[PATCH] Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS
Joel Sherrill
joel at rtems.org
Wed Feb 1 13:53:02 UTC 2017
The inclusion of SMP categorizes the option. Many, if not most, configure
options have a second word which is the category. All the POSIX options
include POSIX in the name, gnat, Go, etc.
All of our services are rtems_CATEGORY.
It isn't about the shortest name with RTEMS. It is about the clearest name
with grouping.
I don't want to see this pattern violated and am opposed to this change.
Otherwise, this would be CONF_MAX_CPUS or similar and we don't want that.
--joel
On Feb 1, 2017 7:16 AM, "Sebastian Huber" <
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
cpukit/libmisc/dummy/default-configuration.c | 2 +-
cpukit/sapi/include/confdefs.h | 83
testsuites/smptests/smp01/system.h | 6 +-
testsuites/smptests/smp02/system.h | 4 +-
testsuites/smptests/smp03/system.h | 6 +-
testsuites/smptests/smp05/init.c | 4 +-
testsuites/smptests/smp07/init.c | 2 +-
testsuites/smptests/smp08/system.h | 4 +-
testsuites/smptests/smp09/init.c | 4 +-
testsuites/smptests/smpaffinity01/init.c | 2 +-
testsuites/smptests/smpatomic01/init.c | 2 +-
testsuites/smptests/smpcache01/init.c | 2 +-
testsuites/smptests/smpcapture01/init.c | 2 +-
testsuites/smptests/smpcapture02/init.c | 2 +-
testsuites/smptests/smpclock01/init.c | 2 +-
testsuites/smptests/smpfatal01/init.c | 2 +-
testsuites/smptests/smpfatal02/init.c | 2 +-
testsuites/smptests/smpfatal05/init.c | 2 +-
testsuites/smptests/smpfatal06/init.c | 2 +-
testsuites/smptests/smpfatal08/init.c | 2 +-
testsuites/smptests/smpipi01/init.c | 2 +-
testsuites/smptests/smpload01/init.c | 2 +-
testsuites/smptests/smplock01/init.c | 2 +-
testsuites/smptests/smpmigration01/init.c | 2 +-
testsuites/smptests/smpmigration02/init.c | 2 +-
testsuites/smptests/smpmrsp01/init.c | 2 +-
testsuites/smptests/smpmutex01/init.c | 2 +-
testsuites/smptests/smpmutex02/init.c | 2 +-
testsuites/smptests/smppsxaffinity01/init.c | 2 +-
testsuites/smptests/smppsxaffinity02/init.c | 2 +-
testsuites/smptests/smppsxmutex01/init.c | 2 +-
testsuites/smptests/smppsxsignal01/init.c | 2 +-
testsuites/smptests/smpschedaffinity01/init.c | 2 +-
testsuites/smptests/smpschedaffinity02/init.c | 2 +-
testsuites/smptests/smpschedaffinity03/init.c | 2 +-
testsuites/smptests/smpschedaffinity04/init.c | 2 +-
testsuites/smptests/smpschedaffinity05/init.c | 2 +-
testsuites/smptests/smpschedsem01/init.c | 2 +-
testsuites/smptests/smpscheduler01/init.c | 2 +-
testsuites/smptests/smpscheduler02/init.c | 2 +-
testsuites/smptests/smpscheduler03/init.c | 2 +-
testsuites/smptests/smpscheduler04/init.c | 2 +-
testsuites/smptests/smpsignal01/init.c | 2 +-
testsuites/smptests/smpstrongapa01/init.c | 2 +-
testsuites/smptests/smpswitchextension01/init.c | 2 +-
testsuites/smptests/smpthreadlife01/init.c | 2 +-
testsuites/smptests/smpunsupported01/init.c | 2 +-
testsuites/smptests/smpwakeafter01/init.c | 2 +-
testsuites/sptests/sptimecounter02/init.c | 2 +-
testsuites/sptests/sptimecounter03/init.c | 2 +-
testsuites/tmtests/tmcontext01/init.c | 2 +-
testsuites/tmtests/tmfine01/init.c | 2 +-
52 files changed, 103 insertions(+), 98 deletions(-)
diff --git a/cpukit/libmisc/dummy/default-configuration.c
b/cpukit/libmisc/dummy/default-configuration.c
index 8d809a0..5b6da04 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -102,7 +102,7 @@ static void Init( rtems_task_argument arg )
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 32
+#define CONFIGURE_MAXIMUM_PROCESSORS 32
#define CONFIGURE_DISABLE_BSP_SETTINGS
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 021d770..fdfc7c0 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -206,15 +206,20 @@ extern rtems_initialization_tasks_table
Initialization_tasks[];
extern int rtems_telnetd_maximum_ptys;
#endif
-#ifndef CONFIGURE_SMP_MAXIMUM_PROCESSORS
- #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
+#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
+ #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to
CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 4.12"
+ #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
+#endif
+#ifndef CONFIGURE_MAXIMUM_PROCESSORS
+ #define CONFIGURE_MAXIMUM_PROCESSORS 1
#endif
* An internal define to indicate that this is an SMP application
* configuration.
