[PATCH 26/30] leon, l4stat: Initial driver commit
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:35 UTC 2017
 c/src/lib/libbsp/sparc/Makefile.am             |   4 +
 c/src/lib/libbsp/sparc/leon2/Makefile.am       |   5 +
 c/src/lib/libbsp/sparc/leon2/preinstall.am     |   4 +
 c/src/lib/libbsp/sparc/leon3/Makefile.am       |   4 +
 c/src/lib/libbsp/sparc/leon3/preinstall.am     |   4 +
 c/src/lib/libbsp/sparc/shared/include/l4stat.h |  91 ++++
 c/src/lib/libbsp/sparc/shared/stat/l4stat.c    | 626 +++++++++++++++++++++++++
 cpukit/libdrvmgr/drvmgr_confdefs.h             |   4 +
 8 files changed, 742 insertions(+)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/l4stat.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/stat/l4stat.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 84056ed..a894f34 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -186,5 +186,9 @@ EXTRA_DIST += shared/include/grtm.h
 EXTRA_DIST += shared/stat/memscrub.c
 EXTRA_DIST += shared/include/memscrub.h
+# L4STAT
+EXTRA_DIST += shared/stat/l4stat.c
+EXTRA_DIST += shared/include/l4stat.h
 include $(top_srcdir)/../../../automake/subdirs.am
 include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 6106f03..94e10cd 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -209,6 +209,11 @@ libbsp_a_SOURCES += ../../sparc/shared/tmtc/grtm.c
 libbsp_a_SOURCES += ../../sparc/shared/scrub/memscrub.c
 include_bsp_HEADERS += ../../sparc/shared/include/memscrub.h
+# L4STAT
+libbsp_a_SOURCES += ../../sparc/shared/stat/l4stat.c
+include_bsp_HEADERS += ../../sparc/shared/include/l4stat.h
 # Driver Manager
 include_drvmgrdir = $(includedir)/drvmgr
 include_drvmgr_HEADERS = ../../sparc/shared/include/drvmgr/ambapp_bus.h
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index eae20e7..19152fe 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -273,6 +273,10 @@ $(PROJECT_INCLUDE)/bsp/memscrub.h: ../../sparc/shared/include/memscrub.h $(PROJE
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/memscrub.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/memscrub.h
+$(PROJECT_INCLUDE)/bsp/l4stat.h: ../../sparc/shared/include/l4stat.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/l4stat.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/l4stat.h
 $(PROJECT_INCLUDE)/drvmgr/$(dirstamp):
 	@$(MKDIR_P) $(PROJECT_INCLUDE)/drvmgr
 	@: > $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index d8db46a..83e1dff 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -243,6 +243,10 @@ libbsp_a_SOURCES += ../../sparc/shared/tmtc/grtm.c
+# L4STAT
 # Driver Manager
 include_drvmgr_HEADERS = ../../sparc/shared/include/drvmgr/ambapp_bus_grlib.h
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index bc709a7..273a52d 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -321,6 +321,10 @@ $(PROJECT_INCLUDE)/bsp/memscrub.h: ../../sparc/shared/include/memscrub.h $(PROJE
diff --git a/c/src/lib/libbsp/sparc/shared/include/l4stat.h b/c/src/lib/libbsp/sparc/shared/include/l4stat.h
new file mode 100644
index 0000000..94fbe4b
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/l4stat.h
@@ -0,0 +1,91 @@
+ * L4STAT APB-Register Driver.
+ * COPYRIGHT (c) 2017.
+ * Cobham Gaisler AB.
