[PATCH] cpukit: Return RTEMS_INVALID_MODE if the rtems_task_create mode is invalid.
Chris Johns
chrisj at rtems.org
Wed Apr 19 03:35:57 UTC 2017
The mode's RTEMS_NO_PREEMPT and RTEMS_INTERRUPT_LEVEL(n) are not valid
with SMP. This change reports the error as RTEMS_INVALID_MODE rather
than RTEMS_UNSATISFIED.
Closes #3000.
cpukit/rtems/include/rtems/rtems/status.h | 8 ++++++--
cpukit/rtems/src/status.c | 3 ++-
cpukit/rtems/src/statustext.c | 3 ++-
cpukit/rtems/src/taskcreate.c | 20 ++++++++++++++++++--
cpukit/score/src/threadinitialize.c | 9 ++-------
5 files changed, 30 insertions(+), 13 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/status.h b/cpukit/rtems/include/rtems/rtems/status.h
index c54404ba14..cc22d8e574 100644
--- a/cpukit/rtems/include/rtems/rtems/status.h
+++ b/cpukit/rtems/include/rtems/rtems/status.h
@@ -177,7 +177,11 @@ typedef enum {
* @note This status will @b NOT be returned to the user.
- RTEMS_PROXY_BLOCKING = 28
+ RTEMS_PROXY_BLOCKING = 28,
+ * This is the status to indicate the mode is invalid.
+ RTEMS_INVALID_MODE = 29
} rtems_status_code;
@@ -188,7 +192,7 @@ typedef enum {
* This is the highest valid value for a Classic API status code.
-#define RTEMS_STATUS_CODES_LAST RTEMS_PROXY_BLOCKING
+#define RTEMS_STATUS_CODES_LAST RTEMS_INVALID_MODE
* @brief Checks if the status code is equal to RTEMS_SUCCESSFUL.
diff --git a/cpukit/rtems/src/status.c b/cpukit/rtems/src/status.c
index 810c0e18de..c0015a9345 100644
--- a/cpukit/rtems/src/status.c
+++ b/cpukit/rtems/src/status.c
@@ -58,7 +58,8 @@ static const int status_code_to_errno [RTEMS_STATUS_CODES_LAST + 1] = {
[RTEMS_INTERNAL_ERROR] = EIO,
[RTEMS_NO_MEMORY] = ENOMEM,
[RTEMS_IO_ERROR] = EIO,
- [RTEMS_PROXY_BLOCKING] = EIO
+ [RTEMS_PROXY_BLOCKING] = EIO,
+ [RTEMS_INVALID_MODE] = EINVAL
int rtems_status_code_to_errno(rtems_status_code sc)
diff --git a/cpukit/rtems/src/statustext.c b/cpukit/rtems/src/statustext.c
index f701ebd356..2f5ea59854 100644
--- a/cpukit/rtems/src/statustext.c
+++ b/cpukit/rtems/src/statustext.c
@@ -53,7 +53,8 @@ static const char *const status_code_text[] = {
"RTEMS_INTERNAL_ERROR",
"RTEMS_NO_MEMORY",
"RTEMS_IO_ERROR",
- "RTEMS_PROXY_BLOCKING"
+ "RTEMS_PROXY_BLOCKING",
+ "RTEMS_INVALID_MODE"
const char *rtems_status_text( rtems_status_code code )
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index 26953828e9..d63e1c11e2 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -49,6 +49,8 @@ rtems_status_code rtems_task_create(
Priority_Control priority;
RTEMS_API_Control *api;
ASR_Information *asr;
+ bool is_preemptible;
+ uint32_t isr_level;
if ( !id )
@@ -138,6 +140,20 @@ rtems_status_code rtems_task_create(
#endif
+ * Setting the mode to non-preemptible and/or the ISR level is not allowed
+ * with SMP. It provides no protection to any data because the setting is
+ * specific to only one core.
+ is_preemptible = _Modes_Is_preempt(initial_modes) ? true : false;
+ isr_level = _Modes_Get_interrupt_level(initial_modes);
+#if defined( RTEMS_SMP )
+ if ( rtems_configuration_is_smp_enabled() ) {
+ if ( !is_preemptible || isr_level != 0 )
+ return RTEMS_INVALID_MODE;
+#endif
* Initialize the core thread for this task.
@@ -149,12 +165,12 @@ rtems_status_code rtems_task_create(
stack_size,
is_fp,
priority,
- _Modes_Is_preempt(initial_modes) ? true : false,
+ is_preemptible,
_Modes_Is_timeslice(initial_modes) ?
THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE :
THREAD_CPU_BUDGET_ALGORITHM_NONE,
NULL, /* no budget algorithm callout */
- _Modes_Get_interrupt_level(initial_modes),
+ isr_level,
(Objects_Name) name
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index c34113db3d..2a76035e69 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -61,13 +61,8 @@ bool _Thread_Initialize(
- if ( !is_preemptible ) {
- return false;
- if ( isr_level != 0 ) {
- return false;
+ _Assert( is_preemptible );
+ _Assert( isr_level == 0 );
#endif
2.11.0
