[PATCH] Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS
Wed Feb 1 13:16:33 UTC 2017
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
 cpukit/libmisc/dummy/default-configuration.c    |  2 +-
 cpukit/sapi/include/confdefs.h                  | 83 +++++++++++++------------
 testsuites/smptests/smp01/system.h              |  6 +-
 testsuites/smptests/smp02/system.h              |  4 +-
 testsuites/smptests/smp03/system.h              |  6 +-
 testsuites/smptests/smp05/init.c                |  4 +-
 testsuites/smptests/smp07/init.c                |  2 +-
 testsuites/smptests/smp08/system.h              |  4 +-
 testsuites/smptests/smp09/init.c                |  4 +-
 testsuites/smptests/smpaffinity01/init.c        |  2 +-
 testsuites/smptests/smpatomic01/init.c          |  2 +-
 testsuites/smptests/smpcache01/init.c           |  2 +-
 testsuites/smptests/smpcapture01/init.c         |  2 +-
 testsuites/smptests/smpcapture02/init.c         |  2 +-
 testsuites/smptests/smpclock01/init.c           |  2 +-
 testsuites/smptests/smpfatal01/init.c           |  2 +-
 testsuites/smptests/smpfatal02/init.c           |  2 +-
 testsuites/smptests/smpfatal05/init.c           |  2 +-
 testsuites/smptests/smpfatal06/init.c           |  2 +-
 testsuites/smptests/smpfatal08/init.c           |  2 +-
 testsuites/smptests/smpipi01/init.c             |  2 +-
 testsuites/smptests/smpload01/init.c            |  2 +-
 testsuites/smptests/smplock01/init.c            |  2 +-
 testsuites/smptests/smpmigration01/init.c       |  2 +-
 testsuites/smptests/smpmigration02/init.c       |  2 +-
 testsuites/smptests/smpmrsp01/init.c            |  2 +-
 testsuites/smptests/smpmutex01/init.c           |  2 +-
 testsuites/smptests/smpmutex02/init.c           |  2 +-
 testsuites/smptests/smppsxaffinity01/init.c     |  2 +-
 testsuites/smptests/smppsxaffinity02/init.c     |  2 +-
 testsuites/smptests/smppsxmutex01/init.c        |  2 +-
 testsuites/smptests/smppsxsignal01/init.c       |  2 +-
 testsuites/smptests/smpschedaffinity01/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity02/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity03/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity04/init.c   |  2 +-
 testsuites/smptests/smpschedaffinity05/init.c   |  2 +-
 testsuites/smptests/smpschedsem01/init.c        |  2 +-
 testsuites/smptests/smpscheduler01/init.c       |  2 +-
 testsuites/smptests/smpscheduler02/init.c       |  2 +-
 testsuites/smptests/smpscheduler03/init.c       |  2 +-
 testsuites/smptests/smpscheduler04/init.c       |  2 +-
 testsuites/smptests/smpsignal01/init.c          |  2 +-
 testsuites/smptests/smpstrongapa01/init.c       |  2 +-
 testsuites/smptests/smpswitchextension01/init.c |  2 +-
 testsuites/smptests/smpthreadlife01/init.c      |  2 +-
 testsuites/smptests/smpunsupported01/init.c     |  2 +-
 testsuites/smptests/smpwakeafter01/init.c       |  2 +-
 testsuites/sptests/sptimecounter02/init.c       |  2 +-
 testsuites/sptests/sptimecounter03/init.c       |  2 +-
 testsuites/tmtests/tmcontext01/init.c           |  2 +-
 testsuites/tmtests/tmfine01/init.c              |  2 +-
 52 files changed, 103 insertions(+), 98 deletions(-)
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
index 8d809a0..5b6da04 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -102,7 +102,7 @@ static void Init( rtems_task_argument arg )
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 32
+#define CONFIGURE_MAXIMUM_PROCESSORS 32
 #define CONFIGURE_DISABLE_BSP_SETTINGS
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 021d770..fdfc7c0 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -206,15 +206,20 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   extern int rtems_telnetd_maximum_ptys;
 #endif
-#ifndef CONFIGURE_SMP_MAXIMUM_PROCESSORS
-  #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
+#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
+  #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 4.12"
+  #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
+#endif
+#ifndef CONFIGURE_MAXIMUM_PROCESSORS
+  #define CONFIGURE_MAXIMUM_PROCESSORS 1
 #endif
  * An internal define to indicate that this is an SMP application
  * configuration.
