[PATCH 4/9] Adding RTEMS termios FREEBSD support
Kevin Kirspel
kevin-kirspel at idexx.com
Thu Feb 9 03:21:35 UTC 2017
rtemsbsd/include/machine/rtems-bsd-termios.h | 68 +++++++++
rtemsbsd/rtems/rtems-bsd-termios.c | 213 +++++++++++++++++++++++++++
2 files changed, 281 insertions(+)
create mode 100755 rtemsbsd/include/machine/rtems-bsd-termios.h
create mode 100755 rtemsbsd/rtems/rtems-bsd-termios.c
diff --git a/rtemsbsd/include/machine/rtems-bsd-termios.h b/rtemsbsd/include/machine/rtems-bsd-termios.h
new file mode 100755
index 0000000..0acb23f
--- /dev/null
+++ b/rtemsbsd/include/machine/rtems-bsd-termios.h
@@ -0,0 +1,68 @@
+ * @file
+ * @ingroup rtems_bsd_machine
+ * @brief TODO.
+ * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_TERMIOS_H_
+#define _RTEMS_BSD_MACHINE_RTEMS_BSD_TERMIOS_H_
+#include <sys/cdefs.h>
+#include <sys/_termios.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <stdarg.h>
+__BEGIN_DECLS
+u_long
+rtems_bsd_ioctl_cmd_to_bsd(struct termios *t, u_long cmd, caddr_t data, int* flush_flags);
+speed_t
+rtems_bsd_rtems_speed_to_bsd_speed(speed_t spd);
+speed_t
+rtems_bsd_bsd_speed_to_rtems_speed(speed_t spd);
+speed_t
+rtems_bsd_get_input_speed(struct termios *t);
+speed_t
+rtems_bsd_get_output_speed(struct termios *t);
+__END_DECLS
+#endif /* _RTEMS_BSD_MACHINE_RTEMS_BSD_TERMIOS_H_ */
diff --git a/rtemsbsd/rtems/rtems-bsd-termios.c b/rtemsbsd/rtems/rtems-bsd-termios.c
index 0000000..cd86581
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-bsd-termios.c
@@ -0,0 +1,213 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief TODO.
+ * Copyright (c) 2009, 2010 embedded brains GmbH. All rights reserved.
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * are met:
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <sys/types.h>
+#include <sys/fcntl.h>
+#include <sys/tty.h>
+#include <sys/ttycom.h>
+#define TTYDEFCHARS
+#include <sys/ttydefaults.h>
+#undef TTYDEFCHARS
+#include <sys/ioccom.h>
+typedef struct
+ speed_t rtems_speed;
+ speed_t bsd_speed;
+}rtems_bsd_termios_speed_entry;
+static rtems_bsd_termios_speed_entry rtems_bsd_speed_table[] = {
+ { B0, 0 },
+ { B50, 50 },
+ { B75, 75 },
+ { B110, 110 },
+ { B134, 134 },
+ { B150, 150 },
+ { B200, 200 },
+ { B300, 300 },
+ { B600, 600 },
+ { B1200, 1200 },
+ { B1800, 1800 },
+ { B2400, 2400 },
+ { B4800, 4800 },
+ { B9600, 9600 },
+ { B19200, 19200 },
+ { B38400, 38400 },
+ { B57600, 57600 },
+ { B115200, 115200 },
+ { B230400, 230400 },
+ { B460800, 460800 },
+#define rtems_bsd_speed_table_size (( int )( sizeof( rtems_bsd_speed_table ) / sizeof( rtems_bsd_speed_table[0] )))
+ * RTEMS ioctl cmd translation for BSD *
+u_long
+ uint32_t c_ispeed;
+ uint32_t c_ospeed;
+ switch (cmd) {
+ case RTEMS_IO_GET_ATTRIBUTES:
+ cmd = TIOCGETA;
+ break;
+ case RTEMS_IO_SET_ATTRIBUTES:
+ cmd = TIOCSETA;
+ c_ispeed = cfgetispeed(t);
+ c_ospeed = cfgetospeed(t);
+ if (c_ispeed && (c_ispeed != c_ospeed)) {
+ cfsetospeed(t, c_ispeed);
+ break;
+ case RTEMS_IO_TCDRAIN:
+ cmd = TIOCSETAW;
+ break;
+ case RTEMS_IO_RCVWAKEUP:
+ break;
+ case RTEMS_IO_SNDWAKEUP:
+ break;
+ case RTEMS_IO_TCFLUSH:
+ cmd = TIOCFLUSH;
+ switch ((intptr_t)data) {
+ case TCIFLUSH:
+ *flush_flags = FREAD;
+ break;
+ case TCOFLUSH:
+ *flush_flags = FWRITE;
+ break;
+ case TCIOFLUSH:
+ *flush_flags = FREAD | FWRITE;
+ break;
+ default:
+ *flush_flags = 0;
+ break;
+ return (cmd);
+ * RTEMS speed translation for BSD speed *
+speed_t
+ rtems_bsd_termios_speed_entry* entry = &rtems_bsd_speed_table[0];
+ rtems_bsd_termios_speed_entry* entry_end = &rtems_bsd_speed_table[rtems_bsd_speed_table_size];
+ while( entry != entry_end ) {
+ if(entry->rtems_speed == spd) {
+ return entry->bsd_speed;
+ entry++;
+ return 0;
+ * BSD speed translation for RTEMS speed *
+speed_t
+ if(entry->bsd_speed == spd) {
+ return entry->rtems_speed;
+ entry++;
+ return 0;
+ * RTEMS get input baud rate from termios *
+speed_t
+ return rtems_bsd_rtems_speed_to_bsd_speed(cfgetispeed(t));
+ * RTEMS get output baud rate from termios *
+speed_t
+ return rtems_bsd_rtems_speed_to_bsd_speed(cfgetospeed(t));
+ * Obtain a termios structure which is similar to the one provided by
+ * the kernel.
+void
+cfmakesane(struct termios *t)
+ t->c_cflag = TTYDEF_CFLAG;
+ t->c_iflag = TTYDEF_IFLAG;
+ t->c_lflag = TTYDEF_LFLAG;
+ t->c_oflag = TTYDEF_OFLAG;
+ cfsetispeed(t, TTYDEF_SPEED);
+ cfsetospeed(t, TTYDEF_SPEED);
+ memcpy(&t->c_cc, ttydefchars, sizeof ttydefchars);
1.9.1
