RFC: PowerPC bsp_specs Clean Up Question
Thu Dec 21 07:13:03 UTC 2017
On 12/12/17 02:54, Joel Sherrill wrote:
> Many of the PowerPC BSPs uses a shared linker script. That's good.
> Unfortunately, there is variation in the start symbol and the use of a
> "-u" (e.g. undefined) symbol in the bsp_specs. I had initially thought
> I would add the start symbol and any use of -u to the linkcmds
> (EXTERN). But now I am thinking that due to use of shared linker
> scripts and inconsistencies, some BSPs are better off if I add command
> line arguments to the linking stage.
> Also some use motld_start.o as the start file which is in conflict
> with other BSPs using the same linker script.
> This is the fragment in bsp_specs I am trying to eliminate or standardize:
> -e __rtems_entry_point -u __vectors motld_start.o%s
> Thoughts?
Why don't we use _start for all entry points and start.o for all start
files?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