-#if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1
+#if CONFIGURE_MAXIMUM_PROCESSORS > 1
   #define _CONFIGURE_SMP_APPLICATION
 #endif
@@ -1030,97 +1035,97 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
             RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
         CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 2
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 2
           , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 3
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 3
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 4
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 4
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 5
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 5
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 6
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 6
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 7
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 7
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 8
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 8
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 9
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 9
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 10
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 10
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 11
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 11
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 12
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 12
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 13
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 13
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 14
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 14
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 15
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 15
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 16
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 16
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 17
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 17
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 18
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 18
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 19
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 19
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 20
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 20
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 21
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 21
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 22
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 22
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 23
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 23
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 24
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 24
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 25
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 25
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 26
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 26
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 27
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 27
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 28
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 28
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 29
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 29
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 30
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 30
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 31
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 31
         #endif
-        #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 32
+        #if CONFIGURE_MAXIMUM_PROCESSORS >= 32
         #endif
         #undef CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
@@ -1128,7 +1133,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     RTEMS_STATIC_ASSERT(
-      CONFIGURE_SMP_MAXIMUM_PROCESSORS
+      CONFIGURE_MAXIMUM_PROCESSORS
         == RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
@@ -2951,7 +2956,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * In an SMP system, each CPU core has its own idle task.
 #if defined(RTEMS_SMP)
-  #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_SMP_MAXIMUM_PROCESSORS
+  #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_MAXIMUM_PROCESSORS
 #else
   #define CONFIGURE_IDLE_TASKS_COUNT 1
 #endif
@@ -3018,7 +3023,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define CONFIGURE_MEMORY_FOR_SMP \
-     (CONFIGURE_SMP_MAXIMUM_PROCESSORS * \
+     (CONFIGURE_MAXIMUM_PROCESSORS * \
       _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) \
 #else
@@ -3383,7 +3388,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MULTIPROCESSING_TABLE,        /* pointer to MP config table */
     #endif
     #ifdef RTEMS_SMP
-      CONFIGURE_SMP_MAXIMUM_PROCESSORS,
+      CONFIGURE_MAXIMUM_PROCESSORS,
     #endif
 #endif
@@ -3395,7 +3400,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   * Instantiate the Per CPU information based upon the user configuration.
  #if defined(CONFIGURE_INIT)
-   Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
+   Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_MAXIMUM_PROCESSORS];
  #endif
 #endif
diff --git a/testsuites/smptests/smp01/system.h b/testsuites/smptests/smp01/system.h
index 7ced2f6..f3f0816 100644
--- a/testsuites/smptests/smp01/system.h
+++ b/testsuites/smptests/smp01/system.h
@@ -25,10 +25,10 @@ rtems_task Test_task(
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS   4
+#define CONFIGURE_MAXIMUM_PROCESSORS   4
 #define CONFIGURE_MAXIMUM_TASKS            \
-    (1 + CONFIGURE_SMP_MAXIMUM_PROCESSORS)
+    (1 + CONFIGURE_MAXIMUM_PROCESSORS)
 #define CONFIGURE_MAXIMUM_SEMAPHORES 1
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
@@ -43,7 +43,7 @@ rtems_task Test_task(
  *  Keep the names and IDs in global variables so another task can use them.
-TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
+TEST_EXTERN volatile bool TaskRan[ CONFIGURE_MAXIMUM_PROCESSORS ];
 void Loop( void );
diff --git a/testsuites/smptests/smp02/system.h b/testsuites/smptests/smp02/system.h
index f4923f3..86d2295 100644
--- a/testsuites/smptests/smp02/system.h
+++ b/testsuites/smptests/smp02/system.h
diff --git a/testsuites/smptests/smp03/system.h b/testsuites/smptests/smp03/system.h
index c15266a..3d9b067 100644
--- a/testsuites/smptests/smp03/system.h
+++ b/testsuites/smptests/smp03/system.h
@@ -52,7 +52,7 @@ rtems_task Test_task(
-TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS + 1 ];
+TEST_EXTERN volatile bool TaskRan[ CONFIGURE_MAXIMUM_PROCESSORS + 1 ];
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index 4a0ca61..7211e8c 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -85,10 +85,10 @@ rtems_task Init(
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS   2
+#define CONFIGURE_MAXIMUM_PROCESSORS   2
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index 85dba89..0dbf70b 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -176,7 +176,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TIMERS           1
 #define CONFIGURE_MAXIMUM_TASKS            2
diff --git a/testsuites/smptests/smp08/system.h b/testsuites/smptests/smp08/system.h
index 63f4b1d..65209aa 100644
--- a/testsuites/smptests/smp08/system.h
+++ b/testsuites/smptests/smp08/system.h
@@ -27,10 +27,10 @@ rtems_task Test_task(
-    (1 + (CONFIGURE_SMP_MAXIMUM_PROCESSORS*3) )
+    (1 + (CONFIGURE_MAXIMUM_PROCESSORS*3) )
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/init.c
index 12b6d75..6629064 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -88,10 +88,10 @@ rtems_task Init(
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
index 2e5fa55..c500cd0 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -229,7 +229,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
+#define CONFIGURE_MAXIMUM_PROCESSORS NUM_CPUS
 #define CONFIGURE_MAXIMUM_TASKS         (NUM_CPUS*2)
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 24abbf5..394cc3f 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -829,7 +829,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK (MS_PER_TICK * 1000)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
 #define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 7c8617f..851e131 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -268,7 +268,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/smpcapture01/init.c
index 4187e19..aae94e1 100644
--- a/testsuites/smptests/smpcapture01/init.c
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -253,7 +253,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture02/init.c b/testsuites/smptests/smpcapture02/init.c
index f2b136a..9926fbb 100644
--- a/testsuites/smptests/smpcapture02/init.c
+++ b/testsuites/smptests/smpcapture02/init.c
@@ -429,7 +429,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS MAX_CPUS
+#define CONFIGURE_MAXIMUM_PROCESSORS MAX_CPUS
 #define CONFIGURE_MAXIMUM_SEMAPHORES MAX_CPUS * TASKS_PER_CPU + 1
 #define CONFIGURE_MAXIMUM_TASKS MAX_CPUS * TASKS_PER_CPU + 1
diff --git a/testsuites/smptests/smpclock01/init.c b/testsuites/smptests/smpclock01/init.c
index 120a079..5972959 100644
--- a/testsuites/smptests/smpclock01/init.c
+++ b/testsuites/smptests/smpclock01/init.c
@@ -174,7 +174,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SCHEDULER_SIMPLE_SMP
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 2710629..2a000a5 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -126,7 +126,7 @@ static rtems_status_code test_driver_init(
   { .fatal = fatal_extension }, \
 #define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 7d8d541..fc25808 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -127,7 +127,7 @@ static rtems_status_code test_driver_init(
diff --git a/testsuites/smptests/smpfatal05/init.c b/testsuites/smptests/smpfatal05/init.c
index bbafb5e..6b0954a 100644
--- a/testsuites/smptests/smpfatal05/init.c
+++ b/testsuites/smptests/smpfatal05/init.c
@@ -57,7 +57,7 @@ static void fatal_extension(
 /* Lets see when the first RTEMS system hits this limit */
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 64
+#define CONFIGURE_MAXIMUM_PROCESSORS 64
