[PATCH] Remove CONFIGURE_SMP_APPLICATION
Wed Feb 1 11:13:40 UTC 2017
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
 cpukit/libmisc/dummy/default-configuration.c    |  2 --
 cpukit/sapi/include/confdefs.h                  | 34 +++++++++----------------
 cpukit/sapi/include/rtems/config.h              |  8 ++----
 testsuites/smptests/smp01/system.h              |  1 -
 testsuites/smptests/smp02/system.h              |  1 -
 testsuites/smptests/smp03/system.h              |  1 -
 testsuites/smptests/smp05/init.c                |  1 -
 testsuites/smptests/smp07/init.c                |  1 -
 testsuites/smptests/smp08/system.h              |  1 -
 testsuites/smptests/smp09/init.c                |  1 -
 testsuites/smptests/smpaffinity01/init.c        |  2 --
 testsuites/smptests/smpatomic01/init.c          |  2 --
 testsuites/smptests/smpcache01/init.c           |  2 --
 testsuites/smptests/smpcapture01/init.c         |  2 --
 testsuites/smptests/smpcapture02/init.c         |  1 -
 testsuites/smptests/smpclock01/init.c           |  2 --
 testsuites/smptests/smpfatal01/init.c           |  2 --
 testsuites/smptests/smpfatal02/init.c           |  2 --
 testsuites/smptests/smpfatal04/init.c           |  4 ---
 testsuites/smptests/smpfatal05/init.c           |  2 --
 testsuites/smptests/smpfatal06/init.c           |  4 +--
 testsuites/smptests/smpfatal08/init.c           |  2 --
 testsuites/smptests/smpipi01/init.c             |  2 --
 testsuites/smptests/smpload01/init.c            |  2 --
 testsuites/smptests/smplock01/init.c            |  2 --
 testsuites/smptests/smpmigration01/init.c       |  2 --
 testsuites/smptests/smpmigration02/init.c       |  2 --
 testsuites/smptests/smpmrsp01/init.c            |  2 --
 testsuites/smptests/smpmutex01/init.c           |  2 --
 testsuites/smptests/smpmutex02/init.c           |  2 --
 testsuites/smptests/smppsxaffinity01/init.c     |  2 --
 testsuites/smptests/smppsxaffinity02/init.c     |  1 -
 testsuites/smptests/smppsxmutex01/init.c        |  2 --
 testsuites/smptests/smppsxsignal01/init.c       |  2 --
 testsuites/smptests/smpschedaffinity01/init.c   |  2 --
 testsuites/smptests/smpschedaffinity02/init.c   |  2 --
 testsuites/smptests/smpschedaffinity03/init.c   |  2 --
 testsuites/smptests/smpschedaffinity04/init.c   |  2 --
 testsuites/smptests/smpschedaffinity05/init.c   |  2 --
 testsuites/smptests/smpschedsem01/init.c        |  2 --
 testsuites/smptests/smpscheduler01/init.c       |  2 --
 testsuites/smptests/smpscheduler02/init.c       |  2 --
 testsuites/smptests/smpscheduler03/init.c       |  2 --
 testsuites/smptests/smpscheduler04/init.c       |  2 --
 testsuites/smptests/smpsignal01/init.c          |  2 --
 testsuites/smptests/smpstrongapa01/init.c       |  2 --
 testsuites/smptests/smpswitchextension01/init.c |  2 --
 testsuites/smptests/smpthreadlife01/init.c      |  2 --
 testsuites/smptests/smpunsupported01/init.c     |  4 +--
 testsuites/smptests/smpwakeafter01/init.c       |  2 --
 testsuites/sptests/sptimecounter02/init.c       |  2 --
 testsuites/sptests/sptimecounter03/init.c       |  2 --
 testsuites/tmtests/tmcontext01/init.c           |  2 --
 testsuites/tmtests/tmfine01/init.c              |  2 --
 54 files changed, 16 insertions(+), 127 deletions(-)
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
index c1898d3..8d809a0 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -102,8 +102,6 @@ static void Init( rtems_task_argument arg )
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_SMP_APPLICATION
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 32
 #define CONFIGURE_DISABLE_BSP_SETTINGS
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index b15d522..cbe4a33 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -206,19 +206,16 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   extern int rtems_telnetd_maximum_ptys;
 #endif
-#if defined(RTEMS_SMP)
-   *  If configured for SMP, then we need to know the maximum CPU cores.
