[PATCH 11/15] HiFive1: set up oscillators
Denis Obrezkov
denisobrezkov at gmail.com
Mon Aug 21 16:27:21 UTC 2017
2017-08-17 17:16 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> On Wed, Aug 16, 2017 at 11:13 AM, Denis Obrezkov
> <denisobrezkov at gmail.com> wrote:
> > c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c | 65
> > 1 file changed, 65 insertions(+)
> > create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> > diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> > new file mode 100644
> > index 0000000..efef4e0
> > --- /dev/null
> > +++ b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> > @@ -0,0 +1,65 @@
> > + * Copyright (c) 2017
> > + * Denis Obrezkov <denisobrezkov at gmail.com>
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.org/license/LICENSE.
> > +#include <bsp.h>
> > +#include <bsp/bootcard.h>
> > +#include <bsp/prci.h>
> > +#include <bsp/fe310.h>
> > + * This routine make initialization of HiFive1 (FE310) counters.
> > +void bsp_start( void )
> > + volatile uint32_t * pll_reg = (volatile uint32_t *) PRCI_PLLCFG;
> > + volatile uint32_t * high_freq_reg = (volatile uint32_t *)
> PRCI_HFROSCCFG;
> > + volatile uint32_t * spi0 = (volatile uint32_t *) 0x10014000;
> > + volatile uint64_t * mtime_reg = (volatile uint64_t * ) 0x0200bff8;
> > + volatile uint64_t * mtimecmp_reg = (volatile uint64_t * ) 0x02004000;
> > +#ifdef USE_HFROSC
> > + /* Setting up osc frequency */
> > + uint32_t tmp_reg = 0;
> > + /* Install divider in high frequency oscillator */
> > + tmp_reg |= (HFROSC_DIV_VAL & 0x2f) << HFROSC_DIV_OFFSET;
> > + tmp_reg |= (HFROSC_TRIM_VAL & 0x1F) << HFROSC_TRIM_OFFSET;
> > + tmp_reg |= (HFROSC_EN_VAL & 0x1) << HFROSC_EN_OFFSET;
> > + (*high_freq_reg) = tmp_reg;
> It would be good to make the above into a function.
I agree but in what file should we place it?
it's not a clock or a timer.
> > + while (( (*high_freq_reg) & ((HFROSC_RDY_VAL & 0x1) \
> > + << HFROSC_RDY_OFFSET)) == 0 ) {
> > +#endif /* USE_HFROSC */
> > +#ifdef USE_HFXOSC
> > + volatile uint32_t * ext_freq_reg = (volatile uint32_t *)
> PRCI_HFXOSCCFG;
> > + (*ext_freq_reg) |= ((HFXOSC_EN_VAL & 0x1) << HFXOSC_EN_OFFSET);
> > + while (( (*ext_freq_reg) & ((HFXOSC_RDY_VAL & 0x1) \
> > + << HFXOSC_RDY_OFFSET)) == 0 ) {
> > + (*pll_reg) |= (0x1 << 18);
> > + (*pll_reg) |= (0x1 << 17);
> > + (*pll_reg) |= (0x1 << PLL_SEL_OFFSET);
> > + (*high_freq_reg) &= ~(0x1 << HFROSC_EN_OFFSET);
> > +#endif /* USE_HFXOSC */
> > +#ifndef USE_PLL
> > + /* Disable PLL */
> > + (*pll_reg) &= ~(0x1 << PLL_SEL_OFFSET);
> > +#else
> > +#endif
> > + bsp_interrupt_initialize();
> > 2.1.4
> > devel mailing list
> > devel at rtems.org
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170821/0f5678a0/attachment.html>
