[PATCH] dosfs: Allow creating a file with similar name.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Dec 6 15:09:24 UTC 2017
Hello Joel,
Am 06.12.2017 um 16:00 schrieb Joel Sherrill:
> Should the test .doc file be updated to include this test case?
I think that "Make sure short file- and directory names and long file-
and directory names are handled correctly for the default character set
(code page 850)" already covers that. It is a case where a file name
should be handled correctly.
> Is this a test case.worth running against other filesystems?
The bug has been (again) a bug that is quite specific to our FAT
implementation. It's more a test to prevent regression in case someone
(for example me) touches the much too complex function
msdos_find_file_in_directory() again. I would think it rather unlikely
that another file system has the same problem with names.
Regards
Christian
> --joel
> On Dec 6, 2017 9:57 AM, "Christian Mauderer"
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     From: Christian Mauderer <Christian.Mauderer at embedded-brains.de
>     <mailto:Christian.Mauderer at embedded-brains.de>>
>     If there is already a file with a long file name it isn't possible to
>     create a second file which has a name that ends on the first files name
>     (for example ets.beam and sets.beam). This patch fixes that.
>      cpukit/libfs/src/dosfs/msdos_misc.c     | 10 +++++++---
>      testsuites/fstests/fsdosfsname01/init.c | 25 +++++++++++++++++++++++++
>      2 files changed, 32 insertions(+), 3 deletions(-)
>     diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c
>     b/cpukit/libfs/src/dosfs/msdos_misc.c
>     index 79aaa36520..24eb2d11e0 100644
>     --- a/cpukit/libfs/src/dosfs/msdos_misc.c
>     +++ b/cpukit/libfs/src/dosfs/msdos_misc.c
>     @@ -1564,9 +1564,13 @@ msdos_find_file_in_directory (
>                          if (entry_matched)
>                              if (lfn_entry ||
>     -                            lfn_checksum != msdos_lfn_checksum(entry))
>     -                            entry_matched = false;
>     -                        else if (name_len_remaining == 0) {
>     +                            name_len_remaining > 0 ||
>     +                            lfn_checksum !=
>     msdos_lfn_checksum(entry)) {
>     +                            msdos_prepare_for_next_entry(&lfn_start,
>      &entry_matched,
>      &name_len_remaining,
>      name_len_for_compare);
>     +                        } else if (name_len_remaining == 0) {
>                                  filename_matched = true;
>                                  rc = msdos_on_entry_found (
>                                      fs_info,
>     diff --git a/testsuites/fstests/fsdosfsname01/init.c
>     b/testsuites/fstests/fsdosfsname01/init.c
>     index d0c909877c..846faf28a3 100644
>     --- a/testsuites/fstests/fsdosfsname01/init.c
>     +++ b/testsuites/fstests/fsdosfsname01/init.c
>     @@ -1097,6 +1097,30 @@ static void test_end_of_string_matches( void )
>        rtems_test_assert( rc == 0 );
>     +static void test_end_of_string_matches_2( void )
>     +  int rc;
>     +  int fd;
>     +  fd = open( MOUNT_DIR "/ets.beam", O_RDWR | O_CREAT,
>     +             S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH |
>     S_IWOTH );
>     +  rtems_test_assert( fd >= 0 );
>     +  rc = close( fd );
>     +  rtems_test_assert( rc == 0 );
>     +  fd = open( MOUNT_DIR "/sets.beam", O_RDWR | O_CREAT,
>     S_IWOTH );
>     +  rc = close( fd );
>     +  rc = unlink( MOUNT_DIR "/sets.beam" );
>     +  rc = unlink( MOUNT_DIR "/ets.beam" );
>      static void test_full_8_3_name( void )
>        int rc;
>     @@ -1151,6 +1175,7 @@ static void
>     test_file_with_same_name_as_volume_label( void )
>      static void test_special_cases( void )
>        test_end_of_string_matches();
>     +  test_end_of_string_matches_2();
>        test_full_8_3_name();
>        test_file_with_same_name_as_volume_label();
>        test_dir_with_same_name_as_volume_label();
>     2.12.3
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
