[PATCH 13/15] HiFive1: add interrupts enable/disable support
Denis Obrezkov denisobrezkov at gmail.com
Mon Aug 21 15:33:37 UTC 2017
2017-08-20 5:18 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
> On Thu, Aug 17, 2017 at 1:13 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> >  cpukit/score/cpu/riscv32/rtems/score/cpu.h | 18 ++++++++++++------
> >  1 file changed, 12 insertions(+), 6 deletions(-)
> > diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> > index 8f8a864..9b484e6 100644
> > --- a/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> > @@ -455,7 +455,7 @@ Context_Control_fp  _CPU_Null_fp_context;
> > -#define CPU_STACK_MINIMUM_SIZE  4096
> > +#define CPU_STACK_MINIMUM_SIZE  700
> >   *  CPU's worst alignment requirement for data types on a byte
> boundary.  This
> > @@ -538,7 +538,6 @@ Context_Control_fp  _CPU_Null_fp_context;
> >   *  level is returned in _level.
> >  static inline uint32_t riscv_interrupt_disable( void )
> >    register uint32_t sstatus;
> > @@ -549,13 +548,15 @@ static inline uint32_t riscv_interrupt_disable(
> void )
> >                          "csrw sstatus, %[temp]; \t"
> >                          : [temp] "=r" (temp) : [sstatus] "r" (sstatus):
> > +#elif FE3XX
> > +  __asm__ volatile ("csrci mstatus, 0x8");
> > +  (void)temp;
> Consider implementing this proprely as we discussed before. Also,
> there's no need for the #elif FE3XX; just modify the #else below.
> Enabling/disabling global interrupts in RISC-V (and this file) is
> ISA/RISC-V specific, not BSP specific.
> >  #else
> >    __asm__ __volatile__ ("csrr %[sstatus], mstatus; \t"
> >                          "andi %[temp], %[sstatus], -2; \t"
> >                          "csrw mstatus, %[temp]; \t"
> >  #endif
> >    return sstatus;
> > @@ -565,15 +566,18 @@ static inline void riscv_interrupt_enable(uint32_t
> level)
> >  #ifdef SEL4
> >    __asm__ __volatile__ ("csrw sstatus, %[level];"
> >                          :: [level] "r" (level):);
> > +#elif FE3XX
> > +  __asm__ volatile ("csrsi mstatus, 0x8");
> ditto
> >  #else
> >    __asm__ __volatile__ ("csrw mstatus, %[level];"
> >  #endif
> >  #define _CPU_ISR_Disable( _level ) \
> > -    _level = riscv_interrupt_disable()
> > +    do { \
> > +    _level = riscv_interrupt_disable();\
> > +    } while(0)
> >   *  Enable interrupts to the previous level (returned by
> _CPU_ISR_Disable).
> > @@ -583,7 +587,9 @@ static inline void riscv_interrupt_enable(uint32_t
> level)
> >  #define _CPU_ISR_Enable( _level )  \
> > -  riscv_interrupt_enable( _level )
> > +    do {\
> > +      riscv_interrupt_enable( _level ); \
> > +    } while(0)
> >   *  This temporarily restores the interrupt to _level before immediately
> > 2.1.4
> > devel mailing list
> > devel at rtems.org
> Hesham
As I answered you earlier I tried your solution and it just didn't work.
I can try it again on the next iteration of the reviewing process, but as I
said
the _level value just isn't preserved between interrupts enabling/disabling.
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170821/444a9ae7/attachment.html>
