[PATCH 13/15] HiFive1: add interrupts enable/disable support
Denis Obrezkov denisobrezkov at gmail.com
Wed Aug 16 15:13:04 UTC 2017
 cpukit/score/cpu/riscv32/rtems/score/cpu.h | 18 ++++++++++++------
 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu.h b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
index 8f8a864..9b484e6 100644
--- a/cpukit/score/cpu/riscv32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
@@ -455,7 +455,7 @@ Context_Control_fp  _CPU_Null_fp_context;
-#define CPU_STACK_MINIMUM_SIZE  4096
+#define CPU_STACK_MINIMUM_SIZE  700
  *  CPU's worst alignment requirement for data types on a byte boundary.  This
@@ -538,7 +538,6 @@ Context_Control_fp  _CPU_Null_fp_context;
  *  level is returned in _level.
 static inline uint32_t riscv_interrupt_disable( void )
   register uint32_t sstatus;
@@ -549,13 +548,15 @@ static inline uint32_t riscv_interrupt_disable( void )
                         "csrw sstatus, %[temp]; \t"
                         : [temp] "=r" (temp) : [sstatus] "r" (sstatus):
+#elif FE3XX
+  __asm__ volatile ("csrci mstatus, 0x8");
+  (void)temp;
 #else
   __asm__ __volatile__ ("csrr %[sstatus], mstatus; \t"
                         "andi %[temp], %[sstatus], -2; \t"
                         "csrw mstatus, %[temp]; \t"
 #endif
   return sstatus;
@@ -565,15 +566,18 @@ static inline void riscv_interrupt_enable(uint32_t level)
 #ifdef SEL4
   __asm__ __volatile__ ("csrw sstatus, %[level];"
                         :: [level] "r" (level):);
+#elif FE3XX
+  __asm__ volatile ("csrsi mstatus, 0x8");
 #else
   __asm__ __volatile__ ("csrw mstatus, %[level];"
 #endif
 #define _CPU_ISR_Disable( _level ) \
-    _level = riscv_interrupt_disable()
+    do { \
+    _level = riscv_interrupt_disable();\
+    } while(0)
  *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
@@ -583,7 +587,9 @@ static inline void riscv_interrupt_enable(uint32_t level)
 #define _CPU_ISR_Enable( _level )  \
-  riscv_interrupt_enable( _level )
+    do {\
+      riscv_interrupt_enable( _level ); \
+    } while(0)
  *  This temporarily restores the interrupt to _level before immediately
2.1.4
