Porting to a NXP K6x series chip
Alan Cudmore alan.cudmore at gmail.com
Fri Feb 24 14:56:27 UTC 2017
For the RAM, maybe 128k can be used for the workspace,heap, and initial
stack, and the other 128k bank can be used for data.
If you get this working, I would not mind trying to port it to the Teensy
3.6 board, which has a similar CPU:
https://www.pjrc.com/store/teensy36.html
Alan
On Fri, Feb 24, 2017 at 9:35 AM, Gedare Bloom <gedare at rtems.org> wrote:
> You have the gist of it. Read through the
> https://docs.rtems.org/branches/master/cpu-supplement/index.html and
> https://docs.rtems.org/branches/master/bsp-howto/index.html for a bit
> more guidance. There is currently no official "porting guide" beyond
> that, so keep asking questions.
> On Thu, Feb 23, 2017 at 1:19 PM,  <george at n3ysa.org> wrote:
> > I've got a FRDM-K64F and would like to get RTEMS running on it for a
> personal project. It has the standard ARM interrupt controller. One
> complication is that the SRAM is divided into two banks of 128K as the
> banks are connected to different buses in the MCU, and causes hard faults
> if an unaligned access crosses the boundary.
> > Looking at the existing code, anything specific too the K6x would go in
> libcpu, and anything specific to board (such as clock setup/debug uart)
> would appear to go in libsp?
> > Thanks,
> > George
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170224/ebb3338c/attachment-0002.html>
