RISC-V interrupts in HiFive1
Hesham Almatary heshamelmatary at gmail.com
Tue Aug 15 03:44:50 UTC 2017
Hi Denis,
You just need to modify riscv_interrupt_disable(). Read the priv-spec
manual for your RISC-V version, and determine which bit should be
cleared (it's called MIE in priv-1.10, but you mentioned you work with
priv-1.9).
Cheers,
Hesham
On Mon, Aug 14, 2017 at 6:10 PM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> Hello all,
> at the end of the GSoC I've found out that interrupts in my BSP
> weren't properly enabled/disabled globally.
> This happens because my work is based on the Hesham's
> BSP for RISC-V and it was done for the previous version of ISA.
> Thus, the Hesham's interrupt enabling/disabling instructions did
> nothing in my version of ISA.
> I've tried to fix this issue, but without much of success.
> Regards, Denis Obrezkov
> devel mailing list
> devel at rtems.org
Hesham
