[PATCH 13/15] HiFive1: add interrupts enable/disable support
Hesham Almatary heshamelmatary at gmail.com
Sun Aug 20 03:18:33 UTC 2017
On Thu, Aug 17, 2017 at 1:13 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
>  cpukit/score/cpu/riscv32/rtems/score/cpu.h | 18 ++++++++++++------
>  1 file changed, 12 insertions(+), 6 deletions(-)
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu.h b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> index 8f8a864..9b484e6 100644
> --- a/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> @@ -455,7 +455,7 @@ Context_Control_fp  _CPU_Null_fp_context;
> -#define CPU_STACK_MINIMUM_SIZE  4096
> +#define CPU_STACK_MINIMUM_SIZE  700
>   *  CPU's worst alignment requirement for data types on a byte boundary.  This
> @@ -538,7 +538,6 @@ Context_Control_fp  _CPU_Null_fp_context;
>   *  level is returned in _level.
>  static inline uint32_t riscv_interrupt_disable( void )
>    register uint32_t sstatus;
> @@ -549,13 +548,15 @@ static inline uint32_t riscv_interrupt_disable( void )
>                          "csrw sstatus, %[temp]; \t"
>                          : [temp] "=r" (temp) : [sstatus] "r" (sstatus):
> +#elif FE3XX
> +  __asm__ volatile ("csrci mstatus, 0x8");
> +  (void)temp;
Consider implementing this proprely as we discussed before. Also,
there's no need for the #elif FE3XX; just modify the #else below.
Enabling/disabling global interrupts in RISC-V (and this file) is
ISA/RISC-V specific, not BSP specific.
>  #else
>    __asm__ __volatile__ ("csrr %[sstatus], mstatus; \t"
>                          "andi %[temp], %[sstatus], -2; \t"
>                          "csrw mstatus, %[temp]; \t"
>  #endif
>    return sstatus;
> @@ -565,15 +566,18 @@ static inline void riscv_interrupt_enable(uint32_t level)
>  #ifdef SEL4
>    __asm__ __volatile__ ("csrw sstatus, %[level];"
>                          :: [level] "r" (level):);
> +#elif FE3XX
> +  __asm__ volatile ("csrsi mstatus, 0x8");
ditto
>  #else
>    __asm__ __volatile__ ("csrw mstatus, %[level];"
>  #endif
>  #define _CPU_ISR_Disable( _level ) \
> -    _level = riscv_interrupt_disable()
> +    do { \
> +    _level = riscv_interrupt_disable();\
> +    } while(0)
>   *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
> @@ -583,7 +587,9 @@ static inline void riscv_interrupt_enable(uint32_t level)
>  #define _CPU_ISR_Enable( _level )  \
> -  riscv_interrupt_enable( _level )
> +    do {\
> +      riscv_interrupt_enable( _level ); \
> +    } while(0)
>   *  This temporarily restores the interrupt to _level before immediately
> 2.1.4
> devel mailing list
> devel at rtems.org
Hesham
