Warning Report on Master
Chris Johns
chrisj at rtems.org
Sun Apr 30 22:36:48 UTC 2017
On 26/04/2017 09:18, Joel Sherrill wrote:
> This is the latest warnings report for the master. This is
> the first report in a LONG time where nearly all BSPs
> were warning free.
> Note that it ignores issues in code associated with the
> old network stack. Now that the status is pretty good,
> nibbling at those is a reasonable step.
> ftp://ftp.rtems.org/pub/rtems/people/joel/warnings/warnings-4.12-master-20170425c
I have attached a warnings report from the `rtems-bsp-builder` for
tier-1 and a smp-debug build on Debian. There are 2 failures:
Failures:
1 smp-debug i386/pc686 build:
configure: /opt/work/chris/rtems/kernel/rtems.git/configure\
--target=i386-rtems4.12 --enable-rtemsbsp=pc686\
--prefix=/opt/rtems/4.12 --enable-debug --enable-smp --enable-tests\
BSP_PRINT_EXCEPTION_CONTEXT=1
error: pc686/lib/include/rtems/score/percpu.h:373:23 error: variable
or field 'Interrupt_frame' declared void
2 smp-debug sparc/leon3 build:
configure: /opt/work/chris/rtems/kernel/rtems.git/configure --target\
=sparc-rtems4.12 --enable-rtemsbsp=leon3 --prefix=/opt/rtems/4.12\
error: c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c:61:2 error:
#error SMP mode not compatible with these interrupt lock primitives
RTEMS Tools Project - RTEMS Kernel BSP Builder, 4.12.not_released
Date: Sat Apr 29 01:01:32 2017
command: /opt/local/rtems/4.12/bin/rtems-bsp-builder --rtems-\
tools=/opt/local/rtems/4.12\
--rtems=/opt/work/chris/rtems/kernel/rtems.git --build=smp-debug\
--log=x --warnings-report=deb-smp-debug.txt
| By Architecture (total : 951) |
| common : 73 warning(s) |
| Shared : 0 | BSP : 0 | Network : 80 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 0 | | |
| 6 | c/src/libchip/network/cs8900.c:150:5 |
| 4 | cpukit/librpc/src/rpc/get_myaddress.c:130:5 |
| 4 | cpukit/libnetworking/net/if_ppp.c:230:9 |
| 4 | cpukit/libnetworking/net/if_ppp.c:228:9 |
| 3 | c/src/libchip/serial/z85c30.c:318:3 |
| 3 | c/src/libchip/serial/z85c30_reg.c:40:3 |
| 3 | c/src/libchip/network/cs8900.c:58:3 |
| 3 | c/src/libchip/serial/mc68681.c:171:3 |
| 3 | c/src/libchip/flash/am29lv160.c:240:5 |
| 3 | c/src/libchip/network/cs8900.c:164:5 |
| 3 | c/src/libchip/network/sonic.c:265:3 |
| 3 | c/src/libchip/rtc/mc146818a.c:102:3 |
| 2 | cpukit/libnetworking/libc/getservbyport.c:52:4 |
| 2 | c/src/libchip/rtc/mc146818a.c:130:3 |
| 2 | cpukit/libnetworking/netinet/tcp_usrreq.c:106:16 |
| 2 | cpukit/libnetworking/netinet/tcp_output.c:393:4 |
| 2 | cpukit/libnetworking/libc/getservbyname.c:52:4 |
| 2 | cpukit/librpc/src/rpc/rpc_prot.c:215:2 |
| 2 | cpukit/librpc/src/rpc/get_myaddress.c:80:1 |
| 2 | cpukit/librpc/src/rpc/rpc_prot.c:255:2 |
| 2 | c/src/libchip/flash/am29lv160.c:245:5 |
| 2 | c/src/libchip/serial/mc68681.c:181:3 |
| 2 | cpukit/librpc/src/rpc/rpcdname.c:78:1 |
| 2 | cpukit/libnetworking/libc/res_update.c:90:12 |
| 2 | c/src/libchip/network/cs8900.c:62:3 |
| 2 | cpukit/libnetworking/netinet/tcp_output.c:408:4 |
| 2 | cpukit/libnetworking/netinet/tcp_output.c:422:5 |
| 2 | cpukit/librpc/src/rpc/getrpcport.c:52:1 |
| 2 | c/src/libchip/serial/z85c30_reg.c:46:3 |
| 2 | c/src/libchip/serial/z85c30.c:325:3 |
| 2 | cpukit/libnetworking/netinet/tcp_usrreq.c:497:16 |
| 2 | cpukit/libnetworking/net/if_ppp.c:563:5 |
| 2 | cpukit/librpc/src/rpc/rpc_prot.c:105:1 |
| 2 | c/src/libchip/network/sonic.c:271:3 |
| 2 | cpukit/libnetworking/lib/getprotoby.c:37:1 |
| 2 | cpukit/librpc/src/rpc/auth_unix.c:102:1 |
| 2 | cpukit/librpc/src/rpc/rpc_dtablesize.c:55:1 |
| 2 | cpukit/libnetworking/lib/getprotoby.c:22:1 |
| 2 | cpukit/librpc/src/rpc/svc_simple.c:71:1 |
| 2 | cpukit/libnetworking/netinet/tcp_output.c:429:5 |
| 2 | cpukit/libnetworking/netinet/tcp_usrreq.c:182:16 |
| 2 | cpukit/librpc/src/rpc/clnt_simple.c:65:1 |
| 2 | cpukit/librpc/src/rpc/rpc_prot.c:138:1 |
| 2 | cpukit/libnetworking/net/if_ppp.c:245:7 |
