[rtems commit] dhrystone/dhry_1.c: Fix may be used uninitialized warning
Gedare Bloom
gedare at rtems.org
Wed Apr 26 00:04:30 UTC 2017
On Mon, Apr 24, 2017 at 6:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: 906e67fe88658122d515a5dcc0570ee56a02877d
> Changeset: http://git.rtems.org/rtems/commit/?id=906e67fe88658122d515a5dcc0570ee56a02877d
> Author: Joel Sherrill <joel at rtems.org>
> Date: Sun Apr 23 11:50:46 2017 -0500
> testsuites/benchmarks/dhrystone/dhry_1.c | 5 +++++
> 1 file changed, 5 insertions(+)
> diff --git a/testsuites/benchmarks/dhrystone/dhry_1.c b/testsuites/benchmarks/dhrystone/dhry_1.c
> index 36ac303..9b64d3a 100644
> --- a/testsuites/benchmarks/dhrystone/dhry_1.c
> +++ b/testsuites/benchmarks/dhrystone/dhry_1.c
> @@ -143,6 +143,11 @@ execution_start:
> Begin_Time = time ( (long *) 0);
> #endif
> +#ifdef __rtems__
> + /* avoid used uninitialized warning */
> + Int_2_Loc = 0;
> +#endif
This looks like unnecessarily catering to the compiler. At any rate,
this kind of change should be located before the call to the timer,
since it maybe perturbs the benchmark timing.
> for (Run_Index = 1; Run_Index <= Number_Of_Runs; ++Run_Index)
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
