[PATCH] libmisc/shell: Make some internal shell functions public.
Chris Johns
chrisj at rtems.org
Mon Aug 14 04:55:46 UTC 2017
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3096.
cpukit/libmisc/shell/internal.h | 15 ---------------
cpukit/libmisc/shell/shell.c | 11 +++++++----
cpukit/libmisc/shell/shell.h | 28 ++++++++++++++++++++++++++++
3 files changed, 35 insertions(+), 19 deletions(-)
diff --git a/cpukit/libmisc/shell/internal.h b/cpukit/libmisc/shell/internal.h
index 56b1bb6077..31df89da05 100644
--- a/cpukit/libmisc/shell/internal.h
+++ b/cpukit/libmisc/shell/internal.h
@@ -11,24 +11,9 @@
#include "shell.h"
-struct rtems_shell_topic_tt;
-typedef struct rtems_shell_topic_tt rtems_shell_topic_t;
-struct rtems_shell_topic_tt {
- const char *topic;
- rtems_shell_topic_t *next;
extern rtems_shell_cmd_t * rtems_shell_first_cmd;
extern rtems_shell_topic_t * rtems_shell_first_topic;
-rtems_shell_topic_t * rtems_shell_lookup_topic(const char *topic);
-bool rtems_shell_can_see_cmd(const rtems_shell_cmd_t *shell_cmd);
-int rtems_shell_execute_cmd(const char *cmd, int argc, char *argv[]);
extern void rtems_shell_register_monitor_commands(void);
extern void rtems_shell_print_heap_info(
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index e7e57933a0..5f042f5855 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -147,6 +147,12 @@ static void rtems_shell_init_once(void)
"running on %m\n");
rtems_shell_init_commands();
+ rtems_shell_register_monitor_commands();
+void rtems_shell_init_environment(void)
+ assert(pthread_once(&rtems_shell_once, rtems_shell_init_once) == 0);
@@ -721,10 +727,7 @@ bool rtems_shell_main_loop(
FILE *stdinToClose = NULL;
FILE *stdoutToClose = NULL;
- eno = pthread_once(&rtems_shell_once, rtems_shell_init_once);
- assert(eno == 0);
- rtems_shell_register_monitor_commands();
+ rtems_shell_init_environment();
shell_env = rtems_shell_init_env(shell_env_arg);
if (shell_env == NULL) {
diff --git a/cpukit/libmisc/shell/shell.h b/cpukit/libmisc/shell/shell.h
index 4d545d6a41..98ddf0a958 100644
--- a/cpukit/libmisc/shell/shell.h
+++ b/cpukit/libmisc/shell/shell.h
@@ -94,6 +94,14 @@ typedef struct {
const char *alias;
} rtems_shell_alias_t;
+struct rtems_shell_topic_tt;
+typedef struct rtems_shell_topic_tt rtems_shell_topic_t;
+struct rtems_shell_topic_tt {
+ const char *topic;
+ rtems_shell_topic_t *next;
* The return value has RTEMS_SHELL_KEYS_EXTENDED set if the key
* is extended, ie a special key.
@@ -125,6 +133,26 @@ extern int rtems_shell_make_args(
int max_args
+extern rtems_shell_topic_t * rtems_shell_lookup_topic(
+ const char *topic
+extern bool rtems_shell_can_see_cmd(
+ const rtems_shell_cmd_t *shell_cmd
+extern int rtems_shell_execute_cmd(
+ const char *cmd, int argc, char *argv[]
+ * Call to set up the shell environment if you need to execute commands before
+ * running a shell.
+extern void rtems_shell_init_environment(
+ void
extern int rtems_shell_cat_file(
FILE *out,
const char *name
2.13.2
