[PATCH] Testsuites for inttypes methods
Aditya Upadhyay aadit0402 at gmail.com
Tue Aug 22 18:30:19 UTC 2017
 testsuites/psxtests/Makefile.am                    |  6 ++
 testsuites/psxtests/configure.ac                   |  6 ++
 testsuites/psxtests/psxinttypes01/Makefile.am      | 22 ++++++
 testsuites/psxtests/psxinttypes01/init.c           | 58 ++++++++++++++
 .../psxtests/psxinttypes01/psxinttypes01.scn       |  3 +
 testsuites/psxtests/psxinttypes02/Makefile.am      | 22 ++++++
 testsuites/psxtests/psxinttypes02/init.c           | 68 ++++++++++++++++
 .../psxtests/psxinttypes02/psxinttypes02.scn       |  4 +
 testsuites/psxtests/psxinttypes03/Makefile.am      | 22 ++++++
 testsuites/psxtests/psxinttypes03/init.c           | 90 ++++++++++++++++++++++
 .../psxtests/psxinttypes03/psxinttypes03.scn       | 10 +++
 testsuites/psxtests/psxinttypes04/Makefile.am      | 22 ++++++
 testsuites/psxtests/psxinttypes04/init.c           | 73 ++++++++++++++++++
 .../psxtests/psxinttypes04/psxinttypes04.scn       |  4 +
 testsuites/psxtests/psxinttypes05/Makefile.am      | 22 ++++++
 testsuites/psxtests/psxinttypes05/init.c           | 70 +++++++++++++++++
 .../psxtests/psxinttypes05/psxinttypes05.scn       |  3 +
 testsuites/psxtests/psxinttypes06/Makefile.am      | 22 ++++++
 testsuites/psxtests/psxinttypes06/init.c           | 70 +++++++++++++++++
 .../psxtests/psxinttypes06/psxinttypes06.scn       |  3 +
 20 files changed, 600 insertions(+)
 create mode 100644 testsuites/psxtests/psxinttypes01/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes01/init.c
 create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
 create mode 100644 testsuites/psxtests/psxinttypes02/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes02/init.c
 create mode 100644 testsuites/psxtests/psxinttypes02/psxinttypes02.scn
 create mode 100644 testsuites/psxtests/psxinttypes03/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes03/init.c
 create mode 100644 testsuites/psxtests/psxinttypes03/psxinttypes03.scn
 create mode 100644 testsuites/psxtests/psxinttypes04/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes04/init.c
 create mode 100644 testsuites/psxtests/psxinttypes04/psxinttypes04.scn
 create mode 100644 testsuites/psxtests/psxinttypes05/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes05/init.c
 create mode 100644 testsuites/psxtests/psxinttypes05/psxinttypes05.scn
 create mode 100644 testsuites/psxtests/psxinttypes06/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes06/init.c
 create mode 100644 testsuites/psxtests/psxinttypes06/psxinttypes06.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index cccdb39..cda0061 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -58,6 +58,12 @@ _SUBDIRS += psxhdrs
 _SUBDIRS += psxintrcritical01
 _SUBDIRS += psxitimer
 endif
+_SUBDIRS += psxinttypes01
+_SUBDIRS += psxinttypes02
+_SUBDIRS += psxinttypes03
+_SUBDIRS += psxinttypes04
+_SUBDIRS += psxinttypes05
+_SUBDIRS += psxinttypes06
 _SUBDIRS += psxkey01
 _SUBDIRS += psxkey02
 _SUBDIRS += psxkey03
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 96a0149..dd5f23f 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -162,6 +162,12 @@ psxid01/Makefile
 psximfs01/Makefile
 psximfs02/Makefile
 psxintrcritical01/Makefile
+psxinttypes01/Makefile
+psxinttypes02/Makefile
+psxinttypes03/Makefile
+psxinttypes04/Makefile
+psxinttypes05/Makefile
+psxinttypes06/Makefile
 psxitimer/Makefile
 psxkey01/Makefile
 psxkey02/Makefile
diff --git a/testsuites/psxtests/psxinttypes01/Makefile.am b/testsuites/psxtests/psxinttypes01/Makefile.am
new file mode 100644
index 0000000..90608d4
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes01
+psxinttypes01_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes01.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+#AM_CPPFLAGS = -I$(top_srcdir)/include