| 2 | cpukit/librpc/src/rpc/rpc_prot.c:115:2 |
| 2 | c/src/libchip/rtc/mc146818a.c:104:7 |
| 2 | cpukit/librpc/src/rpc/svc_udp.c:346:5 |
| 2 | cpukit/librpc/src/rpc/svc_auth_unix.c:59:1 |
| 2 | cpukit/libnetworking/netinet/tcp_usrreq.c:292:16 |
| 2 | cpukit/librpc/src/rpc/svc_auth_unix.c:147:1 |
| 2 | cpukit/libnetworking/libc/gethostnamadr.c:169:4 |
| 2 | cpukit/librpc/src/rpc/rtime.c:75:1 |
| 2 | cpukit/libnetworking/netinet/tcp_usrreq.c:484:16 |
| 2 | cpukit/librpc/src/rpc/rpc_prot.c:146:2 |
| 2 | c/src/libchip/network/cs8900.c:613:5 |
| 1 | c/src/libchip/network/cs8900.c:105:3 |
| 1 | c/src/libchip/flash/am29lv160.c:277:5 |
| 1 | c/src/libchip/serial/mc68681.c:299:3 |
| 1 | c/src/libchip/network/cs8900.c:704:7 |
| 1 | c/src/libchip/network/sonic.c:282:3 |
| 1 | c/src/libchip/network/cs8900.c:71:3 |
| 1 | c/src/libchip/network/cs8900.c:114:3 |
| 1 | c/src/libchip/serial/z85c30.c:410:3 |
| 1 | c/src/libchip/serial/mc68681.c:471:3 |
| 1 | c/src/libchip/serial/z85c30.c:381:3 |
| 1 | c/src/libchip/network/cs8900.c:85:3 |
| 1 | c/src/libchip/serial/z85c30.c:508:3 |
| 1 | c/src/libchip/serial/z85c30.c:779:3 |
| 1 | c/src/libchip/serial/z85c30_reg.c:66:3 |
| 1 | c/src/libchip/network/sonic.c:312:3 |
| 1 | c/src/libchip/flash/am29lv160.c:381:7 |
| 1 | c/src/libchip/network/sonic.c:299:3 |
| 1 | c/src/libchip/serial/z85c30.c:347:3 |
| arm : 1 warning(s) |
| Shared : 0 | BSP : 0 | Network : 205 | Tests : 0 |
| 5 | cpukit/libnetworking/netinet/in_cksum.c:84:1 |
| sparc : 96 warning(s) |
| Shared : 258 | BSP : 0 | Network : 80 | Tests : 0 |
| 16 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:33:36 |
| 12 | c/src/lib/libbsp/sparc/shared/can/grcan.c:49:36 |
| 10 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:30:36 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:691:2 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:695:2 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:416:2 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:494:2 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:50 |
| |1:2 |
| 6 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:31:36 |
| 6 | c/src/lib/libbsp/sparc/shared/spw/grspw.c:1846:2 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:605:2 |
| 6 | c/src/lib/libbsp/sparc/shared/can/occan.c:1291:3 |
| 6 | c/src/lib/libbsp/sparc/shared/irq/genirq.c:103:2 |
| 6 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:50:36 |
| 4 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:426:3 |
| 4 | c/src/lib/libbsp/sparc/shared/irq/genirq.c:111:2 |
| 4 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:504:3 |
| 4 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:701:3 |
| 4 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:705:3 |
| 4 | c/src/lib/libbsp/sparc/shared/spw/grspw.c:1859:2 |
| 4 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:51 |
| |1:3 |
| 4 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:615:3 |
| 4 | c/src/lib/libbsp/sparc/shared/can/occan.c:1295:4 |
| 4 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:37:35 |
| 3 | c/src/lib/libbsp/sparc/shared/net/greth.c:756:21 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c:400:2 |
| 3 | c/src/lib/libbsp/sparc/shared/uart/apbuart.c:571:2 |
| 3 | c/src/lib/libbsp/sparc/shared/tmtc/grtc.c:31:36 |
| 3 | c/src/lib/libbsp/sparc/shared/tmtc/grtm.c:31:36 |
| 3 | c/src/libchip/network/greth.c:653:21 |
| 3 | c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c:630:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:761:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:34:35 |
| 2 | c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c:652:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:581:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:452:2 |
| 2 | c/src/lib/libbsp/sparc/shared/spw/grspw.c:1968:2 |
