Tier-1 build failures.
Wed Apr 26 23:46:26 UTC 2017
Hello,
A tier-1 build with the default `all` build profile has the following failures.
^ Profile Time 6:46:12.960811
+  warnings:10330  exes:49227  objs:241648  libs:6668
Failures:
  1 smp-debug         i386/pc686  build /opt/work/chris/rtems/kernel/rtems.git/c\
                                        onfigure --target=i386-rtems4.12\
                                        --enable-rtemsbsp=pc686\
                                        --prefix=/opt/rtems/4.12 --enable-debug\
                                        --enable-smp --enable-tests\
                                        BSP_PRINT_EXCEPTION_CONTEXT=1
                                          error: pc686/lib/include/rtems/score/p
                                          ercpu.h:373:23 error: variable or
                                          field 'Interrupt_frame' declared void
  2 smp-network       i386/pc686  build /opt/work/chris/rtems/kernel/rtems.git/c\
                                        --prefix=/opt/rtems/4.12 --enable-\
                                        networking --enable-smp --enable-tests\
  3 smp-network-debug i386/pc686  build /opt/work/chris/rtems/kernel/rtems.git/c\
                                        --enable-networking --enable-smp\
                                        --enable-tests\
  4 smp-debug         sparc/leon3 build /opt/work/chris/rtems/kernel/rtems.git/c\
                                        onfigure --target=sparc-rtems4.12\
                                        --enable-rtemsbsp=leon3\
                                          error: c/src/lib/libbsp/sparc/shared/s
                                          pw/grspw_pkt.c:61:2 error: #error SMP
                                          mode not compatible with these
                                          interrupt lock primitives
  5 smp-network       sparc/leon3 build /opt/work/chris/rtems/kernel/rtems.git/c\
  6 smp-network-debug sparc/leon3 build /opt/work/chris/rtems/kernel/rtems.git/c\
                                        --enable-tests
* Passes: 87   Failures: 6