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes01_LDADD)
+LINK_OBJS = $(psxinttypes01_OBJECTS)
+LINK_LIBS = $(psxinttypes01_LDLIBS)
+psxinttypes01$(EXEEXT): $(psxinttypes01_OBJECTS) $(psxinttypes01_DEPENDENCIES)
+	@rm -f psxinttypes01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
index 0000000..ad41a6d
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -0,0 +1,58 @@
+ *  This is the test for inttypes imaxabs method.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/inttypes.h>
+#include <rtems/printer.h>
+#include <rtems/test.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <bsp.h>
+#include <stdint.h>
+#include <errno.h>
+#include <tmacros.h>
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "PSXINTTYPE 01";
+rtems_printer rtems_test_printer;
+ * RTEMS Startup Task
+rtems_task Init(
+  rtems_task_argument ignored
+  rtems_print_printer_printf(&rtems_test_printer);
+  rtems_test_begin();
+  intmax_t a = -1234;
+  intmax_t b = imaxabs(a);
+  printf( "imaxabs_value = %jd\n", b);
+  rtems_test_end();
+  exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
index 0000000..15051e1
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXINTTYPE 01 ***
+imaxabs_value = 1234
+*** END OF TEST PSXINTTYPE 01 ***
diff --git a/testsuites/psxtests/psxinttypes02/Makefile.am b/testsuites/psxtests/psxinttypes02/Makefile.am
index 0000000..2e4ce3b
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes02/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes02
+psxinttypes02_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes02.scn
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes02_LDADD)
+LINK_OBJS = $(psxinttypes02_OBJECTS)
+LINK_LIBS = $(psxinttypes02_LDLIBS)
+psxinttypes02$(EXEEXT): $(psxinttypes02_OBJECTS) $(psxinttypes02_DEPENDENCIES)
+	@rm -f psxinttypes02$(EXEEXT)
+	$(make-exe)
diff --git a/testsuites/psxtests/psxinttypes02/init.c b/testsuites/psxtests/psxinttypes02/init.c
index 0000000..762a711
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes02/init.c
@@ -0,0 +1,68 @@
+ *  This is the test for inttypes imaxdiv method.
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include <errno.h>
+const char rtems_test_name[] = "PSXINTTYPE 02";
+rtems_task Init(
+  /*Test for imaxdiv */
+  intmax_t x,y;
+  imaxdiv_t div_result;
+  x = 27;
+  y = 4;
+  printf("The call to imaxdiv(%lld, %lld)\n", x, y);
+  div_result = imaxdiv(x, y);
+  printf("results in a quotient of %lld, and a remainder of %lld\n\n",
+         div_result.quot, div_result.rem);
+  rtems_test_end();
+  exit( 0 );
diff --git a/testsuites/psxtests/psxinttypes02/psxinttypes02.scn b/testsuites/psxtests/psxinttypes02/psxinttypes02.scn
index 0000000..d691475
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes02/psxinttypes02.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXINTTYPE 02 ***
+The call to imaxdiv(27, 4)
+results in a quotient of 6 and a remainder of 4
+*** END OF TEST PSXINTTYPE 02 ***
diff --git a/testsuites/psxtests/psxinttypes03/Makefile.am b/testsuites/psxtests/psxinttypes03/Makefile.am
index 0000000..137f229
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes03/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes03
+psxinttypes03_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes03.scn
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes03_LDADD)
+LINK_OBJS = $(psxinttypes03_OBJECTS)
+LINK_LIBS = $(psxinttypes03_LDLIBS)
+psxinttypes03$(EXEEXT): $(psxinttypes03_OBJECTS) $(psxinttypes03_DEPENDENCIES)
+	@rm -f psxinttypes03$(EXEEXT)
+	$(make-exe)
diff --git a/testsuites/psxtests/psxinttypes03/init.c b/testsuites/psxtests/psxinttypes03/init.c
index 0000000..58dfb7b
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes03/init.c
@@ -0,0 +1,90 @@
+ *  This is the test for inttypes library. It covers these functions :
+ *  imaxabs(), imaxdiv(), strtoimax(), strtoumax(), wcstoimax(), wcstoumax().
