Regarding running one test
Tanu Hari Dixit
tokencolour at gmail.com
Sat Feb 4 16:22:59 UTC 2017
The following is the output of the configure statement (I ran configure
again because I did not save the output of the previous one)
thd at thd-Inspiron-5537:~/development/rtems/src/builds/erc32_test1$
../../rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=erc32
--enable-tests --prefix=${HOME}/development/rtems/install_path_test1
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.11.99.0
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... sparc-unknown-rtems4.12
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking that generated files are newer than configure... done
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/sh '../../../../rtems/tools/build/configure'
'--prefix=/home/thd/development/rtems/install_path_test1'
'--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'
'--enable-rtemsbsp=erc32' '--enable-tests' '--target=sparc-rtems4.12'
'--cache-file=/dev/null' '--srcdir=../../../../rtems/tools/build'
checking for x86_64-pc-linux-gnu-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking for strerror... yes
checking for strtol... yes
checking for basename... yes
checking for strnlen... yes
checking for bash... /bin/bash
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
configure: running /bin/sh '../../../../rtems/tools/cpu/configure'
'--cache-file=/dev/null' '--srcdir=../../../../rtems/tools/cpu'
checking rtems target cpu... sparc
=== configuring in generic
(/home/thd/development/rtems/src/builds/erc32_test1/tools/cpu/generic)
configure: running /bin/sh ../../../../../rtems/tools/cpu/generic/configure
--disable-option-checking
'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu'
'target_alias=sparc-rtems4.12' --cache-file=/dev/null
--srcdir=../../../../../rtems/tools/cpu/generic
config.status: creating size_rtems
configure: configuring in ./testsuites/tools
configure: running /bin/sh '../../../../rtems/testsuites/tools/configure'
'--cache-file=/dev/null' '--srcdir=../../../../rtems/testsuites/tools'
(/home/thd/development/rtems/src/builds/erc32_test1/testsuites/tools/generic)
../../../../../rtems/testsuites/tools/generic/configure
--srcdir=../../../../../rtems/testsuites/tools/generic
config.status: creating difftest
config.status: creating sorttimes
configure: configuring in sparc-rtems4.12/c
configure: running /bin/sh '../../../../rtems/c/configure'
'--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu'
'--target=sparc-rtems4.12' '--enable-rtemsbsp=erc32' '--enable-tests'
'--with-target-subdir=sparc-rtems4.12'
'--exec-prefix=/home/thd/development/rtems/install_path_test1/sparc-rtems4.12'
'--includedir=/home/thd/development/rtems/install_path_test1/sparc-rtems4.12/include'
'--cache-file=/dev/null' '--srcdir=../../../../rtems/c'
checking host system type... sparc-unknown-rtems4.12
checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
target architecture: sparc.
available BSPs: erc32.
'make all' will build the following BSPs: erc32.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
Thank you,
Tanu Hari Dixit.
On Sat, Feb 4, 2017 at 9:26 PM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
wrote:
> I don’t have the spac toolset so I cannot test your situation. However,
> can you post the output of your configure? I want to make sure it found
> the erc32 BSP.
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Idexx Roswell
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> *From:* Tanu Hari Dixit [mailto:tokencolour at gmail.com]
> *Sent:* Saturday, February 04, 2017 10:27 AM
> *To:* Kuan Hsun Chen <kuan-hsun.chen at tu-dortmund.de>
> *Cc:* rtems-devel at rtems.org <devel at rtems.org>; Kirspel, Kevin <
> *Subject:* Re: Regarding running one test
> Hi Kevin, Kuan-Hsun,
> Thank you for the answer.
> I have run into a problem before trying the above solutions for myself,
> while updating my local copy of the rtems repository with upstream with
> "git pull".
> After I updated the local copy, I built the sparc toolset with
> ../source-builder/sb-set-builder --log=l-sparc-test.txt
> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
> Then I ran ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
> bootstrap.
