Regarding running one test
Tanu Hari Dixit
tokencolour at gmail.com
Sat Feb 4 15:26:50 UTC 2017
Hi Kevin, Kuan-Hsun,
Thank you for the answer.
I have run into a problem before trying the above solutions for myself,
while updating my local copy of the rtems repository with upstream with
"git pull".
After I updated the local copy, I built the sparc toolset with
../source-builder/sb-set-builder --log=l-sparc-test.txt
--prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
Then I ran ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
bootstrap.
Then from builds/erc32_test(subdirectory) I ran
thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ ../../rtems/configure
--target=sparc-rtems4.12 --enable-rtemsbsp=erc32 --enable-tests
--prefix=${HOME}/development/rtems/install_path_test
And when I ran make, It showed the following error;
make[2]: Leaving directory
`/home/thd/development/rtems/src/builds/erc32_test/tools/build'
make[1]: Leaving directory
Making all in tools/cpu
make[1]: Entering directory
`/home/thd/development/rtems/src/builds/erc32_test/tools/cpu'
Making all in generic
make[2]: Entering directory
`/home/thd/development/rtems/src/builds/erc32_test/tools/cpu/generic'
make[2]: Nothing to be done for `all'.
make[2]: Nothing to be done for `all-am'.
Making all in testsuites/tools
`/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools'
`/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools/generic'
Making all in sparc-rtems4.12/c
`/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c'
Making all in .
Making all in erc32
`/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c/erc32'
make[2]: *** No rule to make target `all'. Stop.
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
I have ran into this problem more than once. When last time this happened,
I thought I must have messed up somewhere in the git (or rtems) workflow
and hence decided to make a clean clone of the rtems repo and continue with
it. I also tried git reset --hard <hash-number> last time and had no luck.
Right now, I did not do a hard reset and currently git reflog shows the
following output:
239dd35 HEAD@{0}: pull: Fast-forward
ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
git status shows
thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
On branch master
Your branch is up-to-date with 'origin/master'.
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: c/src/lib/libbsp/powerpc/acinclude.m4
no changes added to commit (use "git add" and/or "git commit -a")
I don't know what I am missing. Do I need to do something before pulling
from upstream? How do I rectify this? Please help me with this.
Thank you,
Tanu Hari Dixit.
On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen <
kuan-hsun.chen at tu-dortmund.de> wrote:
> Or alternatively you can prepare simulator like qemu to executed each of
> it after compiling the source tree.
> Like this in testsuites/hello/:
> 1. qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M -kernel
> 2. hello.exe -smp 4
> Best,
> Kuan-Hsun
> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
>> I use the rtems tester. ftp://ftp.rtems.org/pub/rtems/
>> people/chrisj/rtems-tester/rtems-tester.html
>> Kevin Kirspel
>> Electrical Engineer - Sr. Staff
>> Idexx Roswell
>> 235 Hembree Park Drive
>> Roswell GA 30076
>> Tel: (770)-510-4444 ext. 81642
>> Direct: (770)-688-1642
>> Fax: (770)-510-4445
>> -----Original Message-----
>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari Dixit
>> Sent: Saturday, February 04, 2017 12:23 AM
>> To: rtems-devel at rtems.org <devel at rtems.org>
>> Subject: Regarding running one test
>> Hello all,
>> How do I run a single test from the testsuites? I want to run one test
>> from the rtems/testsuites/fstests. How do I go about doing that?
>> Regards,
>> Tanu Hari Dixit.
>> devel mailing list
>> devel at rtems.org
>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rt
>> ems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFF
>> M1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=
>> zH4W9XS8-wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94e
>> NhQoI76FuuhiadOCFEoiJ3HdxyrrQ&e=
>> devel mailing list
>> devel at rtems.org
> M.Sc. Kuan-Hsun Chen
> TU Dortmund
> Department of Computer Science 12
> Design Automation of Embedded Systems
> Otto-Hahn-Strasse 16, Room 102
> 44227 Dortmund
> Germany
> Phone: *+49 231 755 6124*
> Mail: kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170204/a2e89115/attachment-0001.html>