| 2 | c/src/lib/libbsp/sparc/shared/irq/genirq.c:153:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:641:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:727:2 |
| 2 | c/src/lib/libbsp/sparc/shared/can/grcan.c:483:3 |
| 2 | c/src/lib/libbsp/sparc/shared/can/grcan.c:487:3 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c:411:3 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:559:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:1389:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:783:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:53 |
| |7:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:355:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:503:2 |
| 2 | c/src/lib/libbsp/sparc/shared/can/grcan.c:53:35 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:731:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:58 |
| |8:2 |
| 2 | c/src/lib/libbsp/sparc/shared/can/occan.c:1392:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:1368:2 |
| 2 | c/src/libchip/network/greth.c:655:21 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:106:2 |
| 2 | c/src/lib/libbsp/sparc/shared/uart/apbuart.c:582:4 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:54:35 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:35:35 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:530:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:756:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:86:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:481:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:778:2 |
| 2 | c/src/lib/libbsp/sparc/shared/net/greth.c:758:21 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:692:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:332:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:361:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:670:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:357:2 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:56 |
| |6:2 |
| 1 | c/src/lib/libbsp/sparc/shared/net/greth.c:836:13 |
| 1 | c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c:54:36 |
| 1 | c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c:56:38 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c:467:2 |
| 1 | c/src/libchip/network/greth.c:732:13 |
| 1 | c/src/libchip/network/greth.c:904:17 |
| 1 | c/src/libchip/network/greth.c:841:9 |
| 1 | c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c:739:2 |
| 1 | c/src/lib/libbsp/sparc/shared/tmtc/grtm.c:35:35 |
| 1 | c/src/libchip/network/greth.c:970:17 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c:437:2 |
| 1 | c/src/lib/libbsp/sparc/shared/net/greth.c:1079:17 |
| 1 | c/src/lib/libbsp/sparc/shared/net/greth.c:950:9 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c:489:2 |
| 1 | c/src/lib/libbsp/sparc/shared/tmtc/grtm.c:1179:4 |
| 1 | c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c:698:2 |
| 1 | c/src/lib/libbsp/sparc/shared/tmtc/grtc.c:744:3 |
| 1 | c/src/lib/libbsp/sparc/shared/tmtc/grtm.c:1169:4 |
| 1 | c/src/libchip/network/smc91111.c:1237:8 |
| 1 | c/src/lib/libbsp/sparc/shared/tmtc/grtc.c:732:2 |
| 1 | c/src/libchip/network/smc91111.c:1048:12 |
| 1 | c/src/libchip/network/smc91111.c:442:16 |
| 1 | c/src/lib/libbsp/sparc/shared/net/greth.c:1013:17 |
| 1 | c/src/lib/libbsp/sparc/shared/tmtc/grtc.c:35:35 |
| 1 | c/src/lib/libbsp/sparc/shared/uart/apbuart.c:625:2 |
| By BSP (total : 951) |
| common : 133 warning(s) |
| Shared : 107 | BSP : 0 | Network : 244 | Tests : 0 |
| 8 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:33:36 |
| 6 | c/src/lib/libbsp/sparc/shared/can/grcan.c:49:36 |
| 5 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:30:36 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:605:2 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:691:2 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:695:2 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:416:2 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:494:2 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:50 |