> Then from builds/erc32_test(subdirectory) I ran
> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$
> And when I ran make, It showed the following error;
> make[2]: Leaving directory `/home/thd/development/rtems/
> src/builds/erc32_test/tools/build'
> make[1]: Leaving directory `/home/thd/development/rtems/
> Making all in tools/cpu
> make[1]: Entering directory `/home/thd/development/rtems/
> src/builds/erc32_test/tools/cpu'
> Making all in generic
> make[2]: Entering directory `/home/thd/development/rtems/
> src/builds/erc32_test/tools/cpu/generic'
> make[2]: Nothing to be done for `all'.
> make[2]: Nothing to be done for `all-am'.
> Making all in testsuites/tools
> src/builds/erc32_test/testsuites/tools'
> src/builds/erc32_test/testsuites/tools/generic'
> Making all in sparc-rtems4.12/c
> src/builds/erc32_test/sparc-rtems4.12/c'
> Making all in .
> Making all in erc32
> src/builds/erc32_test/sparc-rtems4.12/c/erc32'
> make[2]: *** No rule to make target `all'. Stop.
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
> I have ran into this problem more than once. When last time this happened,
> I thought I must have messed up somewhere in the git (or rtems) workflow
> and hence decided to make a clean clone of the rtems repo and continue with
> it. I also tried git reset --hard <hash-number> last time and had no luck.
> Right now, I did not do a hard reset and currently git reflog shows the
> following output:
> 239dd35 HEAD@{0}: pull: Fast-forward
> ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__git.rtems.org_rtems.git&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=ryMs7_iFDreSyA8ad3iXqtVo0QByXEG61ZeaU1r6J4A&e=>
> git status shows
> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
> On branch master
> Your branch is up-to-date with 'origin/master'.
> Changes not staged for commit:
> (use "git add <file>..." to update what will be committed)
> (use "git checkout -- <file>..." to discard changes in working directory)
> modified: c/src/lib/libbsp/powerpc/acinclude.m4
> no changes added to commit (use "git add" and/or "git commit -a")
> I don't know what I am missing. Do I need to do something before pulling
> from upstream? How do I rectify this? Please help me with this.
> Thank you,
> Tanu Hari Dixit.
> On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen <
> kuan-hsun.chen at tu-dortmund.de> wrote:
> Or alternatively you can prepare simulator like qemu to executed each of
> it after compiling the source tree.
> Like this in testsuites/hello/:
> 1. qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M -kernel
> 2. hello.exe -smp 4
> Best,
> Kuan-Hsun
> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
> I use the rtems tester. ftp://ftp.rtems.org/pub/rtems/
> people/chrisj/rtems-tester/rtems-tester.html
> <https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_people_chrisj_rtems-2Dtester_rtems-2Dtester.html&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=Gv6QEbMGt88773MgovVmHykfnOxbLOP5J32IzwNVNEc&e=>
> Kevin Kirspel
> Idexx Roswell
> Roswell GA 30076
> Fax: (770)-510-4445
> -----Original Message-----
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari Dixit
> Sent: Saturday, February 04, 2017 12:23 AM
> To: rtems-devel at rtems.org <devel at rtems.org>
> Subject: Regarding running one test
> Hello all,
> How do I run a single test from the testsuites? I want to run one test
> from the rtems/testsuites/fstests. How do I go about doing that?
> Regards,
> Tanu Hari Dixit.
> devel mailing list
> devel at rtems.org
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
> rtems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFFM1bA&r=
> HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=zH4W9XS8-
> wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94eNhQoI76FuuhiadOC
> FEoiJ3HdxyrrQ&e=
> devel mailing list
> devel at rtems.org
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=2TitOf1dwrWdEOQH2NpO_av9kjH_jPk9KJdkJUNk2Js&e=>
> M.Sc. Kuan-Hsun Chen
> TU Dortmund
> Department of Computer Science 12
> Design Automation of Embedded Systems
> Otto-Hahn-Strasse 16, Room 102
> 44227 Dortmund
> Germany
> Phone: *+49 231 755 6124*
> Mail: kuan-hsun.chen at tu-dortmund.de
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170204/0ae5b3c3/attachment-0001.html>
