, config);
+int memscrub_isr_unregister(void)
+	if (priv==NULL){
+	if (priv->isr==NULL){
+	/* Uninstall IRQ handler if needed */
+	drvmgr_interrupt_unregister(priv->dev, 0, memscrub_isr, priv);
+	/* Uninstall user ISR */
+	priv->isr=NULL;
+	priv->isr_arg=NULL;
+int memscrub_error_status(uint32_t *ahbaccess, uint32_t *ahbstatus,
+	uint32_t mask, ahbstatus_val;
+	if (priv==NULL){
+	if ((ahbaccess==NULL) || (ahbstatus==NULL) || (scrubstatus == NULL)){
+	/* Get hardware status */
+	*ahbaccess = REG_READ(&priv->regs->ahbfailing);
+	*ahbstatus = ahbstatus_val = REG_READ(&priv->regs->ahbstatus);
+	*scrubstatus = REG_READ(&priv->regs->status);
+	/* Clear error status */
+	mask = 0;
+	/* Clear CECNT only if we crossed the CE threshold*/
+	if ((ahbstatus_val & AHBS_CE) == 0){
+		/* Don't clear the CECNT */
+		mask |= AHBS_CECNT;
+	/* Clear UECNT only if we crossed the UE threshold*/
+	if ((ahbstatus_val & (AHBS_NE|AHBS_CE|AHBS_SBC|AHBS_SEC)) != AHBS_NE){
+		/* Don't clear the UECNT */
+		mask |= AHBS_UECNT;
+	REG_WRITE(&priv->regs->ahbstatus, ahbstatus_val & mask);
+	REG_WRITE(&priv->regs->status,0);
+int memscrub_active(void)
+	if (priv==NULL){
+	return REG_READ(&priv->regs->status) & STAT_ACTIVE;
+	struct memscrub_priv *priv = arg;
+	uint32_t fadr, ahbstatus, status, mask;
+	ahbstatus = REG_READ(&priv->regs->ahbstatus);
+	if ((ahbstatus & (AHBS_NE|AHBS_DONE)) == 0){
+		return;
+	/* IRQ generated by MEMSCRUB core... handle it here */
+	/* Get Failing address */
+	fadr = REG_READ(&priv->regs->ahbfailing);
+	/* Get Status */
+	status = REG_READ(&priv->regs->status);
+	mask = 0;
+	if ((ahbstatus & AHBS_CE) == 0){
+	if ((ahbstatus & (AHBS_NE|AHBS_CE|AHBS_SBC|AHBS_SEC)) != AHBS_NE){
+	REG_WRITE(&priv->regs->ahbstatus, ahbstatus & mask);
+	/* Let user handle error */
+	(priv->isr)(priv->isr_arg, fadr, ahbstatus, status);
+	return;
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index fd19139..34fc67e 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -59,6 +59,7 @@ extern void spwcuc_register(void);
 extern void grctm_register(void);
 extern void router_register_drv(void);
 extern void ahbstat_register_drv(void);
 /*** LEON2 AMBA Hard coded bus Drivers ***/
@@ -170,6 +171,9 @@ drvmgr_drv_reg_func drvmgr_drivers[] = {
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_AHBSTAT
 	ahbstat_register_drv,
 #endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_MEMSCRUB
+	memscrub_register_drv,
+#endif
 	/*** LEON2 AMBA Drivers ***/
 #ifdef CONFIGURE_DRIVER_LEON2_AT697PCI
2.7.4
