RFC: PowerPC bsp_specs Clean Up Question
Tue Dec 12 15:08:38 UTC 2017
On Mon, Dec 11, 2017 at 8:54 PM, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Many of the PowerPC BSPs uses a shared linker script. That's good.
> Unfortunately, there is variation in the start symbol and the use of a "-u"
> (e.g. undefined) symbol in the bsp_specs. I had initially thought I would
> add the start symbol and any use of -u to the linkcmds (EXTERN). But now I
> am thinking that due to use of shared linker scripts and inconsistencies,
> some BSPs are better off if I add command line arguments to the linking
> stage.
Maybe you need another layer of linkcmds that defines these varying
fields before including the shared linkcmds?
> Also some use motld_start.o as the start file which is in conflict with
> other BSPs using the same linker script.
> This is the fragment in bsp_specs I am trying to eliminate or standardize:
> -e __rtems_entry_point -u __vectors motld_start.o%s
> Thoughts?
> --joel
> devel mailing list
> devel at rtems.org
