Porting to a NXP K6x series chip
Fri Feb 24 15:05:02 UTC 2017
On Fri, Feb 24, 2017 at 8:56 AM, Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> For the RAM, maybe 128k can be used for the workspace,heap, and initial
> stack, and the other 128k bank can be used for data.
I did something similar to this for an old 68000 board which only had 384K
RAM.
You gave good advice for the port/BSP itself. I wouldn't expect much in
what
I would call porting proper. The ARM port should cover the basic CPU
architectural
variations. The issue is going to me in CPU model specifics and
peripherals.
Mostly BSP issues and where peripherals are common across NXP CPUs,
libbsp/arm/.. and libcpu/arm/...
FWIW we are trying to slowly disperse libcpu contents so focusing on the
proper
libbsp directories and asking questions when in doubt is the best path.
> If you get this working, I would not mind trying to port it to the Teensy
> 3.6 board, which has a similar CPU:
> https://www.pjrc.com/store/teensy36.html
> Alan
> On Fri, Feb 24, 2017 at 9:35 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> You have the gist of it. Read through the
>> https://docs.rtems.org/branches/master/cpu-supplement/index.html and
>> https://docs.rtems.org/branches/master/bsp-howto/index.html for a bit
>> more guidance. There is currently no official "porting guide" beyond
>> that, so keep asking questions.
>> On Thu, Feb 23, 2017 at 1:19 PM,  <george at n3ysa.org> wrote:
>> > I've got a FRDM-K64F and would like to get RTEMS running on it for a
>> personal project. It has the standard ARM interrupt controller. One
>> complication is that the SRAM is divided into two banks of 128K as the
>> banks are connected to different buses in the MCU, and causes hard faults
>> if an unaligned access crosses the boundary.
>> > Looking at the existing code, anything specific too the K6x would go in
>> libcpu, and anything specific to board (such as clock setup/debug uart)
>> would appear to go in libsp?
>> > Thanks,
>> > George
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170224/06b9a66c/attachment-0002.html>
