[PATCH 15/15] HiFive1: disable/enable interrupts during context switch
Denis Obrezkov denisobrezkov at gmail.com
Fri Aug 18 15:30:21 UTC 2017
2017-08-17 23:58 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> On Thu, Aug 17, 2017 at 4:17 PM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> > 2017-08-17 22:07 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> >> On Thu, Aug 17, 2017 at 1:48 PM, Denis Obrezkov <
> >> wrote:
> >> > 2017-08-17 17:25 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> >> >> On Wed, Aug 16, 2017 at 11:13 AM, Denis Obrezkov
> >> >> <denisobrezkov at gmail.com> wrote:
> >> >> >  cpukit/score/cpu/riscv32/riscv-context-switch.S | 12 ++++++++++--
> >> >> >  1 file changed, 10 insertions(+), 2 deletions(-)
> >> >> > diff --git a/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> > b/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> > index a199596..bcdfe0e 100644
> >> >> > --- a/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> > +++ b/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> > @@ -46,6 +46,7 @@ PUBLIC(restore)
> >> >> >  SYM(_CPU_Context_switch):
> >> >> >    /* Disable interrupts and store all registers */
> >> >> > +  csrci mstatus, 0x8
> >> >> Why is this necessary?
> >> >> >    SREG x1, 4(a0)
> >> >> >    SREG x2, 8(a0)
> >> >> >    SREG x3, 12(a0)
> >> >> > @@ -78,8 +79,9 @@ SYM(_CPU_Context_switch):
> >> >> >    SREG x30, 120(a0)
> >> >> >    SREG x31, 124(a0)
> >> >> > -SYM(restore):
> >> >> > +SYM(restore):
> >> >> >    LREG x1, 4(a1)
> >> >> >    LREG x2, 8(a1)
> >> >> >    LREG x3, 12(a1)
> >> >> > @@ -111,9 +113,15 @@ SYM(restore):
> >> >> >    LREG x29, 116(a1)
> >> >> >    LREG x30, 120(a1)
> >> >> >    LREG x31, 124(a1)
> >> >> > -       ret
> >> >> > +  csrsi mstatus, 0x8
> >> >> > +  nop
> >> >> > +  nop
> >> >> Why the nops?
> >> >> > +  ret
> >> >> >  SYM(_CPU_Context_restore):
> >> >> >    mv     a1, a0
> >> >> >    j       restore
> >> >> >    nop
> >> >> > 2.1.4
> >> >> > _______________________________________________
> >> >> > devel mailing list
> >> >> > devel at rtems.org
> >> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> > So, don't we turn off interrupts during the context switch?
> >> Nope, and turning them back on unconditionally is wrong too.
> >> > Yes, nops are unnecessary.
> >> > Regards, Denis Obrezkov
> > Ok, I was confused by this obsolete comment:
> > Will remove all that enabling/disabling.
> > Is the same true for start.S file with interrupted task's stack saving?
> I'm not sure exactly what you're referring to, but usually start.S
> will, among other things, turn off and ack pending interrupts to
> quiesce the hardware before handing off the rest of system init to
> boot_card. Eventually RTEMS will enable interrupts again using the
> cpukit's interrupt_enable layer.
I mean when an interrupt occurs, the execution flow jumps to the trap
address.
Then, in my case all process'es registers are saved in a common stack
(I know that dedicated interrupt stack should be implemented, but I haven't
time to do that)
and then we jump to IRQ dispatching routine. After interrupt handling we
restore saved
registers. So, my question is - should we disable/enable interrupts during
interrupt handling?
Disabling:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L201
Jump to dispatching routine:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L241
Enabling interrupts back:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L285
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170818/6c2843c9/attachment.html>
