[PATCH 27/30] leon, gptimer: fixed probing separate interrupts
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:36 UTC 2017
Probing of separate interrupts was done by storing the GPTIMER_CFG_SI bit. But
it was never actually stored since it is bit 8 and the datatype is 8-bit. Now
store the AND result as boolean value instead.
 c/src/lib/libbsp/sparc/shared/timer/gptimer.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/sparc/shared/timer/gptimer.c b/c/src/lib/libbsp/sparc/shared/timer/gptimer.c
index e701211..d26d007 100644
--- a/c/src/lib/libbsp/sparc/shared/timer/gptimer.c
+++ b/c/src/lib/libbsp/sparc/shared/timer/gptimer.c
@@ -293,7 +293,7 @@ int gptimer_init1(struct drvmgr_dev *dev)
 	 *  B. Each Timer have an individual IRQ. The number is:
 	 *        BASE_IRQ + timer_index
-	priv->separate_interrupt = regs->cfg & GPTIMER_CFG_SI;
+	priv->separate_interrupt = !!(regs->cfg & GPTIMER_CFG_SI);
 	return DRVMGR_OK;
2.7.4