-  #if !defined(CONFIGURE_SMP_APPLICATION)
-    #if !defined(CONFIGURE_SMP_MAXIMUM_PROCESSORS)
-      #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
-    #endif
-  #else
-      #error "CONFIGURE_SMP_MAXIMUM_PROCESSORS not specified for SMP Application"
-    #endif
-  #endif
+#ifndef CONFIGURE_SMP_MAXIMUM_PROCESSORS
+  #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
+#endif
+ * An internal define to indicate that this is an SMP application
+ * configuration.
+#if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1
+  #define _CONFIGURE_SMP_APPLICATION
 #endif
@@ -797,7 +794,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) && \
     !defined(CONFIGURE_SCHEDULER_EDF) && \
     !defined(CONFIGURE_SCHEDULER_CBS)
-  #if defined(RTEMS_SMP) && defined(CONFIGURE_SMP_APPLICATION)
+  #ifdef _CONFIGURE_SMP_APPLICATION
      * If no scheduler is specified in an SMP configuration, the
      * priority scheduler is default.
@@ -1499,7 +1496,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * used to specify the initial execution mode of the single Classic API task.
 #ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
     #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
   #else
     #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
@@ -3376,13 +3373,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #else
       false,
     #endif
-    #ifdef RTEMS_SMP
-      #ifdef CONFIGURE_SMP_APPLICATION
-        true,
-      #else
-        false,
-      #endif
-    #endif
     CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS,   /* number of static extensions */
     CONFIGURE_INITIAL_EXTENSION_TABLE,        /* pointer to static extensions */
     #if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/sapi/include/rtems/config.h b/cpukit/sapi/include/rtems/config.h
index 1b48ea9..ddcb77c 100644
--- a/cpukit/sapi/include/rtems/config.h
+++ b/cpukit/sapi/include/rtems/config.h
@@ -237,10 +237,6 @@ typedef struct {
   bool                           stack_allocator_avoids_work_space;
-  #ifdef RTEMS_SMP
-    bool                         smp_enabled;
-  #endif
   uint32_t                       number_of_initial_extensions;
   const rtems_extensions_table  *User_extension_table;
@@ -356,7 +352,7 @@ extern const rtems_configuration_table Configuration;
  * @brief Returns true if the SMP mode of operation is enabled, and false
  * otherwise.
- * On single-processor configurations this is a compile time constant which
+ * In uni-processor configurations this is a compile-time constant which
  * evaluates to false.
  * @retval true SMP mode of operation is enabled.
@@ -364,7 +360,7 @@ extern const rtems_configuration_table Configuration;
 #ifdef RTEMS_SMP
   #define rtems_configuration_is_smp_enabled() \
-        (Configuration.smp_enabled)
+        (rtems_configuration_get_maximum_processors() > 1)
 #else
         false
diff --git a/testsuites/smptests/smp01/system.h b/testsuites/smptests/smp01/system.h
index 3156dab..7ced2f6 100644
--- a/testsuites/smptests/smp01/system.h
+++ b/testsuites/smptests/smp01/system.h
@@ -25,7 +25,6 @@ rtems_task Test_task(
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS   4
 #define CONFIGURE_MAXIMUM_TASKS            \
diff --git a/testsuites/smptests/smp02/system.h b/testsuites/smptests/smp02/system.h
index f062f44..f4923f3 100644
--- a/testsuites/smptests/smp02/system.h
+++ b/testsuites/smptests/smp02/system.h
diff --git a/testsuites/smptests/smp03/system.h b/testsuites/smptests/smp03/system.h
index e673677..c15266a 100644
--- a/testsuites/smptests/smp03/system.h
+++ b/testsuites/smptests/smp03/system.h
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index 31f77a3..4a0ca61 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -85,7 +85,6 @@ rtems_task Init(
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS   2
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index 6acfe21..85dba89 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -176,7 +176,6 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TIMERS           1
diff --git a/testsuites/smptests/smp08/system.h b/testsuites/smptests/smp08/system.h
index de41c0a..63f4b1d 100644
--- a/testsuites/smptests/smp08/system.h
+++ b/testsuites/smptests/smp08/system.h
@@ -27,7 +27,6 @@ rtems_task Test_task(
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/init.c
index d0ea3f7..12b6d75 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -88,7 +88,6 @@ rtems_task Init(
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
index 1b8fc72..2e5fa55 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -227,8 +227,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 007d012..24abbf5 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -829,8 +829,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK (MS_PER_TICK * 1000)
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
 #define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index b8a7b71..7c8617f 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -268,8 +268,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/smpcapture01/init.c
index bfa2d33..4187e19 100644