diff --git a/testsuites/smptests/smpfatal06/init.c b/testsuites/smptests/smpfatal06/init.c
index 4fb4074..37cd9af 100644
--- a/testsuites/smptests/smpfatal06/init.c
+++ b/testsuites/smptests/smpfatal06/init.c
@@ -56,7 +56,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
index fd738d5..92f769a 100644
--- a/testsuites/smptests/smpfatal08/init.c
+++ b/testsuites/smptests/smpfatal08/init.c
@@ -113,7 +113,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpipi01/init.c b/testsuites/smptests/smpipi01/init.c
index 8879296..679b059 100644
--- a/testsuites/smptests/smpipi01/init.c
+++ b/testsuites/smptests/smpipi01/init.c
@@ -202,7 +202,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index bcce1d9..0e10235 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -392,7 +392,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK 1000
   (1 + MAX_INHERIT_OBTAIN_COUNT + 1 + 1 + SEM_WORKER_COUNT)
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
index ac7e9e2..0a37915 100644
--- a/testsuites/smptests/smplock01/init.c
+++ b/testsuites/smptests/smplock01/init.c
@@ -761,7 +761,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmigration01/init.c b/testsuites/smptests/smpmigration01/init.c
index 7ad1e93..6cde34b 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -238,7 +238,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (2 + RUNNER_COUNT)
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index bfba962..4180f53 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -281,7 +281,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index 2690618..cc95567 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -1781,7 +1781,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES MRSP_COUNT
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/smpmutex01/init.c
index 46c0bf3..c7059e8 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -943,7 +943,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS PART_COUNT
+#define CONFIGURE_MAXIMUM_PROCESSORS PART_COUNT
diff --git a/testsuites/smptests/smpmutex02/init.c b/testsuites/smptests/smpmutex02/init.c
index 09e61e1..1604bb7 100644
--- a/testsuites/smptests/smpmutex02/init.c
+++ b/testsuites/smptests/smpmutex02/init.c
@@ -322,7 +322,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + WORKER_COUNT)
 #define CONFIGURE_MAXIMUM_SEMAPHORES (1 + MTX_COUNT)
diff --git a/testsuites/smptests/smppsxaffinity01/init.c b/testsuites/smptests/smppsxaffinity01/init.c
index 89b29f5..c4c4f4f 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
@@ -161,7 +161,7 @@ void *POSIX_Init(
diff --git a/testsuites/smptests/smppsxaffinity02/init.c b/testsuites/smptests/smppsxaffinity02/init.c
index 54d3ead..e8acfb1 100644
--- a/testsuites/smptests/smppsxaffinity02/init.c
+++ b/testsuites/smptests/smppsxaffinity02/init.c
@@ -232,7 +232,7 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS (NUM_CPUS*2)
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/smppsxmutex01/init.c
index 8f19b6e..3ed22b1 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -159,7 +159,7 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 2
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 2
 #define CONFIGURE_SCHEDULER_PRIORITY_SMP
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index 9299292..3676158 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -176,7 +176,7 @@ static void *POSIX_Init(void *arg)
diff --git a/testsuites/smptests/smpschedaffinity01/init.c b/testsuites/smptests/smpschedaffinity01/init.c
index a653f46..778fda7 100644
--- a/testsuites/smptests/smpschedaffinity01/init.c
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -157,7 +157,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS          TASK_COUNT
diff --git a/testsuites/smptests/smpschedaffinity02/init.c b/testsuites/smptests/smpschedaffinity02/init.c
index fe55bc0..9a8cfed 100644
--- a/testsuites/smptests/smpschedaffinity02/init.c
+++ b/testsuites/smptests/smpschedaffinity02/init.c
@@ -211,7 +211,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS          NUM_CPUS
diff --git a/testsuites/smptests/smpschedaffinity03/init.c b/testsuites/smptests/smpschedaffinity03/init.c
index 04ed4ec..a53b30c 100644
--- a/testsuites/smptests/smpschedaffinity03/init.c