+#ifndef __L4STAT_H__
+#define __L4STAT_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define L4STAT_ERR_OK 0
+#define L4STAT_ERR_EINVAL -1
+#define L4STAT_ERR_ERROR -2
+#define L4STAT_ERR_TOOMANY -3
+#define L4STAT_ERR_IMPLEMENTED -4
+/* Register L4STAT driver to Driver Manager */
+void l4stat_register_drv (void);
+extern int l4stat_counter_print(unsigned int counter);
+ * L4STAT CCTRL register fields
+#define CCTRL_NCPU (0xf << CCTRL_NCPU_BIT)
+#define CCTRL_NCNT_L3STAT (0x1ff << CCTRL_NCNT_BIT)
+#define CCTRL_NCNT (0x1f << CCTRL_NCNT_BIT)
+#define CCTRL_MC (0x1 << CCTRL_MC_BIT)
+#define CCTRL_IA (0x1 << CCTRL_IA_BIT)
+#define CCTRL_DS (0x1 << CCTRL_DS_BIT)
+#define CCTRL_EE (0x1 << CCTRL_EE_BIT)
+#define CCTRL_AE (0x1 << CCTRL_AE_BIT)
+#define CCTRL_EL (0x1 << CCTRL_EL_BIT)
+#define CCTRL_CD (0x1 << CCTRL_CD_BIT)
+#define CCTRL_SU (0x3 << CCTRL_SU_BIT)
+#define CCTRL_CL (0x1 << CCTRL_CL_BIT)
+#define CCTRL_EN (0x1 << CCTRL_EN_BIT)
+#define CCTRL_EVENTID (0xff << CCTRL_EVENTID_BIT)
+#define CCTRL_CPUAHBM (0xf << CCTRL_CPUAHBM_BIT)
+#define CCTRL_NCPU_BIT 28
+#define CCTRL_NCNT_BIT 23
+#define CCTRL_MC_BIT 22
+#define CCTRL_IA_BIT 21
+#define CCTRL_DS_BIT 20
+#define CCTRL_EE_BIT 19
+#define CCTRL_AE_BIT 18
+#define CCTRL_EL_BIT 17
+#define CCTRL_CD_BIT 16
+#define CCTRL_SU_BIT 14
+#define CCTRL_CL_BIT 13
+#define CCTRL_EN_BIT 12
+#define CCTRL_EVENTID_BIT 4
+#define CCTRL_CPUAHBM_BIT 0
+#define L4STAT_OPTIONS_EVENT_LEVEL_ENABLE CCTRL_EL
+#define L4STAT_OPTIONS_EVENT_LEVEL_DISABLE 0
+#define L4STAT_OPTIONS_MAXIMUM_DURATION CCTRL_CD
+#define L4STAT_OPTIONS_SUPERVISOR_MODE_FILTER (0x1 << CCTRL_SU_BIT)
+#define L4STAT_OPTIONS_USER_MODE_FILTER (0x2 << CCTRL_SU_BIT)
+#define L4STAT_OPTIONS_NO_FILTER 0
+#define L4STAT_OPTIONS_CLEAR_ON_READ CCTRL_CL
+extern int l4stat_counter_enable(unsigned int counter, int event, int cpu, int options);
+extern int l4stat_counter_disable(unsigned int counter);
+extern int l4stat_counter_set(unsigned int counter, uint32_t val);
+extern int l4stat_counter_get(unsigned int counter, uint32_t *val);
+static inline int l4stat_counter_clear(unsigned int counter)
+	return l4stat_counter_set(counter, 0);
+extern int l4stat_counter_max_set(unsigned int counter, uint32_t val);
+extern int l4stat_counter_max_get(unsigned int counter, uint32_t *val);
+extern int l4stat_tstamp_set(uint32_t val);
+extern int l4stat_tstamp_get(uint32_t *val);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/stat/l4stat.c b/c/src/lib/libbsp/sparc/shared/stat/l4stat.c
index 0000000..a7621fe
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/stat/l4stat.c
@@ -0,0 +1,626 @@
+/* L4STAT APB-Register Driver.
+#include <rtems.h>
+#include <rtems/libio.h>
+#include <stdio.h>
+#include <bsp.h>
+#include <rtems/bspIo.h> /* printk */
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/ambapp_bus.h>
+#include <bsp/l4stat.h>
+/*#define STATIC*/
+#define STATIC static
+/*#define DEBUG 1*/
+#ifdef DEBUG
+#define DBG(x...) printf(x)
+#else
+#define DBG(x...)
