RISC-V interrupts in HiFive1
Denis Obrezkov
denisobrezkov at gmail.com
Tue Aug 15 17:03:55 UTC 2017
2017-08-15 14:57 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Aug 15, 2017 4:32 AM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
> 2017-08-15 5:44 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> Hi Denis,
>> You just need to modify riscv_interrupt_disable(). Read the priv-spec
>> manual for your RISC-V version, and determine which bit should be
>> cleared (it's called MIE in priv-1.10, but you mentioned you work with
>> priv-1.9).
> Is the bit set correctly for the idle thread?
> I assume this is with a real clock driver so is it maintained properly
> across an ISR?
> It is either screwed up by the thread context initialization, context
> switch, or ISR code. ISR code has two exit paths. It could be the
> preemption path. That would occur about 5 seconds into the execution of
> ticker and TA1 will preemption idle.
> I understand this but still can find a mistake.
This is what I get:
*** LOW MEMORY CLOCK TICK TEST ***
TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:09 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:09 12/31/1988
After that I can examine: p Clock_driver_ticks
$8 = 1001
mstatus value is 0x0001800 (interrupts disabled)
Instruction for enabling global interrupts is:
csrsi mstatus, 0x8
for disabling:
csrci mstatus, 0x8
it atomically changes the fourth bit of mstatus (ie bit).
I think that something wrong happens in context switches between TA1, TA2
and Idle.
This is my context switch file:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/cpukit/score/cpu/riscv32/riscv-context-switch.S
Interrupt disabling:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/cpukit/score/cpu/riscv32/rtems/score/cpu.h#L542
Context initialize:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/cpukit/score/cpu/riscv32/riscv-context-initialize.c
Interrupt context save:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L200
Could have a look?
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170815/01867487/attachment-0001.html>