| |1:2 |
| 3 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:31:36 |
| 3 | c/src/lib/libbsp/sparc/shared/spw/grspw.c:1846:2 |
| 3 | c/src/lib/libbsp/sparc/shared/can/occan.c:1291:3 |
| 3 | c/src/lib/libbsp/sparc/shared/irq/genirq.c:103:2 |
| 3 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:50:36 |
| 2 | cpukit/librpc/src/rpc/get_myaddress.c:130:5 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:426:3 |
| 2 | c/src/lib/libbsp/sparc/shared/can/occan.c:1295:4 |
| 2 | c/src/lib/libbsp/sparc/shared/irq/genirq.c:111:2 |
| 2 | cpukit/libnetworking/net/if_ppp.c:230:9 |
| 2 | cpukit/libnetworking/net/if_ppp.c:228:9 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:504:3 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:701:3 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:705:3 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:51 |
| |1:3 |
| 2 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:615:3 |
| 2 | c/src/lib/libbsp/sparc/shared/spw/grspw.c:1859:2 |
| 2 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:37:35 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:761:2 |
| 1 | cpukit/librpc/src/rpc/svc_auth_unix.c:59:1 |
| 1 | cpukit/librpc/src/rpc/get_myaddress.c:80:1 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:34:35 |
| 1 | cpukit/libnetworking/libc/res_update.c:90:12 |
| 1 | cpukit/libnetworking/netinet/tcp_output.c:408:4 |
| 1 | cpukit/libnetworking/net/if_ppp.c:563:5 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:452:2 |
| 1 | c/src/lib/libbsp/sparc/shared/spw/grspw.c:1968:2 |
| 1 | cpukit/libnetworking/netinet/tcp_output.c:429:5 |
| 1 | c/src/lib/libbsp/sparc/shared/irq/genirq.c:153:2 |
| 1 | cpukit/libnetworking/net/if_ppp.c:245:7 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:641:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:56 |
| |6:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:727:2 |
| 1 | c/src/lib/libbsp/sparc/shared/can/grcan.c:483:3 |
| 1 | c/src/lib/libbsp/sparc/shared/can/grcan.c:487:3 |
| 1 | cpukit/libnetworking/netinet/tcp_output.c:393:4 |
| 1 | cpukit/libnetworking/libc/getservbyname.c:52:4 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:559:2 |
| 1 | cpukit/librpc/src/rpc/rpc_prot.c:215:2 |
| 1 | cpukit/librpc/src/rpc/rpc_prot.c:255:2 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:1389:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:783:2 |
| 1 | cpukit/libnetworking/lib/getprotoby.c:37:1 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:86:2 |
| 1 | cpukit/libnetworking/lib/getprotoby.c:22:1 |
| 1 | cpukit/librpc/src/rpc/svc_simple.c:71:1 |
| 1 | cpukit/librpc/src/rpc/clnt_simple.c:65:1 |
| 1 | cpukit/librpc/src/rpc/rpc_prot.c:138:1 |
| 1 | cpukit/librpc/src/rpc/rpc_prot.c:115:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c:731:2 |
| 1 | cpukit/librpc/src/rpc/svc_udp.c:346:5 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:58 |
| |8:2 |
| 1 | cpukit/libnetworking/netinet/tcp_usrreq.c:292:16 |
| 1 | c/src/lib/libbsp/sparc/shared/can/occan.c:1392:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:355:2 |
| 1 | cpukit/libnetworking/netinet/tcp_usrreq.c:484:16 |
| 1 | cpukit/librpc/src/rpc/rpc_prot.c:146:2 |
| 1 | cpukit/libnetworking/libc/getservbyport.c:52:4 |
| 1 | cpukit/libnetworking/netinet/tcp_usrreq.c:106:16 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c:1368:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:503:2 |
| 1 | cpukit/librpc/src/rpc/getrpcport.c:52:1 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:106:2 |
| 1 | cpukit/librpc/src/rpc/auth_unix.c:102:1 |
| 1 | c/src/lib/libbsp/sparc/shared/can/grcan.c:53:35 |
| 1 | cpukit/librpc/src/rpc/rpc_dtablesize.c:55:1 |