+#endif
+#define REG_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+#define REG_READ(addr) (*(volatile unsigned int *)(addr))
+ * DEFINED IN HEADER file
+struct l4stat_regs {
+	unsigned int cval[32];				/* 0x000 */
+	unsigned int cctrl[32];				/* 0x080 */
+	unsigned int cmax[32];				/* 0x100 */
+	unsigned int timestamp;				/* 0x180 */
+struct l4stat_priv {
+	struct drvmgr_dev *dev;
+	/* L4STAT control registers */
+	struct l4stat_regs *regs;
+	/* L4STAT driver register */
+	char devname[9];
+	int ncpu;
+	int ncnt;
+	/* L4stat capabilities */
+	int max_count_support;
+	int internalahb_event_support;
+	int dsu_event_support;
+	int external_event_support;
+	int ahbtrace_event_support;
+STATIC struct l4stat_priv *l4statpriv = NULL;
+/* Event names */
+#ifdef DEBUG
+#define L4STAT_BAD_CMD "N/A. Wrong event"
+STATIC const char *l4stat_event_names[] = {
+	"Instruction cache miss",				/* 0x00 */
+	"Instruction MMU TLB miss",				/* 0x01 */
+	"Instruction cache hold",				/* 0x02 */
+	"Instruction MMU hold",					/* 0x03 */
+	L4STAT_BAD_CMD,						/* 0x04 */
+	L4STAT_BAD_CMD,						/* 0x05 */
+	L4STAT_BAD_CMD,						/* 0x06 */
+	L4STAT_BAD_CMD,						/* 0x07 */
+	"Data cache (read) miss",				/* 0x08 */
+	"Data MMU TLB miss",					/* 0x09 */
+	"Data cache hold",					/* 0x0a */
+	"Data MMU hold",					/* 0x0b */
+	L4STAT_BAD_CMD,						/* 0x0c */
+	L4STAT_BAD_CMD,						/* 0x0d */
+	L4STAT_BAD_CMD,						/* 0x0e */
+	L4STAT_BAD_CMD,						/* 0x0f */
+	"Data write buffer hold",				/* 0x10 */
+	"Total instruction count",				/* 0x11 */
+	"Integer instruction count",				/* 0x12 */
+	"Floating-point unit instruction count",		/* 0x13 */
+	"Branch prediction miss",				/* 0x14 */
+	"Execution time, exluding debug mode",			/* 0x15 */
+	L4STAT_BAD_CMD,						/* 0x16 */
+	"AHB utilization (per AHB master)",			/* 0x17 */
+	"AHB utilization (total)",				/* 0x18 */
+	L4STAT_BAD_CMD,						/* 0x19 */
+	L4STAT_BAD_CMD,						/* 0x1a */
+	L4STAT_BAD_CMD,						/* 0x1b */
+	L4STAT_BAD_CMD,						/* 0x1c */
+	L4STAT_BAD_CMD,						/* 0x1d */
+	L4STAT_BAD_CMD,						/* 0x1e */
+	L4STAT_BAD_CMD,						/* 0x1f */
+	L4STAT_BAD_CMD,						/* 0x20 */
+	L4STAT_BAD_CMD,						/* 0x21 */
+	"Integer branches",					/* 0x22 */
+	L4STAT_BAD_CMD,						/* 0x23 */
+	L4STAT_BAD_CMD,						/* 0x24 */
+	L4STAT_BAD_CMD,						/* 0x25 */
+	L4STAT_BAD_CMD,						/* 0x26 */
+	L4STAT_BAD_CMD,						/* 0x27 */
+	"CALL instructions",					/* 0x28 */
+	L4STAT_BAD_CMD,						/* 0x29 */
+	L4STAT_BAD_CMD,						/* 0x2a */
+	L4STAT_BAD_CMD,						/* 0x2b */
+	L4STAT_BAD_CMD,						/* 0x2c */
+	L4STAT_BAD_CMD,						/* 0x2d */
+	L4STAT_BAD_CMD,						/* 0x2e */
+	L4STAT_BAD_CMD,						/* 0x2f */
+	"Regular type 2 instructions",				/* 0x30 */
+	L4STAT_BAD_CMD,						/* 0x31 */
+	L4STAT_BAD_CMD,						/* 0x32 */
+	L4STAT_BAD_CMD,						/* 0x33 */
+	L4STAT_BAD_CMD,						/* 0x34 */
+	L4STAT_BAD_CMD,						/* 0x35 */
+	L4STAT_BAD_CMD,						/* 0x36 */
+	L4STAT_BAD_CMD,						/* 0x37 */
+	"LOAD and STORE instructions",				/* 0x38 */