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -85,7 +85,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity04/init.c b/testsuites/smptests/smpschedaffinity04/init.c
index a2066ad..e4df282 100644
--- a/testsuites/smptests/smpschedaffinity04/init.c
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -166,7 +166,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity05/init.c b/testsuites/smptests/smpschedaffinity05/init.c
index 2ab828c..c78a60b 100644
--- a/testsuites/smptests/smpschedaffinity05/init.c
+++ b/testsuites/smptests/smpschedaffinity05/init.c
@@ -225,7 +225,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedsem01/init.c b/testsuites/smptests/smpschedsem01/init.c
index 04d8a98..cae5d6e 100644
--- a/testsuites/smptests/smpschedsem01/init.c
+++ b/testsuites/smptests/smpschedsem01/init.c
@@ -77,7 +77,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler01/init.c b/testsuites/smptests/smpscheduler01/init.c
index 734ab8b..5b8744c 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -196,7 +196,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 5ef8de1..4355857 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -403,7 +403,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 1
diff --git a/testsuites/smptests/smpscheduler03/init.c b/testsuites/smptests/smpscheduler03/init.c
index 51098b6..afd020f 100644
--- a/testsuites/smptests/smpscheduler03/init.c
+++ b/testsuites/smptests/smpscheduler03/init.c
@@ -671,7 +671,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_MAX
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_MAX
 #define CONFIGURE_MAXIMUM_PRIORITY 255
diff --git a/testsuites/smptests/smpscheduler04/init.c b/testsuites/smptests/smpscheduler04/init.c
index b87edc9..a4e9da1 100644
--- a/testsuites/smptests/smpscheduler04/init.c
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -180,7 +180,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 3
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index 220ae33..52f2edb 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -235,7 +235,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index 9452583..16ef6e4 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -332,7 +332,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + TASK_COUNT)
 #define CONFIGURE_SCHEDULER_STRONG_APA
diff --git a/testsuites/smptests/smpswitchextension01/init.c b/testsuites/smptests/smpswitchextension01/init.c
index a67409b..3fad1d9 100644
--- a/testsuites/smptests/smpswitchextension01/init.c
+++ b/testsuites/smptests/smpswitchextension01/init.c
@@ -236,7 +236,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (3 + TOGGLER_COUNT)
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index b85ad56..5c2d106 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -506,7 +506,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (CPU_COUNT + 1)
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index 434de25..a5ccaae 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -72,7 +72,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpwakeafter01/init.c b/testsuites/smptests/smpwakeafter01/init.c
index 6038d98..3d091f5 100644
--- a/testsuites/smptests/smpwakeafter01/init.c
+++ b/testsuites/smptests/smpwakeafter01/init.c
@@ -154,7 +154,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/sptimecounter02/init.c
index 3159725..4f8de6a 100644
--- a/testsuites/sptests/sptimecounter02/init.c
+++ b/testsuites/sptests/sptimecounter02/init.c
@@ -257,7 +257,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TIMERS 2
 #define CONFIGURE_MAXIMUM_PERIODS 1
diff --git a/testsuites/sptests/sptimecounter03/init.c b/testsuites/sptests/sptimecounter03/init.c
index bcfb71a..3b57d95 100644
--- a/testsuites/sptests/sptimecounter03/init.c
+++ b/testsuites/sptests/sptimecounter03/init.c
@@ -97,7 +97,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index e5593a6..c368d79 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -273,7 +273,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
diff --git a/testsuites/tmtests/tmfine01/init.c b/testsuites/tmtests/tmfine01/init.c
index 16a7e6e..6841b02 100644
--- a/testsuites/tmtests/tmfine01/init.c
+++ b/testsuites/tmtests/tmfine01/init.c
@@ -512,7 +512,7 @@ static void Init(rtems_task_argument arg)
1.8.4.5
