[PATCH 04/15] HiFive1: add start.S file with basic initialization
Hesham Almatary heshamelmatary at gmail.com
Sun Aug 20 02:55:10 UTC 2017
On Thu, Aug 17, 2017 at 1:12 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
>  c/src/lib/libbsp/riscv32/hifive1/start/start.S | 290 +++++++++++++++++++++++++
>  1 file changed, 290 insertions(+)
>  create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/start.S
> diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/start.S b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
> new file mode 100644
> index 0000000..9531998
> --- /dev/null
> +++ b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
> @@ -0,0 +1,290 @@
> + * Copyright (c) 2015 University of York.
> + * Hesham ALMatary <hmka501 at york.ac.uk>
You should add your name/copyrights.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#include <bsp/linker-symbols.h>
> +#include <rtems/asm.h>
> +# define LREG lw
> +# define SREG sw
> +#define CLINT_BASE 0x02000000
> +#define MTIME_OFFSET 0xBFF8
> +#define MTIMECMP_OFFSET 0x4000
> +#define MTIME_REG CLINT_BASE+MTIME_OFFSET
> +#define MTIMECMP CLINT_BASE+MTIMECMP_OFFSET
> +#define REGBYTES 4
> +EXTERN(bsp_section_bss_begin)
> +EXTERN(bsp_section_bss_end)
> +EXTERN(ISR_Handler)
> +EXTERN(bsp_start_vector_table_end)
> +EXTERN(bsp_start_vector_table_size)
> +EXTERN(bsp_vector_table_size)
> +EXTERN(bsp_section_stack_begin)
> +.balign 4
> +PUBLIC(RISCV_Exception_default)
> +/* PUBLIC(bsp_start_vector_table_begin) */
> +PUBLIC(_start)
> +.section .vector, "ax"
No use of .vector here anymore, so should be deleted. Also commented
code is not encouraged.
> +.section .start, "wax"
> +TYPE_FUNC(_start)
> +SYM(_start):
x1?
> +  li x2, 0
> +  li x3, 0
> +  li x4, 0
> +  li x5, 0
> +  li x6, 0
> +  li x7, 0
> +  li x8, 0
> +  li x9, 0
> +  li x10,0
> +  li x11,0
> +  li x12,0
> +  li x13,0
> +  li x14,0
> +  li x15,0
> +  li x16,0
> +  li x17,0
> +  li x18,0
> +  li x19,0
> +  li x20,0
> +  li x21,0
> +  li x22,0
> +  li x23,0
> +  li x24,0
> +  li x25,0
> +  li x26,0
> +  li x27,0
> +  li x28,0
> +  li x29,0
> +  li x30,0
> +  li x31,0
> +  /* load stack and frame pointers */
> +  la sp, bsp_section_stack_begin
One newline only.
> +/* Clearing .bss */
> +  la t0, bsp_section_bss_begin
> +  la t1, bsp_section_bss_end
> +_loop_clear_bss:
> +  bge t0, t1, _end_clear_bss
> +  addi  t0, t0, 4
> +  sw    x0, 0(t0)
> +  j     _loop_clear_bss
> +  nop
No need for nop
> +_end_clear_bss:
> +/* Copy data */
> +  la t0, _copy_start
> +  la t1, _copy_end
> +  la t3, __data_start_rom
> +_loop_copy_data:
> +  bge t0, t1, _end_copy_data
> +  lb  t4, 0(t3)
> +  sb   t4, 0(t0)
Any reason why you use bytes instead of words?
> +  addi t0, t0, 1
> +  addi t3, t3, 1
> +  j    _loop_copy_data
> +  nop
ditto
> +_end_copy_data:
> + * Examples of generating clock and software interrupts.
> + * interrupts won't be generated because they are turned off
> +irq_gen:
> +/*  sw t0, 0(t1) */
> +  li t2, MTIME_REG
> +  li t4, 0x300000
Try not to use hard-coded value, or use comments where they've to be used.
> +  lw t0, 0(t2)
> +  add t0, t0, t4
> +  li t3, MTIMECMP
> +  sw t0, 0(t3)
> +/* copy MSB of mtime */
> +  addi t3, t3, 4
> +  addi t2, t2, 4
> +/* race condition may arise here */
> +  lw t0, 0(t2)
> +  sw t0, 0(t3)
> +  li t3, 0x02000000
> +  li t4, 0x1
> +  /* sw t4, 0(t3) */
> +  nop
> +/* Enable interrupts in mie register (not enabled in mstatus yet) */
I will aruge interrupts should not be enabled at start, rather, they
should be enabled when you're going to a new thread (init context,
discussed in a previous post).
> +  la t0, RISCV_Exception_default
> +  csrw mtvec, t0
> +  li t0, 0x088
I don't know what 0x88 is; for readability, always use macros with
descriptive names to make it easier for code reviewers and people who
read the code when it's merged.
