[PATCH v2 4/4] posix/src/mutexinit.c: Reorder to make priority a scoped variable
Wed Apr 26 20:42:42 UTC 2017
 cpukit/posix/src/mutexinit.c | 41 +++++++++++++++++++----------------------
 1 file changed, 19 insertions(+), 22 deletions(-)
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index 47e0bcb..cdbba11 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -38,10 +38,6 @@ int pthread_mutex_init(
   const pthread_mutexattr_t *the_attr;
   POSIX_Mutex_Protocol       protocol;
   const Scheduler_Control   *scheduler;
-  Priority_Control           priority;
-  /* initialize to avoid warning for used uninitialized */
-  priority = 0;
   if ( attr ) the_attr = attr;
   else        the_attr = &_POSIX_Mutex_Default_attributes;
@@ -109,23 +105,6 @@ int pthread_mutex_init(
 #endif
-  if ( protocol == POSIX_MUTEX_PRIORITY_CEILING ) {
-    int  prio_ceiling;
-    bool valid;
-    scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
-    prio_ceiling = the_attr->prio_ceiling;
-    if ( prio_ceiling == INT_MAX ) {
-      prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
-    priority = _POSIX_Priority_To_core( scheduler, prio_ceiling, &valid );
-    if ( !valid ) {
-      return EINVAL;
   the_mutex = _POSIX_Mutex_Allocate();
   if ( !the_mutex ) {
@@ -137,9 +116,27 @@ int pthread_mutex_init(
   the_mutex->is_recursive = ( the_attr->type == PTHREAD_MUTEX_RECURSIVE );
   switch ( protocol ) {
-    case POSIX_MUTEX_PRIORITY_CEILING:
+    case POSIX_MUTEX_PRIORITY_CEILING: {
+      int               prio_ceiling;
+      bool              valid;
+      Priority_Control  priority;
+      scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
+      prio_ceiling = the_attr->prio_ceiling;
+      if ( prio_ceiling == INT_MAX ) {
+	prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
+      priority = _POSIX_Priority_To_core( scheduler, prio_ceiling, &valid );
+      if ( !valid ) {
+        _POSIX_Mutex_Free(the_mutex);
+        _Objects_Allocator_unlock();
+	return EINVAL;
       _CORE_ceiling_mutex_Initialize( &the_mutex->Mutex, scheduler, priority );
       break;
     default:
       _Assert(
         the_mutex->protocol == POSIX_MUTEX_NO_PROTOCOL
1.8.3.1
