New lower ticker clock driver issue
Denis Obrezkov denisobrezkov at gmail.com
Mon Aug 14 19:43:33 UTC 2017
Hello all,
I am preparing my code for working without any modifications
with examples-v2. Now I have an issue with a lower ticker example,
this is my output:
*** LOW MEMORY CLOCK TICK TEST ***
TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:09 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:09 12/31/1988
and that's all, no errors. It seems that on some stage my interrupts
aren't switched back on. I think this happens during a context switch.
Could you Hasham, check my context switch and interrupt handling
routine?
My work branch:
https://github.com/embeddedden/rtems-riscv/tree/hifive1
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170814/2c9f7de1/attachment.html>
