[RTEMS Project] #3240: cpukit/libmisc/stackchk/check.c stack addresses formatted incorrectly.
Wed Dec 6 06:04:25 UTC 2017
On 06/12/2017 16:06, groups at chichak.ca wrote:
> Joel,
> I followed all of Chris’ instructions as much as I understood:
You have.
>> On 2017-November-16, at 21:21, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 17/11/2017 15:05, groups at chichak.ca <mailto:groups at chichak.ca> wrote:
>>> (I don’t know how to proceed with getting this reported/fixed.)
>> Please head to the wiki (https://devel.rtems.org/) and select the link in the
>> "Reporting a bug" column of the Releases Table for the release you are reporting
>> the bug against. You will need an account.
>> - Clone the git repo and select the branch.
>> - Make the change and test.
>> - Commit the change with a summary as the first line and then if
>> you need more detail add a body. End the commit message with
>> "Close #12345." with the ticket number.
>>   eg git commit
>>    libmisc: Fix formatting in Stack_check_Dump_threads_usage
>>    Close #12345.
>> - Enter 'git format-patch -1'
>> - Attach the patch to the ticket.
> I guess I didn’t understand. I thought I needed to attach the diff to the ticket
> and some god-like person would do the final vet and push into the repo. No?
Joel is looking at the tickets for 5.1 and this one is fine. It just needs to be
applied. I will update the ticket.
