[PATCH 15/15] HiFive1: disable/enable interrupts during context switch
Sat Aug 19 12:33:05 UTC 2017
On Fri, Aug 18, 2017 at 11:30 AM, Denis Obrezkov
<denisobrezkov at gmail.com> wrote:
> 2017-08-17 23:58 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
>> On Thu, Aug 17, 2017 at 4:17 PM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-08-17 22:07 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
>> >> On Thu, Aug 17, 2017 at 1:48 PM, Denis Obrezkov
>> >> wrote:
>> >> > 2017-08-17 17:25 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
>> >> >> On Wed, Aug 16, 2017 at 11:13 AM, Denis Obrezkov
>> >> >> >  cpukit/score/cpu/riscv32/riscv-context-switch.S | 12 ++++++++++--
>> >> >> >  1 file changed, 10 insertions(+), 2 deletions(-)
>> >> >> > diff --git a/cpukit/score/cpu/riscv32/riscv-context-switch.S
>> >> >> > b/cpukit/score/cpu/riscv32/riscv-context-switch.S
>> >> >> > index a199596..bcdfe0e 100644
>> >> >> > --- a/cpukit/score/cpu/riscv32/riscv-context-switch.S
>> >> >> > +++ b/cpukit/score/cpu/riscv32/riscv-context-switch.S
>> >> >> > @@ -46,6 +46,7 @@ PUBLIC(restore)
>> >> >> >  SYM(_CPU_Context_switch):
>> >> >> >    /* Disable interrupts and store all registers */
>> >> >> > +  csrci mstatus, 0x8
>> >> >> Why is this necessary?
>> >> >> >    SREG x1, 4(a0)
>> >> >> >    SREG x2, 8(a0)
>> >> >> >    SREG x3, 12(a0)
>> >> >> > @@ -78,8 +79,9 @@ SYM(_CPU_Context_switch):
>> >> >> >    SREG x30, 120(a0)
>> >> >> >    SREG x31, 124(a0)
>> >> >> > -SYM(restore):
>> >> >> > +SYM(restore):
>> >> >> >    LREG x1, 4(a1)
>> >> >> >    LREG x2, 8(a1)
>> >> >> >    LREG x3, 12(a1)
>> >> >> > @@ -111,9 +113,15 @@ SYM(restore):
>> >> >> >    LREG x29, 116(a1)
>> >> >> >    LREG x30, 120(a1)
>> >> >> >    LREG x31, 124(a1)
>> >> >> > -       ret
>> >> >> > +  csrsi mstatus, 0x8
>> >> >> > +  nop
>> >> >> > +  nop
>> >> >> Why the nops?
>> >> >> > +  ret
>> >> >> >  SYM(_CPU_Context_restore):
>> >> >> >    mv     a1, a0
>> >> >> >    j       restore
>> >> >> >    nop
>> >> >> > 2.1.4
>> >> >> > _______________________________________________
>> >> >> > devel mailing list
>> >> >> > devel at rtems.org
>> >> >> > http://lists.rtems.org/mailman/listinfo/devel
>> >> > So, don't we turn off interrupts during the context switch?
>> >> Nope, and turning them back on unconditionally is wrong too.
>> >> > Yes, nops are unnecessary.
>> >> > Regards, Denis Obrezkov
>> > Ok, I was confused by this obsolete comment:
>> > Will remove all that enabling/disabling.
>> > Is the same true for start.S file with interrupted task's stack saving?
>> I'm not sure exactly what you're referring to, but usually start.S
>> will, among other things, turn off and ack pending interrupts to
>> quiesce the hardware before handing off the rest of system init to
>> boot_card. Eventually RTEMS will enable interrupts again using the
>> cpukit's interrupt_enable layer.
> I mean when an interrupt occurs, the execution flow jumps to the trap
> address.
> Then, in my case all process'es registers are saved in a common stack
> (I know that dedicated interrupt stack should be implemented, but I haven't
> time to do that)
> and then we jump to IRQ dispatching routine. After interrupt handling we
> restore saved
> registers. So, my question is - should we disable/enable interrupts during
> interrupt handling?
> Disabling:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L201
> Jump to dispatching routine:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L241
> Enabling interrupts back:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L285
This interrupt handling is incomplete/broken I think. Keeping the
interrupts turned off for the duration of RTEMS + User ISR handling is
not "real-time". What other CPU did you look at to understand how to
deal with interrupts?
Usually, the BSP will support installing interrupt handlers that jump
to ISR_Handler(), which then sets up a safe "C" environment for the
user handler to use. The ISR_Handler() should enable interrupts before
invoking the user code. From what I can tell, your implementation of
ISR_Handler doesn't do anything.
Gedare