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include <errno.h>
+rtems_task Init(
+  /*Test for strtoimax */
+  char* endptr;
+  n = strtoimax ("-123junk", &endptr, 10);   /* base 10                    */
+  rtems_test_assert (n == ERANGE);
+  rtems_test_assert (n == EINVAL);
+  printf("BASE 10 : %jd\n", n);
+  n = strtoimax ("11111111", &endptr, 2);   /* base 2                    */
+  printf("BASE 2 : %jd\n", n);
+  n = strtoimax ("XyZ", &endptr, 36);       /* base 36                    */
+  printf("BASE 36 : %jd\n", n);
+  n = strtoimax ("010", &endptr, 0);        /* octal auto-detection  */
+  printf("OCTAL AUTO-DETECTION : %jd\n", n);
+  n = strtoimax ("10", &endptr, 0);         /* decimal auto-detection */
+  printf("DECIMAL AUTO-DETECTION : %jd\n", n);
+  n = strtoimax ("0x10", &endptr, 0);      /* hexadecimal auto-detection */
+  printf("HEXADECIMAL AUTO-DETECTION : %jd\n", n);
+  /* range error             */
+  /* LONG_MAX+1 --> LONG_MAX */
+  errno = 0;
+  printf("%jd\n", strtoimax("9223372036854775808",&endptr,10));
+  printf("%s\n", strerror(errno));
+  rtems_test_end();
+  exit( 0 );
diff --git a/testsuites/psxtests/psxinttypes03/psxinttypes03.scn b/testsuites/psxtests/psxinttypes03/psxinttypes03.scn
index 0000000..05d909c
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes03/psxinttypes03.scn
@@ -0,0 +1,10 @@
+*** BEGIN OF TEST PSXINTTYPE 03 ***
+BASE 10 : -123
+BASE 2 : 255
+BASE 36 : 44027
+OCTAL AUTO-DETECTION : 8
+DECIMAL AUTO-DETECTION : 10
+HEXADECIMAL AUTO-DETECTION : 16
+9223372036854775807
+Result too large
+*** END OF TEST PSXINTTYPE 03 ***
diff --git a/testsuites/psxtests/psxinttypes04/Makefile.am b/testsuites/psxtests/psxinttypes04/Makefile.am
index 0000000..cc59a35
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes04/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes04
+psxinttypes04_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes04.scn
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes04_LDADD)
+LINK_OBJS = $(psxinttypes04_OBJECTS)
+LINK_LIBS = $(psxinttypes04_LDLIBS)
+psxinttypes04$(EXEEXT): $(psxinttypes04_OBJECTS) $(psxinttypes04_DEPENDENCIES)
+	@rm -f psxinttypes04$(EXEEXT)
+	$(make-exe)
diff --git a/testsuites/psxtests/psxinttypes04/init.c b/testsuites/psxtests/psxinttypes04/init.c
index 0000000..969fd49
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes04/init.c
@@ -0,0 +1,73 @@
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include <errno.h>
+const char rtems_test_name[] = "PSXINTTYPE 04";
+rtems_task Init(
+  char* endptr, *nptr;
+  uintmax_t j;
+  int base = 10;
+  rtems_test_assert (base == EINVAL);
+  nptr  = "20690239864abc";
+  /* test for strtoumax */
+  j = strtoumax (nptr, &endptr, base);
+  rtems_test_assert (j == ERANGE);
+  rtems_test_assert (j == EINVAL);
+  printf( "strtoumax = %ju ( base %d )\n", j, base );
+  printf( "Stopped scan at %s\n\n", endptr );
+  rtems_test_end();
+  exit( 0 );
diff --git a/testsuites/psxtests/psxinttypes04/psxinttypes04.scn b/testsuites/psxtests/psxinttypes04/psxinttypes04.scn
index 0000000..c86bc44
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes04/psxinttypes04.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXINTTYPE 04 ***
+strtoumax = 20690239864 (base 10)
