[PATCH v2 07/15] HiFive1: add irq dispatching function
Denis Obrezkov denisobrezkov at gmail.com
Mon Aug 21 23:56:25 UTC 2017
 c/src/lib/libbsp/riscv32/hifive1/include/irq.h     | 12 +++
 c/src/lib/libbsp/riscv32/hifive1/irq/irq.c         | 86 ++++++++++++++++++++++
 c/src/lib/libbsp/riscv32/hifive1/start/start.S     |  3 +-
 .../score/cpu/riscv32/rtems/score/riscv-utility.h  | 26 +++++++
 4 files changed, 126 insertions(+), 1 deletion(-)
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/irq.h b/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
index 67a781f..46d29c7 100644
--- a/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
+++ b/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
@@ -11,6 +11,8 @@
  * Copyright (c) 2015 University of York.
  * Hesham ALMatary <hmka501 at york.ac.uk>
+ * Copyright (c) 2017 Denis Obrezkov <denisobrezkov at gmail.com>
  * modification, are permitted provided that the following conditions
  * are met:
@@ -52,6 +54,16 @@
 #define MCAUSE_MTIME 0x7
 #define MCAUSE_MEXT 0xB
+#define MIE_MSWI (1 << MCAUSE_MSWI)
+#define MIE_MTIME (1 << MCAUSE_MTIME)
+#define MIE_MEXT (1 << MCAUSE_MEXT)
+ * Memory mapped timer, timer comparator and software interrupt registers.
+#define MTIMECMP  ((volatile uint64_t *)0x02004000)
+#define MTIME     ((volatile uint64_t *)0x0200bff8)
+#define MSIP_REG ((volatile uint32_t *) 0x02000000)
 #endif /* ASM */
 #endif /* LIBBSP_GENERIC_RISCV_IRQ_H */
diff --git a/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c b/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
new file mode 100644
index 0000000..fadfdb7
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
@@ -0,0 +1,86 @@
+ * @file
+ * @ingroup riscv_interrupt
+ * @brief Interrupt support.
+ * RISCV CPU Dependent Source
+ * Copyright (c) 2015 University of York.
+ * Hesham ALMatary <hmka501 at york.ac.uk>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <bsp/fe310.h>
+#include <bsp/irq.h>
+#include <bsp/irq-generic.h>
+/* Almost all of the jobs that the following functions should
+ * do are implemented in cpukit
+void bsp_interrupt_handler_default(rtems_vector_number vector)
+    printk("spurious interrupt: %u\n", vector);
+rtems_status_code bsp_interrupt_facility_initialize()
+  return 0;
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
+  return 0;
+rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  return 0;
+ * FIXME: only timer intrrupt is handled
+void handle_trap (uint32_t cause)
+    if (cause & MCAUSE_INT) {
+      /* an interrupt occurred */
+      if ((cause & MCAUSE_MTIME) == MCAUSE_MTIME) {
+	/* Timer interrupt */
+        (*MTIMECMP) = (*MTIME) + FE310_CLOCK_PERIOD;
+        bsp_interrupt_handler_table[1].handler(bsp_interrupt_handler_table[1].arg);
+      } else if ((cause & MCAUSE_MEXT) == MCAUSE_MEXT) {
+	      /*External interrupt */
+      } else if ((cause & MCAUSE_MSWI) == MCAUSE_MSWI) {
+	      /* Software interrupt */
+	      *MSIP_REG = 0;
+    } else {
+      /* an exception occurred */
diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/start.S b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
index 5d0899c..b3fb3f3 100644
--- a/c/src/lib/libbsp/riscv32/hifive1/start/start.S
+++ b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
@@ -209,7 +209,8 @@ trap_entry:
   csrr t0, mcause
   SREG t0, 33*REGBYTES(sp)
-  call handle_trap_new
+  mv   a0, t0
+  call handle_trap
   LREG t0, 32*REGBYTES(sp)
   csrw mepc, t0
diff --git a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h b/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
index c45b05f..8abc0bd 100644
--- a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
+++ b/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
@@ -14,4 +14,30 @@
 #ifndef _RTEMS_SCORE_RISCV_UTILITY_H
 #define _RTEMS_SCORE_RISCV_UTILITY_H
+#define read_csr(reg) ({ unsigned long __tmp; \
+          asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
+          __tmp; })
+#define write_csr(reg, val) \
+      asm volatile ("csrw " #reg ", %0" :: "r"(val))
+#define swap_csr(reg, val) ({ long __tmp; \
+          asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "r"(val)); \
+          __tmp; })
+#define set_csr(reg, bit) ({ unsigned long __tmp; \
+          if (__builtin_constant_p(bit) && (bit) < 32) \
+            asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "i"(bit)); \
+          else \
+            asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "r"(bit)); \
+          __tmp; })
+#define clear_csr(reg, bit) ({ unsigned long __tmp; \
+            asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "i"(bit)); \
+          else \
+            asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "r"(bit)); \
+          __tmp; })
 #endif /* _RTEMS_SCORE_RISCV_UTILITY_H */
2.1.4