--- a/testsuites/smptests/smpcapture01/init.c
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -251,8 +251,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture02/init.c b/testsuites/smptests/smpcapture02/init.c
index 78b5388..f2b136a 100644
--- a/testsuites/smptests/smpcapture02/init.c
+++ b/testsuites/smptests/smpcapture02/init.c
@@ -427,7 +427,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS MAX_CPUS
diff --git a/testsuites/smptests/smpclock01/init.c b/testsuites/smptests/smpclock01/init.c
index ec98e2e..120a079 100644
--- a/testsuites/smptests/smpclock01/init.c
+++ b/testsuites/smptests/smpclock01/init.c
@@ -174,8 +174,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SCHEDULER_SIMPLE_SMP
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 457469f..2710629 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -126,8 +126,6 @@ static rtems_status_code test_driver_init(
   { .fatal = fatal_extension }, \
   RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 3aa20e3..7d8d541 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -127,8 +127,6 @@ static rtems_status_code test_driver_init(
diff --git a/testsuites/smptests/smpfatal04/init.c b/testsuites/smptests/smpfatal04/init.c
index e8b43d7..0215914 100644
--- a/testsuites/smptests/smpfatal04/init.c
+++ b/testsuites/smptests/smpfatal04/init.c
@@ -56,10 +56,6 @@ static void fatal_extension(
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
 #define CONFIGURE_SCHEDULER_CONTROLS
 #define CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER
diff --git a/testsuites/smptests/smpfatal05/init.c b/testsuites/smptests/smpfatal05/init.c
index 506a62e..bbafb5e 100644
--- a/testsuites/smptests/smpfatal05/init.c
+++ b/testsuites/smptests/smpfatal05/init.c
@@ -56,8 +56,6 @@ static void fatal_extension(
 /* Lets see when the first RTEMS system hits this limit */
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 64
diff --git a/testsuites/smptests/smpfatal06/init.c b/testsuites/smptests/smpfatal06/init.c
index 0e363d1..4fb4074 100644
--- a/testsuites/smptests/smpfatal06/init.c
+++ b/testsuites/smptests/smpfatal06/init.c
@@ -56,9 +56,7 @@ static void fatal_extension(
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 2
diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
index ee1f94c..fd738d5 100644
--- a/testsuites/smptests/smpfatal08/init.c
+++ b/testsuites/smptests/smpfatal08/init.c
@@ -113,8 +113,6 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpipi01/init.c b/testsuites/smptests/smpipi01/init.c
index 8c39d18..8879296 100644
--- a/testsuites/smptests/smpipi01/init.c
+++ b/testsuites/smptests/smpipi01/init.c
@@ -202,8 +202,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index d4c303d..bcce1d9 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -392,8 +392,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK 1000
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
index e57b441..ac7e9e2 100644
--- a/testsuites/smptests/smplock01/init.c
+++ b/testsuites/smptests/smplock01/init.c
@@ -761,8 +761,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmigration01/init.c b/testsuites/smptests/smpmigration01/init.c
index 12c0cb0..7ad1e93 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -238,8 +238,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (2 + RUNNER_COUNT)
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index 193d599..bfba962 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -281,8 +281,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index bb729e0..2690618 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -1771,8 +1771,6 @@ static void Init(rtems_task_argument arg)
   rtems_test_exit(0);
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/smpmutex01/init.c
index 33b7e93..46c0bf3 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -943,8 +943,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS PART_COUNT
diff --git a/testsuites/smptests/smpmutex02/init.c b/testsuites/smptests/smpmutex02/init.c
index ab4af65..09e61e1 100644
--- a/testsuites/smptests/smpmutex02/init.c
+++ b/testsuites/smptests/smpmutex02/init.c
@@ -322,8 +322,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + WORKER_COUNT)
 #define CONFIGURE_MAXIMUM_SEMAPHORES (1 + MTX_COUNT)
diff --git a/testsuites/smptests/smppsxaffinity01/init.c b/testsuites/smptests/smppsxaffinity01/init.c
index cb9e0b3..89b29f5 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
@@ -161,8 +161,6 @@ void *POSIX_Init(
diff --git a/testsuites/smptests/smppsxaffinity02/init.c b/testsuites/smptests/smppsxaffinity02/init.c
index 9f2190f..54d3ead 100644
--- a/testsuites/smptests/smppsxaffinity02/init.c
+++ b/testsuites/smptests/smppsxaffinity02/init.c
@@ -230,7 +230,6 @@ void *POSIX_Init(
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/smppsxmutex01/init.c
index 1cd7be5..8f19b6e 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -159,8 +159,6 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 2
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 2
 #define CONFIGURE_SCHEDULER_PRIORITY_SMP