-#if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1
+#if CONFIGURE_MAXIMUM_PROCESSORS > 1
#define _CONFIGURE_SMP_APPLICATION
#endif
@@ -1030,97 +1035,97 @@ extern rtems_initialization_tasks_table
RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 2
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 2
, CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 3
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 3
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 4
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 4
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 5
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 5
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 6
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 6
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 7
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 7
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 8
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 8
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 9
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 9
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 10
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 10
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 11
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 11
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 12
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 12
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 13
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 13
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 14
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 14
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 15
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 15
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 16
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 16
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 17
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 17
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 18
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 18
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 19
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 19
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 20
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 20
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 21
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 21
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 22
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 22
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 23
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 23
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 24
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 24
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 25
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 25
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 26
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 26
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 27
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 27
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 28
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 28
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 29
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 29
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 30
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 30
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 31
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 31
#endif
- #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 32
+ #if CONFIGURE_MAXIMUM_PROCESSORS >= 32
#endif
#undef CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
@@ -1128,7 +1133,7 @@ extern rtems_initialization_tasks_table
RTEMS_STATIC_ASSERT(
- CONFIGURE_SMP_MAXIMUM_PROCESSORS
+ CONFIGURE_MAXIMUM_PROCESSORS
== RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
@@ -2951,7 +2956,7 @@ extern rtems_initialization_tasks_table
* In an SMP system, each CPU core has its own idle task.
#if defined(RTEMS_SMP)
- #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_SMP_MAXIMUM_PROCESSORS
+ #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_MAXIMUM_PROCESSORS
#else
#define CONFIGURE_IDLE_TASKS_COUNT 1
#endif
@@ -3018,7 +3023,7 @@ extern rtems_initialization_tasks_table
#define CONFIGURE_MEMORY_FOR_SMP \
- (CONFIGURE_SMP_MAXIMUM_PROCESSORS * \
+ (CONFIGURE_MAXIMUM_PROCESSORS * \
_Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) \
#else
@@ -3383,7 +3388,7 @@ extern rtems_initialization_tasks_table
CONFIGURE_MULTIPROCESSING_TABLE, /* pointer to MP config
table */
#endif
#ifdef RTEMS_SMP
- CONFIGURE_SMP_MAXIMUM_PROCESSORS,
+ CONFIGURE_MAXIMUM_PROCESSORS,
#endif
#endif
@@ -3395,7 +3400,7 @@ extern rtems_initialization_tasks_table
* Instantiate the Per CPU information based upon the user configuration.
#if defined(CONFIGURE_INIT)
- Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_
PROCESSORS];
+ Per_CPU_Control_envelope _Per_CPU_Information[
CONFIGURE_MAXIMUM_PROCESSORS];
#endif
#endif
diff --git a/testsuites/smptests/smp01/system.h b/testsuites/smptests/smp01/
system.h
index 7ced2f6..f3f0816 100644
--- a/testsuites/smptests/smp01/system.h
+++ b/testsuites/smptests/smp01/system.h
@@ -25,10 +25,10 @@ rtems_task Test_task(
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 4
+#define CONFIGURE_MAXIMUM_PROCESSORS 4
#define CONFIGURE_MAXIMUM_TASKS \
- (1 + CONFIGURE_SMP_MAXIMUM_PROCESSORS)
+ (1 + CONFIGURE_MAXIMUM_PROCESSORS)
#define CONFIGURE_MAXIMUM_SEMAPHORES 1
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
@@ -43,7 +43,7 @@ rtems_task Test_task(
* Keep the names and IDs in global variables so another task can use
them.
-TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
+TEST_EXTERN volatile bool TaskRan[ CONFIGURE_MAXIMUM_PROCESSORS ];
void Loop( void );
diff --git a/testsuites/smptests/smp02/system.h b/testsuites/smptests/smp02/
system.h
index f4923f3..86d2295 100644
--- a/testsuites/smptests/smp02/system.h
+++ b/testsuites/smptests/smp02/system.h
diff --git a/testsuites/smptests/smp03/system.h b/testsuites/smptests/smp03/
system.h
index c15266a..3d9b067 100644
--- a/testsuites/smptests/smp03/system.h
+++ b/testsuites/smptests/smp03/system.h
@@ -52,7 +52,7 @@ rtems_task Test_task(
them.
-TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS + 1 ];
+TEST_EXTERN volatile bool TaskRan[ CONFIGURE_MAXIMUM_PROCESSORS + 1 ];
them.
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/
init.c
index 4a0ca61..7211e8c 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -85,10 +85,10 @@ rtems_task Init(
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 2
+#define CONFIGURE_MAXIMUM_PROCESSORS 2
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/
init.c
index 85dba89..0dbf70b 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -176,7 +176,7 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_TIMERS 1
#define CONFIGURE_MAXIMUM_TASKS 2
diff --git a/testsuites/smptests/smp08/system.h b/testsuites/smptests/smp08/
system.h
index 63f4b1d..65209aa 100644
--- a/testsuites/smptests/smp08/system.h
+++ b/testsuites/smptests/smp08/system.h
@@ -27,10 +27,10 @@ rtems_task Test_task(
- (1 + (CONFIGURE_SMP_MAXIMUM_PROCESSORS*3) )
+ (1 + (CONFIGURE_MAXIMUM_PROCESSORS*3) )
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/
init.c
index 12b6d75..6629064 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -88,10 +88,10 @@ rtems_task Init(
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/
index 2e5fa55..c500cd0 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -229,7 +229,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
+#define CONFIGURE_MAXIMUM_PROCESSORS NUM_CPUS
#define CONFIGURE_MAXIMUM_TASKS (NUM_CPUS*2)
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/
smpatomic01/init.c
index 24abbf5..394cc3f 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -829,7 +829,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MICROSECONDS_PER_TICK (MS_PER_TICK * 1000)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/
smpcache01/init.c
index 7c8617f..851e131 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -268,7 +268,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/
smpcapture01/init.c
index 4187e19..aae94e1 100644
--- a/testsuites/smptests/smpcapture01/init.c
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -253,7 +253,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture02/init.c b/testsuites/smptests/
smpcapture02/init.c
index f2b136a..9926fbb 100644
--- a/testsuites/smptests/smpcapture02/init.c
+++ b/testsuites/smptests/smpcapture02/init.c
@@ -429,7 +429,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS MAX_CPUS
+#define CONFIGURE_MAXIMUM_PROCESSORS MAX_CPUS
#define CONFIGURE_MAXIMUM_SEMAPHORES MAX_CPUS * TASKS_PER_CPU + 1
#define CONFIGURE_MAXIMUM_TASKS MAX_CPUS * TASKS_PER_CPU + 1
diff --git a/testsuites/smptests/smpclock01/init.c b/testsuites/smptests/
smpclock01/init.c
index 120a079..5972959 100644
--- a/testsuites/smptests/smpclock01/init.c
+++ b/testsuites/smptests/smpclock01/init.c
@@ -174,7 +174,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_SCHEDULER_SIMPLE_SMP
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/
smpfatal01/init.c
index 2710629..2a000a5 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -126,7 +126,7 @@ static rtems_status_code test_driver_init(
{ .fatal = fatal_extension }, \
#define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/
smpfatal02/init.c
index 7d8d541..fc25808 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -127,7 +127,7 @@ static rtems_status_code test_driver_init(
diff --git a/testsuites/smptests/smpfatal05/init.c b/testsuites/smptests/
smpfatal05/init.c
index bbafb5e..6b0954a 100644
--- a/testsuites/smptests/smpfatal05/init.c
+++ b/testsuites/smptests/smpfatal05/init.c
@@ -57,7 +57,7 @@ static void fatal_extension(
/* Lets see when the first RTEMS system hits this limit */
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 64
+#define CONFIGURE_MAXIMUM_PROCESSORS 64
diff --git a/testsuites/smptests/smpfatal06/init.c b/testsuites/smptests/
smpfatal06/init.c