+	"LOAD instructions",					/* 0x39 */
+	"STORE instructions",					/* 0x3a */
+	L4STAT_BAD_CMD,						/* 0x3b */
+	L4STAT_BAD_CMD,						/* 0x3c */
+	L4STAT_BAD_CMD,						/* 0x3d */
+	L4STAT_BAD_CMD,						/* 0x3e */
+	L4STAT_BAD_CMD,						/* 0x3f */
+	"AHB IDLE cycles",					/* 0x40 */
+	"AHB BUSY cycles",					/* 0x41 */
+	"AHB Non-Seq. transfers",				/* 0x42 */
+	"AHB Seq. transfers",					/* 0x43 */
+	"AHB read accesses",					/* 0x44 */
+	"AHB write accesses",					/* 0x45 */
+	"AHB byte accesses",					/* 0x46 */
+	"AHB half-word accesses",				/* 0x47 */
+	"AHB word accesses",					/* 0x48 */
+	"AHB double word accesses",				/* 0x49 */
+	"AHB quad word accesses",				/* 0x4A */
+	"AHB eight word accesses",				/* 0x4B */
+	"AHB waitstates",					/* 0x4C */
+	"AHB RETRY responses",					/* 0x4D */
+	"AHB SPLIT responses",					/* 0x4E */
+	"AHB SPLIT delay",					/* 0x4F */
+	"AHB bus locked",					/* 0x50 */
+	L4STAT_BAD_CMD,						/* 0x51 */
+	L4STAT_BAD_CMD,						/* 0x52 */
+	L4STAT_BAD_CMD,						/* 0x53 */
+	L4STAT_BAD_CMD,						/* 0x54 */
+	L4STAT_BAD_CMD,						/* 0x55 */
+	L4STAT_BAD_CMD,						/* 0x56 */
+	L4STAT_BAD_CMD,						/* 0x57 */
+	L4STAT_BAD_CMD,						/* 0x58 */
+	L4STAT_BAD_CMD,						/* 0x59 */
+	L4STAT_BAD_CMD,						/* 0x5a */
+	L4STAT_BAD_CMD,						/* 0x5b */
+	L4STAT_BAD_CMD,						/* 0x5c */
+	L4STAT_BAD_CMD,						/* 0x5d */
+	L4STAT_BAD_CMD,						/* 0x5e */
+	L4STAT_BAD_CMD,						/* 0x5f */
+	"external event 0",					/* 0x60 */
+	"external event 1",					/* 0x61 */
+	"external event 2",					/* 0x62 */
+	"external event 3",					/* 0x63 */
+	"external event 4",					/* 0x64 */
+	"external event 5",					/* 0x65 */
+	"external event 6",					/* 0x66 */
+	"external event 7",					/* 0x67 */
+	"external event 8",					/* 0x68 */
+	"external event 9",					/* 0x69 */
+	"external event 10",					/* 0x6A */
+	"external event 11",					/* 0x6B */
+	"external event 12",					/* 0x6C */
+	"external event 13",					/* 0x6D */
+	"external event 14",					/* 0x6E */
+	"external event 15",					/* 0x6F */
+	"AHB IDLE cycles (2)",					/* 0x70 */
+	"AHB BUSY cycles (2)",					/* 0x71 */
+	"AHB Non-Seq. transfers (2)",				/* 0x72 */
+	"AHB Seq. transfers (2)",				/* 0x73 */
+	"AHB read accesses (2)",				/* 0x74 */
+	"AHB write accesses (2)",				/* 0x75 */
+	"AHB byte accesses (2)",				/* 0x76 */
+	"AHB half-word accesses (2)",				/* 0x77 */
+	"AHB word accesses (2)",				/* 0x78 */
+	"AHB double word accesses (2)",				/* 0x79 */
+	"AHB quad word accesses (2)",				/* 0x7A */
+	"AHB eight word accesses (2)",				/* 0x7B */
+	"AHB waitstates (2)",					/* 0x7C */
+	"AHB RETRY responses (2)",				/* 0x7D */
+	"AHB SPLIT responses (2)",				/* 0x7E */
+	"AHB SPLIT delay (2)",					/* 0x7F */
+	"PMC: master 0 has grant",				/* 0x80 */
+	"PMC: master 1 has grant",				/* 0x81 */
+	"PMC: master 2 has grant",				/* 0x82 */
+	"PMC: master 3 has grant",				/* 0x83 */
+	"PMC: master 4 has grant",				/* 0x84 */
+	"PMC: master 5 has grant",				/* 0x85 */
+	"PMC: master 6 has grant",				/* 0x86 */
