[PATCH 11/15] HiFive1: set up oscillators
Denis Obrezkov denisobrezkov at gmail.com
Wed Aug 16 15:13:02 UTC 2017
 c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c | 65 +++++++++++++++++++++++
 1 file changed, 65 insertions(+)
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
new file mode 100644
index 0000000..efef4e0
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
@@ -0,0 +1,65 @@
+ *  Copyright (c) 2017
+ *  Denis Obrezkov <denisobrezkov at gmail.com>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/prci.h>
+#include <bsp/fe310.h>
+ * This routine make initialization of HiFive1 (FE310) counters.
+void bsp_start( void )
+  volatile uint32_t * pll_reg = (volatile uint32_t *) PRCI_PLLCFG;
+  volatile uint32_t * high_freq_reg = (volatile uint32_t *) PRCI_HFROSCCFG;
+  volatile uint32_t * spi0 = (volatile uint32_t *) 0x10014000;
+  volatile uint64_t * mtime_reg = (volatile uint64_t * ) 0x0200bff8;
+  volatile uint64_t * mtimecmp_reg = (volatile uint64_t * ) 0x02004000;
+#ifdef USE_HFROSC
+  /* Setting up osc frequency */
+  uint32_t tmp_reg = 0;
+  /* Install divider in high frequency oscillator */
+  tmp_reg |= (HFROSC_DIV_VAL & 0x2f) << HFROSC_DIV_OFFSET;
+  tmp_reg |= (HFROSC_TRIM_VAL & 0x1F) << HFROSC_TRIM_OFFSET;
+  tmp_reg |= (HFROSC_EN_VAL & 0x1) << HFROSC_EN_OFFSET;
+  (*high_freq_reg) = tmp_reg;
+  while (( (*high_freq_reg) & ((HFROSC_RDY_VAL & 0x1) \
+                  << HFROSC_RDY_OFFSET)) == 0 ) {
+#endif /* USE_HFROSC */
+#ifdef USE_HFXOSC
+  volatile uint32_t * ext_freq_reg = (volatile uint32_t *) PRCI_HFXOSCCFG;
+  (*ext_freq_reg) |= ((HFXOSC_EN_VAL & 0x1) << HFXOSC_EN_OFFSET);
+  while (( (*ext_freq_reg) & ((HFXOSC_RDY_VAL & 0x1) \
+                  << HFXOSC_RDY_OFFSET)) == 0 ) {
+  (*pll_reg) |= (0x1 << 18);
+  (*pll_reg) |= (0x1 << 17);
+  (*pll_reg) |= (0x1 << PLL_SEL_OFFSET);
+  (*high_freq_reg) &= ~(0x1 << HFROSC_EN_OFFSET);
+#endif /* USE_HFXOSC */
+#ifndef USE_PLL
+  /* Disable PLL */
+  (*pll_reg) &= ~(0x1 << PLL_SEL_OFFSET);
+#else
+#endif
+  bsp_interrupt_initialize();
2.1.4