| 1 | cpukit/libnetworking/netinet/tcp_usrreq.c:182:16 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:54:35 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:581:2 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c:35:35 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c:530:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:756:2 |
| 1 | cpukit/librpc/src/rpc/rtime.c:75:1 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:53 |
| |7:2 |
| 1 | cpukit/librpc/src/rpc/rpcdname.c:78:1 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_701.c:481:2 |
| 1 | cpukit/libnetworking/netinet/tcp_output.c:422:5 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c:778:2 |
| 1 | cpukit/libnetworking/netinet/tcp_usrreq.c:497:16 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:692:2 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/grpci2.c:332:2 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:361:2 |
| 1 | cpukit/librpc/src/rpc/rpc_prot.c:105:1 |
| 1 | cpukit/librpc/src/rpc/svc_auth_unix.c:147:1 |
| 1 | c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c:670:2 |
| 1 | cpukit/libnetworking/libc/gethostnamadr.c:169:4 |
| 1 | c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c:357:2 |
| 1 | cpukit/libnetworking/netinet/in_cksum.c:84:1 |
| arm/altcycv_devkit : 0 warning(s) |
| arm/altcycv_devkit_smp : 0 warning(s) |
| arm/xilinx_zynq_zc702 : 0 warning(s) |
| arm/xilinx_zynq_zc706 : 0 warning(s) |
| arm/xilinx_zynq_zedboard : 0 warning(s) |
| sparc/leon2 : 26 warning(s) |
| Shared : 134 | BSP : 0 | Network : 40 | Tests : 0 |
| sparc/leon3 : 11 warning(s) |
| Shared : 124 | BSP : 0 | Network : 40 | Tests : 0 |
| By Build (total : 951) |
| common : 0 warning(s) |
| smp-debug : 170 warning(s) |
| Shared : 258 | BSP : 0 | Network : 285 | Tests : 0 |
| 36 | c/src/libchip/network/cs8900.c:150:5 |
| 18 | c/src/libchip/serial/z85c30.c:318:3 |
| 18 | c/src/libchip/serial/z85c30_reg.c:40:3 |
| 18 | c/src/libchip/rtc/mc146818a.c:102:3 |
| 18 | c/src/libchip/network/cs8900.c:58:3 |
| 18 | c/src/libchip/serial/mc68681.c:171:3 |
| 18 | c/src/libchip/flash/am29lv160.c:240:5 |
| 18 | c/src/libchip/network/cs8900.c:164:5 |
| 18 | c/src/libchip/network/sonic.c:265:3 |
| 14 | cpukit/librpc/src/rpc/get_myaddress.c:130:5 |
| 14 | cpukit/libnetworking/net/if_ppp.c:230:9 |
| 14 | cpukit/libnetworking/net/if_ppp.c:228:9 |
| 12 | c/src/libchip/network/cs8900.c:613:5 |
| 12 | c/src/libchip/serial/z85c30_reg.c:46:3 |
| 12 | c/src/libchip/rtc/mc146818a.c:104:7 |
| 12 | c/src/libchip/rtc/mc146818a.c:130:3 |
| 12 | c/src/libchip/network/cs8900.c:62:3 |
| 12 | c/src/libchip/flash/am29lv160.c:245:5 |
| 12 | c/src/libchip/network/sonic.c:271:3 |
| 12 | c/src/libchip/serial/mc68681.c:181:3 |
| 12 | c/src/libchip/serial/z85c30.c:325:3 |
| 7 | cpukit/librpc/src/rpc/svc_auth_unix.c:59:1 |
| 7 | cpukit/librpc/src/rpc/get_myaddress.c:80:1 |
| 7 | cpukit/libnetworking/libc/res_update.c:90:12 |
| 7 | cpukit/libnetworking/netinet/tcp_output.c:408:4 |
| 7 | cpukit/libnetworking/net/if_ppp.c:563:5 |
| 7 | cpukit/libnetworking/netinet/tcp_output.c:429:5 |
| 7 | cpukit/libnetworking/net/if_ppp.c:245:7 |
| 7 | cpukit/libnetworking/netinet/tcp_output.c:393:4 |
| 7 | cpukit/libnetworking/libc/getservbyname.c:52:4 |
| 7 | cpukit/librpc/src/rpc/rpc_prot.c:215:2 |
| 7 | cpukit/librpc/src/rpc/rpc_prot.c:255:2 |
| 7 | cpukit/libnetworking/lib/getprotoby.c:37:1 |
| 7 | cpukit/libnetworking/lib/getprotoby.c:22:1 |
| 7 | cpukit/librpc/src/rpc/svc_simple.c:71:1 |
| 7 | cpukit/librpc/src/rpc/clnt_simple.c:65:1 |
| 7 | cpukit/librpc/src/rpc/rpc_prot.c:138:1 |
| 7 | cpukit/librpc/src/rpc/rpc_prot.c:115:2 |
| 7 | cpukit/librpc/src/rpc/svc_udp.c:346:5 |
| 7 | cpukit/libnetworking/netinet/tcp_usrreq.c:292:16 |
| 7 | cpukit/libnetworking/netinet/tcp_usrreq.c:484:16 |
| 7 | cpukit/librpc/src/rpc/rpc_prot.c:146:2 |
| 7 | cpukit/libnetworking/libc/getservbyport.c:52:4 |
| 7 | cpukit/libnetworking/netinet/tcp_usrreq.c:106:16 |
| 7 | cpukit/librpc/src/rpc/getrpcport.c:52:1 |
