[PATCH 11/15] HiFive1: set up oscillators
Thu Aug 17 15:16:00 UTC 2017
On Wed, Aug 16, 2017 at 11:13 AM, Denis Obrezkov
<denisobrezkov at gmail.com> wrote:
>  c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c | 65 +++++++++++++++++++++++
>  1 file changed, 65 insertions(+)
>  create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> new file mode 100644
> index 0000000..efef4e0
> --- /dev/null
> +++ b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> @@ -0,0 +1,65 @@
> + *  Copyright (c) 2017
> + *  Denis Obrezkov <denisobrezkov at gmail.com>
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#include <bsp.h>
> +#include <bsp/bootcard.h>
> +#include <bsp/prci.h>
> +#include <bsp/fe310.h>
> + * This routine make initialization of HiFive1 (FE310) counters.
> +void bsp_start( void )
> +  volatile uint32_t * pll_reg = (volatile uint32_t *) PRCI_PLLCFG;
> +  volatile uint32_t * high_freq_reg = (volatile uint32_t *) PRCI_HFROSCCFG;
> +  volatile uint32_t * spi0 = (volatile uint32_t *) 0x10014000;
> +  volatile uint64_t * mtime_reg = (volatile uint64_t * ) 0x0200bff8;
> +  volatile uint64_t * mtimecmp_reg = (volatile uint64_t * ) 0x02004000;
> +#ifdef USE_HFROSC
> +  /* Setting up osc frequency */
> +  uint32_t tmp_reg = 0;
> +  /* Install divider in high frequency oscillator */
> +  tmp_reg |= (HFROSC_DIV_VAL & 0x2f) << HFROSC_DIV_OFFSET;
> +  tmp_reg |= (HFROSC_TRIM_VAL & 0x1F) << HFROSC_TRIM_OFFSET;
> +  tmp_reg |= (HFROSC_EN_VAL & 0x1) << HFROSC_EN_OFFSET;
> +  (*high_freq_reg) = tmp_reg;
It would be good to make the above into a function.
> +  while (( (*high_freq_reg) & ((HFROSC_RDY_VAL & 0x1) \
> +                  << HFROSC_RDY_OFFSET)) == 0 ) {
> +#endif /* USE_HFROSC */
> +#ifdef USE_HFXOSC
> +  volatile uint32_t * ext_freq_reg = (volatile uint32_t *) PRCI_HFXOSCCFG;
> +  (*ext_freq_reg) |= ((HFXOSC_EN_VAL & 0x1) << HFXOSC_EN_OFFSET);
> +  while (( (*ext_freq_reg) & ((HFXOSC_RDY_VAL & 0x1) \
> +                  << HFXOSC_RDY_OFFSET)) == 0 ) {
> +  (*pll_reg) |= (0x1 << 18);
> +  (*pll_reg) |= (0x1 << 17);
> +  (*pll_reg) |= (0x1 << PLL_SEL_OFFSET);
> +  (*high_freq_reg) &= ~(0x1 << HFROSC_EN_OFFSET);
> +#endif /* USE_HFXOSC */
> +#ifndef USE_PLL
> +  /* Disable PLL */
> +  (*pll_reg) &= ~(0x1 << PLL_SEL_OFFSET);
> +#else
> +#endif
> +  bsp_interrupt_initialize();
> 2.1.4
> devel mailing list
> devel at rtems.org