> +  csrs mie, t0
> +  csrci mstatus, 0x8
> +  csrwi mie, 0x088
> +  csrsi mstatus, 0x8
> +  call boot_card
> +  nop
> +bsp_start_vector_table_begin:
> +  .word RISCV_Exception_default /* bad_trap */
> +  .word RISCV_Exception_default /* pmp_trap */
> +  .word RISCV_Exception_default /* illegal_insn_trap */
> +  .word RISCV_Exception_default /* misaligned_load_trap */
> +  .word RISCV_Exception_default /* misaligned_store_trap */
> +  .word RISCV_Exception_default /* mcall_trap*/
> +#define TRAP_FROM_MACHINE_MODE_VECTOR 13
> +  .word RISCV_Exception_default /* __trap_from_machine_mode */
> +  .word RISCV_Exception_default /*bad_trap  */
> +bsp_start_vector_table_end:
> +.section .start,"ax"
> +.align  4
> +.type   _external_start, %function
> +.normal_start:
> +.balign 4
> +TYPE_FUNC(RISCV_Exception_default)
> +SYM(RISCV_Exception_default):
> +  nop
> +trap_entry:
encode 0x8 in a macro
> +  addi sp, sp, -34*REGBYTES
> +  SREG x1, 1*REGBYTES(sp)
> +  SREG x2, 2*REGBYTES(sp)
> +  SREG x3, 3*REGBYTES(sp)
> +  SREG x4, 4*REGBYTES(sp)
> +  SREG x5, 5*REGBYTES(sp)
> +  SREG x6, 6*REGBYTES(sp)
> +  SREG x7, 7*REGBYTES(sp)
> +  SREG x8, 8*REGBYTES(sp)
> +  SREG x9, 9*REGBYTES(sp)
> +  SREG x10, 10*REGBYTES(sp)
> +  SREG x11, 11*REGBYTES(sp)
> +  SREG x12, 12*REGBYTES(sp)
> +  SREG x13, 13*REGBYTES(sp)
> +  SREG x14, 14*REGBYTES(sp)
> +  SREG x15, 15*REGBYTES(sp)
> +  SREG x16, 16*REGBYTES(sp)
> +  SREG x17, 17*REGBYTES(sp)
> +  SREG x18, 18*REGBYTES(sp)
> +  SREG x19, 19*REGBYTES(sp)
> +  SREG x20, 20*REGBYTES(sp)
> +  SREG x21, 21*REGBYTES(sp)
> +  SREG x22, 22*REGBYTES(sp)
> +  SREG x23, 23*REGBYTES(sp)
> +  SREG x24, 24*REGBYTES(sp)
> +  SREG x25, 25*REGBYTES(sp)
> +  SREG x26, 26*REGBYTES(sp)
> +  SREG x27, 27*REGBYTES(sp)
> +  SREG x28, 28*REGBYTES(sp)
> +  SREG x29, 29*REGBYTES(sp)
> +  SREG x30, 30*REGBYTES(sp)
> +  SREG x31, 31*REGBYTES(sp)
> +  csrr t0, mepc
> +  SREG t0, 32*REGBYTES(sp)
> +  csrr t0, mcause
> +  SREG t0, 33*REGBYTES(sp)
> +  call handle_trap_new
> +  LREG t0, 32*REGBYTES(sp)
> +  csrw mepc, t0
> +  LREG t0, 33*REGBYTES(sp)
> +  csrw mcause, t0
> +  LREG x1, 1*REGBYTES(sp)
> +  LREG x2, 2*REGBYTES(sp)
> +  LREG x3, 3*REGBYTES(sp)
> +  LREG x4, 4*REGBYTES(sp)
> +  LREG x5, 5*REGBYTES(sp)
> +  LREG x6, 6*REGBYTES(sp)
> +  LREG x7, 7*REGBYTES(sp)
> +  LREG x8, 8*REGBYTES(sp)
> +  LREG x9, 9*REGBYTES(sp)
> +  LREG x10, 10*REGBYTES(sp)
> +  LREG x11, 11*REGBYTES(sp)
> +  LREG x12, 12*REGBYTES(sp)
> +  LREG x13, 13*REGBYTES(sp)
> +  LREG x14, 14*REGBYTES(sp)
> +  LREG x15, 15*REGBYTES(sp)
> +  LREG x16, 16*REGBYTES(sp)
> +  LREG x17, 17*REGBYTES(sp)
> +  LREG x18, 18*REGBYTES(sp)
> +  LREG x19, 19*REGBYTES(sp)
> +  LREG x20, 20*REGBYTES(sp)
> +  LREG x21, 21*REGBYTES(sp)
> +  LREG x22, 22*REGBYTES(sp)
> +  LREG x23, 23*REGBYTES(sp)
> +  LREG x24, 24*REGBYTES(sp)
> +  LREG x25, 25*REGBYTES(sp)
> +  LREG x26, 26*REGBYTES(sp)
> +  LREG x27, 27*REGBYTES(sp)
> +  LREG x28, 28*REGBYTES(sp)
> +  LREG x29, 29*REGBYTES(sp)
> +  LREG x30, 30*REGBYTES(sp)
> +  LREG x31, 31*REGBYTES(sp)
> +  addi sp, sp, 34*REGBYTES
> +  nop
> +  nop
> +  nop
> +  mret
> 2.1.4
> devel mailing list
> devel at rtems.org
Hesham
