Does rtems-test work on MinGW64?
Jiri Gaisler jiri at gaisler.se
Tue Aug 15 21:02:16 UTC 2017
I have fixed the compile problems for the sis simulator on MinGW64, and
I am now trying to run it through the rtems-test utility. This does
however not work and gives the following error log:
$ rtems-test --rtems-bsp=erc32-sis
sparc-rtems4.12/c/erc32/testsuites           RTEMS Testing - Tester,
4.12.not_released
 Command Line: C:/msys64/opt/rtems/4.12/bin/rtems-test
--rtems-bsp=erc32-sis sparc-rtems4.12/c/erc32/testsuites
 Python: 2.7.13 (default, Jan 17 2017, 13:56:44)  [GCC 6.3.0 64 bit (AMD64)]
[  2/566] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   | sparc/erc32:
linpack.exe
[  1/566] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   | sparc/erc32:
dhrystone.exe
error: run.cfg:70: execute failed:
/C/msys64/opt/rtems/4.12/bin/sparc-rtems4.12-sis.exe -nouartrx -r -tlim
600 s sparc-rtems4.12/c/erc32/testsuites/benchmarks/linpack/linpack.exe:
exit-code:2
600 s
sparc-rtems4.12/c/erc32/testsuites/benchmarks/dhrystone/dhrystone.exe:
exit-code:2
If I run the executed command separately on the command line in the
MinGW64 shell, it runs fine:
$  /C/msys64/opt/rtems/4.12/bin/sparc-rtems4.12-sis.exe -nouartrx -r
-tlim 600 s
sparc-rtems4.12/c/erc32/testsuites/fstests/fsdosfsname01/fsdosfsname01.exe
 SIS - SPARC instruction simulator 2.8,  copyright Jiri Gaisler 1995
 Bug-reports to jiri at gaisler.se
 ERC32 emulation enabled
simulation limit = 4105032704 (600000.000 ms)
*** BEGIN OF TEST FSDOSFSNAME 1 ***
*** END OF TEST FSDOSFSNAME 1 ***
Is rtems-test supported on MinGW64 for any other simulator ...?
Jiri.