+	"PMC: master 7 has grant",				/* 0x87 */
+	"PMC: master 8 has grant",				/* 0x88 */
+	"PMC: master 9 has grant",				/* 0x89 */
+	"PMC: master 10 has grant",				/* 0x8A */
+	"PMC: master 11 has grant",				/* 0x8B */
+	"PMC: master 12 has grant",				/* 0x8C */
+	"PMC: master 13 has grant",				/* 0x8D */
+	"PMC: master 14 has grant",				/* 0x8E */
+	"PMC: master 15 has grant",				/* 0x8F */
+	"PMC: master 0 lacks grant",				/* 0x90 */
+	"PMC: master 1 lacks grant",				/* 0x91 */
+	"PMC: master 2 lacks grant",				/* 0x92 */
+	"PMC: master 3 lacks grant",				/* 0x93 */
+	"PMC: master 4 lacks grant",				/* 0x94 */
+	"PMC: master 5 lacks grant",				/* 0x95 */
+	"PMC: master 6 lacks grant",				/* 0x96 */
+	"PMC: master 7 lacks grant",				/* 0x97 */
+	"PMC: master 8 lacks grant",				/* 0x98 */
+	"PMC: master 9 lacks grant",				/* 0x99 */
+	"PMC: master 10 lacks grant",				/* 0x9A */
+	"PMC: master 11 lacks grant",				/* 0x9B */
+	"PMC: master 12 lacks grant",				/* 0x9C */
+	"PMC: master 13 lacks grant",				/* 0x9D */
+	"PMC: master 14 lacks grant",				/* 0x9E */
+	"PMC: master 15 lacks grant",				/* 0x9F */
+#endif /* DEBUG */
+/* Driver prototypes */
+STATIC int l4stat_init(struct l4stat_priv *priv);
+int l4stat_init1(struct drvmgr_dev *dev);
+struct drvmgr_drv_ops l4stat_ops =
+	.init = {l4stat_init1, NULL, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct amba_dev_id l4stat_ids[] =
+	{VENDOR_GAISLER, GAISLER_L4STAT},
+	{VENDOR_GAISLER, GAISLER_L3STAT},
+	{0, 0}		/* Mark end of table */
+struct amba_drv_info l4stat_drv_info =
+		DRVMGR_OBJ_DRV,			/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_AMBAPP_GAISLER_L4STAT_ID,/* Driver ID */
+		"L4STAT_DRV",			/* Driver Name */
+		DRVMGR_BUS_TYPE_AMBAPP,		/* Bus Type */
+		&l4stat_ops,
+		NULL,				/* Funcs */
+		0,				/* No devices yet */
+		sizeof(struct l4stat_priv),	/* Let DRVMGR allocate for us */
+	&l4stat_ids[0],
+	DBG("Registering L4STAT driver\n");
+	drvmgr_drv_register(&l4stat_drv_info.general);
+	struct ambapp_apb_info *apb;
+	struct amba_dev_info *ainfo = priv->dev->businfo;
+	unsigned int tmp;
+	unsigned short dev_id;
+	/* Find L4STAT core from Plug&Play information */
+	apb = ainfo->info.apb_slv;
+	/* Check if L4STAT or L3STAT core from Plug&Play information */
+	dev_id = ainfo->id.device;
+	/* Check if rev 1 of core (only rev 0 supported) */
+	if (apb->ver != 0) {
+		DBG("L4STAT rev 0 only supported.\n");
+		return L4STAT_ERR_ERROR;
+	/* Found L4STAT core, init private structure */
+	priv->regs = (struct l4stat_regs *)apb->start;
+	DBG("L4STAT regs 0x%08x\n", (unsigned int) priv->regs);
+	/* Find L4STAT capabilities */
+	tmp = REG_READ(&priv->regs->cctrl[0]);
+	/* The CPU field in the register is just information of the
+	 * cpus that are connected to the stat unit, but it is not
+	 * really used for anything else. I can still have more masters
+	 * on the bus (e.g. IOMMU) that I can collect stats from,
+	 * so it makes no sense to limit the cpus to the actual cpus.