+Stopped scan at abc
+*** END OF TEST PSXINTTYPE 04 ***
diff --git a/testsuites/psxtests/psxinttypes05/Makefile.am b/testsuites/psxtests/psxinttypes05/Makefile.am
index 0000000..1a9e1e6
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes05/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes05
+psxinttypes05_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes05.scn
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes05_LDADD)
+LINK_OBJS = $(psxinttypes05_OBJECTS)
+LINK_LIBS = $(psxinttypes05_LDLIBS)
+psxinttypes05$(EXEEXT): $(psxinttypes05_OBJECTS) $(psxinttypes05_DEPENDENCIES)
+	@rm -f psxinttypes05$(EXEEXT)
+	$(make-exe)
diff --git a/testsuites/psxtests/psxinttypes05/init.c b/testsuites/psxtests/psxinttypes05/init.c
index 0000000..bac42cc
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes05/init.c
@@ -0,0 +1,70 @@
+ *  This is the test for inttypes wcstoimax method.
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include <errno.h>
+const char rtems_test_name[] = "PSXINTTYPE 05";
+rtems_task Init(
+  int base = 10;
+  wchar_t *nptr1, *endptr1;
+  intmax_t m;
+  nptr1 = L"10110134932";
+  /* Test for wcstoimax */
+  m = wcstoimax(nptr1, &endptr1, base);
+  rtems_test_assert (m == ERANGE);
+  rtems_test_assert (m == EINVAL);
+  printf( "wcstoimax = %jd\n", m );
+  rtems_test_end();
+  exit( 0 );
diff --git a/testsuites/psxtests/psxinttypes05/psxinttypes05.scn b/testsuites/psxtests/psxinttypes05/psxinttypes05.scn
index 0000000..67e3eb8
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes05/psxinttypes05.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXINTTYPE 05 ***
+wcstoumax = 10110134932
+*** END OF TEST PSXINTTYPE 05 ***
diff --git a/testsuites/psxtests/psxinttypes06/Makefile.am b/testsuites/psxtests/psxinttypes06/Makefile.am
index 0000000..a284e5a
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes06/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes06
+psxinttypes06_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes06.scn
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes06_LDADD)
+LINK_OBJS = $(psxinttypes06_OBJECTS)
+LINK_LIBS = $(psxinttypes06_LDLIBS)
+psxinttypes06$(EXEEXT): $(psxinttypes06_OBJECTS) $(psxinttypes06_DEPENDENCIES)
+	@rm -f psxinttypes06$(EXEEXT)
+	$(make-exe)
diff --git a/testsuites/psxtests/psxinttypes06/init.c b/testsuites/psxtests/psxinttypes06/init.c
index 0000000..15c75cf
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes06/init.c
@@ -0,0 +1,70 @@
+ *  This is the test for inttypes wcstoumax method.
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include <errno.h>
+const char rtems_test_name[] = "PSXINTTYPE 06";
+rtems_task Init(
+  uintmax_t k;
+  int base = 10;
+  /*test for wcstoumax */
+  k = wcstoumax (nptr1, &endptr1, base);
+  rtems_test_assert (k == ERANGE);
+  rtems_test_assert (k == EINVAL);
+  printf( "wcstoumax value : %ju\n", k );
+  rtems_test_end();
+  exit( 0 );
diff --git a/testsuites/psxtests/psxinttypes06/psxinttypes06.scn b/testsuites/psxtests/psxinttypes06/psxinttypes06.scn
index 0000000..d14b9a8
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes06/psxinttypes06.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXINTTYPE 06 ***
+*** END OF TEST PSXINTTYPE 06 ***
2.7.4