index 4fb4074..37cd9af 100644
--- a/testsuites/smptests/smpfatal06/init.c
+++ b/testsuites/smptests/smpfatal06/init.c
@@ -56,7 +56,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/
smpfatal08/init.c
index fd738d5..92f769a 100644
--- a/testsuites/smptests/smpfatal08/init.c
+++ b/testsuites/smptests/smpfatal08/init.c
@@ -113,7 +113,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpipi01/init.c b/testsuites/smptests/
smpipi01/init.c
index 8879296..679b059 100644
--- a/testsuites/smptests/smpipi01/init.c
+++ b/testsuites/smptests/smpipi01/init.c
@@ -202,7 +202,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/
smpload01/init.c
index bcce1d9..0e10235 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -392,7 +392,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
(1 + MAX_INHERIT_OBTAIN_COUNT + 1 + 1 + SEM_WORKER_COUNT)
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/
smplock01/init.c
index ac7e9e2..0a37915 100644
--- a/testsuites/smptests/smplock01/init.c
+++ b/testsuites/smptests/smplock01/init.c
@@ -761,7 +761,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmigration01/init.c
b/testsuites/smptests/smpmigration01/init.c
index 7ad1e93..6cde34b 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -238,7 +238,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS (2 + RUNNER_COUNT)
diff --git a/testsuites/smptests/smpmigration02/init.c
b/testsuites/smptests/smpmigration02/init.c
index bfba962..4180f53 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -281,7 +281,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/
smpmrsp01/init.c
index 2690618..cc95567 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -1781,7 +1781,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES MRSP_COUNT
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/
smpmutex01/init.c
index 46c0bf3..c7059e8 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -943,7 +943,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS PART_COUNT
+#define CONFIGURE_MAXIMUM_PROCESSORS PART_COUNT
diff --git a/testsuites/smptests/smpmutex02/init.c b/testsuites/smptests/
smpmutex02/init.c
index 09e61e1..1604bb7 100644
--- a/testsuites/smptests/smpmutex02/init.c
+++ b/testsuites/smptests/smpmutex02/init.c
@@ -322,7 +322,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS (1 + WORKER_COUNT)
#define CONFIGURE_MAXIMUM_SEMAPHORES (1 + MTX_COUNT)
diff --git a/testsuites/smptests/smppsxaffinity01/init.c
b/testsuites/smptests/smppsxaffinity01/init.c
index 89b29f5..c4c4f4f 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
@@ -161,7 +161,7 @@ void *POSIX_Init(
diff --git a/testsuites/smptests/smppsxaffinity02/init.c
b/testsuites/smptests/smppsxaffinity02/init.c
index 54d3ead..e8acfb1 100644
--- a/testsuites/smptests/smppsxaffinity02/init.c
+++ b/testsuites/smptests/smppsxaffinity02/init.c
@@ -232,7 +232,7 @@ void *POSIX_Init(
#define CONFIGURE_MAXIMUM_POSIX_THREADS (NUM_CPUS*2)
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/
index 8f19b6e..3ed22b1 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -159,7 +159,7 @@ static void *POSIX_Init(void *arg)
#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 2
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
diff --git a/testsuites/smptests/smppsxsignal01/init.c
b/testsuites/smptests/smppsxsignal01/init.c
index 9299292..3676158 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -176,7 +176,7 @@ static void *POSIX_Init(void *arg)
diff --git a/testsuites/smptests/smpschedaffinity01/init.c
b/testsuites/smptests/smpschedaffinity01/init.c
index a653f46..778fda7 100644
--- a/testsuites/smptests/smpschedaffinity01/init.c
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -157,7 +157,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
diff --git a/testsuites/smptests/smpschedaffinity02/init.c
b/testsuites/smptests/smpschedaffinity02/init.c
index fe55bc0..9a8cfed 100644
--- a/testsuites/smptests/smpschedaffinity02/init.c
+++ b/testsuites/smptests/smpschedaffinity02/init.c
@@ -211,7 +211,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS NUM_CPUS
diff --git a/testsuites/smptests/smpschedaffinity03/init.c
b/testsuites/smptests/smpschedaffinity03/init.c
index 04ed4ec..a53b30c 100644
--- a/testsuites/smptests/smpschedaffinity03/init.c
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -85,7 +85,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity04/init.c
b/testsuites/smptests/smpschedaffinity04/init.c