+	 * Therefore, I will take the maximum number as 16. */
+	/*priv->ncpu = ((tmp & CCTRL_NCPU) >> CCTRL_NCPU_BIT) + 1;*/
+	priv->ncpu = 16;
+	if (dev_id == GAISLER_L3STAT) {
+		priv->ncnt = ((tmp & CCTRL_NCNT_L3STAT) >> CCTRL_NCNT_BIT) + 1;
+	}else{
+		priv->ncnt = ((tmp & CCTRL_NCNT) >> CCTRL_NCNT_BIT) + 1;
+	priv->max_count_support = (tmp & CCTRL_MC) >> CCTRL_MC_BIT;
+	priv->internalahb_event_support = (tmp & CCTRL_IA) >> CCTRL_IA_BIT;
+	priv->dsu_event_support = (tmp & CCTRL_DS) >> CCTRL_DS_BIT;
+	priv->external_event_support = (tmp & CCTRL_EE) >> CCTRL_EE_BIT;
+	priv->ahbtrace_event_support = (tmp & CCTRL_AE) >> CCTRL_AE_BIT;
+	/* DEBUG print */
+	DBG("L4STAT with following capabilities:\n");
+	DBG(" -NCPU: %d, NCNT: %d, MaxCNT: %s\n", priv->ncpu, priv->ncnt,
+			(priv->max_count_support?"Available":"N/A"));
+	DBG(" -Events= InternalAHB: %s, DSU: %s, External: %s, AHBTRACE: %s\n",
+			(priv->internalahb_event_support?"Available":"N/A"),
+			(priv->dsu_event_support?"Available":"N/A"),
+			(priv->external_event_support?"Available":"N/A"),
+			(priv->ahbtrace_event_support?"Available":"N/A"));
+	return L4STAT_ERR_OK;
+	struct l4stat_priv *priv = dev->priv;
+	DBG("L4STAT[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
+	if (l4statpriv) {
+		DBG("Driver only supports one L4STAT core\n");
+		return DRVMGR_FAIL;
+	if (priv == NULL) {
+		return DRVMGR_NOMEM;
+	priv->dev = dev;
+	l4statpriv = priv;
+	/* Initilize driver struct */
+	if (l4stat_init(priv) != L4STAT_ERR_OK) {
+	/* Startup Action:
+	 *	- None
+	/* Device name */
+	sprintf(priv->devname, "l4stat0");
+	return DRVMGR_OK;
+int l4stat_counter_enable(unsigned int counter, int event, int cpu, int options)
+	struct l4stat_priv *priv = l4statpriv;
+	unsigned int ctrl;
+		DBG("L4STAT Device not initialized\n");
+		return L4STAT_ERR_EINVAL;
+	if (counter >= priv->ncnt) {
+		DBG("L4STAT Wrong counter\n");
+	if ((cpu < 0) || (cpu >= priv->ncpu)) {
+		DBG("L4STAT Wrong cpu\n");
+	if ((options & L4STAT_OPTIONS_MAXIMUM_DURATION) ||
+			(options & L4STAT_OPTIONS_EVENT_LEVEL_ENABLE)) {
+		if (priv->max_count_support == 0) {
+			DBG("L4STAT maximum duration count not supported\n");
+			return L4STAT_ERR_IMPLEMENTED;
+	/* Check event is supported */
+	if ((event < 0) || (event >= 0x80)) {
+		DBG("L4STAT Wrong event\n");
+	if ((event == 0x18) || (event == 0x17)) {
+		if (priv->internalahb_event_support == 0) {
+			DBG("L4STAT internal ahb event not supported\n");
+	if ((event >= 0x40) && (event < 0x60)) {
+		if (priv->dsu_event_support == 0) {
+			DBG("L4STAT dsu event not supported\n");
+	if ((event >= 0x60) && (event < 0x70)) {
+		if (priv->external_event_support == 0) {