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index b954cbd..9299292 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -176,8 +176,6 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/smptests/smpschedaffinity01/init.c b/testsuites/smptests/smpschedaffinity01/init.c
index 1f1e32a..a653f46 100644
--- a/testsuites/smptests/smpschedaffinity01/init.c
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -155,8 +155,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity02/init.c b/testsuites/smptests/smpschedaffinity02/init.c
index 1b81f6b..fe55bc0 100644
--- a/testsuites/smptests/smpschedaffinity02/init.c
+++ b/testsuites/smptests/smpschedaffinity02/init.c
@@ -209,8 +209,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity03/init.c b/testsuites/smptests/smpschedaffinity03/init.c
index 5b8acf7..04ed4ec 100644
--- a/testsuites/smptests/smpschedaffinity03/init.c
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -83,8 +83,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity04/init.c b/testsuites/smptests/smpschedaffinity04/init.c
index f5ccab8..a2066ad 100644
--- a/testsuites/smptests/smpschedaffinity04/init.c
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -164,8 +164,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity05/init.c b/testsuites/smptests/smpschedaffinity05/init.c
index 5f23503..2ab828c 100644
--- a/testsuites/smptests/smpschedaffinity05/init.c
+++ b/testsuites/smptests/smpschedaffinity05/init.c
@@ -223,8 +223,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedsem01/init.c b/testsuites/smptests/smpschedsem01/init.c
index 3ef9ab1..04d8a98 100644
--- a/testsuites/smptests/smpschedsem01/init.c
+++ b/testsuites/smptests/smpschedsem01/init.c
@@ -75,8 +75,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler01/init.c b/testsuites/smptests/smpscheduler01/init.c
index 9518a4d..734ab8b 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -196,8 +196,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 0e4480b..5ef8de1 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -402,8 +402,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_SEMAPHORES 2
 #define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 1
diff --git a/testsuites/smptests/smpscheduler03/init.c b/testsuites/smptests/smpscheduler03/init.c
index 4aa6a01..51098b6 100644
--- a/testsuites/smptests/smpscheduler03/init.c
+++ b/testsuites/smptests/smpscheduler03/init.c
@@ -671,8 +671,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_MAX
 #define CONFIGURE_MAXIMUM_PRIORITY 255
diff --git a/testsuites/smptests/smpscheduler04/init.c b/testsuites/smptests/smpscheduler04/init.c
index 2e5b213..b87edc9 100644
--- a/testsuites/smptests/smpscheduler04/init.c
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -180,8 +180,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 3
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index aa7aac1..220ae33 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -235,8 +235,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 2
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index 56f49cf..9452583 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -332,8 +332,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + TASK_COUNT)
 #define CONFIGURE_SCHEDULER_STRONG_APA
diff --git a/testsuites/smptests/smpswitchextension01/init.c b/testsuites/smptests/smpswitchextension01/init.c
index eda8a9c..a67409b 100644
--- a/testsuites/smptests/smpswitchextension01/init.c
+++ b/testsuites/smptests/smpswitchextension01/init.c
@@ -236,8 +236,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (3 + TOGGLER_COUNT)
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index 8b9079c..b85ad56 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -506,8 +506,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (CPU_COUNT + 1)
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index 52c3181..434de25 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -72,9 +72,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpwakeafter01/init.c b/testsuites/smptests/smpwakeafter01/init.c
index b82bd3f..6038d98 100644
--- a/testsuites/smptests/smpwakeafter01/init.c
+++ b/testsuites/smptests/smpwakeafter01/init.c
@@ -154,8 +154,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/sptimecounter02/init.c
index e01b1e9..3159725 100644
--- a/testsuites/sptests/sptimecounter02/init.c
+++ b/testsuites/sptests/sptimecounter02/init.c
@@ -257,8 +257,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TIMERS 2
 #define CONFIGURE_MAXIMUM_PERIODS 1
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/sptests/sptimecounter03/init.c b/testsuites/sptests/sptimecounter03/init.c
index 2595c7d..bcfb71a 100644
--- a/testsuites/sptests/sptimecounter03/init.c
+++ b/testsuites/sptests/sptimecounter03/init.c
@@ -97,8 +97,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index f9890e6..e5593a6 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -273,8 +273,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
diff --git a/testsuites/tmtests/tmfine01/init.c b/testsuites/tmtests/tmfine01/init.c
index c703d76..16a7e6e 100644
--- a/testsuites/tmtests/tmfine01/init.c
+++ b/testsuites/tmtests/tmfine01/init.c
@@ -512,8 +512,6 @@ static void Init(rtems_task_argument arg)
1.8.4.5
