[PATCH 5/9] Adding RTEMS support for FREEBSD virtual device operations
Kevin Kirspel kevin-kirspel at idexx.com
Thu Feb 9 03:21:36 UTC 2017
 rtemsbsd/sys/fs/devfs/devfs_vnops.c | 136 ++++++++++++++++++++++++++++++++++++
 1 file changed, 136 insertions(+)
 create mode 100755 rtemsbsd/sys/fs/devfs/devfs_vnops.c
diff --git a/rtemsbsd/sys/fs/devfs/devfs_vnops.c b/rtemsbsd/sys/fs/devfs/devfs_vnops.c
new file mode 100755
index 0000000..8c4a786
--- /dev/null
+++ b/rtemsbsd/sys/fs/devfs/devfs_vnops.c
@@ -0,0 +1,136 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <sys/types.h>
+#include <sys/conf.h>
+#include <sys/kernel.h>
+#include <sys/file.h>
+#include <sys/malloc.h>
+#include <sys/proc.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <fs/devfs/devfs_int.h>
+static MALLOC_DEFINE(M_CDEVPDATA, "DEVFSP", "Metainfo for cdev-fp data");
+struct mtx	cdevpriv_mtx;
+MTX_SYSINIT(cdevpriv_mtx, &cdevpriv_mtx, "cdevpriv lock", MTX_DEF);
+int
+devfs_get_cdevpriv(void **datap)
+	struct file *fp;
+	struct cdev_privdata *p;
+	int error;
+	fp = curthread->td_fpop;
+	if (fp == NULL)
+		return (EBADF);
+	p = fp->f_cdevpriv;
+	if (p != NULL) {
+		error = 0;
+		*datap = p->cdpd_data;
+	} else
+		error = ENOENT;
+	return (error);
+int
+devfs_set_cdevpriv(void *priv, d_priv_dtor_t *priv_dtr)
+	struct file *fp;
+	struct cdev_priv *cdp;
+	int error;
+	if (fp == NULL)
+		return (ENOENT);
+	cdp = cdev2priv((struct cdev *)fp->f_data);
+	p = malloc(sizeof(struct cdev_privdata), M_CDEVPDATA, M_WAITOK);
+	p->cdpd_data = priv;
+	p->cdpd_dtr = priv_dtr;
+	p->cdpd_fp = fp;
+	mtx_lock(&cdevpriv_mtx);
+	if (fp->f_cdevpriv == NULL) {
+		LIST_INSERT_HEAD(&cdp->cdp_fdpriv, p, cdpd_list);
+		fp->f_cdevpriv = p;
+		mtx_unlock(&cdevpriv_mtx);
+		error = 0;
+	} else {
+		free(p, M_CDEVPDATA);
+		error = EBUSY;
+	return (error);
+void
+devfs_destroy_cdevpriv(struct cdev_privdata *p)
+	mtx_assert(&cdevpriv_mtx, MA_OWNED);
+	KASSERT(p->cdpd_fp->f_cdevpriv == p,
+	    ("devfs_destoy_cdevpriv %p != %p", p->cdpd_fp->f_cdevpriv, p));
+	p->cdpd_fp->f_cdevpriv = NULL;
+	LIST_REMOVE(p, cdpd_list);
+	(p->cdpd_dtr)(p->cdpd_data);
+static void
+devfs_fpdrop(struct file *fp)
+  if ((p = fp->f_cdevpriv) == NULL) {
+    return;
+  devfs_destroy_cdevpriv(p);
+void
+devfs_clear_cdevpriv(void)
+  struct file *fp;
+  if (fp == NULL)
+    return;
+  devfs_fpdrop(fp);
1.9.1