+			DBG("L4STAT external event not supported\n");
+	if ((event >= 0x70) && (event < 0x80)) {
+		if (priv->ahbtrace_event_support == 0) {
+			DBG("L4STAT ahbtrace event not supported\n");
+	/* Prepare counter control */
+	ctrl = (options & ~(CCTRL_EVENTID | CCTRL_CPUAHBM));
+	/* Put event id */
+	ctrl = (ctrl | ((event << CCTRL_EVENTID_BIT) & CCTRL_EVENTID));
+	/* Put cpu id */
+	ctrl = (ctrl | ((cpu << CCTRL_CPUAHBM_BIT) & CCTRL_CPUAHBM));
+	/* Enable counter */
+	ctrl = (ctrl | CCTRL_EN);
+	REG_WRITE(&priv->regs->cctrl[counter], ctrl);
+	/* DEBUG print */
+	DBG("L4STAT COUNTER[%d] enabled with event: %s, cpu: %d\n", counter,
+			l4stat_event_names[event],cpu);
+int l4stat_counter_disable(unsigned int counter)
+	/* Disable counter */
+	REG_WRITE(&priv->regs->cctrl[counter], 0);
+	/* DEBUG print */
+	DBG("L4STAT COUNTER[%d] disabled\n", counter);
+int l4stat_counter_get(unsigned int counter, uint32_t * val)
+	if (val == NULL) {
+		DBG("L4STAT Wrong pointer\n");
+	*val = REG_READ(&priv->regs->cval[counter]);
+int l4stat_counter_set(unsigned int counter, uint32_t val)
+	REG_WRITE(&priv->regs->cval[counter],val);
+int l4stat_counter_max_get(unsigned int counter, uint32_t * val)
+	*val = REG_READ(&priv->regs->cmax[counter]);
+int l4stat_counter_max_set(unsigned int counter, uint32_t val)
+	REG_WRITE(&priv->regs->cmax[counter],val);
+int l4stat_tstamp_get(uint32_t * val)
+	*val = REG_READ(&priv->regs->timestamp);
+int l4stat_tstamp_set(uint32_t val)
+	REG_WRITE(&priv->regs->timestamp,val);
+int l4stat_counter_print(unsigned int counter)
+#ifdef DEBUG
+	unsigned int val;
+	unsigned int event;
+	/* Get counter val*/
+	val = REG_READ(&priv->regs->cval[counter]);
+	/* Get counter info*/
+	ctrl = REG_READ(&priv->regs->cctrl[counter]);
+	if ((ctrl & CCTRL_EN) == 0) {
+	event = (ctrl & CCTRL_EVENTID) >> CCTRL_EVENTID_BIT;
+	/* DEBUG print */
+	DBG("L4STAT COUNTER[%d], Event: %s, Count: %d [0x%08x]\n",
+		counter, l4stat_event_names[event],val,val);
+#endif /* DEBUG */
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index 34fc67e..82829bd 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -60,6 +60,7 @@ extern void grctm_register(void);
 extern void router_register_drv(void);
 extern void ahbstat_register_drv(void);
 extern void memscrub_register_drv(void);
+extern void l4stat_register_drv(void);
 /*** LEON2 AMBA Hard coded bus Drivers ***/
@@ -174,6 +175,9 @@ drvmgr_drv_reg_func drvmgr_drivers[] = {
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_MEMSCRUB
 	memscrub_register_drv,
 #endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_L4STAT
+	l4stat_register_drv,
+#endif
 	/*** LEON2 AMBA Drivers ***/
 #ifdef CONFIGURE_DRIVER_LEON2_AT697PCI
2.7.4