| 7 | cpukit/librpc/src/rpc/auth_unix.c:102:1 |
| 7 | cpukit/librpc/src/rpc/rpc_dtablesize.c:55:1 |
| 7 | cpukit/libnetworking/netinet/tcp_usrreq.c:182:16 |
| 7 | cpukit/librpc/src/rpc/rtime.c:75:1 |
| 7 | cpukit/librpc/src/rpc/rpcdname.c:78:1 |
| 7 | cpukit/libnetworking/netinet/tcp_output.c:422:5 |
| 7 | cpukit/libnetworking/netinet/tcp_usrreq.c:497:16 |
| 7 | cpukit/librpc/src/rpc/rpc_prot.c:105:1 |
| 7 | cpukit/librpc/src/rpc/svc_auth_unix.c:147:1 |
| 7 | cpukit/libnetworking/libc/gethostnamadr.c:169:4 |
| 6 | c/src/libchip/network/cs8900.c:85:3 |
| 6 | c/src/libchip/flash/am29lv160.c:277:5 |
| 6 | c/src/libchip/network/sonic.c:299:3 |
| 6 | c/src/libchip/serial/z85c30.c:347:3 |
| 6 | c/src/libchip/network/sonic.c:312:3 |
| 6 | c/src/libchip/serial/z85c30.c:508:3 |
| 6 | c/src/libchip/serial/z85c30_reg.c:66:3 |
| |1:2 |
| 6 | c/src/libchip/network/cs8900.c:71:3 |
| 6 | c/src/libchip/network/cs8900.c:114:3 |
| 6 | c/src/libchip/serial/z85c30.c:779:3 |
| 6 | c/src/libchip/serial/z85c30.c:410:3 |
| 6 | c/src/libchip/network/cs8900.c:105:3 |
| 6 | c/src/libchip/serial/mc68681.c:471:3 |
| 6 | c/src/libchip/serial/z85c30.c:381:3 |
| 6 | c/src/libchip/serial/mc68681.c:299:3 |
| 6 | c/src/libchip/network/sonic.c:282:3 |
| 6 | c/src/libchip/network/cs8900.c:704:7 |
| 6 | c/src/libchip/flash/am29lv160.c:381:7 |
| |1:3 |
| |7:2 |
| |8:2 |
| |6:2 |
| Warning Map |
| arm/xilinx_zynq_zedboard-smp-debug : 74 |
| warning: #warning "implement a proper getservbyport_r" [-Wcpp] |
| warning: 'level' is used uninitialized in this function |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| warning: incompatible implicit declaration of built-in function |
| 'memmove' |
| warning: 'Irql' may be used uninitialized in this function |
| [-Wmaybe-uninitialized] |
| warning: nested extern declaration of 'rtems_interrupt_enable' |
| [-Wnested-externs] |
| warning: variable 'tp' set but not used [-Wunused-but-set- |
| variable] |
| warning: dereferencing type-punned pointer will break strict- |
| aliasing rules [-Wstrict-aliasing] |
| warning: 'Irql' is used uninitialized in this function |
| [-Wuninitialized] |
| warning: enumeration value '_ACCEPT_STAT' not handled in switch |
| [-Wswitch] |
| warning: no previous prototype for 'get_myaddress' [-Wmissing- |
| prototypes] |
| warning: enumeration value '_REJECT_STAT' not handled in switch |
| [-Wswitch] |
| [-Wuninitialized] |
| warning: no previous prototype for '_rpc_get_default_domain' |
| [-Wmissing-prototypes] |
| warning: variable 'ttl' set but not used [-Wunused-but-set- |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| warning: no previous prototype for 'getrpcport' [-Wmissing- |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| warning: no previous prototype for 'getprotobynumber_static' |
| warning: no previous prototype for 'set_rpc_maxgrouplist' |
| warning: no previous prototype for '_rpc_dtablesize' |
| [-Wuninitialized] |
| warning: no previous prototype for 'getprotobyname_static' |
| warning: no previous prototype for 'registerrpc' [-Wmissing- |
| prototypes] |
| [-Wuninitialized] |
| warning: nested extern declaration of 'rtems_interrupt_disable' |
| variable] |
| [-Wuninitialized] |
| warning: no previous prototype for 'callrpc' [-Wmissing- |
| prototypes] |
| warning: no previous prototype for 'xdr_rejected_reply' |
| warning: 'level' may be used uninitialized in this function |
| [-Wuninitialized] |
| warning: no previous prototype for 'xdr_accepted_reply' |
| warning: nested extern declaration of 'rtems_interrupt_flash' |
| warning: no previous prototype for 'svcudp_enablecache' |
| warning: no previous prototype for '_svcauth_short' [-Wmissing- |
| prototypes] |
| warning: no previous prototype for '_svcauth_unix' [-Wmissing- |
| prototypes] |
| variable] |
| [-Wuninitialized] |
| warning: #warning "implement a proper gethostbyaddr_r" [-Wcpp] |
