GSoC Mentors / Projects of Interest
Tanu Hari Dixit tokencolour at gmail.com
Wed Feb 1 18:14:16 UTC 2017
> If you're logged in then you should see a small link "Modify ↓" just
> above the ticket box.
I clicked on the Modify link but it doesn't give me an option to edit
the description.
Thanks,
Tanu Hari Dixit.
On Wed, Feb 1, 2017 at 10:47 PM, Kuan Hsun Chen
<kuan-hsun.chen at tu-dortmund.de> wrote:
> Hi Gedare,
> I think we are not able to modify the content of tickets. I have tried the
> ticket I initialized before.
> I can only change properties summary and action.
> Best,
> Kuan-Hsun
> 2017-02-01 17:55 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
>> On Wed, Feb 1, 2017 at 12:49 AM, Tanu Hari Dixit <tokencolour at gmail.com>
>> wrote:
>> > Hello,
>> > I'm unable to change the content of "Description" field on Trac. I
>> > read https://devel.rtems.org/wiki/TracTickets and couldn't find any
>> > luck. I read a thread on Trac's mailing list
>> > (https://lists.gt.net/trac/users/46376). Perhaps, it has to do
>> > something with TICKET_EDIT_DESCRIPTION permissions. How do I go about
>> > doing this? What is it that I'm missing?
>> > Regards,
>> > Tanu Hari Dixit.
>> > On Wed, Feb 1, 2017 at 9:25 AM, Tanu Hari Dixit <tokencolour at gmail.com>
>> > wrote:
>> >>> * You removed the "Introduction" section. Any reason or just an
>> >>> oversight?
>> >>> * The 'status' field is gone too. But, I think the status is not
>> >>> needed in the ticket format.
>> >> I removed the "Introduction" section by mistake. I'll include it.
>> >>> Did you face any difficulties in making the transition? It would be
>> >>> good to document your workflow on the Open Projects page.
>> >> I wikiformatted the text myself. But it would have been better if I
>> >> had just copied the already formatted text that pops up when we try to
>> >> edit the project page
>> >> (https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP?action=edit).
>> >> No difficulties as such. I'll document the workflow on the open
>> >> projects page.
>> >>> We should convert all of the open projects to tickets eventually. And
>> >>> then generate a report in the Open Projects page based on the tickets.
>> >>> I have done this for the BSP ones and found the following changes
>> >>> should be made in the workflow:
>> >> Could you please direct me to the tickets you created? I couldn't find
>> >> them on Trac.
>> >>> I knew I had bought at least one so went to Amazon to see what we
>> >>> have here at OAR.
>> >>> https://www.amazon.com/GearMo-Header-TTL-232R-3V3-Windows-Support/dp/B004LBXO2A
>> >>> Other folks in the community may have alternatives. It is a pretty
>> >>> generic
>> >>> piece of hardware. But there was that issue with the FTDI driver
>> >>> refusing
>> >>> to work with cloned FTDI chips. So I would bet there are some out
>> >>> there
>> >>> you don't want.
>> >> I'll include the above hyperlink.
>> >> Thanks,
>> >> Tanu Hari Dixit.
>> >> On Wed, Feb 1, 2017 at 4:33 AM, Joel Sherrill <joel at rtems.org> wrote:
>> >>> On Tue, Jan 31, 2017 at 12:54 PM, Gedare Bloom <gedare at rtems.org>
>> >>> wrote:
>> >>>> On Tue, Jan 31, 2017 at 12:21 PM, Tanu Hari Dixit
>> >>>> wrote:
>> >>>> > Hello,
>> >>>> > I created (https://devel.rtems.org/ticket/2891#ticket) on the lines
>> >>>> > of
>> >>>> > Gedare's advice for this open project
>> >>>> > (https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP).
>> >>>> Looks nice, a few minor things:
>> >>>> oversight?
>> >>>> > The link to buy USB-TTL FTDI Cable 3.3V on the open project page is
>> >>>> > probably broken. What should I replace it with? Please tell if some
>> >>>> See if you can find something appropriate on Google?
>> >>> have here at OAR.
>> >>> generic
>> >>> refusing
>> >>> there
>> >>> you don't want.
>> >>>> > edit is needed and whether I should follow this pattern.
>> >>>> > Furthermore,
>> >>>> > please indicate whether this project is of interest. Also which
>> >>>> > other
>> >>>> > open projects should be converted to tickets?
>> >>>> tickets.
>> >>>> * Use only one keyword. I prefer "SoC" so it is generic to other
>> >>>> 'summer of code' style projects.
>> >>>> * Use the components field to further categorize. We have some
>> >>>> obvious
>> >>>> ones for the subheadings now, such as 'bsps', 'libbsd', 'testing'.
