[PATCH 05/15] HiFive1: add basic header files
Denis Obrezkov denisobrezkov at gmail.com
Wed Aug 16 15:12:56 UTC 2017
 c/src/lib/libbsp/riscv32/hifive1/include/bsp.h     | 53 +++++++++++++++++
 c/src/lib/libbsp/riscv32/hifive1/include/bspopts.h | 68 ++++++++++++++++++++++
 c/src/lib/libbsp/riscv32/hifive1/include/irq.h     | 57 ++++++++++++++++++
 c/src/lib/libbsp/riscv32/hifive1/include/tm27.h    | 53 +++++++++++++++++
 4 files changed, 231 insertions(+)
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/include/bsp.h
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/include/bspopts.h
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/include/irq.h
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/include/tm27.h
diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/bsp.h b/c/src/lib/libbsp/riscv32/hifive1/include/bsp.h
new file mode 100644
index 0000000..669a8b8
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/include/bsp.h
@@ -0,0 +1,53 @@
+ * Copyright (c) 2017 Denis Obrezkov <denisobrezkov at gmail.com>
+ * Copyright (c) 2015 University of York.
+ * Hesham ALMatary <hmka501 at york.ac.uk>
+ * COPYRIGHT (c) 1989-1999.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef LIBBSP_RISCV_SIM_H
+#define LIBBSP_RISCV_SIM_H
+#include <rtems.h>
+#include <bspopts.h>
+#include <bsp/default-initial-extension.h>
+#include <rtems/devnull.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define BSP_DEFAULT_UNIFIED_WORK_AREAS
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_RISCV_H */
diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/bspopts.h b/c/src/lib/libbsp/riscv32/hifive1/include/bspopts.h
index 0000000..47c2f0d
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/include/bspopts.h
@@ -0,0 +1,68 @@
+ * are met:
+ * SUCH DAMAGE.
+/* include/bspopts.h.in.  Generated from configure.ac by autoheader.  */
+/* If defined, then the BSP Framework will put a non-zero pattern into the
+   RTEMS Workspace and C program heap. This should assist in finding code that
+   assumes memory starts set to zero. */
+#undef BSP_DIRTY_MEMORY
+/* If defined, print a message and wait until pressed before resetting board
+   when application exits. */
+#undef BSP_PRESS_KEY_FOR_RESET
+/* If defined, prints the exception context when an unexpected exception
+   occurs. */
+#undef BSP_PRINT_EXCEPTION_CONTEXT
+/* If defined, reset the board when the application exits. */
+#undef BSP_RESET_BOARD_AT_EXIT
+/* reset vector address for BSP start */
+#undef BSP_START_RESET_VECTOR
+/* Define to the address where bug reports for this package should be sent. */
+#undef PACKAGE_BUGREPORT
+/* Define to the full name of this package. */
+#undef PACKAGE_NAME
+/* Define to the full name and version of this package. */
+#undef PACKAGE_STRING
+/* Define to the one symbol short name of this package. */
+#undef PACKAGE_TARNAME
+/* Define to the home page for this package. */
+#undef PACKAGE_URL
+/* Define to the version of this package. */
+#undef PACKAGE_VERSION
diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/irq.h b/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
index 0000000..67a781f
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
@@ -0,0 +1,57 @@
+ * @file
+ * @ingroup RISCV_IRQ
+ * @brief Interrupt definitions.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef LIBBSP_GENERIC_RISCV_IRQ_H
+#define LIBBSP_GENERIC_RISCV_IRQ_H
+#ifndef ASM
+#include <rtems.h>
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#define BSP_INTERRUPT_VECTOR_MIN  0x0
+#define BSP_INTERRUPT_VECTOR_MAX  0x24
+#define MCAUSE_INT 0x80000000
+#define MCAUSE_MSWI 0x3
+#define MCAUSE_MTIME 0x7
+#define MCAUSE_MEXT 0xB
+#endif /* ASM */
+#endif /* LIBBSP_GENERIC_RISCV_IRQ_H */
diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/tm27.h b/c/src/lib/libbsp/riscv32/hifive1/include/tm27.h
index 0000000..10dac82
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/include/tm27.h
@@ -0,0 +1,53 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+ * @name Interrupt mechanisms for Time Test 27
+#define MUST_WAIT_FOR_INTERRUPT 0
+#define Install_tm27_vector( handler ) /* empty */
+#define Cause_tm27_intr() /* empty */
+#define Clear_tm27_intr() /* empty */
+#define Lower_tm27_intr() /* empty */
+#endif
2.1.4