| warning: no previous prototype for 'rtime' [-Wmissing- |
| prototypes] |
| variable] |
| [-Wswitch] |
| warning: no previous prototype for 'in_cksum' [-Wmissing- |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| sparc/leon3-smp-debug : 107 |
| 'memmove' |
| prototypes] |
| prototypes] |
| warning: implicit declaration of function |
| 'rtems_interrupt_enable' [-Wimplicit-function-declaration] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| warning: 'oldLevel' may be used uninitialized in this function |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wswitch] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| prototypes] |
| [-Wswitch] |
| [-Wuninitialized] |
| c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:588:2 |
| variable] |
| variable] |
| c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:501:2 |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wuninitialized] |
| variable] |
| warning: 'oldLevel' is used uninitialized in this function |
| [-Wuninitialized] |
| prototypes] |
| c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:511:3 |
| variable] |
| [-Wuninitialized] |
| c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:566:2 |
| prototypes] |
| c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c:537:2 |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| 'rtems_interrupt_disable' [-Wimplicit-function-declaration] |
| arm/altcycv_devkit_smp-smp-debug : 74 |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| 'memmove' |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| prototypes] |
| [-Wswitch] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| prototypes] |
| prototypes] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| variable] |
| [-Wswitch] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| arm/altcycv_devkit-smp-debug : 74 |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| 'memmove' |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| prototypes] |
| [-Wswitch] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| prototypes] |
| prototypes] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| variable] |
| [-Wswitch] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| arm/xilinx_zynq_zc706-smp-debug : 74 |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| 'memmove' |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| prototypes] |
| [-Wswitch] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| prototypes] |
| prototypes] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| variable] |
| [-Wswitch] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| sparc/leon2-smp-debug : 158 |
| 'memmove' |
| prototypes] |
| prototypes] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wswitch] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| prototypes] |
| [-Wswitch] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| variable] |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| warning: format '%x' expects argument of type 'unsigned int', |
| but argument 2 has type 'short unsigned int *' [-Wformat=] |
| [-Wuninitialized] |
| variable] |
| warning: format '%d' expects argument of type 'int', but |
| argument 2 has type 'rtems_vector_number {aka long unsigned |
| int}' [-Wformat=] |
| [-Wuninitialized] |
| but argument 2 has type 'caddr_t {aka char *}' [-Wformat=] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| arm/xilinx_zynq_zc702-smp-debug : 74 |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| 'memmove' |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| prototypes] |
| [-Wswitch] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| [-Wswitch] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| [-Wuninitialized] |
| prototypes] |
| prototypes] |
| variable] |
| [-Wuninitialized] |
| prototypes] |
| variable] |
| [-Wswitch] |
| prototypes] |
| [-Wuninitialized] |
| [-Wuninitialized] |
| [-Wuninitialized] |
