Running/Debugging RTEMS applications on Zynq
Thu Feb 9 02:15:41 UTC 2017
On 08/02/2017 21:37, Chris Johns wrote:
> It is missing some steps which I will fill in when I can. I hope it
> helps get you going.
I have completed documenting the set up to run RTEMS applications
including running the RTEMS debugger test built by libbsd.