index a2066ad..e4df282 100644
--- a/testsuites/smptests/smpschedaffinity04/init.c
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -166,7 +166,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity05/init.c
b/testsuites/smptests/smpschedaffinity05/init.c
index 2ab828c..c78a60b 100644
--- a/testsuites/smptests/smpschedaffinity05/init.c
+++ b/testsuites/smptests/smpschedaffinity05/init.c
@@ -225,7 +225,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedsem01/init.c b/testsuites/smptests/
index 04d8a98..cae5d6e 100644
--- a/testsuites/smptests/smpschedsem01/init.c
+++ b/testsuites/smptests/smpschedsem01/init.c
@@ -77,7 +77,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler01/init.c
b/testsuites/smptests/smpscheduler01/init.c
index 734ab8b..5b8744c 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -196,7 +196,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler02/init.c
b/testsuites/smptests/smpscheduler02/init.c
index 5ef8de1..4355857 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -403,7 +403,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 1
diff --git a/testsuites/smptests/smpscheduler03/init.c
b/testsuites/smptests/smpscheduler03/init.c
index 51098b6..afd020f 100644
--- a/testsuites/smptests/smpscheduler03/init.c
+++ b/testsuites/smptests/smpscheduler03/init.c
@@ -671,7 +671,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_MAX
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_MAX
#define CONFIGURE_MAXIMUM_PRIORITY 255
diff --git a/testsuites/smptests/smpscheduler04/init.c
b/testsuites/smptests/smpscheduler04/init.c
index b87edc9..a4e9da1 100644
--- a/testsuites/smptests/smpscheduler04/init.c
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -180,7 +180,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS 3
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/
smpsignal01/init.c
index 220ae33..52f2edb 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -235,7 +235,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpstrongapa01/init.c
b/testsuites/smptests/smpstrongapa01/init.c
index 9452583..16ef6e4 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -332,7 +332,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS (1 + TASK_COUNT)
#define CONFIGURE_SCHEDULER_STRONG_APA
diff --git a/testsuites/smptests/smpswitchextension01/init.c
b/testsuites/smptests/smpswitchextension01/init.c
index a67409b..3fad1d9 100644
--- a/testsuites/smptests/smpswitchextension01/init.c
+++ b/testsuites/smptests/smpswitchextension01/init.c
@@ -236,7 +236,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS (3 + TOGGLER_COUNT)
diff --git a/testsuites/smptests/smpthreadlife01/init.c
b/testsuites/smptests/smpthreadlife01/init.c
index b85ad56..5c2d106 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -506,7 +506,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS (CPU_COUNT + 1)
diff --git a/testsuites/smptests/smpunsupported01/init.c
b/testsuites/smptests/smpunsupported01/init.c
index 434de25..a5ccaae 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -72,7 +72,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpwakeafter01/init.c
b/testsuites/smptests/smpwakeafter01/init.c
index 6038d98..3d091f5 100644
--- a/testsuites/smptests/smpwakeafter01/init.c
+++ b/testsuites/smptests/smpwakeafter01/init.c
@@ -154,7 +154,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/
index 3159725..4f8de6a 100644
--- a/testsuites/sptests/sptimecounter02/init.c
+++ b/testsuites/sptests/sptimecounter02/init.c
@@ -257,7 +257,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TIMERS 2
#define CONFIGURE_MAXIMUM_PERIODS 1
diff --git a/testsuites/sptests/sptimecounter03/init.c b/testsuites/sptests/
index bcfb71a..3b57d95 100644
--- a/testsuites/sptests/sptimecounter03/init.c
+++ b/testsuites/sptests/sptimecounter03/init.c
@@ -97,7 +97,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/
tmcontext01/init.c
index e5593a6..c368d79 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -273,7 +273,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
diff --git a/testsuites/tmtests/tmfine01/init.c
b/testsuites/tmtests/tmfine01/init.c
index 16a7e6e..6841b02 100644
--- a/testsuites/tmtests/tmfine01/init.c
+++ b/testsuites/tmtests/tmfine01/init.c
@@ -512,7 +512,7 @@ static void Init(rtems_task_argument arg)
1.8.4.5
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170201/86e243e1/attachment-0001.html>