>> >>>> Others should be identified or else we can create new components if
>> >>>> necessary. I'd like to stick with the current subheadings for this
>> >>>> year's GSoC, but we can revise later.
>> >>>> > Probably the community is interested in the idea to create simple
>> >>>> > examples or sanity tests for all RTEMS directives so that they can
>> >>>> > be
>> >>>> > included in the documentation (something that is user friendly).
>> >>>> > Also,
>> >>>> > there was a thread titled 'Desirable Application Stacks (Add-On
>> >>>> > Library Collections)' . Which ideas can be derived from there?
>> >>>> > Regards,
>> >>>> > Tanu Hari Dixit.
>> >>>> > On Tue, Jan 31, 2017 at 4:52 AM, Joel Sherrill <joel at rtems.org>
>> >>>> > wrote:
>> >>>> >> On Mon, Jan 30, 2017 at 5:13 PM, Gedare Bloom <gedare at rtems.org>
>> >>>> >> wrote:
>> >>>> >>> On Mon, Jan 30, 2017 at 12:25 PM, Tanu Hari Dixit
>> >>>> >>> wrote:
>> >>>> >>> > I'll be glad to do it. Please guide me as to how to proceed.
>> >>>> >>> We will need to import each existing Open Project description
>> >>>> >>> into a
>> >>>> >>> new ticket. It would be best to start with one to "try it out".
>> >>>> >>> The
>> >>>> >>> project title should be the Summary of the ticket, the text of
>> >>>> >>> the
>> >>>> >>> project page should be converted into the Description of the
>> >>>> >>> ticket,
>> >>>> >>> type should be Enhancement, Milestone "Indefinite", and put GSoC
>> >>>> >>> into
>> >>>> >>> the keywords, and we might want to use some other keywords e.g.
>> >>>> >>> to
>> >>>> >>> define the project type (e.g. one of: testing, ecosystem, kernel,
>> >>>> >>> statistics, BSP, API, libbsd, languages, libraries). The owner
>> >>>> >>> should
>> >>>> >>> be assigned to one of the mentors if indicated, with others in CC
>> >>>> >>> if
>> >>>> >>> any, or else set blank.
>> >>>> >> I agree it would be nice to get all the Open Project ideas as
>> >>>> >> tickets
>> >>>> >> and
>> >>>> >> off the Wiki. Some of the ideas are likely no longer
>> >>>> >> interesting/valid
>> >>>> >> at
>> >>>> >> this point and could just be deleted.
>> >>>> >> FWIW I also want to move some of the Wiki content into Sphinx
>> >>>> >> documents.
>> >>>> >> I think being able to release them with RTEMS branches and use git
>> >>>> >> for revision control.
>> >>>> >> --joel
>> >>>> >>> > On Mon, Jan 30, 2017 at 9:38 PM, Gedare Bloom
>> >>>> >>> > wrote:
>> >>>> >>> >> Yes that would be much nicer. Maybe we can get potential GSoC
>> >>>> >>> >> Students
>> >>>> >>> >> to do the work ;)
>> >>>> >>> >> On Mon, Jan 30, 2017 at 1:40 AM, Sebastian Huber
>> >>>> >>> >> <sebastian.huber at embedded-brains.de> wrote:
>> >>>> >>> >> > Maybe we should move all this open projects wiki stuff into
>> >>>> >>> >> > tickets
>> >>>> >>> >> > with
>> >>>> >>> >> > some sort of "GSoC" tag.
>> >>>> >>> >> > Sebastian Huber, embedded brains GmbH
>> >>>> >>> >> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> >>>> >>> >> > Phone   : +49 89 189 47 41-16
>> >>>> >>> >> > Fax     : +49 89 189 47 41-09
>> >>>> >>> >> > E-Mail  : sebastian.huber at embedded-brains.de
>> >>>> >>> >> > PGP     : Public key available on request.
>> >>>> >>> >> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>> >>>> >>> >> > des
>> >>>> >>> >> > EHUG.
>> >>>> >>> >> _______________________________________________
>> >>>> >>> >> devel mailing list
>> >>>> >>> >> devel at rtems.org
>> >>>> >>> >> http://lists.rtems.org/mailman/listinfo/devel
>> >>>> >>> devel mailing list
>> >>>> >>> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
> M.Sc. Kuan-Hsun Chen
> TU Dortmund
> Department of Computer Science 12
> Design Automation of Embedded Systems
> Otto-Hahn-Strasse 16, Room 102
> 44227 Dortmund
> Germany
> Phone:  +49 231 755 6124
> Mail:   kuan-hsun.chen at tu-dortmund.de
